    Develop module with API
    42 Posts 6 Posters 19.8k Views 6 Watching
    • htilburgsH Offline
      htilburgs
      @Sean,
      Thank you for explaining and pointing me out.
      I understand what was the issue. I’ve cleaned up the code and removed the caroussel part (and unneeded variables), because I don’t use that.
      Added the possibility for showing or not showing some items.
      Up to the next part… HTML Markup
      (still trying to learn JS, but not afraid to ask and AI is my best friend) ☺
        htilburgs
        Strugling with formatting. When I use the basic code, I got the result I like but it’s not displayed nice. I like to have 3 columns.
        		var MPT = this.MPT;
        		// Creating the div's for your data items
        		var top = document.createElement("div");
        		top.classList.add("list-row");
        		// Fajr from data
        		var mptFajr = document.createElement("div");
        		mptFajr.classList.add("small", "bright", "Fajr");
        		mptFajr.innerHTML = "Fajr : " + MPT.Fajr + " الفجر";
        		wrapper.appendChild(mptFajr);
        		// Sunrise from data
        		if (this.config.showSunrise != false) {
        		    var mptSunrise = document.createElement("div");
        		    mptSunrise.classList.add("small", "bright", "Sunrise");
        		    mptSunrise.innerHTML = "Sunrise : " + MPT.Sunrise + " شروق الشمس";
        		    wrapper.appendChild(mptSunrise);
        		// Dhuhr from data
        		var mptDhuhr = document.createElement("div");
        		mptDhuhr.classList.add("small", "bright", "Dhuhr");
        		mptDhuhr.innerHTML = "Duhr : " + MPT.Dhuhr + " الظهر";
        		wrapper.appendChild(mptDhuhr);
        		// Asr from data
        		var mptAsr = document.createElement("div");
        		mptAsr.classList.add("small", "bright", "Asr");
        		mptAsr.innerHTML = "Asr : " + MPT.Asr + " العصر";
        		wrapper.appendChild(mptAsr);
        		// Sunset from data
        		if (this.config.showSunset != false) {
        		    var mptSunset = document.createElement("div");
        		    mptSunset.classList.add("small", "bright", "Sunset");
        		    mptSunset.innerHTML = "Sunset : " + MPT.Sunset + " غروب الشمس";
        		    wrapper.appendChild(mptSunset);
        		// Maghrib from data
        		var mptMaghrib = document.createElement("div");
        		mptMaghrib.classList.add("small", "bright", "Maghrib");
        		mptMaghrib.innerHTML = "Maghrib : " + MPT.Maghrib + " المغرب";
        		wrapper.appendChild(mptMaghrib);
        		// Isha from data
        		var mptIsha = document.createElement("div");
        		mptIsha.classList.add("small", "bright", "Isha");
        		mptIsha.innerHTML = "Isha : " + MPT.Isha + " العشاء";
        		wrapper.appendChild(mptIsha);
        		// Midnight from data
        		if (this.config.showMidnight != false) {
        		    var mptMidnight = document.createElement("div");
        		    mptMidnight.classList.add("small", "bright", "Midnight");
        		    mptMidnigh
        alt text
        Now I trying for several hours to figure out how to create table, columns, rows…
        I’ve changed the code part to
        		var MPT = this.MPT;
        		var logs = document.createElement("table");
        		var callWrapper = document.createElement("tr");
        		callWrapper.classList.add("small");
        		// Fajr
        		var FajrTextCell = document.createElement("td");
        		FajrTextCell.className.add = "xsmall bright fajrtext";
        		FajrTextCell.innerHTML = "Fajr";
        		callWrapper.appendChild(FajrTextCell);
        		var FajrTimeCell = document.createElement("td");
        		FajrTimeCell.className = "xsmall bright fajrtime";
        		FajrTimeCell.innerHTML = MPT.Fajr;
        		callWrapper.appendChild(FajrTimeCell);
        		var FajrArabCell = document.createElement("td");
        		FajrArabCell.className = "xsmall bright fajrarab";
        		FajrArabCell.innerHTML = "الفجر";
        		callWrapper.appendChild(FajrArabCell);
        		logs.appendChild(callWrapper);
        		wrapper.appendChild(logs);
        		return wrapper;
        The result for 1 item is nice
        alt text
        But when I repeat this for the other items, no rows are created and everything is on the same row.
        		var MPT = this.MPT;
        //Table Test
        		// Fajr
        		// Sunrise
        		var SunriseTextCell = document.createElement("td");
        		SunriseTextCell.className.add = "xsmall bright sunrisetext";
        		SunriseTextCell.innerHTML = "Sunrise";
        		var SunriseTimeCell = document.createElement("td");
        		SunriseTimeCell.className = "xsmall bright fajrtime";
        		SunriseTimeCell.innerHTML = MPT.Sunrise;
        		callWrapper.appendChild(SunriseTimeCell);
        		var SunriseArabCell = document.createElement("td");
        		SunriseArabCell.className = "xsmall bright sunrisearab";
        		SunriseArabCell.innerHTML = "شروق الشمس";
        		callWrapper.appendChild(SunriseArabCell);
        		return wrapper;
        alt text
        Any help to get me on the right track again?
          A Former User @htilburgs
          @htilburgs
          Insert “tr” element after each row.
            htilburgs
            Don’t I do this with this?
            S ? 2 Replies Last reply Reply Quote 0
              sdetweil @htilburgs
              @htilburgs yes, for each row, and the columns added to the row
              htilburgsH 1 Reply Last reply Reply Quote 0
                htilburgs @sdetweil
                @sdetweil I don’t understand what you mean.
                  sdetweil @htilburgs
                  @htilburgs make a table with HTML.
                  tr have to be added to table for each row
                  And td need to be added for each tr
                  Right? Exactly the same using code
                    @htilburgs
                    https://www.w3schools.com/jsref/dom_obj_table.asp
                    This might be help. Read following articles about table on that site.
                      htilburgs
                      @Sean @sdetweil I finaly figured it out! Thanx for the support and pointing me in the correct direction. See the result:
                      alt text
                      		var MPT = this.MPT;
                      		// creating the tablerows
                      		// Fajr
                      		var FajrRow = document.createElement("tr")
                      		FajrRow.className = "small fajr-row";
                      		FajrRow.appendChild(FajrTextCell);
                      		table.appendChild(FajrRow);
                      		FajrTimeCell.className = "bright";
                      		FajrRow.appendChild(FajrTimeCell);
                      		FajrRow.appendChild(FajrArabCell);
                      		return table;
                        Fabulous! Nice work!
                          htilburgs
                          @Mykle1 Thanks for the MMM-UFO “templates”. This really helped me to get started.
                          First one down, several to go…:winking_face:
                            Mykle1 Project Sponsor Module Developer @htilburgs
                            @htilburgs
                            You’re welcome, mate. And with @sdetweil and @Sean you found the best help possible. :thumbsup:
                              betle
                              Thanks tipobet
                                rick93
                                Hi @Mykle1 , i am impressed with your MMM-UFO template.
                                Unfortunately the link -->https://ufo-api.herokuapp.com/api/sightings/search?city=new york&state=ny&limit=50&skip=0 seem like down.
                                Could you please have a look at it? so that I could refer to.
                                Thanks!!
                                  Mykle1 Project Sponsor Module Developer @rick93
                                  @rick93 said in Develop module with API:
                                  Well, I just took a look at the api and it is down, as you already discovered. There is nothing I can do about that. However, I will take a look around and see if I can find another. Unknown if I will be able to find one but give me some time. No promises. I will do my best.
                                    rick93 @Mykle1
                                    @Mykle1 thanks for your prompt reply and support. I am looking at your API information to compare with your tutorial in the module so that I know what parameter to change. It’s fine if you can share the API’s data/code, doesn’t really need to repair the link or find another. let me know if you can recall back from any previous code in storage. Appreciate!
                                      I’m not really sure what you are asking me for. The API is dead so there is nothing that I can give you. The link is good but the API is dead so there is no repairing it. :-/
                                        rick93 @Mykle1
                                        @Mykle1 said in Develop module with API:
                                        @Mykle1 Understood. I am actually trying to create my module for the Singapore weather forecast via API --“https://api.data.gov.sg/v1/environment/4-day-weather-forecast”.
                                        I am new to MM as well as JS, so I do like to learn the way you code for the API, so I can get the idea to code my own.
                                        Anyway, I will find another example to continue my coding.
                                        Thanks.
                                          First, you should aspire to learn how others code. I have a basic understanding of coding but I manage to make things work, usually. Only with the help and guidance of others have I managed to create some modules. Anyway . . .
                                          The url you have for the weather data is working. Great! I took the data and ran it through the json viewer. I assume you did the same as per the instructions in the UFO module readme. By substituting the url and changing some naming in the node helper and js file you should be able to get the data. Setting up the divs should not be too hard either.
                                          See what you can manage on your own and I will try to help you when you get stuck.
                                          Paying it forward.
                                          Peace!
                                            • 2 / 3
