    Failed at the magicmirror@2.7.1 start script.
    npm issuesmagic mirror2.7.1
    21 Posts 3 Posters 11.0k Views 3 Watching
    • V
      vdotjay
      @sdetweil Okay thank you i’ll try it now
      • V
        vdotjay
        Hi, I get the same error this is the log file
        1 verbose cli [ ‘/usr/local/bin/node’, ‘/usr/local/bin/npm’, ‘start’ ]
        2 info using npm@6.9.0
        3 info using node@v10.16.0
        4 verbose run-script [ ‘prestart’, ‘start’, ‘poststart’ ]
        5 info lifecycle magicmirror@2.7.1~prestart: magicmirror@2.7.1
        6 info lifecycle magicmirror@2.7.1~start: magicmirror@2.7.1
        7 verbose lifecycle magicmirror@2.7.1~start: unsafe-perm in lifecycle true
        8 verbose lifecycle magicmirror@2.7.1~start: PATH: /usr/local/lib/node_modules/npm/node_modules/npm-lifecycle/node-gyp-bin:/home/phablet/MagicMirror/node_modules/.bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/snap/bin
        9 verbose lifecycle magicmirror@2.7.1~start: CWD: /home/phablet/MagicMirror
        10 silly lifecycle magicmirror@2.7.1~start: Args: [ ‘-c’, ‘sh run-start.sh’ ]
        11 silly lifecycle magicmirror@2.7.1~start: Returned: code: 1 signal: null
        12 info lifecycle magicmirror@2.7.1~start: Failed to exec start script
        13 verbose stack Error: magicmirror@2.7.1 start: sh run-start.sh
        13 verbose stack Exit status 1
        13 verbose stack at EventEmitter. (/usr/local/lib/node_modules/npm/node_modules/npm-lifecycle/index.js:301:16)
        13 verbose stack at EventEmitter.emit (events.js:198:13)
        13 verbose stack at ChildProcess. (/usr/local/lib/node_modules/npm/node_modules/npm-lifecycle/lib/spawn.js:55:14)
        13 verbose stack at ChildProcess.emit (events.js:198:13)
        13 verbose stack at maybeClose (internal/child_process.js:982:16)
        13 verbose stack at Process.ChildProcess._handle.onexit (internal/child_process.js:259:5)
        14 verbose pkgid magicmirror@2.7.1
        15 verbose cwd /home/phablet/MagicMirror
        16 verbose Linux 3.4.0-6-flo
        17 verbose argv “/usr/local/bin/node” “/usr/local/bin/npm” “start”
        18 verbose node v10.16.0
        19 verbose npm v6.9.0
        20 error code ELIFECYCLE
        21 error errno 1
        22 error magicmirror@2.7.1 start: sh run-start.sh
        22 error Exit status 1
        23 error Failed at the magicmirror@2.7.1 start script.
        23 error This is probably not a problem with npm. There is likely additional logging output above.
        24 verbose exit [ 1, true ]
          sdetweil @vdotjay
          @vdotjay ok, does sh exist? and electron?
          ls ~/MagicMirror/node_modules/electron/dist
          V 1 Reply Last reply
          • nischiN
            nischi
            sh is a command which is runing on unix systems (such as macos, linux) do you try that on a windows machine?
              sdetweil @nischi
              @nischi he is running ubuntu linux
              nischiN 1 Reply Last reply
              • nischiN
                nischi @sdetweil
                @sdetweil oh i only read the error, my fault, sorry.
                • V
                  vdotjay @sdetweil
                  @sdetweil Hi.
                  Electron is there but Sh isn’t
                    sdetweil @vdotjay
                    @vdotjay said in Failed at the magicmirror@2.7.1 start script.:
                    but Sh isn’t
                    lowercase sh, right?
                    • V
                      vdotjay
                      Hi, sorry yes lowercase sh
                        also, looks like a known restriction
                        https://askubuntu.com/questions/646655/ubuntu-touch-executable-files-wont-launch-in-home-directory
                          u can also try changing package.json
                            "scripts": {
                              "start": "sh run-start.sh",   //< --- to "start": "bash run-start.sh",
                          if the security thing is right
                          • V
                            vdotjay
                            Okay thank you I will try it
                            • V
                              vdotjay
                              Hi, I have tried what u said and what the link you provided said and i still cannot get it to work
