    MMM-CalendarExt
    198 Posts 45 Posters 258.3k Views 45 Watching
      JKTitanium @Vauxdvihl
      @vauxdvihl
      Hi, Sorry I new here. Do I need a seperate Calender for each icon/emoj? Can I use Rules for one single Calendar?
        [[global:former-user]] @JKTitanium
        @jktitanium
        Symbol is fixed per calendar.
        However each event style(color or font except symbol) could be variable by condition.
        • F Offline
          Frek
          Hi. In weeks view with event time displayed, is there a way to remove the starting time and ending time on full day events?
            [[global:former-user]] @Frek
            @frek
            Add this into your css/custom.css;
            .CALEXT .tableStyle .eventTime {
            display: none;
            • F Offline
              Frek @Guest
              @sean
              Thx for the reply.
              I already have this in my css to display time, that I want:
              div.CALEXT .tableStyle .eventTime {
              display:block;
              font-weight:normal;
              font-size:70%;
              But I was wondering if on full day events its possible to only show title, not the time
                @frek
                div.CALEXT .tableStyle .fulldayevent .eventTime {
                  display:none;
                Try this.
                • F Offline
                  Frek @Guest
                  @sean
                  tried adding i to my custom.css and no change. my .css looks like:
                   * Magic Mirror                                      *
                   * Custom CSS                                        *
                   * By Michael Teeuw http://michaelteeuw.nl           *
                   * MIT Licensed.                                     *
                   * Add any custom CSS below.                         *
                   * Changes to this files will be ignored by GIT. *
                   body {
                    margin: 10px;
                    height: calc(100% - 20px);
                    width: calc(100% - 20px);
                    display:none;
                    display:block;
                    font-weight:normal;
                    font-size:70%;
                   .CALEXT .tableStyle td.slot {
                    max-height:200px;
                    height:200px;
                   .CALEXT .tableStyle {
                    margin:0;
                    max-width: 100%;
                    @frek said in MMM-CalendarExt:
                    display:none;
                    display:block;
                    font-weight:normal;
                    font-size:70%;
                    max-height:200px;
                    height:200px;
                    margin:0;
                    max-width: 100%;
                    I tested with your CSS but it works as expectation.
                    • F Offline
                      Frek @Guest
                      @sean ah suck… my test calendar didnt have a full day event… just a long normal event. Google calandar tricked me by showing me it as a fullday event in their app…No wonder why it didnt work… thx for the help =)
                      • G Offline
                        goalie2k
                        Is it possible to make the event time display on the SAME line as the event title?
                          [[global:former-user]] @goalie2k
                          @goalie2k
                          Of course possible by adjusting CSS
                          .CALEXT .event .eventContainer {
                            display: flex;
                            flex-direction: row;
                            flex-wrap: wrap;
                          .CALEXT .eventTime {
                            order: 2;
                            width: 30%;
                          .CALEXT .eventContent {
                            order: 1;
                            width: 70%;
                          It will show like this.
                          G 1 Reply Last reply Reply Quote 1
                          • G Offline
                            goalie2k @Guest
                            @Sean said in MMM-CalendarExt:
                            order: 2;
                            width: 30%;
                            YOU ROCK! Thank you!
                              Subintro
                              Hey does anyone know how to change text on the calendars?
                              I’m using the ‘Current’ event, but it looks kind of confusing as it says ‘In 50 minutes’, which makes it seem like the event is in 50 minutes, but really ends in 50 minutes
                                [[global:former-user]] @Subintro
                                @Subintro
                                With MMM-CalendarExt, it’s not so easy. You just use useRelative:0 to display normal time. Anyway “CURRENT” event will not be thing of “START IN FUTURE”, It is already started and be a kind of “END IN FUTURE” things. “CURRENT” means that.
                                How about using MMM-CalendarExt2? That is new build-up and the feature can be configurable and customizable by configuration.
                                https://github.com/eouia/MMM-CalendarExt2/wiki/Event-Time#2-relative
                                  Subintro @Guest
                                  @Sean
                                  Oh nice, I’ll check it out. Hopefully wont have to change too much with my config
                                    Smotx
                                    Little help please,
                                    how to reduce the height of the module?
                                    It adapts automatically to the content, but suddenly exceeds the top one
                                    alt text
                                    Thx a lot.
                                      [[global:former-user]] @Smotx
                                      @Smotx
                                      See this;
                                      https://github.com/eouia/MMM-CalendarExt/wiki/Manipulation-of-looks#viewlimit--viewoverflow
                                        Smotx @Guest
                                        @Sean
                                        Thx for help, with your indication, i have finally used
                                        overflowHeight: 200,
                                          redink
                                          Is there a way to show the event start time in the same space as the even name?
                                          Like 6p Swim Lesson
                                            [[global:former-user]] @redink
                                            @redink
                                            More detailed adjusting might be needed, but commonly see this.
                                            https://forum.magicmirror.builders/topic/4624/mmm-calendarext/148
                                            And, add onlyStartingTime: 1, in your view configuration
                                            • 10
                                            • 8 / 10
