    This device is not allowed to access your mirror.
    10 Posts 4 Posters 4.7k Views 3 Watching
      Julia
      var config = {
      	address: '0.0.0.0',
      	port: 8080,
      	ipwhitelist: [],
      		    module: "MMM-Remote-Control",
                                                    position: 'right',
                                                   apiKey:  ' '
      This is my config file but even If I whitelist every ip address I still can’t connect
      “Thisdevice is not allowed to access your mirror.
      Please check your config.js or config.js.sample to change this.”
      Any ideas?
      Pi 3b+ and mobile hotspot btw
      S B 2 Replies Last reply Reply Quote 0
        sdetweil @Julia
        @Julia what device is trying to connect?
        Is it using remote-control apis?
          Julia
          @sdetweil I am trying to connect my laptop. What do you mean by “Is it using remote-control apis?”?
            bhepler Module Developer @Julia
            @Julia - Where are you receiving that error message? Are you getting that on your mobile device trying to use the configuration app? Or is that on the mirror itself?
            I would try replacing the '0.0.0.0' value with your Pi’s IP address.
              Julia
              The error is on my phone. Replacing the ‘0.0.0.0’ value with my Pi’s ip address makes no difference. I still get the same message.
                sdetweil @Julia
                @Julia note that the strings in config are case sensitive, it should be
                ipWhitelist
                not
                ipwhitelist
                  dxfan227
                  is an api key required to run properly?
                    sdetweil @dxfan227
                    @dxfan227 not for the base framework, and most of the default modules. (Weather needs one)
                      dxfan227
                      @sdetweil Ok
                      Perhapes the config is missing the part I bolded here? :
                      module: “MMM-Remote-Control”,
                      position: ‘right’,
                      apiKey: ’ ’
                        sdetweil @dxfan227
                        @dxfan227 that shouldn’t matter.
                        The message the OP posted comes from server.js after checking the ipWhitelist config variable
