    Phone Notifications
    97 Posts 31 Posters 165.4k Views 33 Watching
      chengstark @ronny3050
      @ronny3050 the new .js seems not updating the notifications
        moosedookie @ronny3050
        @ronny3050 Oh wow, lol. I totally missed that.
          astronauti
          Somehow it does not work for me… Here my config file:
                      		module: 'phone_notification',
                      		position: 'bottom_right',
                      		header: 'Benachrichtigungen',
                          		accessToken: 'o.bYXXXXXXXXXXXXXXXXX',
                          		numberOfNotifications: 5,
                          		displayNotificationIcon: true,
                          		displayMessage: true,
                          		displayCount: true,
                          		alert: true,
                          		fade: true,
                          		maxCharacters: 50
          There is only a text message on my screen saying phone_notification module_7_phone_notification
            rajbadri
            same problem here
              rajbadri
                chengstark @rajbadri
                @rajbadri exactly! i have the same thing
                • G Offline
                  gismo2006
                  Hmm,
                  I have the same Problem… :-)
                  Does anybody know, where the mistake is?
                  Greets gismo2006
                  • G Offline
                    gismo2006
                    Yeah! :-)
                    If you look in my last post you can read that i have the same problem like the post before. Yesterday evening i remember myself at scool time and the computer lessons. I remember there was diffrent editors which will help to manage your code. But the important feature was the code check option. so i copy the code of phone_notification.js in a editor and press the check button. (It will be found in modules/phone_notification) And the editor display me some error. There was an missing In line 123 (console.log("display icon: "); ) I have edit this, then saving the file an everythink works fine.
                    I hope that will help you.
                    Sorry for my bad englich :-) I hope you can understand…
                    Greets gismo2006
                    R 1 Reply Last reply Reply Quote 3
                    • cowboysdudeC Offline
                      Great work Gismo!!! :)
                        ronny3050 Module Developer @gismo2006
                        @gismo2006 Excellent work gismo! I made that mistake on my last push. I have updated the module. Thank you :D
                        • G Offline
                          gismo2006
                          Hi, thank you for your praise.
                          But the really excelent work you are doing. @ronny3050 I think there was some more mistake too… If i paste the missing " the module will displayed correctly but it won´t regonize notifications. Some post before my post, moosedookie post a link to github. I now copy this files and the module work correctly.
                          I´m now thinking about your email module :-)
                          Greets gismo2006
                          R 1 Reply Last reply Reply Quote 2
                            @gismo2006 Thank you once more for finding the bug! I am not sure why moosedookie’s link works. I’ll compare the two and let you know.
                            Please do try it :D
                              Stupid Iphone LOL
                              • G Offline
                                gismo2006
                                @cowboysdude Hi, sorry i didn’t understand your last post. I’m not using a Iphone… :-)
                                  cowboysdude Module Developer @gismo2006
                                  @gismo2006 said in Phone Notifications:
                                  I know it’s not your fault. They are just not willing to make it easy to people who own them because they want to control the ecosystem…
                                  • L Offline
                                    Les
                                    When should notifications appear? Because MM just says “No New Notifications”
                                    I signed up for a pushbutton account. Went to setting generated my api key. installed pushbutton module. ran npm install. then added the following to my config.js
                                                            header: 'Xperia Z3',
        accessToken: 'o.XXXX$',
        displayCount: true,
        alert: true,
        fade: true,
        maxCharacters: 50
                                    Really all I want to do is display an incoming call (don’t care about historical, although I can see them in ppushbucket… An help would be appreciated.
                                    • W Offline
                                      willharwell @Les
                                      @Les
                                      Having the same issue here.
                                      From the command line where I started npm I see nop nop nop push, each time a notification comes in.
                                      • G Offline
                                        gismo2006
                                        I’ve got the same Problem some time ago. I didn’t know where the Problem is, but I can explain you @Les and @willharwell what I have done and it works fine at my mirror.
                                        At first I have sing up at phushbellt Then I have installed like the Readme file says.
                                        BUT then no notification will displayed. After spending hour for hour i opend the Link of moosedookie some post before and manually download the notification.js from this Link. Then I copy and overwrite it in the module Folder at my Raspberry.
                                        And now everything works fine. For example If I push “test notification” in the Handy app, it will displayed directly.
                                        I hope you understand…
                                        greets gismo
                                          @willharwell and @Les can you please try the latest push and let me know? I hope it will fix the issue.
                                          • N Offline
                                            nobita @ronny3050
                                            @ronny3050 said in Phone Notifications:
                                            How to Update your module
                                            • 3 / 5
