    MMM-CalendarExt
    198 Posts 45 Posters 276.4k Views 45 Watching
    • F
      Frek
      Hi. In weeks view with event time displayed, is there a way to remove the starting time and ending time on full day events?
      ? 1 Reply Last reply
        A Former User @Frek
        @frek
        Add this into your css/custom.css;
        .CALEXT .tableStyle .eventTime {
        display: none;
        F 1 Reply Last reply
        • F
          Frek @Guest
          @sean
          Thx for the reply.
          I already have this in my css to display time, that I want:
          div.CALEXT .tableStyle .eventTime {
          display:block;
          font-weight:normal;
          font-size:70%;
          But I was wondering if on full day events its possible to only show title, not the time
            A Former User @Frek
            @frek
            div.CALEXT .tableStyle .fulldayevent .eventTime {
              display:none;
            Try this.
            • F
              Frek @Guest
              @sean
              tried adding i to my custom.css and no change. my .css looks like:
               * Magic Mirror                                      *
               * Custom CSS                                        *
               * By Michael Teeuw http://michaelteeuw.nl           *
               * MIT Licensed.                                     *
               * Add any custom CSS below.                         *
               * Changes to this files will be ignored by GIT. *
               body {
                margin: 10px;
                height: calc(100% - 20px);
                width: calc(100% - 20px);
                display:none;
                display:block;
                font-weight:normal;
                font-size:70%;
               .CALEXT .tableStyle td.slot {
                max-height:200px;
                height:200px;
               .CALEXT .tableStyle {
                margin:0;
                max-width: 100%;
                A Former User @Frek
                @frek said in MMM-CalendarExt:
                display:none;
                display:block;
                font-weight:normal;
                font-size:70%;
                max-height:200px;
                height:200px;
                margin:0;
                max-width: 100%;
                I tested with your CSS but it works as expectation.
                • F
                  Frek @Guest
                  @sean ah suck… my test calendar didnt have a full day event… just a long normal event. Google calandar tricked me by showing me it as a fullday event in their app…No wonder why it didnt work… thx for the help =)
                  • G
                    goalie2k
                    Is it possible to make the event time display on the SAME line as the event title?
                      A Former User @goalie2k
                      @goalie2k
                      Of course possible by adjusting CSS
                      .CALEXT .event .eventContainer {
                        display: flex;
                        flex-direction: row;
                        flex-wrap: wrap;
                      .CALEXT .eventTime {
                        order: 2;
                        width: 30%;
                      .CALEXT .eventContent {
                        order: 1;
                        width: 70%;
                      It will show like this.
                      G 1 Reply Last reply
                      • G
                        goalie2k @Guest
                        @Sean said in MMM-CalendarExt:
                        order: 2;
                        width: 30%;
                        YOU ROCK! Thank you!
                          Subintro
                          Hey does anyone know how to change text on the calendars?
                          I’m using the ‘Current’ event, but it looks kind of confusing as it says ‘In 50 minutes’, which makes it seem like the event is in 50 minutes, but really ends in 50 minutes
                            A Former User @Subintro
                            @Subintro
                            With MMM-CalendarExt, it’s not so easy. You just use useRelative:0 to display normal time. Anyway “CURRENT” event will not be thing of “START IN FUTURE”, It is already started and be a kind of “END IN FUTURE” things. “CURRENT” means that.
                            How about using MMM-CalendarExt2? That is new build-up and the feature can be configurable and customizable by configuration.
                            https://github.com/eouia/MMM-CalendarExt2/wiki/Event-Time#2-relative
                              Subintro @Guest
                              @Sean
                              Oh nice, I’ll check it out. Hopefully wont have to change too much with my config
                                Smotx
                                Little help please,
                                how to reduce the height of the module?
                                It adapts automatically to the content, but suddenly exceeds the top one
                                alt text
                                Thx a lot.
                                  A Former User @Smotx
                                  @Smotx
                                  See this;
                                  https://github.com/eouia/MMM-CalendarExt/wiki/Manipulation-of-looks#viewlimit--viewoverflow
                                    Smotx @Guest
                                    @Sean
                                    Thx for help, with your indication, i have finally used
                                    overflowHeight: 200,
                                      redink
                                      Is there a way to show the event start time in the same space as the even name?
                                      Like 6p Swim Lesson
                                        A Former User @redink
                                        @redink
                                        More detailed adjusting might be needed, but commonly see this.
                                        https://forum.magicmirror.builders/topic/4624/mmm-calendarext/148
                                        And, add onlyStartingTime: 1, in your view configuration
                                        • I
                                          isaac2004
                                          Seems I cannot get the module to load. tried a few things, but it is just blank. I have the latest version of MM
                                            A Former User @isaac2004
                                            @isaac2004 I need log or more detailed info to catch what happened.
                                            • 10
                                            • 8 / 10
