    Issues with electron.js on installation
    6 Posts 3 Posters 4.3k Views 3 Watching
      azmuth94
      npm start dev
      > magicmirror@2.0.0 start /home/pi/MagicMirror
      > electron js/electron.js "dev"
      sh: 1: electron: not found
      npm ERR! Linux 4.4.11-v7+
      npm ERR! argv "/usr/local/bin/node" "/usr/local/bin/npm" "start" "dev"
      npm ERR! node v4.2.1
      npm ERR! npm  v2.14.7
      npm ERR! file sh
      npm ERR! code ELIFECYCLE
      npm ERR! errno ENOENT
      npm ERR! syscall spawn
      npm ERR! magicmirror@2.0.0 start: `electron js/electron.js "dev"`
      npm ERR! spawn ENOENT
      npm ERR!
      npm ERR! Failed at the magicmirror@2.0.0 start script 'electron js/electron.js "dev"'.
      npm ERR! This is most likely a problem with the magicmirror package,
      npm ERR! not with npm itself.
      npm ERR!     electron js/electron.js "dev"
      npm ERR! You can get their info via:
      npm ERR!     npm owner ls magicmirror
      npm ERR!     /home/pi/MagicMirror/npm-debug.log
        azmuth94
        also forgot to mention i am using a RPi 3
        Alternatively I thought trying a manual installation would have a different outcome and have come across the following issue:
        0_1475079599447_upload-ac58cf39-e797-4bd0-bf57-248744771e2e
        • strawberry 3.141S Offline
          strawberry 3.141 Project Sponsor Module Developer @azmuth94
          @azmuth94 did you try to update node? you’re running 4.2, I’m using 6.5
            azmuth94 @strawberry 3.141
            @strawberry-3.141 i upgraded my version of node to 6.6.0, still same issue:
            0_1475083613232_upload-013572d4-419b-48c6-a1d4-9cc765263dc1
              jc21
              Try:
              sudo npm install -g electron
              If you get any errors with that command then something needs fixing outside of the MagicMirror package and installation.
              A 1 Reply Last reply Reply Quote 1
                azmuth94 @jc21
                @jc21 yes issue was solved once I set my system time
