    How to use the 'node_helper', 'serialport'
    23 Posts 2 Posters 9.1k Views 2 Watching
      sdetweil @nhpunch
      @nhpunch sorry, i don’t understand
        @sdetweil you make up your own messages…
        so, you have a push button on the screen (done by module_name,js)… when push button,
        send button name and 1 to node helper… when it gets 1, it uses serial port to send to arduino.
        when u let up on button , you send 0…
        write out what you WANT the system to do… (design)
        then implement THAT design
        N 1 Reply Last reply
        • N
          nhpunch @sdetweil
          I’m doing what you said, but I do not know how to send it to the node_helper when the button is pressed.
          I’m so sorry.
            sdetweil @nhpunch
            @nhpunch this.sendSocketNotification(…,…)
            from the doc
            this.sendSocketNotification(notification, payload)
            notification String - The notification identifier.
            payload AnyType - Optional. A notification payload.
            If you want to send a notification to the node_helper, use the sendSocketNotification(notification, payload). Only the node_helper of this module will receive the socket notification.
            Example:
            this.sendSocketNotification('SET_CONFIG', this.config);
            you’ll see in the sample that this is used twice… once by the module_name.js to send the config over to the node_helper and once by the node_helper to send a new text string to the module_name.js to display
            its also used in your module, from the first post above
              start: function () {
                this.sendSocketNotification('CONFIG', this.config)
            • N
              nhpunch
              I did my best, but I did not succeed.
              I’m a real idiot.
              Can you take a look at my code?
                sdetweil @nhpunch
                @nhpunch sure. Make a GitHub repo, and let me know
                • N
                  nhpunch
                  https://github.com/nhpunch/sohard
                  I created ‘is_Pushed’ and tried to work by repeating false, true when the button was pressed
                    sdetweil @nhpunch
                    @nhpunch said in How to use the 'node_helper', 'serialport':
                    Ok, the fundamental problem is what happens in getDom()…
                    until getDom() returns this modules contribution to the single web page… that content is NOT IN the DOM… It is just in memory in your module.
                    so the jquery $(button) will not work. ($ means document.) and the content is NOT IN the document… (yet)
                    SO, you could change to use the non jquery
                    button.addEventListener('click', ()=> {
                       	//$(button).on("click", function(){
                       		if(self.hidden){
                       		//	$(overlay).fadeIn(1000);
                       		//	$(button).fadeTo(1000, 0.3);
                       		//	$(text).html('OFF');
                                                   Log.log("button pushed 'on' ")
                       			self.hidden = false;
                       			self._isPushed = false;
                       		}else{
                       		//	$(overlay).fadeOut(1000);
                       		//	$(button).fadeTo(1000, 1);
                       		//	$(text).html('ON');
                                                   Log.log("button pushed 'off' ")
                       			self.hidden = true;
                       			self._isPushed = true;
                       	return wrapper;
                    but… all the data elements button, overlay and text will be long gone by the time the button is pushed.
                    so you will have to redesign finding them again (document.getElementByID()… or something, a different jquery selector.)
                    OR
                    you can push the jquery code off into a timeout handler (wait a second or 2)…
                    but you will still have to redesign how to find the button… as its data element on the stack of getDom() will be long gone.
                    think of getDom() as a person taking notes… they write it down on their notepad.
                    then LATER they edit a big document and add their text…
                    until they complete that task, you can search thru the big document all u want, the text will NOT be there…
                    when I used the sample above, the button responded…
                    u know you can open the developers window (npm start dev) and select the console window,
                    and messages from the module_name.js will show there
                    message from the node_helper will appear in the terminal window where u issued npm start dev & (note the & at the end to allow the prompt to come back)…
                    • N
                      nhpunch @sdetweil
                      const NodeHelper = require('node_helper')
                      const Serialport = require("serialport");
                        socketNotificationReceived: function (notification, payload) {
                          if (notification === 'CONFIG') {
                            const self = this;
                            self.config = payload;
                          else if(notification ==='BUTTON_PRESSED')
                          var serialport = new Serialport('/dev/ttyACM0', {
                      		baudRate: 9600
                          var led = 0;
                            serialport.open(function () {
                              console.log('connect...');
                              serialport.on('data', function(data) { // 아두이노로부터 전달된 데이터
                                console.log('data received: ' + data);
                              if(this._isPushed==false)
                                serialport.write("0");
                              else if(this._isPushed==true)
                                serialport.write("1");
                      Thank you very much…!!! Overlay is not important.
                      It was working as you told me.
                      Currently, node_helper sets the following, but serial.write does not work. May I ask you one last time?
                      I’m really desperate:folded_hands_light_skin_tone: :folded_hands_light_skin_tone: :folded_hands_light_skin_tone: :folded_hands_light_skin_tone:
                      I uploaded the Arduino code.
                      int led = 13;
                      void setup() {
                        Serial.begin(9600);
                        pinMode(led, OUTPUT);
                        Serial.println(“hello”);
                      void loop() {
                        static int incomingValue = 0; // nodeJS에서 보낸값
                        if ( Serial.available() > 0 ) { // 뭔가 입력값이 있다면
                          incomingValue = Serial.read();
                          Serial.println(incomingValue);
                        if ( incomingValue == 49 ) { // 값이 ‘1’ 이면
                        digitalWrite(13, HIGH); // LED를 켠다.
                        if ( incomingValue == 48 ) { // 값이 ‘0’ 이면
                        digitalWrite(13, LOW); // LED를 끈다.
                        deayl(2000);
                        where is _isPushed defined or set?
                        i know it is in module_name.js, but node_helper cannot see it…
                        you should send that as the payload on button_pressed message
                        • N
                          nhpunch
                                const self = this;
                                this._isPushed = payload;
                          		baudRate: 9600
                          Is that right? I’m really sorry for you.
                            sdetweil @nhpunch
                            @nhpunch yes if you send it that way
                            this.sendSocketNotification(“BUTTON_PUSHED”,this._isPushed)
                            N 2 Replies Last reply
                            • N
                              nhpunch @sdetweil
                              false, true works with two button in module
                              It seems that the value can not be sent to the node_helper
                              why?
                              	buttonoff.addEventListener('click', ()=> {
                              			Log.log("button pushed 'on'")
                                 			this._isPushed = false;
                              			console.log(this._isPushed);
                                 			this._isPushed = true;
                              this is module
                                        serialport.write(this._isPushed==true? '1' : '0');
                              this is node_helper
                              • N
                                nhpunch @sdetweil
                                      console.log(payload);
                                ‘false’ is displayed in the terminal window
                                ._isPushed is passed to node_helper, but I think that the changed value is not sent when the button is pressed.
                                Please advise…:folded_hands_light_skin_tone: :folded_hands_light_skin_tone: :folded_hands_light_skin_tone:
                                If this is solved, it’s really a success.:flexed_biceps_light_skin_tone:
                                  sdetweil @nhpunch
                                  • N
                                    nhpunch
                                    ._isPushed was sent
                                    but there was an error… im really sad
                                      sdetweil @nhpunch
                                      @nhpunch that is in the node_helper, serial library
                                      looks like serialport.write(data: string|Buffer|Array,
                                      i don’t know anything about serial port api… looks like promise based, so would need callbacks or .then()
                                      • N
                                        nhpunch @sdetweil
                                        omg… I’m so screwed up
                                        My ignorantness makes me cry…'ㅠ I don’t know why there was a mistake
                                        Thank you @sdetweil You’re awesome!
