    MMM-ResRobot - Public transport information for Sweden
    138 Posts 27 Posters 222.3k Views 28 Watching
    • N Offline
      nn1mda @Alvinger
      @Alvinger
      Thanks for your effort! I have updated the module using “git pull” and replaced my config with the sample you have, now the magicmirror doesn’t start at all. Can you find the cause? I have tried some different things but it doesn’t work. When I remove the module it works fine, so it’s something here…
         module: "MMM-ResRobot",
         position: "left",
         header: "Departures",
          routes: [
          skipMinutes: 0,
          maximumEntries: 6,
          truncateAfter: 5,
          apiKey: "71a3996f-***"
        Alvinger @nn1mda
        @nn1mda
        Sorry! There is a documentation error in the README.
        The routes needs to enclosed by curly braces, like this:
           position: "left",
            routes: [
             {from: "740000003", to: "740000001"},
             {from: "740000002", to: ""},
            skipMinutes: 0,
            maximumEntries: 6,
            truncateAfter: 5,
        • N Offline
          nn1mda @Alvinger
          @Alvinger
          Still don’t start. Updated again and restarted but still the same problem, don’t start. :(
          Can you see anything else that is wrong here?
             position: "left",
              routes: [
              skipMinutes: 0,
              maximumEntries: 6,
              truncateAfter: 5,
            Alvinger @nn1mda
            @nn1mda
            You are missing a comma after the closing brace “]” in routes.
            The format is:
            routes: [ {...}],
            • N Offline
              nn1mda @Alvinger
              @Alvinger
              Perfect! Think you need to update your Readme file with this as well.
              Now the module loads, but stuck on “fetching departures” for 5 minutes now. The same problem I had before I hoped the update would solve.
              Do you have any idea?
              A 2 Replies Last reply Reply Quote 0
                Alvinger @nn1mda
                @nn1mda Strange, I’m running the latest version and it works (as of 1 minute ago) without any issues.
                Have you tried running magicmirror from the shell? node serveronly
                That way errors and status messages will be printed directly to the terminal making it easier to troubleshoot.
                  Alvinger @nn1mda
                  @nn1mda I copied your config above and fixed the comma. It does indeed show “fetching departures”/Inga avgångar which isn’t a big surprise as the API-key is masked. Using my API key it works as expected, see output below. You probably used an invalid API key, double check that it is correct.
                  • N Offline
                    nn1mda
                    Wow, I feel stupid now. Had to change project status for the API key from “test” to “released”. Didn’t knew that.
                    Big thank you for all your support!
                    • O Offline
                      off112
                      Is it possible to add/show which track a train departures from?
                        Alvinger @off112
                        @off112 it should be quite simple. I’ll look into it.
                        • O Offline
                          off112 @Alvinger
                          @Alvinger That would be wonderful. Thank you :)
                            Alvinger @off112
                            @off112 I have just pushed an update that includes the departure track info. Try it out and let me know of any issues.
                            • V Offline
                              Von Sudden @Alvinger
                              @Alvinger Västtrafik user here. I got the upgrade.
                              Either the line type icon or the track number is shown as “undefined”. Neither is actually visible. Screenshot below.
                              https://www.dropbox.com/s/p6zhnt1z1rysoja/DSC_0976.JPG?dl=0
                                Alvinger @Von Sudden
                                @Von-Sudden thanks, quick fixes aren’t always the best. I’ll have a look. Thanks for the info.
                                  @Von-Sudden I just pushed a quick fix, please try it out.
                                  V 2 Replies Last reply Reply Quote 0
                                  • V Offline
                                    @Alvinger From what I can see at ResRobot - Stolptidtabeller 2 ( https://www.trafiklab.se/node/14075/console ), it seems as if Västtrafik does not always post the fields rtTime, rtTrack and rtDate in the response from the API.
                                    • V Offline
                                      @Alvinger Almost there. The type symbols are gone, and some tracks are still undefined.
                                      https://www.dropbox.com/s/zbxs418ax24p90w/DSC_0977.JPG?dl=0
                                      • O Offline
                                        off112
                                        @Alvinger Thank you for your good work :)
                                        • V Offline
                                          @Alvinger I made a quick fix of line 120 in MMM-ResRobot.js
                                          depLineCell.innerHTML = departure.track || " ";
                                          That made the odd “undefined” tracks disappear from the track column if Västtrafik does not provide that field.
                                          The FontAwesome symbol is still missing in the type column, though.
                                          Thanks for the awesome work.
                                          A 1 Reply Last reply Reply Quote 2
                                            @Von-Sudden thank you for helping out. I will look into the font awedome issue.
                                            • 4 / 7
