    Failed at the magicmirror@2.7.1 start script.
    npm issuesmagic mirror2.7.1
    21 Posts 3 Posters 9.9k Views 3 Watching
    • V Offline
      vdotjay
      Hi, I get the same error this is the log file
      1 verbose cli [ ‘/usr/local/bin/node’, ‘/usr/local/bin/npm’, ‘start’ ]
      2 info using npm@6.9.0
      3 info using node@v10.16.0
      4 verbose run-script [ ‘prestart’, ‘start’, ‘poststart’ ]
      5 info lifecycle magicmirror@2.7.1~prestart: magicmirror@2.7.1
      6 info lifecycle magicmirror@2.7.1~start: magicmirror@2.7.1
      7 verbose lifecycle magicmirror@2.7.1~start: unsafe-perm in lifecycle true
      8 verbose lifecycle magicmirror@2.7.1~start: PATH: /usr/local/lib/node_modules/npm/node_modules/npm-lifecycle/node-gyp-bin:/home/phablet/MagicMirror/node_modules/.bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/snap/bin
      9 verbose lifecycle magicmirror@2.7.1~start: CWD: /home/phablet/MagicMirror
      10 silly lifecycle magicmirror@2.7.1~start: Args: [ ‘-c’, ‘sh run-start.sh’ ]
      11 silly lifecycle magicmirror@2.7.1~start: Returned: code: 1 signal: null
      12 info lifecycle magicmirror@2.7.1~start: Failed to exec start script
      13 verbose stack Error: magicmirror@2.7.1 start: sh run-start.sh
      13 verbose stack Exit status 1
      13 verbose stack at EventEmitter. (/usr/local/lib/node_modules/npm/node_modules/npm-lifecycle/index.js:301:16)
      13 verbose stack at EventEmitter.emit (events.js:198:13)
      13 verbose stack at ChildProcess. (/usr/local/lib/node_modules/npm/node_modules/npm-lifecycle/lib/spawn.js:55:14)
      13 verbose stack at ChildProcess.emit (events.js:198:13)
      13 verbose stack at maybeClose (internal/child_process.js:982:16)
      13 verbose stack at Process.ChildProcess._handle.onexit (internal/child_process.js:259:5)
      14 verbose pkgid magicmirror@2.7.1
      15 verbose cwd /home/phablet/MagicMirror
      16 verbose Linux 3.4.0-6-flo
      17 verbose argv “/usr/local/bin/node” “/usr/local/bin/npm” “start”
      18 verbose node v10.16.0
      19 verbose npm v6.9.0
      20 error code ELIFECYCLE
      21 error errno 1
      22 error magicmirror@2.7.1 start: sh run-start.sh
      22 error Exit status 1
      23 error Failed at the magicmirror@2.7.1 start script.
      23 error This is probably not a problem with npm. There is likely additional logging output above.
      24 verbose exit [ 1, true ]
        sdetweil @vdotjay
        @vdotjay ok, does sh exist? and electron?
        ls ~/MagicMirror/node_modules/electron/dist
        • nischiN Offline
          nischi
          sh is a command which is runing on unix systems (such as macos, linux) do you try that on a windows machine?
            sdetweil @nischi
            @nischi he is running ubuntu linux
            nischiN 1 Reply Last reply Reply Quote 0
            • nischiN Offline
              nischi @sdetweil
              @sdetweil oh i only read the error, my fault, sorry.
              • V Offline
                vdotjay @sdetweil
                @sdetweil Hi.
                Electron is there but Sh isn’t
                  sdetweil @vdotjay
                  @vdotjay said in Failed at the magicmirror@2.7.1 start script.:
                  but Sh isn’t
                  lowercase sh, right?
                  • V Offline
                    vdotjay
                    Hi, sorry yes lowercase sh
                      also, looks like a known restriction
                      https://askubuntu.com/questions/646655/ubuntu-touch-executable-files-wont-launch-in-home-directory
                        u can also try changing package.json
                          "scripts": {
                            "start": "sh run-start.sh",   //< --- to "start": "bash run-start.sh",
                        if the security thing is right
                        • V Offline
                          vdotjay
                          Okay thank you I will try it
                          • V Offline
                            vdotjay
                            Hi, I have tried what u said and what the link you provided said and i still cannot get it to work
