    MMM-Spotify
    249 Posts 51 Posters 357.2k Views 54 Watching
      A Former User @Cr4z33
      @Cr4z33 said in MMM-Spotify:
      white big Spotify logo came up at MM loading and then disappeared.
      This is normal. Unless you should customize CSS, with no playback, the module will be disappeared by default. (Some PPL have wanted so I added that feature.)
      When playing on any Spotify player starts, module will be appeared. (If it can get current playback info from server)
      • Cr4z33C
        Cr4z33
        @Sean OK so to be 100% sure everything is set properly I start installing the module from scratch again generating once more the JSON file and the token.
        • Cr4z33C
          Cr4z33
          @Sean working now!
          For some reason previous installation generated a token without .JSON at the end (I know because I made a backup on the Desktop) while this time it was generated properly!
          Thanks for your support anyway. :grinning_face_with_smiling_eyes:
            mmmmh Project Sponsor
            @Sean Is it intentional that the z-index of the artwork (or the Spotify logo) is equal to or higher than whatever the Alert module shows? Alerts do not cover the Spotify module’s content.
              A Former User @mmmmh
              @mmmmh not intentional. i rarely use alert module, so i didnt know about it. if you can make PR to fix it, feel free to contribute.
              • L
                larrougos
                Hi all! i ve set a config as
                SPOTIFY_MA_PLAYLIST: {
                            notificationExec: {
                                notification: "SPOTIFY_PLAY",
                                payload: (params) => {
                                    console.log("SPOTIFY_MA_PLAYLIST")
                                    return {
                                        context_uri: "spotify:playlist:1EaTnmluBfauzzcOdjebNG", // Uri of a personnal playlist or album
                                notification: "SPOTIFY_SHUFFLE", // added this to toogle shuffle
                                notification: "SPOTIFY_NEXT" // added this to not always have the same song starting first
                and activate it with
                            pattern: "play my playlist on spotify", // (.*)  is an action  eg: play my playlist / run my playlist etc...
                            command: "SPOTIFY_MA_PLAYLIST"
                but every time i get this result which is very weird
                weird response
                any ideas plz?
                  A Former User @larrougos
                  @larrougos
                  It seems MMM-AssistantMk2’s commands.
                  You made some mistakes.
                  This is somewhat similar what you want.
                  "SPOTIFY_MA_PLAYLIST": {
                    notificationExec: {
                      payload: "spotify:playlist:1EaTnmluBfauzzcOdjebNG"
                  notificationExec cannot emit multiple notifications. It will emit just one - In your case, the last “SPOTIFY_NEXT” would be emitted. that’s why your issue happened.
                  If you want to emit several notifications, use MMM-NotificationTrigger to relay and chain notifications. Or you can use moduleExec to make some logics. (Anyway that is not the point).
                  And SPOTIFY_SHUFFLE is just toggle flag for current status, so it will not guarantee to be a shuffle mode.
                  • L
                    larrougos @Guest
                    @Sean said in MMM-Spotify:
                    @larrougos
                      notificationExec: {
                    ok!! thats a start! can you please help me with that! i mean how this should have a proper syntax! i would really appreciate.
                    Also another problem that i have is that if spotify is not already playing in the background i am not able to play anything. whatever command i give. and the frontend does not even show the spotify logo. it just disappears on after one sec on start.
                      @larrougos
                      In that case, maybe, the module cannot find available active devices. It doesn’t mean you have no device. But by default, Spotify doesn’t know which device is yours unless it is powered and logged as your account.
                      So at least one of your devices need to be activated when this SDK is used. I recommend to install Raspotify, that could makes your spotify always on.
                      • L
                        larrougos @Guest
                        @larrougos
                        i am running from ubuntu laptop with Spotify application! i tried with raspotify to install but from what i understood it does not support the laptop arch!
                          rabbit83ka @kwaeksler
                          First of all thanks for the module and the effort you put in it.
                          updated
                          1.1.0 (2019-03-25)
                          • Device Limitation : Now you can allow or limit devices to display its playing on MM.
                          One question regarding the device limitation: if I leave it empty, the module shows the cover etc. as it should. If I try to limit it to my echo dot with
                           allowDevices: ["myechodot"],
                          the spotify logo appears if I start playback on the echo dot, but no cover etc. is shown. Any hints?
                            A Former User @rabbit83ka
                            @rabbit83ka
                            When you play something on your echodot, nothing been displayed?
                              rabbit83ka @Guest
                              @Sean
                              If I comment out
                              //allwoeDevices: ["myechodot" ]
                              it shows the album cover/etx/progress etc. when I play something on my echo dot. With
                              the spotify logo appears when something is played on the echodot, but no cover/text/progress etc. is shown.
                              • I
                                Ivanov_d
                                • I
                                  Ivanov_d
                                  I have the following recipies:
                                  var recipe = {
                                    transcriptionHook: {
                                      HIDE_ALL_MODULES: {
                                        pattern: "standby mode",
                                        command: "HIDEMODULES"
                                      SHOW_ALL_MODULES: {
                                        pattern: "show modules",
                                        command: "SHOWMODULES"
                                      SCREEN_ON: {
                                        pattern: "turn on screen",
                                        command: "SCREENON"
                                      SCREEN_OFF: {
                                        pattern: "turn off screen",
                                        command: "SCREENOFF"
                                      REBOOT: {
                                        pattern: "reboot the mirror",
                                        command: "REBOOT"
                                      SHUTDOWN: {
                                        pattern: "extinction totale",
                                        command: "SHUTDOWN"
                                      STOP_PLAY: {
                                        pattern: "stop the video", // this is for youtube but it is preferable to have youtubeAutoplay: false, when running spotify so you don't get interaction with youtube player.
                                        command: "STOP_VID"
                                      SPOTIFY_PREVIOUS: {
                                        pattern: "previous song",
                                        command: "SPOTIFY_PREVIOUS"
                                      SPOTIFY_PAUSE: {
                                        pattern : "stop the music",
                                        command: "SPOTIFY_PAUSE"
                                      SPOTIFY_PLAY: {
                                        pattern : "music please",
                                        command: "SPOTIFY_PLAY"
                                        SPOTIFY_NEXT: {
                                        pattern: "next song",
                                        command: "SPOTIFY_NEXT"
                                      SPOTIFY_VOLUME: {
                                        pattern: "set music volume to ([0-9]{1,2}[0]?|100)",
                                        command: "SPOTIFY_VOLUME"
                                      SPOTIFY_SEARCH: {
                                        pattern: "play (.*) on Spotify",
                                        command: "SPOTIFY_SEARCH"
                                      SPOTIFY_SEARCH_PLAYLIST: {
                                        pattern: "playlist (.*) on Spotify",
                                        command: "SPOTIFY_SEARCH_PLAYLIST"
                                      	pattern: "(.*) my playlist",   // (.*)  is an action  eg: play my playlist / run my playlist etc...
                                    	SPOTIFY_TRANSFER: {
                                      	pattern: "play the music on (.*)", // (.*)  is the name of your device
                                      	command: "SPOTIFY_TRANSFER"
                                      VOLUME_UP: {
                                        pattern: "volume up",
                                        command: "CMD_VOLUME_UP"
                                      VOLUME_DOWN: {
                                        pattern: "volume down",
                                        command: "CMD_VOLUME_DOWN"
                                      SET_VOLUME: {
                                        pattern: "set master volume to ([0-9]{1,2}[0]?|100)",
                                        command: "CMD_VOLUME_SET"
                                    command: {
                                      STOP_VID: {
                                        moduleExec: {
                                          module: ["MMM-AssistantMk2"],
                                          exec: (module, params, key) => {
                                            module.assistant.subdom.youtube.innerHTML = "";
                                            module.assistant.subdom.youtube.style.display = "none";
                                            module.youtubePlaying = false;
                                      SPOTIFY_TRANSFER: {
                                        notificationExec: {
                                          notification: "SPOTIFY_TRANSFER",
                                            console.log("SPOTIFY_TRANSFER @",params)
                                            return params[1];
                                      SPOTIFY_PAUSE: {
                                        notificationExec: {
                                          notification: "SPOTIFY_PAUSE"
                                      SPOTIFY_PLAY: {
                                        notificationExec: {
                                        notificationExec:  {
                                              return {
                                                context_uri:"spotify:playlist:0ka8HWt4xXcnTK5OpOuN2k",   // Uri of a personnal playlist or album
                                    	SPOTIFY_NEXT: {
                                        notificationExec: {
                                      SPOTIFY_PREVIOUS: {
                                        notificationExec: {
                                          notification: "SPOTIFY_PREVIOUS"
                                      SPOTIFY_VOLUME: {
                                        notificationExec: {
                                          notification: "SPOTIFY_VOLUME",
                                            console.log("SPOTIFY_VOLUME @",params)
                                            return params[1];
                                    	SPOTIFY_SEARCH: {
                                        notificationExec: {
                                          notification: "SPOTIFY_SEARCH",
                                              console.log("SPOTIFY_SEARCH @",params)
                                              return {
                                                type: "artist,track,album,playlist",
                                                query: params[1],
                                                random:false,
                                        notificationExec: {
                                              console.log("SPOTIFY_SEARCH_PLAYLIST @",params)
                                              return {
                                                type: "playlist",
                                                query: params[1],
                                                random:true,
                                      CMD_VOLUME_UP: {
                                        notificationExec: {
                                          notification: "VOLUME_UP"
                                      CMD_VOLUME_DOWN: {
                                        notificationExec: {
                                          notification: "VOLUME_DOWN"
                                      CMD_VOLUME_SET: {
                                        notificationExec: {
                                          notification: "VOLUME_SET",
                                          payload: (params, key) => {
                                            console.log("@", params);
                                            return params[1];
                                  exports.recipe = recipe // Don't remove this line.
                                  However, the
                                      SPOTIFY_PLAY: {
                                  Doesn’t work. It recognizes the command, but nothing happens. Playback from the mirror (raspotify) doesn’t happen. If I switch the source from my desktop/phone spotify app to Raspotify, then everything is fine (e.g. I renamed the player from Raspotify to MagicMirror if that matters).
                                  There are no errors in the logs as far as I can see.
                                  Any thoughts?
                                    A Former User @Ivanov_d
                                    @Ivanov_d
                                    Only that command doesn’t work? Other’s OK?
                                    Raspotify should be already running when you use this module. (This module cannot boot up Raspotify itself)
                                    • I
                                      Ivanov_d
                                      @Sean yes, the other commands work. I can skip the song, increase/decrease the volume and etc. Also Raspotify is running, because I can start the playback on the mirror from my Desktop/Smartphone app.0_1563467613897_Untitled20190718193321.png
                                      • I
                                        Ivanov_d
                                        @Sean, I did some more testing and I can confirm that this is the only command that doesn’t work. Maybe I am not understanding it correctly.
                                        My expected results would be:
                                        1. Raspotify is running in the background (but no music is playing)
                                        2. When I say “music please” spotify will start a random song and play it on the MagicMirror
                                        The result however is:
                                        1. Raspotify is running in the background and no music is playing
                                        2. When I say “music please” I see no errors in the logs, however, no music is starting as well
                                        3. To workaround this I start the music from my smartphone or desktop app and switch the player to MagicMirror, after that I can control the player via AssistankMK2
                                          @Ivanov_d
                                          There could be 2(or 3)kinds of possibility about your issue;
                                          1. AssistantMk2 cannot catch your word “music please”
                                          2. AssistantMk2 could catch “music please” but cannot emit “SPOTIFY_PLAY” notification
                                          3. Spotify cannot receive (or understand) SPOTIFY_PLAY notification. (hmmm… I can’t agree about this)
                                          Well, I’ll test from last third issue. Wait for a while.
                                            @Ivanov_d
                                            I just tested 3rd case, and there is no problem to work. I think your music please phrase is not hooked, because music is reserved word for default Music feature of Assistant itself(for Youtube Music or Spotify on Google Home itself, but not yet supported by SDK for devices - only allowed for Google Home or some genuine devices). Some keywords or phrases are reserved for Google itself. Unless you override the keywords by Custom Action for Assistant (And even though, cannot guarantee it will work), your music keyword couldn’t work.
                                            Can you try other phrase? like “stay tune.” or any phrase you like.
                                            • 12
                                            • 13
                                            • 5 / 13
