    MMM-DarkSkyForecast - Yet ANOTHER weather module
    334 Posts 67 Posters 931.8k Views 74 Watching
      chris1971 @onkelbobby
      @onkelbobby
      Done… after several trails I got the right setup … 0_1554403496449_04.04.2019.jpg
      • T
        trividar
        Is there a way to hide or delete the „power by …“ signet? Thx… by the way thanks for answering my previous question, I just resized 20px and it works now 👌 thx🤘
          Smotx
          I have test to modify every lines on original CSS and i can’t found how to reduce space top and under ‘day’
          alt text
          Thx for help
          sorry, I knew stupid, I had already asked this question and already had the answer ^^
          For help others who wants to redure space :
          .MMM-DarkSkyForecast .module-header {
            margin-bottom: 20px; /* adjust to taste */
          .MMM-DarkSkyForecast .module-header.forecast-header {
          .MMM-DarkSkyForecast .wrapper.tiled .forecast-container .forecast-item .time,
          .MMM-DarkSkyForecast .wrapper.tiled .forecast-container .forecast-item .day-name {
          line-height: 20px; /* adjust to taste */
          Thx to module designer
          • O
            Ore77
            can someone help me out?
            I dont know how to resolve this issue.
            My console says : " …MIME type is not executable…".
              go to the MM/modules folder and do
              ls MMM-Dark*
              then
              cd MMM-DarkSkyForecast
              then
              ls
              the error says that MMM-DarkSkyForecast.js is not present in the MMM-DarkSkyForecast folder (error 404)
              • O
                Ore77
                thanks for you reply.
                The file is definitely in that directory.
                  sdetweil @Ore77
                  @Ore77 is it spelled exactly like that… can u edit that file (nano MMM-DarkSkyForecast.js , ctrl-x to exit editor)
                  • O
                    Ore77
                    yea its exactly this file. And i´m able to edit and save without issues.
                      is this s new install?
                      • O
                        Ore77
                        yes its a fresh install. Its the first 3rd party module i´ve installed.
                          sdetweil @Ore77
                          @Ore77 and the path is
                          /home/pi/MagicMirror/modules/MMM-DarkSkyForecast
                          right? u need to be in /home/pi/MagicMirror/modules before you do the git clone
                            sdetweil @Ore77
                            @Ore77 did u get it solved?
                            • O
                              Ore77 @sdetweil
                              @sdetweil i considered the path´s in my configuration. Nevertheless after a second install of raspbian it suddenly worked.
                              I installed all updates of raspbian before i got over to MagicMirror this time.
                              Maybe it has something to do with that.
                                sdetweil @Ore77
                                @Ore77 no idea… glad u got it fixed… can u mark your issue solved
                                  Smotx
                                  Hi here,
                                  It’s possible to change only this text color ?
                                  alt text
                                  • H
                                    humdinger44
                                    Hey guys,
                                    I too am trying to solve the “Loading…” problem. I’ve tried a number of things but the most telling clue I have is that dark sky doesn’t register any api use for my key. I’ve tried resetting the key, no difference. No errors show up in the dev tool. Does anyone see any problems with my config?
                                       	module: "MMM-DarkSkyForecast",
                                      	header: "Weather",
                                    	classes: "default everyone",
                                      	disabled: false,
                                      		config:
                                        			apikey: "**************",
                                        			latitude: "**.******",
                                        			longitude: "-**.******",
                                        			iconset: "2m",
                                        			forecastLayout: "table"
                                      motdog @humdinger44
                                      @humdinger44 longitude should have - you have _ that could be it
                                      • H
                                        humdinger44 @motdog
                                        @motdog Thanks, I double checked that but it is the negative sign “-”
                                          the ‘loading’ problem is typical of a module that displays a default message (‘Loading…’)
                                          which is replaced when the data arrives. So, the data did not arrive…
                                          can u open the developers window and select the console tab and put DarkSky in the filter box. to remove any other messages…
                                          there should be some message about the api usage, key, … something
                                            I changed my key so it was invalid, and see an error in the terminal window
                                            [MMM-DarkSkyForecast] 15-May-19 09:11 ** ERROR ** null
                                            • 10
                                            • 11
                                            • 12
                                            • 13
                                            • 16
                                            • 17
                                            • 11 / 17
