    MMM-Spotify
    249 Posts 51 Posters 306.6k Views 54 Watching
    • Cr4z33C Offline
      Cr4z33 @Guest
      @Sean said in MMM-Spotify:
      The only thing I suspect is that you are using different account on MMM-Spotify and your real spotify player.
      Even if wasn’t the token OK at MM loading log?
        A Former User @Cr4z33
        @Cr4z33 said in MMM-Spotify:
        Token might be OK with different account, but if different account is used, it cannot derive current playback info. (You cannot get spotify info from your friend’s account playback with your account). Have you several accounts for spotify?
          white big Spotify logo came up at MM loading and then disappeared.
          This is normal. Unless you should customize CSS, with no playback, the module will be disappeared by default. (Some PPL have wanted so I added that feature.)
          When playing on any Spotify player starts, module will be appeared. (If it can get current playback info from server)
          • Cr4z33C Offline
            Cr4z33
            @Sean OK so to be 100% sure everything is set properly I start installing the module from scratch again generating once more the JSON file and the token.
            • Cr4z33C Offline
              Cr4z33
              @Sean working now!
              For some reason previous installation generated a token without .JSON at the end (I know because I made a backup on the Desktop) while this time it was generated properly!
              Thanks for your support anyway. :grinning_face_with_smiling_eyes:
                mmmmh Project Sponsor
                @Sean Is it intentional that the z-index of the artwork (or the Spotify logo) is equal to or higher than whatever the Alert module shows? Alerts do not cover the Spotify module’s content.
                  A Former User @mmmmh
                  @mmmmh not intentional. i rarely use alert module, so i didnt know about it. if you can make PR to fix it, feel free to contribute.
                  • L Offline
                    larrougos
                    Hi all! i ve set a config as
                    SPOTIFY_MA_PLAYLIST: {
                                notificationExec: {
                                    notification: "SPOTIFY_PLAY",
                                    payload: (params) => {
                                        console.log("SPOTIFY_MA_PLAYLIST")
                                        return {
                                            context_uri: "spotify:playlist:1EaTnmluBfauzzcOdjebNG", // Uri of a personnal playlist or album
                                    notification: "SPOTIFY_SHUFFLE", // added this to toogle shuffle
                                    notification: "SPOTIFY_NEXT" // added this to not always have the same song starting first
                    and activate it with
                                pattern: "play my playlist on spotify", // (.*)  is an action  eg: play my playlist / run my playlist etc...
                                command: "SPOTIFY_MA_PLAYLIST"
                    but every time i get this result which is very weird
                    weird response
                    any ideas plz?
                      A Former User @larrougos
                      @larrougos
                      It seems MMM-AssistantMk2’s commands.
                      You made some mistakes.
                      This is somewhat similar what you want.
                      "SPOTIFY_MA_PLAYLIST": {
                        notificationExec: {
                          payload: "spotify:playlist:1EaTnmluBfauzzcOdjebNG"
                      notificationExec cannot emit multiple notifications. It will emit just one - In your case, the last “SPOTIFY_NEXT” would be emitted. that’s why your issue happened.
                      If you want to emit several notifications, use MMM-NotificationTrigger to relay and chain notifications. Or you can use moduleExec to make some logics. (Anyway that is not the point).
                      And SPOTIFY_SHUFFLE is just toggle flag for current status, so it will not guarantee to be a shuffle mode.
                      • L Offline
                        larrougos @Guest
                        @larrougos
                          notificationExec: {
                        ok!! thats a start! can you please help me with that! i mean how this should have a proper syntax! i would really appreciate.
                        Also another problem that i have is that if spotify is not already playing in the background i am not able to play anything. whatever command i give. and the frontend does not even show the spotify logo. it just disappears on after one sec on start.
                          @larrougos
                          In that case, maybe, the module cannot find available active devices. It doesn’t mean you have no device. But by default, Spotify doesn’t know which device is yours unless it is powered and logged as your account.
                          So at least one of your devices need to be activated when this SDK is used. I recommend to install Raspotify, that could makes your spotify always on.
                          • L Offline
                            larrougos @Guest
                            @larrougos
                            i am running from ubuntu laptop with Spotify application! i tried with raspotify to install but from what i understood it does not support the laptop arch!
                              rabbit83ka @kwaeksler
                              First of all thanks for the module and the effort you put in it.
                              updated
                              1.1.0 (2019-03-25)
                              • Device Limitation : Now you can allow or limit devices to display its playing on MM.
                              One question regarding the device limitation: if I leave it empty, the module shows the cover etc. as it should. If I try to limit it to my echo dot with
                               allowDevices: ["myechodot"],
                              the spotify logo appears if I start playback on the echo dot, but no cover etc. is shown. Any hints?
                                A Former User @rabbit83ka
                                @rabbit83ka
                                When you play something on your echodot, nothing been displayed?
                                  rabbit83ka @Guest
                                  @Sean
                                  If I comment out
                                  //allwoeDevices: ["myechodot" ]
                                  it shows the album cover/etx/progress etc. when I play something on my echo dot. With
                                  the spotify logo appears when something is played on the echodot, but no cover/text/progress etc. is shown.
                                  • I Offline
                                    Ivanov_d
                                    • I Offline
                                      Ivanov_d
                                      I have the following recipies:
                                      var recipe = {
                                        transcriptionHook: {
                                          HIDE_ALL_MODULES: {
                                            pattern: "standby mode",
                                            command: "HIDEMODULES"
                                          SHOW_ALL_MODULES: {
                                            pattern: "show modules",
                                            command: "SHOWMODULES"
                                          SCREEN_ON: {
                                            pattern: "turn on screen",
                                            command: "SCREENON"
                                          SCREEN_OFF: {
                                            pattern: "turn off screen",
                                            command: "SCREENOFF"
                                          REBOOT: {
                                            pattern: "reboot the mirror",
                                            command: "REBOOT"
                                          SHUTDOWN: {
                                            pattern: "extinction totale",
                                            command: "SHUTDOWN"
                                          STOP_PLAY: {
                                            pattern: "stop the video", // this is for youtube but it is preferable to have youtubeAutoplay: false, when running spotify so you don't get interaction with youtube player.
                                            command: "STOP_VID"
                                          SPOTIFY_PREVIOUS: {
                                            pattern: "previous song",
                                            command: "SPOTIFY_PREVIOUS"
                                          SPOTIFY_PAUSE: {
                                            pattern : "stop the music",
                                            command: "SPOTIFY_PAUSE"
                                          SPOTIFY_PLAY: {
                                            pattern : "music please",
                                            command: "SPOTIFY_PLAY"
                                            SPOTIFY_NEXT: {
                                            pattern: "next song",
                                            command: "SPOTIFY_NEXT"
                                          SPOTIFY_VOLUME: {
                                            pattern: "set music volume to ([0-9]{1,2}[0]?|100)",
                                            command: "SPOTIFY_VOLUME"
                                          SPOTIFY_SEARCH: {
                                            pattern: "play (.*) on Spotify",
                                            command: "SPOTIFY_SEARCH"
                                          SPOTIFY_SEARCH_PLAYLIST: {
                                            pattern: "playlist (.*) on Spotify",
                                            command: "SPOTIFY_SEARCH_PLAYLIST"
                                          	pattern: "(.*) my playlist",   // (.*)  is an action  eg: play my playlist / run my playlist etc...
                                        	SPOTIFY_TRANSFER: {
                                          	pattern: "play the music on (.*)", // (.*)  is the name of your device
                                          	command: "SPOTIFY_TRANSFER"
                                          VOLUME_UP: {
                                            pattern: "volume up",
                                            command: "CMD_VOLUME_UP"
                                          VOLUME_DOWN: {
                                            pattern: "volume down",
                                            command: "CMD_VOLUME_DOWN"
                                          SET_VOLUME: {
                                            pattern: "set master volume to ([0-9]{1,2}[0]?|100)",
                                            command: "CMD_VOLUME_SET"
                                        command: {
                                          STOP_VID: {
                                            moduleExec: {
                                              module: ["MMM-AssistantMk2"],
                                              exec: (module, params, key) => {
                                                module.assistant.subdom.youtube.innerHTML = "";
                                                module.assistant.subdom.youtube.style.display = "none";
                                                module.youtubePlaying = false;
                                          SPOTIFY_TRANSFER: {
                                            notificationExec: {
                                              notification: "SPOTIFY_TRANSFER",
                                                console.log("SPOTIFY_TRANSFER @",params)
                                                return params[1];
                                          SPOTIFY_PAUSE: {
                                            notificationExec: {
                                              notification: "SPOTIFY_PAUSE"
                                          SPOTIFY_PLAY: {
                                            notificationExec: {
                                            notificationExec:  {
                                                  return {
                                                    context_uri:"spotify:playlist:0ka8HWt4xXcnTK5OpOuN2k",   // Uri of a personnal playlist or album
                                        	SPOTIFY_NEXT: {
                                            notificationExec: {
                                          SPOTIFY_PREVIOUS: {
                                            notificationExec: {
                                              notification: "SPOTIFY_PREVIOUS"
                                          SPOTIFY_VOLUME: {
                                            notificationExec: {
                                              notification: "SPOTIFY_VOLUME",
                                                console.log("SPOTIFY_VOLUME @",params)
                                                return params[1];
                                        	SPOTIFY_SEARCH: {
                                            notificationExec: {
                                              notification: "SPOTIFY_SEARCH",
                                                  console.log("SPOTIFY_SEARCH @",params)
                                                  return {
                                                    type: "artist,track,album,playlist",
                                                    query: params[1],
                                                    random:false,
                                            notificationExec: {
                                                  console.log("SPOTIFY_SEARCH_PLAYLIST @",params)
                                                  return {
                                                    type: "playlist",
                                                    query: params[1],
                                                    random:true,
                                          CMD_VOLUME_UP: {
                                            notificationExec: {
                                              notification: "VOLUME_UP"
                                          CMD_VOLUME_DOWN: {
                                            notificationExec: {
                                              notification: "VOLUME_DOWN"
                                          CMD_VOLUME_SET: {
                                            notificationExec: {
                                              notification: "VOLUME_SET",
                                              payload: (params, key) => {
                                                console.log("@", params);
                                                return params[1];
                                      exports.recipe = recipe // Don't remove this line.
                                      However, the
                                          SPOTIFY_PLAY: {
                                      Doesn’t work. It recognizes the command, but nothing happens. Playback from the mirror (raspotify) doesn’t happen. If I switch the source from my desktop/phone spotify app to Raspotify, then everything is fine (e.g. I renamed the player from Raspotify to MagicMirror if that matters).
                                      There are no errors in the logs as far as I can see.
                                      Any thoughts?
                                        A Former User @Ivanov_d
                                        @Ivanov_d
                                        Only that command doesn’t work? Other’s OK?
                                        Raspotify should be already running when you use this module. (This module cannot boot up Raspotify itself)
                                        • I Offline
                                          Ivanov_d
                                          @Sean yes, the other commands work. I can skip the song, increase/decrease the volume and etc. Also Raspotify is running, because I can start the playback on the mirror from my Desktop/Smartphone app.0_1563467613897_Untitled20190718193321.png
                                          • I Offline
                                            Ivanov_d
                                            @Sean, I did some more testing and I can confirm that this is the only command that doesn’t work. Maybe I am not understanding it correctly.
                                            My expected results would be:
                                            1. Raspotify is running in the background (but no music is playing)
                                            2. When I say “music please” spotify will start a random song and play it on the MagicMirror
                                            The result however is:
                                            1. Raspotify is running in the background and no music is playing
                                            2. When I say “music please” I see no errors in the logs, however, no music is starting as well
                                            3. To workaround this I start the music from my smartphone or desktop app and switch the player to MagicMirror, after that I can control the player via AssistankMK2
                                            • 12
                                            • 13
                                            • 5 / 13
