    Failed at the magicmirror@2.7.1 start script.
    npm issuesmagic mirror2.7.1
    21 Posts 3 Posters 10.0k Views 3 Watching
      ok, looking thru search results i find this process
      https://stackoverflow.com/questions/42308879/npm-err-code-elifecycle
      114 (upvotes)
      (from the MagicMirror folder)
      Step 1: $ npm cache clean --force
      Step 2: Delete node_modules by $ rm -rf node_modules folder or delete it manually by going into the directory and right-click > delete.
      Step 2a: Delete package-lock.json file too.
      Step 3: npm install
      To start again, $ npm start
      • V Offline
        vdotjay
        @sdetweil Okay thank you i’ll try it now
        • V Offline
          vdotjay
          Hi, I get the same error this is the log file
          1 verbose cli [ ‘/usr/local/bin/node’, ‘/usr/local/bin/npm’, ‘start’ ]
          2 info using npm@6.9.0
          3 info using node@v10.16.0
          4 verbose run-script [ ‘prestart’, ‘start’, ‘poststart’ ]
          5 info lifecycle magicmirror@2.7.1~prestart: magicmirror@2.7.1
          6 info lifecycle magicmirror@2.7.1~start: magicmirror@2.7.1
          7 verbose lifecycle magicmirror@2.7.1~start: unsafe-perm in lifecycle true
          8 verbose lifecycle magicmirror@2.7.1~start: PATH: /usr/local/lib/node_modules/npm/node_modules/npm-lifecycle/node-gyp-bin:/home/phablet/MagicMirror/node_modules/.bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/snap/bin
          9 verbose lifecycle magicmirror@2.7.1~start: CWD: /home/phablet/MagicMirror
          10 silly lifecycle magicmirror@2.7.1~start: Args: [ ‘-c’, ‘sh run-start.sh’ ]
          11 silly lifecycle magicmirror@2.7.1~start: Returned: code: 1 signal: null
          12 info lifecycle magicmirror@2.7.1~start: Failed to exec start script
          13 verbose stack Error: magicmirror@2.7.1 start: sh run-start.sh
          13 verbose stack Exit status 1
          13 verbose stack at EventEmitter. (/usr/local/lib/node_modules/npm/node_modules/npm-lifecycle/index.js:301:16)
          13 verbose stack at EventEmitter.emit (events.js:198:13)
          13 verbose stack at ChildProcess. (/usr/local/lib/node_modules/npm/node_modules/npm-lifecycle/lib/spawn.js:55:14)
          13 verbose stack at ChildProcess.emit (events.js:198:13)
          13 verbose stack at maybeClose (internal/child_process.js:982:16)
          13 verbose stack at Process.ChildProcess._handle.onexit (internal/child_process.js:259:5)
          14 verbose pkgid magicmirror@2.7.1
          15 verbose cwd /home/phablet/MagicMirror
          16 verbose Linux 3.4.0-6-flo
          17 verbose argv “/usr/local/bin/node” “/usr/local/bin/npm” “start”
          18 verbose node v10.16.0
          19 verbose npm v6.9.0
          20 error code ELIFECYCLE
          21 error errno 1
          22 error magicmirror@2.7.1 start: sh run-start.sh
          22 error Exit status 1
          23 error Failed at the magicmirror@2.7.1 start script.
          23 error This is probably not a problem with npm. There is likely additional logging output above.
          24 verbose exit [ 1, true ]
            sdetweil @vdotjay
            @vdotjay ok, does sh exist? and electron?
            ls ~/MagicMirror/node_modules/electron/dist
            • nischiN Offline
              nischi
              sh is a command which is runing on unix systems (such as macos, linux) do you try that on a windows machine?
                sdetweil @nischi
                @nischi he is running ubuntu linux
                nischiN 1 Reply Last reply Reply Quote 0
                • nischiN Offline
                  nischi @sdetweil
                  @sdetweil oh i only read the error, my fault, sorry.
                  • V Offline
                    vdotjay @sdetweil
                    @sdetweil Hi.
                    Electron is there but Sh isn’t
                      sdetweil @vdotjay
                      @vdotjay said in Failed at the magicmirror@2.7.1 start script.:
                      but Sh isn’t
                      lowercase sh, right?
                      • V Offline
                        vdotjay
                        Hi, sorry yes lowercase sh
                          also, looks like a known restriction
                          https://askubuntu.com/questions/646655/ubuntu-touch-executable-files-wont-launch-in-home-directory
                            u can also try changing package.json
                              "scripts": {
                                "start": "sh run-start.sh",   //< --- to "start": "bash run-start.sh",
                            if the security thing is right
                            • V Offline
                              vdotjay
                              Okay thank you I will try it
                              • V Offline
                                vdotjay
                                Hi, I have tried what u said and what the link you provided said and i still cannot get it to work
