    Failed at the magicmirror@2.7.1 start script.
    npm issuesmagic mirror2.7.1
    21 Posts 3 Posters 10.5k Views 3 Watching
    • V Offline
      vdotjay
      Yes I did an npm install after git clone
      node version - v10.16.
      npm version - 6.9.0
        sdetweil @vdotjay
        @vdotjay does this file contain any additional info
        /home/phablet/.npm/_logs/2019-06-25T21_41_02_288Z-debug.log
          sdetweil @vdotjay
          @vdotjay also, did u install any other modules prior to starting the mirror app?
          • V Offline
            vdotjay @sdetweil
            Hi, this is from the log
            1 verbose cli [ ‘/usr/local/bin/node’, ‘/usr/local/bin/npm’, ‘start’ ]
            2 info using npm@6.9.0
            3 info using node@v10.16.0
            4 verbose run-script [ ‘prestart’, ‘start’, ‘poststart’ ]
            5 info lifecycle magicmirror@2.7.1~prestart: magicmirror@2.7.1
            6 info lifecycle magicmirror@2.7.1~start: magicmirror@2.7.1
            7 verbose lifecycle magicmirror@2.7.1~start: unsafe-perm in lifecycle true
            8 verbose lifecycle magicmirror@2.7.1~start: PATH: /usr/local/lib/node_modules/npm/node_modules/npm-lifecycle/node-gyp-bin:/home/phablet/MagicMirror/node_modules/.bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/snap/bin
            9 verbose lifecycle magicmirror@2.7.1~start: CWD: /home/phablet/MagicMirror
            10 silly lifecycle magicmirror@2.7.1~start: Args: [ ‘-c’, ‘sh run-start.sh’ ]
            11 silly lifecycle magicmirror@2.7.1~start: Returned: code: 1 signal: null
            12 info lifecycle magicmirror@2.7.1~start: Failed to exec start script
            13 verbose stack Error: magicmirror@2.7.1 start: sh run-start.sh
            13 verbose stack Exit status 1
            13 verbose stack at EventEmitter. (/usr/local/lib/node_modules/npm/node_modules/npm-lifecycle/index.js:301:16)
            13 verbose stack at EventEmitter.emit (events.js:198:13)
            13 verbose stack at ChildProcess. (/usr/local/lib/node_modules/npm/node_modules/npm-lifecycle/lib/spawn.js:55:14)
            13 verbose stack at ChildProcess.emit (events.js:198:13)
            13 verbose stack at maybeClose (internal/child_process.js:982:16)
            13 verbose stack at Process.ChildProcess._handle.onexit (internal/child_process.js:259:5)
            14 verbose pkgid magicmirror@2.7.1
            15 verbose cwd /home/phablet/MagicMirror
            16 verbose Linux 3.4.0-6-flo
            17 verbose argv “/usr/local/bin/node” “/usr/local/bin/npm” “start”
            18 verbose node v10.16.0
            19 verbose npm v6.9.0
            20 error code ELIFECYCLE
            21 error errno 1
            22 error magicmirror@2.7.1 start: sh run-start.sh
            22 error Exit status 1
            23 error Failed at the magicmirror@2.7.1 start script.
            23 error This is probably not a problem with npm. There is likely additional logging output above.
            24 verbose exit [ 1, true ]
              ok, looking thru search results i find this process
              https://stackoverflow.com/questions/42308879/npm-err-code-elifecycle
              114 (upvotes)
              (from the MagicMirror folder)
              Step 1: $ npm cache clean --force
              Step 2: Delete node_modules by $ rm -rf node_modules folder or delete it manually by going into the directory and right-click > delete.
              Step 2a: Delete package-lock.json file too.
              Step 3: npm install
              To start again, $ npm start
              • V Offline
                vdotjay
                @sdetweil Okay thank you i’ll try it now
                • V Offline
                  vdotjay
                  Hi, I get the same error this is the log file
                  21 error errno 1
                    sdetweil @vdotjay
                    @vdotjay ok, does sh exist? and electron?
                    ls ~/MagicMirror/node_modules/electron/dist
                    • nischiN Offline
                      nischi
                      sh is a command which is runing on unix systems (such as macos, linux) do you try that on a windows machine?
                        sdetweil @nischi
                        @nischi he is running ubuntu linux
                        nischiN 1 Reply Last reply Reply Quote 0
                        • nischiN Offline
                          nischi @sdetweil
                          @sdetweil oh i only read the error, my fault, sorry.
                          • V Offline
                            vdotjay @sdetweil
                            @sdetweil Hi.
                            Electron is there but Sh isn’t
                              sdetweil @vdotjay
                              @vdotjay said in Failed at the magicmirror@2.7.1 start script.:
                              but Sh isn’t
                              lowercase sh, right?
                              • V Offline
                                vdotjay
                                Hi, sorry yes lowercase sh
                                  also, looks like a known restriction
                                  https://askubuntu.com/questions/646655/ubuntu-touch-executable-files-wont-launch-in-home-directory
                                    u can also try changing package.json
                                      "scripts": {
                                        "start": "sh run-start.sh",   //< --- to "start": "bash run-start.sh",
                                    if the security thing is right
                                    • V Offline
                                      vdotjay
                                      Okay thank you I will try it
                                      • V Offline
                                        vdotjay
                                        Hi, I have tried what u said and what the link you provided said and i still cannot get it to work
