    602 Posts 67 Posters 2.3m Views 68 Watching
      bill22
      @evroom
      /usr/bin/omxplayer --info --avdict rtsp_transport:tcp --live --video_queue 4 --fps 30 --win '351 968 703 1210' rtsp://192.168.178.1:554/?avm=1&freq=394&bw=8&msys=dvbc&mtype=256qam&sr=6900&specinv=0&pids=0,16,17,18,20,266,593,594,595,598,1801,1802,1803
      output:
      pi@raspberrypi:~ $ /usr/bin/omxplayer --info --avdict rtsp_transport:tcp --live --video_queue 4 --fps 30 --win '351 968 703 1210' rtsp://192.168.178.1:554/?avm=1&freq=394&bw=8&msys=dvbc&mtype=256qam&sr=6900&specinv=0&pids=0,16,17,18,20,266,593,594,595,598,1801,1802,1803
      [1] 989
      [2] 990
      [3] 991
      [4] 992
      [5] 993
      [6] 994
      [7] 995
      [2]   Fertig                  freq=394
      [3]   Fertig                  bw=8
      pi@raspberrypi:~ $
      requested log for:
      /usr/bin/omxplayer --genlog --hw --avdict rtsp_transport:tcp --live --video_queue 4 --fps 30 --win '351 968 703 1210' rtsp://192.168.178.1:554/?avm=1&freq=394&bw=8&msys=dvbc&mtype=256qam&sr=6900&specinv=0&pids=0,16,17,18,20,266,593,594,595,598,1801,1802,1803
      Log:
      21:51:55 T:1443630962 DEBUG: DllBcm: Using omx system library
      21:51:55 T:1443632668 DEBUG: DllOMX: Using omx system library
      21:51:55 T:1443633892 DEBUG: DllAvFormat: Using libavformat system library
      21:51:55 T:1443636500 DEBUG: DBus connection succeeded
      Thank you and have a good evening!
      • evroomE
        evroom @bill22
        @bill22
        2 more commands.
        Just to be sure of a few things.
        The --hw option did change the log output and the D-bus errors are gone.
        $ /usr/bin/omxplayer --version
        I get:
        omxplayer - Commandline multimedia player for the Raspberry Pi
                Build date: Fri, 07 Jun 2019 19:49:22 +0000
                Version   : f06235c [master]
                Repository: https://github.com/popcornmix/omxplayer.git
        And:
        /usr/bin/omxplayer --info --hw --avdict rtsp_transport:tcp --live --video_queue 4 --fps 30 --win '6351 968 703 1210' rtsp://184.72.239.149/vod/mp4:BigBuckBunny_115k.mov
        I get:
        Input #0, rtsp, from 'rtsp://184.72.239.149/vod/mp4:BigBuckBunny_115k.mov':
          Metadata:
            title           : BigBuckBunny_115k.mov
          Duration: 00:09:56.48, start: 0.000000, bitrate: N/A
            Stream #0:0: Audio: aac (LC), 12000 Hz, stereo, fltp
            Stream #0:1: Video: h264 (Constrained Baseline), yuv420p(progressive), 240x160, 24 fps, 24 tbr, 90k tbn, 48 tbc
        have a nice day ;)
        MagicMirror version: 2.37.0
          bill22
          @evroom
          Hi and good evening!
          Looks i get the same as you:
          I get:
          I get:
            Metadata:
          have a nice day ;)
          • evroomE
            evroom @bill22
            @bill22
            Looks like you are doomed to watch Buck Bunny for the rest of your Magic Mirror life :-)
            You did not get an error with — hw in your previous mail.
            It did return with the prompt, right ?
            You did not have to stop it using control C, I mean to say?
            Normally omxplayer exits with: have a nice day ; )
            Can you try
            /usr/bin/omxplayer --genlog --hw --win '351 968 703 1210' rtsp://192.168.178.1:554/?avm=1&freq=394&bw=8&msys=dvbc&mtype=256qam&sr=6900&specinv=0&pids=0,16,17,18,20,266,593,594,595,598,1801,1802,1803
            And check the log file.
              bill22
              @evroom
              Hopefully not…! we may need to find another one if we cannot fix it… :-)
              No i didn’t stop it using control C.
              returns:
              [1] 1897
              [2] 1898
              [3] 1899
              [4] 1900
              [5] 1901
              [6] 1902
              [7] 1903
              [2]   Fertig                  freq=394
              [4]   Fertig                  msys=dvbc
              Log shows:
              17:08:24 T:2113103317 DEBUG: DllBcm: Using omx system library
              17:08:24 T:2113104714 DEBUG: DllOMX: Using omx system library
              17:08:24 T:2113105528 DEBUG: DllAvFormat: Using libavformat system library
              17:08:24 T:2113107746 DEBUG: DBus connection succeeded
              • evroomE
                evroom @bill22
                @bill22
                Okay, I think it is stumbling over the ampersands in your RTSP URL.
                Try it with the RTSP part single quoted, like:
                $ /usr/bin/omxplayer --genlog --hw --win '351 968 703 1210' 'rtsp://192.168.178.1:554/?avm=1&freq=394&bw=8&msys=dvbc&mtype=256qam&sr=6900&specinv=0&pids=0,16,17,18,20,266,593,594,595,598,1801,1802,1803'
                Quotes work in general. Tested it on friend Buck Bunny.
                  bill22
                  @evroom
                  Allright! :thumbs_up:
                  i have a picture overlay with the omxplayer showing the live stream TV signal!
                  Unfortunately it runs for a second and stops, continuously . > (buffer, cache,…?)
                  Audio is not there correctly. It sounds like white noise for a second and stops continuously.
                    bill22
                    @evroom
                    FYI:
                    shows:
                    Video codec omx-mpeg2 width 720 height 576 profile 4 fps 25.000000
                    Audio codec mp2 channels 2 samplerate 48000 bitspersample 16
                    Subtitle count: 1, state: off, index: 1, delay: 0
                    V:PortSettingsChanged: 720x576@25.00 interlace:3 deinterlace:1 anaglyph:0 par:1.42 display:0 layer:0 alpha:255 aspectMode:0
                    • evroomE
                      evroom @bill22
                      @bill22
                      Getting somewhere.
                      Now you need to slowly add additional parameters.
                      Like --live --video_queue 4
                        bill22
                        i might be wrong. I added it here and received the error message “…file not found”:
                        /usr/bin/omxplayer --genlog --hw --win --live --video_queue 4 '351 968 703 1210' 'rtsp://192.168.178.1:554/?avm=1&freq=394&bw=8&msys=dvbc&mtype=256qam&sr=6900&specinv=0&pids=0,16,17,18,20,266,593,594,595,598,1801,1802,1803'
                        Do i need to add those parameters somewhere else?
                        • evroomE
                          evroom @bill22
                          @bill22
                          /usr/bin/omxplayer --genlog --hw --live --video_queue 4 --win '351 968 703 1210' 'rtsp://192.168.178.1:554/?avm=1&freq=394&bw=8&msys=dvbc&mtype=256qam&sr=6900&specinv=0&pids=0,16,17,18,20,266,593,594,595,598,1801,1802,1803'
                            bill22
                            @evroom
                            Thanks!
                            OK, positive effect on the video, running pretty smooth now!
                            Audio still missing…
                            • evroomE
                              evroom @bill22
                              @bill22
                              With Buck Bunny you had audio, right?
                              Audio over hdmi or audio jack?
                              Try adding --audio_queue 4
                              Then try removing --hw
                                bill22
                                @evroom
                                yes with Buck Bunny the audio was there.
                                I use audio over HDMI.
                                adding
                                --audio_queue 4
                                didn’t change the behaviour .
                                removed
                                --hw
                                Audio is working smoothly together with video ! !
                                • evroomE
                                  evroom @bill22
                                  @bill22
                                  Great!!
                                  Now you could try to enable the RTSPStream module again.
                                  Use
                                  url: ''rtsp://192.168.178.1:554/?avm=1&freq=394&bw=8&msys=dvbc&mtype=256qam&sr=6900&specinv=0&pids=0,16,17,18,20,266,593,594,595,598,1801,1802,1803'',
                                  It can be that you need to play a little.
                                  single quote single quote < url > single quote single quote
                                  double quote single quote < url > single quote double quote
                                  single quote < url with & > single quote
                                  I hope you understand what I mean.
                                  Look at the pm2 log for clues.
                                  Over and out for today.
                                    bill22
                                    @evroom
                                    Thank you very much for your guidance getting it to this point !!!
                                    Great that it is working so far!
                                    Have a good evening and i will follow your recommendations and let you know the outcome!
                                    Bill
                                    evroomE 2 Replies Last reply Reply Quote 0
                                    • evroomE
                                      evroom @bill22
                                      @bill22
                                      Try this
                                      url: 'rtsp://192.168.178.1:554/?avm=1\&freq=394\&bw=8\&msys=dvbc\&mtype=256qam\&sr=6900\&specinv=0\&pids=0,16,17,18,20,266,593,594,595,598,1801,1802,1803',
                                      Perhaps even the ? needs to be escaped
                                      url: 'rtsp://192.168.178.1:554/\?avm=1\&freq=394\&bw=8\&msys=dvbc\&mtype=256qam\&sr=6900\&specinv=0\&pids=0,16,17,18,20,266,593,594,595,598,1801,1802,1803',
                                      • evroomE
                                        evroom @bill22
                                        @bill22
                                        Here a procedure on how to use omxplayer as an addition to MM (without MMM-RTSPStream).
                                        This is how I use it for my Axis IP cam.
                                        You might need to reposition a few modules to make place for the overlaid stream.
                                        pi@MagicPi:~ $ cd
                                        pi@MagicPi:~ $ vi avm_stream.sh
                                        #!/bin/bash
                                        echo "Starting AVM stream ..."
                                        /usr/bin/omxplayer --genlog --live --video_queue 4 --win '351 968 703 1210' 'rtsp://192.168.178.1:554/?avm=1&freq=394&bw=8&msys=dvbc&mtype=256qam&sr=6900&specinv=0&pids=0,16,17,18,20,266,593,594,595,598,1801,1802,1803'
                                        pi@MagicPi:~ $ chmod +x avm_stream.sh
                                        pi@MagicPi:~ $ pm2 start avm_stream.sh
                                        i@MagicPi:~ $ pm2 save
                                        i@MagicPi:~ $ pm2 status
                                        Instead of vi you of course can use nano or so.
                                        When it runs you can remove the --genlog option.
                                        And I kind of lost track which exact command worked for you at the end.
                                          bill22
                                          The command working with the omx player is:
                                          /usr/bin/omxplayer --genlog --live --video_queue 4 --audio_queue 4 --win '1 720 503 1010' 'rtsp://192.168.178.1:554/?avm=1&freq=394&bw=8&msys=dvbc&mtype=256qam&sr=6900&specinv=0&pids=0,16,17,18,20,266,593,594,595,598,1801,1802,1803'
                                          • evroomE
                                            evroom @bill22
                                            @bill22
                                            MMM-RTSPStream modification for AVM DVB-C stream.
                                            $ vi ~/MagicMirror/config/config.js
                                                    frameRate: "25",
                                                    protocol: "tcp",
                                            	url: 'rtsp://192.168.178.1:554/?avm=1&freq=394&bw=8&msys=dvbc&mtype=256qam&sr=6900&specinv=0&pids=0,16,17,18,20,266,593,594,595,598,1801,1802,1803'
                                            $ cd /home/pi/MagicMirror/modules/MMM-RTSPStream
                                            $ cp -p node_helper.js node_helper.js.original
                                            $ nano node_helper.js
                                            Use [control]- (control minus) and enter 101 to go to line 101
                                                       var args = ["--live", "--video_queue", "4", "--fps", "30",
                                            Change the line to:
                                                      var args = ["--live", "--video_queue", "4", "--audio_queue", "4", "--fps", "25",
                                            Use [control]x and then Y to save the file.
                                            $ pm2 restart mm
                                            $ pm2 logs mm
                                            $ ps -eaf | grep omxplayer | grep -v grep
                                            $ pm2 status
                                            • 15
                                            • 16
                                            • 17
                                            • 18
                                            • 19
                                            • 30
                                            • 31
                                            • 17 / 31
