    MMM-ResRobot - Public transport information for Sweden
    138 Posts 27 Posters 227.4k Views 28 Watching
    • E
      Eburkis
      @Alvinger said in MMM-ResRobot - Public transport information for Sweden:
      @Eburkis
      I haven’t been active for a while due to other things than magic mirrors.
      Let me take a look and see if I can find out what’s wrong.
      yes do that pls :) it would be very nice
      • E
        Eburkis @Alvinger
        @Eburkis
        —Update–
        now the module is working and seems to fetching the data but don’t displays anything…
        dont know whats wrong now
        • N
          norden1978 @Alvinger
          @Alvinger sounds great :)
            rich710
            Same for me, Fetching departures… forever, I have checked my ID:s on ResRobot and entered them in an url, to test.
            Happy for help.
            Regards //Richard
            • N
              nn1mda
              Installed this today, but it doesn’t work.
              Does it work for anyone else? And if so - what did you do? :)
              AlvingerA 1 Reply Last reply
              • AlvingerA
                Alvinger @nn1mda
                @nn1mda
                I haven’t been active in the Magic Mirror community for some time but I just checked and for me it works without issues. Did you get your API key?
                • AlvingerA
                  Alvinger @Alvinger
                  I’ve just pushed an update to github that resolves the scheduling issues some users have been experiencing. Please update the module. NOTE! There has been a breaking change in version 1.3 in that the config parameters have changed. See the start of this topic or the README.
                  N 1 Reply Last reply
                  • N
                    nn1mda @Alvinger
                    @Alvinger
                    Thanks for your effort! I have updated the module using “git pull” and replaced my config with the sample you have, now the magicmirror doesn’t start at all. Can you find the cause? I have tried some different things but it doesn’t work. When I remove the module it works fine, so it’s something here…
                       module: "MMM-ResRobot",
                       position: "left",
                       header: "Departures",
                        routes: [
                        skipMinutes: 0,
                        maximumEntries: 6,
                        truncateAfter: 5,
                        apiKey: "71a3996f-***"
                    • AlvingerA
                      Alvinger @nn1mda
                      @nn1mda
                      Sorry! There is a documentation error in the README.
                      The routes needs to enclosed by curly braces, like this:
                         position: "left",
                          routes: [
                           {from: "740000003", to: "740000001"},
                           {from: "740000002", to: ""},
                          skipMinutes: 0,
                          maximumEntries: 6,
                          truncateAfter: 5,
                      • N
                        nn1mda @Alvinger
                        @Alvinger
                        Still don’t start. Updated again and restarted but still the same problem, don’t start. :(
                        Can you see anything else that is wrong here?
                           position: "left",
                            routes: [
                            skipMinutes: 0,
                            maximumEntries: 6,
                            truncateAfter: 5,
                        • AlvingerA
                          Alvinger @nn1mda
                          @nn1mda
                          You are missing a comma after the closing brace “]” in routes.
                          The format is:
                          routes: [ {...}],
                          • N
                            nn1mda @Alvinger
                            @Alvinger
                            Perfect! Think you need to update your Readme file with this as well.
                            Now the module loads, but stuck on “fetching departures” for 5 minutes now. The same problem I had before I hoped the update would solve.
                            Do you have any idea?
                            AlvingerA 2 Replies Last reply
                            • AlvingerA
                              Alvinger @nn1mda
                              @nn1mda Strange, I’m running the latest version and it works (as of 1 minute ago) without any issues.
                              Have you tried running magicmirror from the shell? node serveronly
                              That way errors and status messages will be printed directly to the terminal making it easier to troubleshoot.
                              • AlvingerA
                                Alvinger @nn1mda
                                @nn1mda I copied your config above and fixed the comma. It does indeed show “fetching departures”/Inga avgångar which isn’t a big surprise as the API-key is masked. Using my API key it works as expected, see output below. You probably used an invalid API key, double check that it is correct.
                                • N
                                  nn1mda
                                  Wow, I feel stupid now. Had to change project status for the API key from “test” to “released”. Didn’t knew that.
                                  Big thank you for all your support!
                                  • O
                                    off112
                                    Is it possible to add/show which track a train departures from?
                                    • AlvingerA
                                      Alvinger @off112
                                      @off112 it should be quite simple. I’ll look into it.
                                      O 1 Reply Last reply
                                      • O
                                        off112 @Alvinger
                                        @Alvinger That would be wonderful. Thank you :)
                                        • AlvingerA
                                          Alvinger @off112
                                          @off112 I have just pushed an update that includes the departure track info. Try it out and let me know of any issues.
                                          V 1 Reply Last reply
                                          • V
                                            Von Sudden @Alvinger
                                            @Alvinger Västtrafik user here. I got the upgrade.
                                            Either the line type icon or the track number is shown as “undefined”. Neither is actually visible. Screenshot below.
                                            https://www.dropbox.com/s/p6zhnt1z1rysoja/DSC_0976.JPG?dl=0
                                            • 4 / 7
