    MMM-CalendarExt
    198 Posts 45 Posters 271.8k Views 45 Watching
      A Former User @Frek
      @frek
      div.CALEXT .tableStyle .fulldayevent .eventTime {
        display:none;
      Try this.
      • F
        Frek @Guest
        @sean
        tried adding i to my custom.css and no change. my .css looks like:
         * Magic Mirror                                      *
         * Custom CSS                                        *
         * By Michael Teeuw http://michaelteeuw.nl           *
         * MIT Licensed.                                     *
         * Add any custom CSS below.                         *
         * Changes to this files will be ignored by GIT. *
         body {
          margin: 10px;
          height: calc(100% - 20px);
          width: calc(100% - 20px);
          display:none;
         div.CALEXT .tableStyle .eventTime {
          display:block;
          font-weight:normal;
          font-size:70%;
         .CALEXT .tableStyle td.slot {
          max-height:200px;
          height:200px;
         .CALEXT .tableStyle {
          margin:0;
          max-width: 100%;
          A Former User @Frek
          @frek said in MMM-CalendarExt:
          display:none;
          display:block;
          font-weight:normal;
          font-size:70%;
          max-height:200px;
          height:200px;
          margin:0;
          max-width: 100%;
          I tested with your CSS but it works as expectation.
          • F
            Frek @Guest
            @sean ah suck… my test calendar didnt have a full day event… just a long normal event. Google calandar tricked me by showing me it as a fullday event in their app…No wonder why it didnt work… thx for the help =)
            • G
              goalie2k
              Is it possible to make the event time display on the SAME line as the event title?
                A Former User @goalie2k
                @goalie2k
                Of course possible by adjusting CSS
                Add this into your css/custom.css
                .CALEXT .event .eventContainer {
                  display: flex;
                  flex-direction: row;
                  flex-wrap: wrap;
                .CALEXT .eventTime {
                  order: 2;
                  width: 30%;
                .CALEXT .eventContent {
                  order: 1;
                  width: 70%;
                It will show like this.
                G 1 Reply Last reply Reply Quote 1
                • G
                  goalie2k @Guest
                  @Sean said in MMM-CalendarExt:
                  order: 2;
                  width: 30%;
                  YOU ROCK! Thank you!
                    Subintro
                    Hey does anyone know how to change text on the calendars?
                    I’m using the ‘Current’ event, but it looks kind of confusing as it says ‘In 50 minutes’, which makes it seem like the event is in 50 minutes, but really ends in 50 minutes
                      A Former User @Subintro
                      @Subintro
                      With MMM-CalendarExt, it’s not so easy. You just use useRelative:0 to display normal time. Anyway “CURRENT” event will not be thing of “START IN FUTURE”, It is already started and be a kind of “END IN FUTURE” things. “CURRENT” means that.
                      How about using MMM-CalendarExt2? That is new build-up and the feature can be configurable and customizable by configuration.
                      https://github.com/eouia/MMM-CalendarExt2/wiki/Event-Time#2-relative
                        Subintro @Guest
                        @Sean
                        Oh nice, I’ll check it out. Hopefully wont have to change too much with my config
                          Smotx
                          Little help please,
                          how to reduce the height of the module?
                          It adapts automatically to the content, but suddenly exceeds the top one
                          alt text
                          Thx a lot.
                            A Former User @Smotx
                            @Smotx
                            See this;
                            https://github.com/eouia/MMM-CalendarExt/wiki/Manipulation-of-looks#viewlimit--viewoverflow
                              Smotx @Guest
                              @Sean
                              Thx for help, with your indication, i have finally used
                              overflowHeight: 200,
                                redink
                                Is there a way to show the event start time in the same space as the even name?
                                Like 6p Swim Lesson
                                  A Former User @redink
                                  @redink
                                  More detailed adjusting might be needed, but commonly see this.
                                  https://forum.magicmirror.builders/topic/4624/mmm-calendarext/148
                                  And, add onlyStartingTime: 1, in your view configuration
                                  • I
                                    isaac2004
                                    Seems I cannot get the module to load. tried a few things, but it is just blank. I have the latest version of MM
                                      A Former User @isaac2004
                                      @isaac2004 I need log or more detailed info to catch what happened.
                                        mmmmh Project Sponsor
                                        I successfully use the module on two other screens. I just set up a new one without tweaks and I run into the following error in the console (nothing gets loaded, server-side there are no errors being logged):
                                        Uncaught (in promise) TypeError: hookDom.appendChild is not a function
                                            at Render.js:590
                                            at Array.forEach (<anonymous>)
                                            at Render.drawViews (Render.js:581)
                                            at Class.getDom (MMM-CalendarExt.js:209)
                                            at main.js:110
                                            at new Promise (<anonymous>)
                                            at updateDom (main.js:109)
                                            at Object.updateDom (main.js:518)
                                            at Class.updateDom (module.js:358)
                                            at Class.draw (MMM-CalendarExt.js:680)
                                          A Former User @mmmmh
                                          @mmmmh did you set a position of view? your error says there might be an issue. I’m on a business trip now so i cannot check at this moment. later i’ll look inside.
                                            mmmmh Project Sponsor @Guest
                                            @Sean yes, I set it to top_left:
                                                        module: 'MMM-CalendarExt',
                                                        position: "top_left", //anywhere. It is not related to real position of view
                                                        classes: "default standard everyone",
                                                        config: { // Read below
                                                            system: {
        show: ['current', 'upcoming'],
        locale: 'de',
        showEmptyView: 0,
        fullDayEventLocalize: 1,
        redrawInterval: 300000,
                                                            defaultView: {
        position: 'calendar',
        positionOrder: -1,
        overflowRolling: 0,
        overflowHeight: 0,
        overflowDuration: 2,
        timeFormat: 'H:mm',
        dateFormat: "ddd, D. MMM",
        fullDayEventDateFormat: "ddd, D. MMM",
        ellipsis: 0,
        limit: 20,
        oneLineEvent: 1,
                                                            views: {
        current: {
        title: "Now...",
        direction: "column",
        showEmptyView: 0,
        useRelative: 0,
        upcoming: {
        title: "Was steht an...",
        useRelative: 0,
        overflowHeight: 0,
        overflowRolling: 0,
        symbol: "male",
        styleName: "style24",
        url: "redacted",
        auth: {
        user: 'redacted',
        pass: 'redacted',
        method: 'basic'
                                            Don’t worry, it’s not urgent.
                                            • 10
                                            • 8 / 10
