    Develop module with API
    42 Posts 6 Posters 22.3k Views 6 Watching
      A Former User @htilburgs
      @htilburgs
      Insert “tr” element after each row.
      • htilburgsH
        htilburgs
        Don’t I do this with this?
        var callWrapper = document.createElement("tr");
        callWrapper.appendChild(FajrTextCell);
        (still trying to learn JS, but not afraid to ask and AI is my best friend) ☺
        S ? 2 Replies Last reply Reply Quote 0
          sdetweil @htilburgs
          @htilburgs yes, for each row, and the columns added to the row
          htilburgsH 1 Reply Last reply Reply Quote 0
          • htilburgsH
            htilburgs @sdetweil
            @sdetweil I don’t understand what you mean.
              sdetweil @htilburgs
              @htilburgs make a table with HTML.
              tr have to be added to table for each row
              And td need to be added for each tr
              Right? Exactly the same using code
                @htilburgs
                https://www.w3schools.com/jsref/dom_obj_table.asp
                This might be help. Read following articles about table on that site.
                • htilburgsH
                  htilburgs
                  @Sean @sdetweil I finaly figured it out! Thanx for the support and pointing me in the correct direction. See the result:
                  alt text
                  		var MPT = this.MPT;
                  		// creating the tablerows
                  		// Fajr
                  		var FajrRow = document.createElement("tr")
                  		FajrRow.className = "small fajr-row";
                  		var FajrTextCell = document.createElement("td");
                  		FajrTextCell.innerHTML = "Fajr";
                  		FajrRow.appendChild(FajrTextCell);
                  		table.appendChild(FajrRow);
                  		var FajrTimeCell = document.createElement("td");
                  		FajrTimeCell.className = "bright";
                  		FajrTimeCell.innerHTML = MPT.Fajr;
                  		FajrRow.appendChild(FajrTimeCell);
                  		var FajrArabCell = document.createElement("td");
                  		FajrArabCell.innerHTML = "الفجر";
                  		FajrRow.appendChild(FajrArabCell);
                  		return table;
                    Fabulous! Nice work!
                    • htilburgsH
                      htilburgs
                      @Mykle1 Thanks for the MMM-UFO “templates”. This really helped me to get started.
                      First one down, several to go…:winking_face:
                      • Mykle1M
                        Mykle1 Project Sponsor Module Developer @htilburgs
                        @htilburgs
                        You’re welcome, mate. And with @sdetweil and @Sean you found the best help possible. :thumbsup:
                          betle
                          Thanks tipobet
                            rick93
                            Hi @Mykle1 , i am impressed with your MMM-UFO template.
                            Unfortunately the link -->https://ufo-api.herokuapp.com/api/sightings/search?city=new york&state=ny&limit=50&skip=0 seem like down.
                            Could you please have a look at it? so that I could refer to.
                            Thanks!!
                            • Mykle1M
                              Mykle1 Project Sponsor Module Developer @rick93
                              @rick93 said in Develop module with API:
                              Well, I just took a look at the api and it is down, as you already discovered. There is nothing I can do about that. However, I will take a look around and see if I can find another. Unknown if I will be able to find one but give me some time. No promises. I will do my best.
                                rick93 @Mykle1
                                @Mykle1 thanks for your prompt reply and support. I am looking at your API information to compare with your tutorial in the module so that I know what parameter to change. It’s fine if you can share the API’s data/code, doesn’t really need to repair the link or find another. let me know if you can recall back from any previous code in storage. Appreciate!
                                • Mykle1M
                                  I’m not really sure what you are asking me for. The API is dead so there is nothing that I can give you. The link is good but the API is dead so there is no repairing it. :-/
                                    rick93 @Mykle1
                                    @Mykle1 said in Develop module with API:
                                    @Mykle1 Understood. I am actually trying to create my module for the Singapore weather forecast via API --“https://api.data.gov.sg/v1/environment/4-day-weather-forecast”.
                                    I am new to MM as well as JS, so I do like to learn the way you code for the API, so I can get the idea to code my own.
                                    Anyway, I will find another example to continue my coding.
                                    Thanks.
                                    • Mykle1M
                                      First, you should aspire to learn how others code. I have a basic understanding of coding but I manage to make things work, usually. Only with the help and guidance of others have I managed to create some modules. Anyway . . .
                                      The url you have for the weather data is working. Great! I took the data and ran it through the json viewer. I assume you did the same as per the instructions in the UFO module readme. By substituting the url and changing some naming in the node helper and js file you should be able to get the data. Setting up the divs should not be too hard either.
                                      See what you can manage on your own and I will try to help you when you get stuck.
                                      Paying it forward.
                                      Peace!
                                      • Mykle1M
                                          rick93 @Mykle1
                                          Hi @Mykle1 , I am trying to display only one parameter on the magic mirror,unfortunately it show undefined. I tried different ways but still cant make it.
                                          I don’t not know what is the root cause since I was using MMM_UFO as my template. Do you mind to have a look on my module and advice me?
                                          Thank you very much.
                                          https://github.com/rick0222/MM-SW
                                            rick93 @rick93
                                            rick93 about 2 hours ago
                                            I am not sure is the issue came from the API that I inserted not correct and return a wrong data. but I have no idea how I can make it work.
                                            this.url = "https://api.data.gov.sg/v1/environment/4-day-weather-forecast";
                                            		this.SW = [];
                                            • 2 / 3
