    Failed at the magicmirror@2.7.1 start script.
    npm issuesmagic mirror2.7.1
    21 Posts 3 Posters 10.5k Views 3 Watching
    • V Offline
      vdotjay
      Hi, I am running Ubuntu Touch on a Nexus 7 (2013) I am stuck here and have tried everything and I have no idea what the problem is?
      magicmirror@2.7.1 start /home/phablet/MagicMirror
      sh run-start.sh
      npm ERR! code ELIFECYCLE
      npm ERR! errno 1
      npm ERR! magicmirror@2.7.1 start: ‘sh run-start.sh’
      npm ERR! Exit status 1
      npm ERR!
      npm ERR! Failed at the magicmirror@2.7.1 start script.
      npm ERR! /home/phablet/.npm/_logs/2019-06-25T21_41_02_288Z-debug.log
      • V Offline
        vdotjay
          Can u tell us the versions of node and npm?
          node -v
          npm -v
          You did an npm install after the git clone or file unzip, right?
          • V Offline
            vdotjay
            Yes I did an npm install after git clone
            node version - v10.16.
            npm version - 6.9.0
              sdetweil @vdotjay
              @vdotjay does this file contain any additional info
                sdetweil @vdotjay
                @vdotjay also, did u install any other modules prior to starting the mirror app?
                • V Offline
                  vdotjay @sdetweil
                  Hi, this is from the log
                  1 verbose cli [ ‘/usr/local/bin/node’, ‘/usr/local/bin/npm’, ‘start’ ]
                  2 info using npm@6.9.0
                  3 info using node@v10.16.0
                  4 verbose run-script [ ‘prestart’, ‘start’, ‘poststart’ ]
                  5 info lifecycle magicmirror@2.7.1~prestart: magicmirror@2.7.1
                  6 info lifecycle magicmirror@2.7.1~start: magicmirror@2.7.1
                  7 verbose lifecycle magicmirror@2.7.1~start: unsafe-perm in lifecycle true
                  8 verbose lifecycle magicmirror@2.7.1~start: PATH: /usr/local/lib/node_modules/npm/node_modules/npm-lifecycle/node-gyp-bin:/home/phablet/MagicMirror/node_modules/.bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/snap/bin
                  9 verbose lifecycle magicmirror@2.7.1~start: CWD: /home/phablet/MagicMirror
                  10 silly lifecycle magicmirror@2.7.1~start: Args: [ ‘-c’, ‘sh run-start.sh’ ]
                  11 silly lifecycle magicmirror@2.7.1~start: Returned: code: 1 signal: null
                  12 info lifecycle magicmirror@2.7.1~start: Failed to exec start script
                  13 verbose stack Error: magicmirror@2.7.1 start: sh run-start.sh
                  13 verbose stack Exit status 1
                  13 verbose stack at EventEmitter. (/usr/local/lib/node_modules/npm/node_modules/npm-lifecycle/index.js:301:16)
                  13 verbose stack at EventEmitter.emit (events.js:198:13)
                  13 verbose stack at ChildProcess. (/usr/local/lib/node_modules/npm/node_modules/npm-lifecycle/lib/spawn.js:55:14)
                  13 verbose stack at ChildProcess.emit (events.js:198:13)
                  13 verbose stack at maybeClose (internal/child_process.js:982:16)
                  13 verbose stack at Process.ChildProcess._handle.onexit (internal/child_process.js:259:5)
                  14 verbose pkgid magicmirror@2.7.1
                  15 verbose cwd /home/phablet/MagicMirror
                  16 verbose Linux 3.4.0-6-flo
                  17 verbose argv “/usr/local/bin/node” “/usr/local/bin/npm” “start”
                  18 verbose node v10.16.0
                  19 verbose npm v6.9.0
                  20 error code ELIFECYCLE
                  21 error errno 1
                  22 error magicmirror@2.7.1 start: sh run-start.sh
                  22 error Exit status 1
                  23 error Failed at the magicmirror@2.7.1 start script.
                  23 error This is probably not a problem with npm. There is likely additional logging output above.
                  24 verbose exit [ 1, true ]
                    ok, looking thru search results i find this process
                    https://stackoverflow.com/questions/42308879/npm-err-code-elifecycle
                    114 (upvotes)
                    (from the MagicMirror folder)
                    Step 1: $ npm cache clean --force
                    Step 2: Delete node_modules by $ rm -rf node_modules folder or delete it manually by going into the directory and right-click > delete.
                    Step 2a: Delete package-lock.json file too.
                    Step 3: npm install
                    To start again, $ npm start
                    • V Offline
                      vdotjay
                      @sdetweil Okay thank you i’ll try it now
                      • V Offline
                        vdotjay
                        Hi, I get the same error this is the log file
                        21 error errno 1
                          sdetweil @vdotjay
                          @vdotjay ok, does sh exist? and electron?
                          ls ~/MagicMirror/node_modules/electron/dist
                          • nischiN Offline
                            nischi
                            sh is a command which is runing on unix systems (such as macos, linux) do you try that on a windows machine?
                              sdetweil @nischi
                              @nischi he is running ubuntu linux
                              nischiN 1 Reply Last reply Reply Quote 0
                              • nischiN Offline
                                nischi @sdetweil
                                @sdetweil oh i only read the error, my fault, sorry.
                                • V Offline
                                  vdotjay @sdetweil
                                  @sdetweil Hi.
                                  Electron is there but Sh isn’t
                                    sdetweil @vdotjay
                                    @vdotjay said in Failed at the magicmirror@2.7.1 start script.:
                                    but Sh isn’t
                                    lowercase sh, right?
                                    • V Offline
                                      vdotjay
                                      Hi, sorry yes lowercase sh
                                        also, looks like a known restriction
                                        https://askubuntu.com/questions/646655/ubuntu-touch-executable-files-wont-launch-in-home-directory
                                          u can also try changing package.json
                                            "scripts": {
                                              "start": "sh run-start.sh",   //< --- to "start": "bash run-start.sh",
                                          if the security thing is right
                                          • V Offline
                                            vdotjay
                                            Okay thank you I will try it
