    How to use the 'node_helper', 'serialport'
    23 Posts 2 Posters 8.8k Views 2 Watching
      sdetweil @nhpunch
      @nhpunch there are two parts of a MagicMirror module
      1. node_helper, runs on server, can use require(…some other library…)
      2. module_name.js, runs in browser, manages data presented on screen, cannot use require(…)
      so, the two parts can talk to each other by sending socket messages, using the supplied function
      sendSocketNotification(some_id_string, some_data_packet)
      the receiver of the message gets called at the function socketNotificationReceived(some_id_string, some_data_packet)
      get my sample module that has both parts, and uses timer,
      https://github.com/sdetweil/SampleModule
      also see the developers doc here
      https://github.com/MichMich/MagicMirror/tree/master/modules
      my sample implements all the functions so you can see them…
      not all are needed… so u can comment out the ones u don’t need to use
      config for my sample, to add to config.js is
          module: "SampleModule",
          position: "center",
            message: "this is a test from config entry"
      • N Offline
        nhpunch @sdetweil
        I was really grateful and ran the sample code.
        But I do not know what to send as a module to do what I want.
        Can you help me with my module and node_helper?
          sdetweil @nhpunch
          @nhpunch sorry, i don’t understand
            @sdetweil you make up your own messages…
            so, you have a push button on the screen (done by module_name,js)… when push button,
            send button name and 1 to node helper… when it gets 1, it uses serial port to send to arduino.
            when u let up on button , you send 0…
            write out what you WANT the system to do… (design)
            then implement THAT design
            • N Offline
              nhpunch @sdetweil
              I’m doing what you said, but I do not know how to send it to the node_helper when the button is pressed.
              I’m so sorry.
                sdetweil @nhpunch
                @nhpunch this.sendSocketNotification(…,…)
                from the doc
                this.sendSocketNotification(notification, payload)
                notification String - The notification identifier.
                payload AnyType - Optional. A notification payload.
                If you want to send a notification to the node_helper, use the sendSocketNotification(notification, payload). Only the node_helper of this module will receive the socket notification.
                Example:
                this.sendSocketNotification('SET_CONFIG', this.config);
                you’ll see in the sample that this is used twice… once by the module_name.js to send the config over to the node_helper and once by the node_helper to send a new text string to the module_name.js to display
                its also used in your module, from the first post above
                  start: function () {
                    this.sendSocketNotification('CONFIG', this.config)
                • N Offline
                  nhpunch
                  I did my best, but I did not succeed.
                  I’m a real idiot.
                  Can you take a look at my code?
                    sdetweil @nhpunch
                    @nhpunch sure. Make a GitHub repo, and let me know
                    • N Offline
                      nhpunch
                      https://github.com/nhpunch/sohard
                      I created ‘is_Pushed’ and tried to work by repeating false, true when the button was pressed
                        sdetweil @nhpunch
                        @nhpunch said in How to use the 'node_helper', 'serialport':
                        Ok, the fundamental problem is what happens in getDom()…
                        until getDom() returns this modules contribution to the single web page… that content is NOT IN the DOM… It is just in memory in your module.
                        so the jquery $(button) will not work. ($ means document.) and the content is NOT IN the document… (yet)
                        SO, you could change to use the non jquery
                        button.addEventListener('click', ()=> {
                           	//$(button).on("click", function(){
                           		if(self.hidden){
                           		//	$(overlay).fadeIn(1000);
                           		//	$(button).fadeTo(1000, 0.3);
                           		//	$(text).html('OFF');
                                                       Log.log("button pushed 'on' ")
                           			self.hidden = false;
                           			self._isPushed = false;
                           		}else{
                           		//	$(overlay).fadeOut(1000);
                           		//	$(button).fadeTo(1000, 1);
                           		//	$(text).html('ON');
                                                       Log.log("button pushed 'off' ")
                           			self.hidden = true;
                           			self._isPushed = true;
                           	return wrapper;
                        but… all the data elements button, overlay and text will be long gone by the time the button is pushed.
                        so you will have to redesign finding them again (document.getElementByID()… or something, a different jquery selector.)
                        OR
                        you can push the jquery code off into a timeout handler (wait a second or 2)…
                        but you will still have to redesign how to find the button… as its data element on the stack of getDom() will be long gone.
                        think of getDom() as a person taking notes… they write it down on their notepad.
                        then LATER they edit a big document and add their text…
                        until they complete that task, you can search thru the big document all u want, the text will NOT be there…
                        when I used the sample above, the button responded…
                        u know you can open the developers window (npm start dev) and select the console window,
                        and messages from the module_name.js will show there
                        message from the node_helper will appear in the terminal window where u issued npm start dev & (note the & at the end to allow the prompt to come back)…
                        • N Offline
                          nhpunch @sdetweil
                          const NodeHelper = require('node_helper')
                          const Serialport = require("serialport");
                            socketNotificationReceived: function (notification, payload) {
                              if (notification === 'CONFIG') {
                                const self = this;
                                self.config = payload;
                              else if(notification ==='BUTTON_PRESSED')
                              var serialport = new Serialport('/dev/ttyACM0', {
                          		baudRate: 9600
                              var led = 0;
                                serialport.open(function () {
                                  console.log('connect...');
                                  serialport.on('data', function(data) { // 아두이노로부터 전달된 데이터
                                    console.log('data received: ' + data);
                                  if(this._isPushed==false)
                                    serialport.write("0");
                                  else if(this._isPushed==true)
                                    serialport.write("1");
                          Thank you very much…!!! Overlay is not important.
                          It was working as you told me.
                          Currently, node_helper sets the following, but serial.write does not work. May I ask you one last time?
                          I’m really desperate:folded_hands_light_skin_tone: :folded_hands_light_skin_tone: :folded_hands_light_skin_tone: :folded_hands_light_skin_tone:
                          I uploaded the Arduino code.
                          int led = 13;
                          void setup() {
                            Serial.begin(9600);
                            pinMode(led, OUTPUT);
                            Serial.println(“hello”);
                          void loop() {
                            static int incomingValue = 0; // nodeJS에서 보낸값
                            if ( Serial.available() > 0 ) { // 뭔가 입력값이 있다면
                              incomingValue = Serial.read();
                              Serial.println(incomingValue);
                            if ( incomingValue == 49 ) { // 값이 ‘1’ 이면
                            digitalWrite(13, HIGH); // LED를 켠다.
                            if ( incomingValue == 48 ) { // 값이 ‘0’ 이면
                            digitalWrite(13, LOW); // LED를 끈다.
                            deayl(2000);
                            where is _isPushed defined or set?
                            i know it is in module_name.js, but node_helper cannot see it…
                            you should send that as the payload on button_pressed message
                            • N Offline
                              nhpunch
                                    const self = this;
                                    this._isPushed = payload;
                              		baudRate: 9600
                              Is that right? I’m really sorry for you.
                                sdetweil @nhpunch
                                @nhpunch yes if you send it that way
                                this.sendSocketNotification(“BUTTON_PUSHED”,this._isPushed)
                                N 2 Replies Last reply Reply Quote 0
                                • N Offline
                                  nhpunch @sdetweil
                                  false, true works with two button in module
                                  It seems that the value can not be sent to the node_helper
                                  why?
                                  	buttonoff.addEventListener('click', ()=> {
                                  			Log.log("button pushed 'on'")
                                     			this._isPushed = false;
                                  			console.log(this._isPushed);
                                     			this._isPushed = true;
                                  this is module
                                            serialport.write(this._isPushed==true? '1' : '0');
                                  this is node_helper
                                  • N Offline
                                    nhpunch @sdetweil
                                          console.log(payload);
                                    ‘false’ is displayed in the terminal window
                                    ._isPushed is passed to node_helper, but I think that the changed value is not sent when the button is pressed.
                                    Please advise…:folded_hands_light_skin_tone: :folded_hands_light_skin_tone: :folded_hands_light_skin_tone:
                                    If this is solved, it’s really a success.:flexed_biceps_light_skin_tone:
                                      sdetweil @nhpunch
                                      • N Offline
                                        nhpunch
                                        ._isPushed was sent
                                        but there was an error… im really sad
                                          sdetweil @nhpunch
                                          @nhpunch that is in the node_helper, serial library
                                          looks like serialport.write(data: string|Buffer|Array,
                                          i don’t know anything about serial port api… looks like promise based, so would need callbacks or .then()
                                          • N Offline
                                            nhpunch @sdetweil
                                            omg… I’m so screwed up
                                            My ignorantness makes me cry…'ㅠ I don’t know why there was a mistake
                                            Thank you @sdetweil You’re awesome!
