    Phone Notifications
    97 Posts 31 Posters 169.5k Views 33 Watching
      ronny3050 Module Developer @gismo2006
      @gismo2006 Excellent work gismo! I made that mistake on my last push. I have updated the module. Thank you :D
      • G
        gismo2006
        Hi, thank you for your praise.
        But the really excelent work you are doing. @ronny3050 I think there was some more mistake too… If i paste the missing " the module will displayed correctly but it won´t regonize notifications. Some post before my post, moosedookie post a link to github. I now copy this files and the module work correctly.
        I´m now thinking about your email module :-)
        Greets gismo2006
        R 1 Reply Last reply
        Reply Quote 2
          @gismo2006 Thank you once more for finding the bug! I am not sure why moosedookie’s link works. I’ll compare the two and let you know.
          Please do try it :D
          • cowboysdudeC
            Stupid Iphone LOL
            • G
              gismo2006
              @cowboysdude Hi, sorry i didn’t understand your last post. I’m not using a Iphone… :-)
              • cowboysdudeC
                cowboysdude Module Developer @gismo2006
                @gismo2006 said in Phone Notifications:
                I know it’s not your fault. They are just not willing to make it easy to people who own them because they want to control the ecosystem…
                • L
                  Les
                  When should notifications appear? Because MM just says “No New Notifications”
                  I signed up for a pushbutton account. Went to setting generated my api key. installed pushbutton module. ran npm install. then added the following to my config.js
                                          module: 'phone_notification',
                                          position: 'bottom_right',
                                          header: 'Xperia Z3',
                                                  accessToken: 'o.XXXX$',
                                                  numberOfNotifications: 5,
                                                  displayNotificationIcon: true,
                                                  displayMessage: true,
                                                  displayCount: true,
                                                  alert: true,
                                                  fade: true,
                                                  maxCharacters: 50
                  Really all I want to do is display an incoming call (don’t care about historical, although I can see them in ppushbucket… An help would be appreciated.
                  W 1 Reply Last reply
                  • W
                    willharwell @Les
                    @Les
                    Having the same issue here.
                    From the command line where I started npm I see nop nop nop push, each time a notification comes in.
                    • G
                      gismo2006
                      I’ve got the same Problem some time ago. I didn’t know where the Problem is, but I can explain you @Les and @willharwell what I have done and it works fine at my mirror.
                      At first I have sing up at phushbellt Then I have installed like the Readme file says.
                      BUT then no notification will displayed. After spending hour for hour i opend the Link of moosedookie some post before and manually download the notification.js from this Link. Then I copy and overwrite it in the module Folder at my Raspberry.
                      And now everything works fine. For example If I push “test notification” in the Handy app, it will displayed directly.
                      I hope you understand…
                      greets gismo
                        @willharwell and @Les can you please try the latest push and let me know? I hope it will fix the issue.
                        • N
                          nobita @ronny3050
                          @ronny3050 said in Phone Notifications:
                          How to Update your module
                            ronny3050 Module Developer @nobita
                            @nobita call ‘git pull’ in the phone_notification directory.
                            • G
                              guybatt234
                              Has there been any progress in making notifications time out?
                                mschlesinger19
                                @guybatt234 I am not sure if the fix was ever put in for reversing the order but I figured out how to reverse the order of notifications. In phone_notification.js in the cleanPayload function instead of pushing to the back of the array just call a payload.unshift(newPayload) and that should treat it like a stack and not a queue
                                • ToastT
                                  Toast
                                  im on the latest revision but not receiving any notifcations
                                  • lucallmonL
                                    lucallmon
                                    Has anyone had an issue with filling up your notifications and then no new notifications come through at all?
                                    • rchaseR
                                      rchase
                                      Anyone ever get iphone work?
                                      lucallmonL 1 Reply Last reply
                                      • lucallmonL
                                        lucallmon @rchase
                                        @rchase android seems to work fine. As long as there’s a pushbullet app for iPhone it should work. I don’t even use the app on my phone.
                                          MaengMarco
                                          How can I reset?
                                          Notifications always keep.
                                          Also The second notification is output hundreds or thousands of times.
                                          What should I do??
                                          • O
                                            Oliver_Tooth
                                            I’ve just installed your module for use with an iPhone. As I understand it, push-functionality is somewhat limited with Apple, but what can I expect this module to receive? Facebook messenger? Email? Calls/texts? Currently it doesn’t look like it’s receiving anything, but that may be because i’ve configured it wrong!
                                            Cheers!
                                            • 3 / 5
