    MMM-GroveGestures
    51 Posts 8 Posters 31.0k Views 12 Watching
      Benjaminh86
      Hello World,
      I love your module!
      I use MMM-page-selector to switch between 2 pages. I wanted to use grove gesture to change pages, but I can not adapt the script.
      I can see my gestures in the Magic Mirror when I pass my hand in front of the grove gesture; after, i do not know what to put in config.js
      Can you help me?
      For information, my english is bad, and I do not know anything about programming!
      Thank you
      BenH
        [[global:former-user]] @Benjaminh86
        @Benjaminh86
        Let’s assume You have page 1 and 2.
        You can assign gesture LEFT to 1, RIGHT to 2.
        At that case, you can add this to your command set(default or any other you want).
        "LEFT": {
          notificationExec: {
            notification: "PAGE_SELECT",
            payload: "1",
        "RIGHT": {
          notificationExec: {
            payload: "2",
        The problem is, MMM-page-selector has no feature of “NEXT PAGE” or “PREVIOUS PAGE”. so when there be more than 2 pages, you should assign gestures per each page.
          Benjaminh86 @Guest
          @Sean as I said, I’m a beginner, and I do not understand everything in programming.
          In addition, I have a synthaxe error on the line “exec: (module, gestures) => {”
          it indicates a problem with the symbol =>.
          Can you help me?
            @Benjaminh86
            Show me your configuration.
              Benjaminh86 @Guest
              @Sean
              here is my configuration for your module :
              module: “MMM-GroveGestures”,
              position: “top_right”,
              pages: {‘all’: ‘top_right’},
              autoStart: true, //When Mirror starts, recognition will start.
              verbose:false, // If set as true, useful messages will be logged.
              recognitionTimeout: 1000, //Gesture sequence will be ended after this time from last recognized gesture.
              cancelGesture: “WAVE”, //If set, You can cancel gesture sequence with this gesture.
              visible: true, //Recognized gesture sequence will be displayed on position
              idleTimer: 1000*60*30, // `0` for disable, After this time from last gesture, onIdle will be executed.
              onIdle: { // See command section
                moduleExec: {
                  module: [],
                    module.hide(1000, null, {lockstring:"GESTURE"})
              onDetected: {
                notificationExec: {
                  notification: "GESTURE_DETECTED",
                /* You can make Mirror to wake up the modules which were hidden by onIdle with any gestures.
                moduleExec: {
                  module: [],
                  exec: (module) => {
                    module.show(1000, null, {lockstring:"GESTURE"})
              gestureMapFromTo: { //When your sensor is installed with rotated direction, you can calibrate with this.
                "Up": "UP",
                "Down": "DOWN",
                "Left": "LEFT",
                "Right": "RIGHT",
                "Forward": "FORWARD",
                "Backward": "BACKWARD",
                "Clockwise": "CLOCKWISE",
                "anti-clockwise": "ANTICLOCKWISE",
                "wave": "WAVE"
              commandSet: {
                   "LEFT": {
              	notificationExec: {
              		payload: "main",
                    "RIGHT": {
              	notificationExec: {
              		payload: "2",
                @Benjaminh86
                Your configuration about commandSet has something wrong.
                commandSet: {
                  "default" : {
                    "LEFT": {
                      notificationExec: {
                        payload: "main",
                    "RIGHT": {
                      notificationExec: {
                        payload: "2",
                  @Benjaminh86
                  And Have you syntax error? How did you know? Have you used npm check:config? That knows old-fashioned style javascript grammar. So it might not understand new trendy ES6 style grammar.
                  Try this to check your javascript syntax.
                  http://esprima.org/demo/validate.html
                    Benjaminh86 @Guest
                    @Sean
                    I used the command “npm run config: check”
                      Benjaminh86 @Guest
                      @Sean I modified my JavaScript and corrected the errors.
                      On my Magic Mirror, I can see my left right scan, but the page does not change.
                      an idea…
                        @Benjaminh86
                        Well, If notification would be emitted properly, remains are MMM-page-selector’s business.
                        You can check whether notification is broadcasted well with npm start dev (before it, stop your pm2) or Ctrl+Shift+i on MM running. You can get some useful messages on dev-console
                          Benjaminh86 @Guest
                          Hello @Sean
                          i will watch npm start dev.
                          Thanks for your help.
                          BenH
                            bolish
                            Hi @Benjaminh86
                            If it can help you, this is how I’m dealing with it :
                            • I uses MMM-GroveGestures / MMM-Pages / MMM-Pages indicator / MMM-Notificationtrigger
                            MMM-Pages allows PAGE_INCREMENT / PAGE_DECREMENT notification reception.
                            MMM-Pages is allow able to send you the active page number back is you ask for QUERY_PAGE_NUMBER.
                            So basically, in MMM-GroveGesture , I wanted specific gestures depending on the active page :
                            • I’ve created one command set per page (1/2/3/4/5)
                            • I’ve put PAGE_INCREMENT / DECREMENT as a default gesture (left / right) on all commands sets (as those one are always the same)
                            • I’ve put specific up / down / etc… gestures and related notification in different commands set depending on the page.
                            • I’ve added a specific fire into MMM-NotificationTrigger so that each time “PAGE INCREMENT / DECREMENT” is triggered, it also fires “PAGE NUMBER IS” back (thanks to “PAGE_QUERY_NUMBER”)
                            This way, MMM-GrovesGestures always knows on which page I’m and is using the proper command set.
                            Hope this will help you.
                              Benjaminh86 @bolish
                              Thank you so much @bolish !!
                              in principle, I understand how it works, but I’m really fond of programming.
                              without wanting to abuse, can you show me your scripts MMM-GroveGestures, MMM-Pages, MMM-NotificationTrigger…
                                bolish
                                @Benjaminh86
                                I will be able to do it later tonight as not at home for now.
                                Honestly, I clearly don’t have any knowledge at all neither, I just started MM 2 months ago and never touched to a Raspberry or Javascript or even text edit before…
                                Just by reading around on MM forums + the incredible community support, I managed it by playing around myself with different modules.
                                I’m still not an expert, but it works and I’m proud of myself!
                                If you want to understand how it works yourself for purposes of proudness, I would recommend you to :
                                • Install MMM-Pages (config in config.js is easy)
                                • Install MMM-RemoteControl (appart from changing the IP adress at the top of your config.js, there is nothing else to do. This will allow you to send notification from your smartphone browser as a matter of testing. And when you will be comfortable, you will see that this will allow you to configurate your own smartphone command app for the mirror, it’s pretty powerful and simple)
                                • Install MMM-NotificationTrigger (basically, it works like that : if Notification A is received, please send notification B
                                Start to play with NotificationTrigger and MMM-Pages to do something like this :
                                • On your smartphone browser (after ahving installed MMM-RemoteControl and configured it) : send some notification like this to MMM-Pages and see if the pages changes :
                                http://YOURIP:8080/remote?action=NOTIFICATION&notification=PAGE_INCREMENT"
                                "http://YOURIP:8080/remote?action=NOTIFICATION&notification=PAGE_DECREMENT"
                                Try to configure MMM-NotificationTrigger so that when “PAGE_INCREMENT” is received, it will fire “PAGE_QUERY_NUMBER” (to MMM-Pages that will then respond with “PAGE_NUMBER_IS” + payload “X”, X being the page number).
                                Try to configure MMM-NotificaitonTrigger so that when “PAGE_NUMBER_IS” is received (with payload), and alert is shown on the mirror with the returned Page Number as a payload.
                                Once you will have done that, you will have understand how everything works (you will be able to delete the alert shown on the message which was just a test).
                                If you manage to do that, the MMM-GroveGestures part in the end will be a piece of cake (and don’t worry, the above is not difficult at all if you want to learn by yourself).
                                I will try to post you a working extract of my config.js this evening. If I forget, please remind me.
                                Regards
                                  Benjaminh86 @bolish
                                  @bolish
                                  you seem to know how to do things better than me; there are some who understand faster than others, I must be part of the 2nd categories!
                                  I already installed remote control that works well. I will try with all the information you give me as soon as I have time (I am not at home now).
                                  it may seem a little easy for me to ask you your scripts, but it allows me to understand the operation and interactions, so I want to see them when you have time.
                                  Thanks for your help :)
                                    Screech
                                    Hi, I’m interrested in using this module (Great job by the way).
                                    But in hardware I have number of choice :
                                    https://fr.aliexpress.com/item/Fast-Free-Ship-Based-on-PAJ7620U2-Gesture-Recognition-Sensor-9-Gesture-Recognition-Grove-Gesture-Recognition-Sensor/32796887595.html
                                    This one seam to be the same as yours at 22.33€
                                    But there other with the same "chipset’ :
                                    https://fr.aliexpress.com/item/PAJ7620U2-Divers-Geste-Reconnaissance-Capteur-Module-Pour-Arduino-Int-gr-9-geste-IIC-interface-reconnaissance-intelligente/32963443120.html
                                    At 3.52€ … The only “difference” I see is the number of pin : 5 instead of 4… there is a “INT” Pin… do you know if it’s compatible and what’s the use of this “INT” pin ?
                                      [[global:former-user]] @Screech
                                      @Screech
                                      I’m not annexpert so I cannot declare, but…
                                      I think INT means Interrupt, It can give additional feature about interruptions to device. Anyway I think it would work when INT is not connected, but not sure. Sorry.
                                        Screech @Guest
                                        @Sean
                                        Thank you for the info ;) I just command one to test ;)
                                        Cya in about 1 month (when I receiv and test it) I give you a feedback then :D
                                          bolish
                                          @Benjaminh86
                                          Here is an extract of mine that should help you to understand. You just have to tweak the notification and pages based on your setup.
                                          			// 22
                                          			module: "MMM-GroveGestures",
                                          				verbose:true, // If set as `true`, useful messages will be logged.
                                          				cancelGesture: "WAVE", //If set, You can cancel gesture sequence with this gesture.
                                          				idleTimer: "0", // `0` for disable, After this time from last gesture, onIdle will be executed.
                                          				defaultCommandSet: "DEFAULT_MODE",
                                          				commandSet: {
                                          					"DEFAULT_MODE": {
                                          							"LEFT": {
                                          						        notificationExec: {
                                          						          notification: "PAGE_INCREMENT",
                                          							"RIGHT": {
                                          						        notificationExec: {
                                          						          notification: "PAGE_DECREMENT",
                                          					"0": { // this corresponds to the page N° sent back by MMM-Pages
                                          							"LEFT": {
                                          						        notificationExec: {
                                          							"RIGHT": {
                                          						        notificationExec: {
                                          							"UP": {
                                          						        notificationExec: {
                                          						          notification: "CALEXT2_SCENE_NEXT",
        payload: null,
                                          							"DOWN": {
                                          						        notificationExec: {
                                          						          notification: "CALEXT2_SCENE_PREVIOUS",
        payload: null,
                                          					"1": {
                                          						        "LEFT-RIGHT-LEFT": {
                                          						        notificationExec: {
                                          						          notification: "REMOTE_ACTION",
                                          							    payload: {
                                          							  	action: "SHOW",
                                          							  	module: "module_13_MMM-BackgroundSlideshow",
                                          						        "RIGHT-LEFT-RIGHT": {
                                          						        notificationExec: {
                                          							    payload: {
                                          							  	action: "HIDE",
                                          						        "UP-DOWN-UP": {
                                          						        notificationExec: {
                                          							    payload: {
                                          							  	action: "SHOW",
                                          							  	module: "module_14_MMM-BackgroundSlideshowInfo",
                                          		        				"DOWN-UP-DOWN": {
                                          						        notificationExec: {
                                          							    payload: {
                                          							  	action: "HIDE",
                                          							"LEFT": {
                                          						        notificationExec: {
                                          							"RIGHT": {
                                          						        notificationExec: {
                                          							"UP": {
                                          						        notificationExec: {
                                          						          notification: "ARTICLE_MORE_DETAILS",
                                          							"DOWN": {
                                          						        notificationExec: {
                                          						          notification: "ARTICLE_LESS_DETAILS",
                                          							"CLOCKWISE": {
                                          						        notificationExec: {
                                          						          notification: "BACKGROUNDSLIDESHOW_NEXT",
                                          							"ANTICLOCKWISE": {
                                          						        notificationExec: {
                                          						          notification: "ARTICLE_PREVIOUS",
                                          					"2": {
                                          							"LEFT": {
                                          						        notificationExec: {
                                          							"RIGHT": {
                                          						        notificationExec: {
                                          							"UP": {
                                          						        notificationExec: {
                                          						          notification: "SWD_NEXT",
                                          							"DOWN": {
                                          						        notificationExec: {
                                          						          notification: "SWD_PREV",
                                          							"FORWARD-BACKWARD": {
                                          						        notificationExec: {
                                          						          notification: "SWD_PAUSE",
                                          							"BACKWARD-FORWARD": {
                                          						        notificationExec: {
                                          						          notification: "SWD_PLAY",
                                          					commandSetTrigger: {
                                          					  "DEFAULT_MODE": "DEFAULT_MODE",
                                            					  "PAGE_NUMBER_IS": (payload) => { return payload } // this is what set the right command set based on MMM-Pages feedback "PAGE_NUMBER_IS"
                                          			//22
                                          			module: "MMM-NotificationTrigger",
                                          				useWebhook: false,
                                          				triggers: [
                                          						// Is hiding the compliments module when newsfeed article is toggled fullscreen
                                          						trigger: "ARTICLE_MORE_DETAILS",
                                          						fires: [
                                          								fire: "REMOTE_ACTION",
                                          								  payload: {
                                              									action: "HIDE",
                                              									module: "module_6_compliments",
                                          						// Is showing the compliments module again when newsfeed is minimized.
                                          						trigger: "ARTICLE_LESS_DETAILS",
                                          						fires: [
                                          								  payload: {
                                              									action: "SHOW",
                                          						// Is triggering PAGE NUMBER NOTIFICATION when pages is changing
                                          						trigger: "PAGE_DECREMENT",
                                          						fires: [
                                          								fire: "QUERY_PAGE_NUMBER",
                                          						trigger: "PAGE_INCREMENT",
                                          						fires: [
                                          						// Slideshow_Show.
                                          						trigger: "SLIDESHOW_SHOW",
                                          						fires: [
                                          								  payload: {
                                              									action: "SHOW",
                                          						// Slideshow_Hide.
                                          						trigger: "SLIDESHOW_HIDE",
                                          						fires: [
                                          								  payload: {
                                              									action: "HIDE",
                                          						// SlideshowInfo_Show.
                                          						trigger: "SLIDESHOWINFO_SHOW",
                                          						fires: [
                                          								  payload: {
                                              									action: "SHOW",
                                          						// SlideshowInfo_Hide.
                                          						trigger: "SLIDESHOWINFO_HIDE",
                                          						fires: [
                                          								  payload: {
                                              									action: "HIDE",
                                          						fires: [
                                          								  payload: {
                                              									action: "SHOW",
                                          						// AT START - Is hiding MMM-ImageSlideshow at start.
                                          						trigger: "ALL_MODULES_STARTED",
                                          						fires: [
                                          								  payload: {
                                              									action: "HIDE",
                                          								  payload: {
                                              									action: "HIDE",
                                          								fire: "PAGE_INCREMENT",
                                          						// SHUTDONW - turns screen off and shutdown pi
                                          						trigger: "SCREENOFFSHUTDOWN",
                                          						fires: [
                                          								  payload: {
                                              									action: "MONITOROFF",
                                          								  payload: {
                                              									action: "SHUTDOWN",
                                            Benjaminh86 @bolish
                                            Hello @bolish,
                                            thanks for sharing the script. I will watch this carefully ;)
                                            BenH
