    Develop module with API
    42 Posts 6 Posters 21.3k Views 6 Watching
      Mykle1 Project Sponsor Module Developer @htilburgs
      @htilburgs
      You’re welcome, mate. And with @sdetweil and @Sean you found the best help possible. :thumbsup:
        betle
        Thanks tipobet
          rick93
          Hi @Mykle1 , i am impressed with your MMM-UFO template.
          Unfortunately the link -->https://ufo-api.herokuapp.com/api/sightings/search?city=new york&state=ny&limit=50&skip=0 seem like down.
          Could you please have a look at it? so that I could refer to.
          Thanks!!
            Mykle1 Project Sponsor Module Developer @rick93
            @rick93 said in Develop module with API:
            Well, I just took a look at the api and it is down, as you already discovered. There is nothing I can do about that. However, I will take a look around and see if I can find another. Unknown if I will be able to find one but give me some time. No promises. I will do my best.
              rick93 @Mykle1
              @Mykle1 thanks for your prompt reply and support. I am looking at your API information to compare with your tutorial in the module so that I know what parameter to change. It’s fine if you can share the API’s data/code, doesn’t really need to repair the link or find another. let me know if you can recall back from any previous code in storage. Appreciate!
                I’m not really sure what you are asking me for. The API is dead so there is nothing that I can give you. The link is good but the API is dead so there is no repairing it. :-/
                  rick93 @Mykle1
                  @Mykle1 said in Develop module with API:
                  @Mykle1 Understood. I am actually trying to create my module for the Singapore weather forecast via API --“https://api.data.gov.sg/v1/environment/4-day-weather-forecast”.
                  I am new to MM as well as JS, so I do like to learn the way you code for the API, so I can get the idea to code my own.
                  Anyway, I will find another example to continue my coding.
                  Thanks.
                    First, you should aspire to learn how others code. I have a basic understanding of coding but I manage to make things work, usually. Only with the help and guidance of others have I managed to create some modules. Anyway . . .
                    The url you have for the weather data is working. Great! I took the data and ran it through the json viewer. I assume you did the same as per the instructions in the UFO module readme. By substituting the url and changing some naming in the node helper and js file you should be able to get the data. Setting up the divs should not be too hard either.
                    See what you can manage on your own and I will try to help you when you get stuck.
                    Paying it forward.
                    Peace!
                        rick93 @Mykle1
                        Hi @Mykle1 , I am trying to display only one parameter on the magic mirror,unfortunately it show undefined. I tried different ways but still cant make it.
                        I don’t not know what is the root cause since I was using MMM_UFO as my template. Do you mind to have a look on my module and advice me?
                        Thank you very much.
                        https://github.com/rick0222/MM-SW
                          rick93 @rick93
                          rick93 about 2 hours ago
                          I am not sure is the issue came from the API that I inserted not correct and return a wrong data. but I have no idea how I can make it work.
                          this.url = "https://api.data.gov.sg/v1/environment/4-day-weather-forecast";
                          		this.SW = [];
                            @rick93
                            Ok, I’ll take a look at it. :-)
                              @rick93
                              Give me your email in a private chat message and I’ll send you the fixed files.
                              You’re doing well. Don’t worry about making mistakes or being new. Everyone here has, at one time or another, been right where you are. I still struggle with coding. I’m just too old and too stupid to stop trying.
                                rick93 @Mykle1
                                @rick93
                                Big thanks !! @Mykle1 it’s just a simple code change that made my module works !! fantastic!
                                  @rick93
                                  You’re welcome, mate. Congrats on making your module!
                                  • 2 / 3
