    MMM-CalendarExt
    198 Posts 45 Posters 271.8k Views 45 Watching
    • F
      Frek @Guest
      @sean ah suck… my test calendar didnt have a full day event… just a long normal event. Google calandar tricked me by showing me it as a fullday event in their app…No wonder why it didnt work… thx for the help =)
      • G
        goalie2k
        Is it possible to make the event time display on the SAME line as the event title?
          A Former User @goalie2k
          @goalie2k
          Of course possible by adjusting CSS
          Add this into your css/custom.css
          .CALEXT .event .eventContainer {
            display: flex;
            flex-direction: row;
            flex-wrap: wrap;
          .CALEXT .eventTime {
            order: 2;
            width: 30%;
          .CALEXT .eventContent {
            order: 1;
            width: 70%;
          It will show like this.
          G 1 Reply Last reply Reply Quote 1
          • G
            goalie2k @Guest
            @Sean said in MMM-CalendarExt:
            order: 2;
            width: 30%;
            YOU ROCK! Thank you!
              Subintro
              Hey does anyone know how to change text on the calendars?
              I’m using the ‘Current’ event, but it looks kind of confusing as it says ‘In 50 minutes’, which makes it seem like the event is in 50 minutes, but really ends in 50 minutes
                A Former User @Subintro
                @Subintro
                With MMM-CalendarExt, it’s not so easy. You just use useRelative:0 to display normal time. Anyway “CURRENT” event will not be thing of “START IN FUTURE”, It is already started and be a kind of “END IN FUTURE” things. “CURRENT” means that.
                How about using MMM-CalendarExt2? That is new build-up and the feature can be configurable and customizable by configuration.
                https://github.com/eouia/MMM-CalendarExt2/wiki/Event-Time#2-relative
                  Subintro @Guest
                  @Sean
                  Oh nice, I’ll check it out. Hopefully wont have to change too much with my config
                    Smotx
                    Little help please,
                    how to reduce the height of the module?
                    It adapts automatically to the content, but suddenly exceeds the top one
                    alt text
                    Thx a lot.
                      A Former User @Smotx
                      @Smotx
                      See this;
                      https://github.com/eouia/MMM-CalendarExt/wiki/Manipulation-of-looks#viewlimit--viewoverflow
                        Smotx @Guest
                        @Sean
                        Thx for help, with your indication, i have finally used
                        overflowHeight: 200,
                          redink
                          Is there a way to show the event start time in the same space as the even name?
                          Like 6p Swim Lesson
                            A Former User @redink
                            @redink
                            More detailed adjusting might be needed, but commonly see this.
                            https://forum.magicmirror.builders/topic/4624/mmm-calendarext/148
                            And, add onlyStartingTime: 1, in your view configuration
                            • I
                              isaac2004
                              Seems I cannot get the module to load. tried a few things, but it is just blank. I have the latest version of MM
                                A Former User @isaac2004
                                @isaac2004 I need log or more detailed info to catch what happened.
                                  mmmmh Project Sponsor
                                  I successfully use the module on two other screens. I just set up a new one without tweaks and I run into the following error in the console (nothing gets loaded, server-side there are no errors being logged):
                                  Uncaught (in promise) TypeError: hookDom.appendChild is not a function
                                      at Render.js:590
                                      at Array.forEach (<anonymous>)
                                      at Render.drawViews (Render.js:581)
                                      at Class.getDom (MMM-CalendarExt.js:209)
                                      at main.js:110
                                      at new Promise (<anonymous>)
                                      at updateDom (main.js:109)
                                      at Object.updateDom (main.js:518)
                                      at Class.updateDom (module.js:358)
                                      at Class.draw (MMM-CalendarExt.js:680)
                                    A Former User @mmmmh
                                    @mmmmh did you set a position of view? your error says there might be an issue. I’m on a business trip now so i cannot check at this moment. later i’ll look inside.
                                      mmmmh Project Sponsor @Guest
                                      @Sean yes, I set it to top_left:
                                                  module: 'MMM-CalendarExt',
                                                  position: "top_left", //anywhere. It is not related to real position of view
                                                  classes: "default standard everyone",
                                                  config: { // Read below
                                                      system: {
                                                          show: ['current', 'upcoming'],
                                                          locale: 'de',
                                                          showEmptyView: 0,
                                                          fullDayEventLocalize: 1,
                                                          redrawInterval: 300000,
                                                      defaultView: {
                                                          position: 'calendar',
                                                          positionOrder: -1,
                                                          overflowRolling: 0,
                                                          overflowHeight: 0,
                                                          overflowDuration: 2,
                                                          timeFormat: 'H:mm',
                                                          dateFormat: "ddd, D. MMM",
                                                          fullDayEventDateFormat: "ddd, D. MMM",
                                                          ellipsis: 0,
                                                          limit: 20,
                                                          oneLineEvent: 1,
                                                      views: {
                                                          current: {
                                                              title: "Now...",
                                                              direction: "column",
                                                              showEmptyView: 0,
                                                              useRelative: 0,
                                                          upcoming: {
                                                              title: "Was steht an...",
                                                              useRelative: 0,
                                                              overflowHeight: 0,
                                                              overflowRolling: 0,
                                                              symbol: "male",
                                                              styleName: "style24",
                                                              url: "redacted",
                                                              auth: {
        user: 'redacted',
        pass: 'redacted',
        method: 'basic'
                                      Don’t worry, it’s not urgent.
                                        @mmmmh
                                        Well, I tried with yours and it works.
                                        But two things you probably have wrong.
                                        • url: "redacted", is it right? it will make parsing error and it could be reason of your front error message.
                                        • showEmptyView:1 will affect on only system level, not view level. You’ve set showEmptyView:0 in system, so empty view will not appear.
                                          @Sean thanks for making the effort to test it. I went the same way now. I removed everything and picked a public trash collection calendar (nice idea of yours) - still the same error. (I also commented out the showEmptyView options.)
                                          The error appears locally (RPI3+) as well as in web browsers of all flavors.
                                          Here’s the full config file:
                                          var config = {
                                              address: "",
                                              port: 8080,
                                              ipWhitelist:
                                              language: "de",
                                              timeFormat: 24,
                                              units: "metric",
                                                          system: {
                                                              locale: 'de',
                                                              // showEmptyView: 0,
                                                          defaultView: {
                                                              positionOrder: -1,
                                                              overflowRolling: 0,
                                                              overflowHeight: 0,
                                                              timeFormat: 'H:mm',
                                                              ellipsis: 0,
                                                              limit: 20,
                                                              oneLineEvent: 1,
                                                          views: {
                                                              current: {
        title: "Now...",
        useRelative: 0,
                                                              upcoming: {
        title: "Upcoming...",
        useRelative: 0,
        overflowHeight: 0,
        overflowRolling: 0,
        symbol: "male",
        url: "https://www.ekm-mittelsachsen.de/de/service-dienstleistungen/entsorgungstermine-abfallkalender/abfallkalender/ical/stadt/4870/year/2019/",
                                            @mmmmh i’m on business trip now, after back home, i’ll try your new config.
                                            • 10
                                            • 8 / 10
