    MMM-ResRobot - Public transport information for Sweden
    138 Posts 27 Posters 209.7k Views 28 Watching
    • AlvingerA Offline
      Alvinger @nn1mda
      @nn1mda
      You are missing a comma after the closing brace “]” in routes.
      The format is:
      routes: [ {...}],
      • N Offline
        nn1mda @Alvinger
        @Alvinger
        Perfect! Think you need to update your Readme file with this as well.
        Now the module loads, but stuck on “fetching departures” for 5 minutes now. The same problem I had before I hoped the update would solve.
        Do you have any idea?
        AlvingerA 2 Replies Last reply Reply Quote 0
        • AlvingerA Offline
          Alvinger @nn1mda
          @nn1mda Strange, I’m running the latest version and it works (as of 1 minute ago) without any issues.
          Have you tried running magicmirror from the shell? node serveronly
          That way errors and status messages will be printed directly to the terminal making it easier to troubleshoot.
          • AlvingerA Offline
            Alvinger @nn1mda
            @nn1mda I copied your config above and fixed the comma. It does indeed show “fetching departures”/Inga avgångar which isn’t a big surprise as the API-key is masked. Using my API key it works as expected, see output below. You probably used an invalid API key, double check that it is correct.
            • N Offline
              nn1mda
              Wow, I feel stupid now. Had to change project status for the API key from “test” to “released”. Didn’t knew that.
              Big thank you for all your support!
              • O Offline
                off112
                Is it possible to add/show which track a train departures from?
                AlvingerA 1 Reply Last reply Reply Quote 0
                • AlvingerA Offline
                  Alvinger @off112
                  @off112 it should be quite simple. I’ll look into it.
                  • O Offline
                    off112 @Alvinger
                    @Alvinger That would be wonderful. Thank you :)
                    • AlvingerA Offline
                      Alvinger @off112
                      @off112 I have just pushed an update that includes the departure track info. Try it out and let me know of any issues.
                      • V Offline
                        Von Sudden @Alvinger
                        @Alvinger Västtrafik user here. I got the upgrade.
                        Either the line type icon or the track number is shown as “undefined”. Neither is actually visible. Screenshot below.
                        https://www.dropbox.com/s/p6zhnt1z1rysoja/DSC_0976.JPG?dl=0
                        • AlvingerA Offline
                          Alvinger @Von Sudden
                          @Von-Sudden thanks, quick fixes aren’t always the best. I’ll have a look. Thanks for the info.
                          • AlvingerA Offline
                            @Von-Sudden I just pushed a quick fix, please try it out.
                            V 2 Replies Last reply Reply Quote 0
                            • V Offline
                              @Alvinger From what I can see at ResRobot - Stolptidtabeller 2 ( https://www.trafiklab.se/node/14075/console ), it seems as if Västtrafik does not always post the fields rtTime, rtTrack and rtDate in the response from the API.
                              • V Offline
                                @Alvinger Almost there. The type symbols are gone, and some tracks are still undefined.
                                https://www.dropbox.com/s/zbxs418ax24p90w/DSC_0977.JPG?dl=0
                                • O Offline
                                  off112
                                  @Alvinger Thank you for your good work :)
                                  • V Offline
                                    @Alvinger I made a quick fix of line 120 in MMM-ResRobot.js
                                    depLineCell.innerHTML = departure.track || " ";
                                    That made the odd “undefined” tracks disappear from the track column if Västtrafik does not provide that field.
                                    The FontAwesome symbol is still missing in the type column, though.
                                    Thanks for the awesome work.
                                    AlvingerA 1 Reply Last reply Reply Quote 2
                                    • AlvingerA Offline
                                      @Von-Sudden thank you for helping out. I will look into the font awedome issue.
                                      • L Offline
                                        leanro
                                        Hej!
                                        I’m trying to get the MMM-Resrobot to work but … no success. In my MM, it permanently says “Fetching Departures …”
                                        I have an API-key which seems to work, I checked at https://api.resrobot.se/v2/departureBoard?key=WITH-MY-API-KEY-HERE&id=740015972.
                                        My config.js looks like this:
        module: "MMM-ResRobot",
        header: "Departures",
        routes: [ // stations from:
        {from: "740015972", to: ""},
        apiKey: "WITH-MY-API-KEY-HERE"
                                        The MMM-ResRobot.js looks like this:
                                        defaults: {
                                        updateInterval: 5 * 60 * 1000,
                                        animationSpeed: 2000,
                                        fade: true,
                                        fadePoint: 0.25, // Start on 1/4th of the list.
                                        apiBase: “https://api.resrobot.se/v2/departureBoard?format=json&passlist=0”,
                                        skipMinutes: 0, // Number of minutes to skip before showing departures
                                        maximumEntries: 6, // Maximum Entries to show on screen
                                        truncateAfter: 5, // A value > 0 will truncate direction name at … … …
                                        iconTable: {
                                        “B”: “fa fa-bus”,
                                        “S”: “fa fa-subway”,
                                        “J”: “fa fa-train”,
                                        “U”: “fa fa-subway”,
                                        “F”: “fa fa-ship”,
                                        Anyone who has an idea?
                                        Appreciated! Tack!
                                        • L Offline
                                          leanro @leanro
                                          @leanro said in MMM-ResRobot - Public transport information for Sweden:
                                          Hej!
                                          Appreciated! Tack!
                                          After angrily restarting the RPi, the module works. Can’t tell you, why it didn’t work in the first place but I can confirm that the configs i posted before work.
                                          Good luck!
                                          Update: whenever sth is changed in the configs, a reload does not help I need to totally stop MM and restart for the changes to be effective.
                                          • AlvingerA Offline
                                            Alvinger @leanro
                                            @leanro great to hear it works. I had one or two of these “fetching departures” when I ran MagicMirror on my Rpi 1 with 256MB memory but since switching to a VM I haven’t seen it. As you have noticed, the solution is to restart MagicMirror.
                                            • 5 / 7
