    MMM-DarkSkyForecast - Yet ANOTHER weather module
    334 Posts 67 Posters 933.7k Views 74 Watching
    • O
      Ore77
      can someone help me out?
      I dont know how to resolve this issue.
      My console says : " …MIME type is not executable…".
        go to the MM/modules folder and do
        ls MMM-Dark*
        then
        cd MMM-DarkSkyForecast
        then
        ls
        the error says that MMM-DarkSkyForecast.js is not present in the MMM-DarkSkyForecast folder (error 404)
        • O
          Ore77
          thanks for you reply.
          The file is definitely in that directory.
            sdetweil @Ore77
            @Ore77 is it spelled exactly like that… can u edit that file (nano MMM-DarkSkyForecast.js , ctrl-x to exit editor)
            • O
              Ore77
              yea its exactly this file. And i´m able to edit and save without issues.
                is this s new install?
                • O
                  Ore77
                  yes its a fresh install. Its the first 3rd party module i´ve installed.
                  S 2 Replies Last reply
                    sdetweil @Ore77
                    @Ore77 and the path is
                    /home/pi/MagicMirror/modules/MMM-DarkSkyForecast
                    right? u need to be in /home/pi/MagicMirror/modules before you do the git clone
                    O 1 Reply Last reply
                      sdetweil @Ore77
                      @Ore77 did u get it solved?
                      • O
                        Ore77 @sdetweil
                        @sdetweil i considered the path´s in my configuration. Nevertheless after a second install of raspbian it suddenly worked.
                        I installed all updates of raspbian before i got over to MagicMirror this time.
                        Maybe it has something to do with that.
                          sdetweil @Ore77
                          @Ore77 no idea… glad u got it fixed… can u mark your issue solved
                            Smotx
                            Hi here,
                            It’s possible to change only this text color ?
                            alt text
                            • H
                              humdinger44
                              Hey guys,
                              I too am trying to solve the “Loading…” problem. I’ve tried a number of things but the most telling clue I have is that dark sky doesn’t register any api use for my key. I’ve tried resetting the key, no difference. No errors show up in the dev tool. Does anyone see any problems with my config?
                                 	module: "MMM-DarkSkyForecast",
                                	header: "Weather",
                              	classes: "default everyone",
                                	disabled: false,
                                		config:
                                  			apikey: "**************",
                                  			latitude: "**.******",
                                  			longitude: "-**.******",
                                  			iconset: "2m",
                                  			forecastLayout: "table"
                              M 1 Reply Last reply
                                motdog @humdinger44
                                @humdinger44 longitude should have - you have _ that could be it
                                H 1 Reply Last reply
                                • H
                                  humdinger44 @motdog
                                  @motdog Thanks, I double checked that but it is the negative sign “-”
                                    the ‘loading’ problem is typical of a module that displays a default message (‘Loading…’)
                                    which is replaced when the data arrives. So, the data did not arrive…
                                    can u open the developers window and select the console tab and put DarkSky in the filter box. to remove any other messages…
                                    there should be some message about the api usage, key, … something
                                      I changed my key so it was invalid, and see an error in the terminal window
                                      [MMM-DarkSkyForecast] 15-May-19 09:11 ** ERROR ** null
                                      • H
                                        humdinger44 @sdetweil
                                        @sdetweil https://imgur.com/d2Xeqgs.jpg I dont see anything like that
                                        https://i.imgur.com/d2Xeqgs.jpg shows the errors tab. i dont believe any of them apply to darksky
                                          sdetweil @humdinger44
                                          @humdinger44 note, this is in the terminal window where u issue npm start…
                                          Or it should appear in the pm2 logs
                                          • H
                                            this?
                                            https://i.imgur.com/SZZOQHm.png?1
                                            note that my internet connection up and running
                                            • 10
                                            • 11
                                            • 12
                                            • 13
                                            • 16
                                            • 17
                                            • 11 / 17
