    DailyDilbert
    20 Posts 8 Posters 12.4k Views 7 Watching
      Maximillium
      Hi! Is there anyone that could tell me how to shrink the size of the DailyDilbert comic?
      lavolp3L 1 Reply Last reply
      • lavolp3L
        lavolp3 Module Developer @Maximillium
        @maximillium I did it like this but had to search for a while as well.
        You can put this in your custom.css and use whatever value you prefer
        .MMM-DailyDilbert #dilbert-content {
          width: 900px;
        A tip if you’re interested:
        If you open the mirror in your browser (I’m using chrome mirror_ip:8080) and open the developer’s console with F12 you can see all the css involved (in the “styles” tab). Then you can right-click on the image and press “investigate” or whatever it’s called in english and you can see all the css affecting this picture. You can even toggle properties on/off live. Just discovered all the possibilites with this function working on this problem.
        How to troubleshoot modules
        MMM-soccer v2, MMM-AVStock
        • L
          Loengard
          Hi there - in the hope someone could point me in the right direction, any ideas on how to create a module for the daily Garfield comic?
          lavolp3L 2 Replies Last reply
          • lavolp3L
            lavolp3 Module Developer @Loengard
            @loengard What you would need basically is a scraping function.
            One of my (too many) projects currently is to create a module like MMM-WebScraper.
            However, I think it should be possible to take MMM-DailyXKCD or MMM-DailyDilbert as a start. There is a scraper included somehow, haven’t looked at the code yet.
            Then you could change the basic url to the Garfield comic.
            I’ll check it out as well.
            • lavolp3L
              @loengard Well it’s done. The changes were quite easy :-)
              Try it out, it is very rough and there are several things still called “Dilbert” :-).
              https://github.com/lavolp3/MMM-DailyDilbert
              I think it would make sense to eventually create a “ComicStrip” module and let the user choose between Dilbert, Garfield, xkcd and what else can be created. @kjb085 was already mentioning a website agnostic module.
              But I’d like to leave the decision to @andrecarlucci (or is it @kjb085?) and/or @Blastitt who have put much more work into it.
              Reply Quote 2
              • L
                Loengard
                I only saw your message now. Thank you so much!!
                  smackenzie5 @lavolp3
                  Thanks @lavolp3 - worked well.
                    surger13 Project Sponsor @lavolp3
                    @lavolp3
                    i need help. i can’t get it to work. the screen stays black when the module is active. during installation i get the following message:
                    pi@MagicMirrorPi:~/MagicMirror/modules/MMM-ComicStrips $ npm install
                    npm WARN saveError ENOENT: no such file or directory, open '/home/pi/MagicMirror/modules/package.json'
                    npm WARN enoent ENOENT: no such file or directory, open '/home/pi/MagicMirror/modules/package.json'
                    npm WARN modules No description
                    npm WARN modules No repository field.
                    npm WARN modules No README data
                    npm WARN modules No license field.
                    up to date in 0.568s
                    • bheplerB
                      bhepler Module Developer
                      It appears that the installation instructions on MMM-ComicStrips didn’t include everything from MMM-DailyDilbert. Try this instead:
                      npm install -p cheerio.
                        surger13 Project Sponsor @bhepler
                        @bhepler
                        Thanks bhelper, that’s it.
                        In my opinion it would be a nice option for the module if you could select multiple comics to be displayed at selectable intervals, not just one as in the current version. I find it hard to choose one ;)
                        • lavolp3L
                          lavolp3 Module Developer @surger13
                          @surger13 You know what? I have this nearly finished. Multiple comics to choose from, adjustable intervals etc etc.
                          It’s not easy however, since the comics have different sizes.
                          I’ll send a link for beta testing as soon as I’m finished.
                            @lavolp3
                            Glad to hear it and thank you for your efforts.
                            With the current MMM-ComicStrips module, “garfield” and “peanuts” remain black.
                            Also the parameter timeForDaily doesn’t seem to work for me. Only one comic is displayed the whole day.
                            • qu1queQ
                              qu1que Project Sponsor
                              Hi, I’ve just installed MMM-ComicStrips module, everything worked fine, but only one thing I can’t solve, is the width of the comic. I’ve tried to change the comicWidth value on config.js from 500 to 300 but no result.
                              Before that, I’d tried MMM-DailyDilbert module, and editing custom.css as @lavolp3 said on another post, but same result.
                              This is how it shows the comic Dilbert on my mirror:
                              Any idea on how to solve it?
                              • lavolp3L
                                lavolp3 Module Developer @qu1que
                                @qu1que
                                Hi, please do a git pull (maybe also an npm install since I now introduced a package.json) and try it again.
                                Had a small mistake in the image width description. Thanks for noticing!
                                I guess I should “publish” this module here so we can move discussion and bugs to another thread.
                                qu1queQ 1 Reply Last reply
                                • qu1queQ
                                  qu1que Project Sponsor @lavolp3
                                  @lavolp3
                                  Now it fits perfectly!!
                                  I’ve just have to make git pull inside the module folder. There’s no need to do npm install
                                  Another question, I see that your module is not in the 3rd Party Modules of MM project
                                  https://github.com/MichMich/MagicMirror/wiki/3rd-party-modules
                                  It would be a good idea to include it.
                                  Thanks for your work!!
