    602 Posts 67 Posters 2.4m Views 68 Watching
      bill22
      The command working with the omx player is:
      /usr/bin/omxplayer --genlog --live --video_queue 4 --audio_queue 4 --win '1 720 503 1010' 'rtsp://192.168.178.1:554/?avm=1&freq=394&bw=8&msys=dvbc&mtype=256qam&sr=6900&specinv=0&pids=0,16,17,18,20,266,593,594,595,598,1801,1802,1803'
      evroomE 1 Reply Last reply
      • evroomE
        evroom @bill22
        @bill22
        MMM-RTSPStream modification for AVM DVB-C stream.
        $ vi ~/MagicMirror/config/config.js
                frameRate: "25",
                protocol: "tcp",
        	url: 'rtsp://192.168.178.1:554/?avm=1&freq=394&bw=8&msys=dvbc&mtype=256qam&sr=6900&specinv=0&pids=0,16,17,18,20,266,593,594,595,598,1801,1802,1803'
        $ cd /home/pi/MagicMirror/modules/MMM-RTSPStream
        $ cp -p node_helper.js node_helper.js.original
        $ nano node_helper.js
        Use [control]- (control minus) and enter 101 to go to line 101
                   var args = ["--live", "--video_queue", "4", "--fps", "30",
        Change the line to:
                  var args = ["--live", "--video_queue", "4", "--audio_queue", "4", "--fps", "25",
        Use [control]x and then Y to save the file.
        $ pm2 restart mm
        $ pm2 logs mm
        $ ps -eaf | grep omxplayer | grep -v grep
        $ pm2 status
        MagicMirror version: 2.37.0
          bill22
          @evroom
          it shows the following status after the modification:
          pi@raspberrypi:~ $ pm2 restart mm
          [PM2] Applying action restartProcessId on app [mm](ids: 1)
          [PM2] [mm](1) ✓
          │ Name        │ id │ mode │ status  │ ↺  │ cpu │ memory   │
          │ avm_stream  │ 2  │ fork │ stopped │ 1  │ 0%  │ 0 B      │
          │ mm          │ 1  │ fork │ online  │ 1  │ 0%  │ 2.5 MB   │
          │ omx_stream1 │ 0  │ fork │ stopped │ 31 │ 0%  │ 0 B      │
           Use `pm2 show <id|name>` to get more details about an app
          pi@raspberrypi:~ $ pm2 logs mm
          [TAILING] Tailing last 15 lines for [mm] process (change the value with --lines option)
          1|mm       | npm ERR!     /home/pi/.npm/_logs/2019-07-09T20_38_42_696Z-debug.log
          1|mm       |
          1|mm       | (electron:1742): Gtk-WARNING **: cannot open display: :0
          1|mm       | npm ERR! code ELIFECYCLE
          1|mm       | npm ERR! errno 1
          1|mm       | npm ERR! magicmirror@2.7.1 start: `sh run-start.sh`
          1|mm       | npm ERR! Exit status 1
          1|mm       | npm ERR!
          1|mm       | npm ERR! Failed at the magicmirror@2.7.1 start script.
          1|mm       | npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
          1|mm       |
          1|mm       | npm ERR! A complete log of this run can be found in:
          1|mm       | npm ERR!     /home/pi/.npm/_logs/2019-07-09T20_38_45_348Z-debug.log
          1|mm       | ATTENTION: default value of option force_s3tc_enable overridden by environment.
          1|mm       |     "--avdict",
          1|mm       |     "rtsp_transport:tcp",
          1|mm       |     "--win",
          1|mm       |     "666, 393, 1018, 635",
          1|mm       |     "--live",
          1|mm       |     "--video_queue",
          1|mm       |     "4",
          1|mm       |     "--audio_queue",
          1|mm       |     "4",
          1|mm       |     "--fps",
          1|mm       |     "25",
          1|mm       |     "rtsp://192.168.178.1:554/?avm=1&freq=394&bw=8&msys=dvbc&mtype=256qam&sr=6900&specinv=0&pids=0,16,17,18,20,266,593,594,595,598,1801,1802,1803"
          1|mm       | ]
          1|mm       | Starting PM2 for omx_stream1
          1|mm       | PM2 started for omx_stream1
          pi@raspberrypi:~ $ ps -eaf | grep omxplayer | grep -v grep
          pi        6325   813  0 23:17 ?        00:00:00 bash /usr/bin/omxplayer --avdict rtsp_transport:tcp --win 666, 393, 1018, 635 --live --video_queue 4 --audio_queue 4 --fps 25 rtsp://192.168.178.1:554/?avm=1&freq=394&bw=8&msys=dvbc&mtype=256qam&sr=6900&specinv=0&pids=0,16,17,18,20,266,593,594,595,598,1801,1802,1803
          pi        6327  6325  0 23:17 ?        00:00:00 bash /usr/bin/omxplayer --avdict rtsp_transport:tcp --win 666, 393, 1018, 635 --live --video_queue 4 --audio_queue 4 --fps 25 rtsp://192.168.178.1:554/?avm=1&freq=394&bw=8&msys=dvbc&mtype=256qam&sr=6900&specinv=0&pids=0,16,17,18,20,266,593,594,595,598,1801,1802,1803
          pi@raspberrypi:~ $ pm2 status
          │ omx_stream1 │ 0  │ fork │ online  │ 117 │ 0%  │ 2.6 MB   │
          • evroomE
            evroom @bill22
            @bill22
            Overall it looks good I would say.
            The ERR are a concern, but I do not see a connection with RTSP.
            Give the /home/pi/.npm/_logs/2019-07-09T20_38_42_696Z-debug.log and /home/pi/.npm/_logs/2019-07-09T20_38_45_348Z-debug.loga clue ?
            Or when you restart mm, the newly generated log files ?
            With $ ps -eaf | grep omxplayer | grep -v grepand pm2 status, are the PIDs for omxplayer and omx_stream1 stable, or do they change ?
            Could you do ?
            $ pstree -ap `pgrep omxplayer | head -1`; pstree -ap `pm2 status | grep omx_stream1 | awk '{print $10}'`
            • evroomE
              evroom
              The pstree command might not work when the width of your terminal is not enough.
              Make it wide enough to have pm2 status show the PID column.
                bill22
                @evroom
                i couldnt find something in the log so far…
                I may overlook something here in genera. Looks like the avm_stream is still starting on rebooting the RPI…I tried with stop and save within pm2 already…So if I reboot, the avm_stream is online again…
                │ avm_stream  │ 2  │ fork │ stopped │ 0  │ 0%  │ 0 B      │
                │ mm          │ 1  │ fork │ online  │ 0  │ 0%  │ 2.6 MB   │
                │ omx_stream1 │ 0  │ fork │ stopped │ 15 │ 0%  │ 0 B      │
                pi@raspberrypi:~ $ pstree -ap `pgrep omxplayer | head -1`; pstree -ap `pm2 status | grep omx_stream1 | awk '{print $10}'`
                systemd,1 splash
                  ├─PM2 v3.5.1: God,813
                  │   ├─bash,923 /home/pi/mm.sh
                  │   │   └─npm,929
                  │   │       ├─sh,1047 -c sh run-start.sh
                  │   │       │   └─sh,1048 run-start.sh
                  │   │       │       └─node,1049 /home/pi/MagicMirror/node_modules/.bin/electron js/electron.js
                  │   │       │           ├─electron,1064
                  │   │       │           │   ├─electron,1126
                  │   │       │           │   │   └─electron,1467
                  │   │       │           │   │       ├─{Chrome_ChildIOT},1473
                  │   │       │           │   │       ├─{CompositorTileW},1496
                  │   │       │           │   │       ├─{CompositorTileW},1501
                  │   │       │           │   │       ├─{CompositorTileW},1503
                  │   │       │           │   │       ├─{Compositor},1495
                  │   │       │           │   │       ├─{File thread},1479
                  │   │       │           │   │       ├─{GpuMemoryThread},1474
                  │   │       │           │   │       ├─{ScriptStreamer },1539
                  │   │       │           │   │       ├─{TaskSchedulerBa},1469
                  │   │       │           │   │       ├─{TaskSchedulerBa},1470
                  │   │       │           │   │       ├─{TaskSchedulerFo},1472
                  │   │       │           │   │       ├─{TaskSchedulerFo},1737
                  │   │       │           │   │       ├─{TaskSchedulerSe},1468
                  │   │       │           │   │       └─{electron},1524
                  │   │       │           │   ├─electron,1454
                  │   │       │           │   │   ├─{Chrome_ChildIOT},1511
                  │   │       │           │   │   ├─{TaskSchedulerBa},1507
                  │   │       │           │   │   ├─{TaskSchedulerBa},1508
                  │   │       │           │   │   ├─{TaskSchedulerFo},1509
                  │   │       │           │   │   ├─{TaskSchedulerFo},1510
                  │   │       │           │   │   ├─{TaskSchedulerSe},1506
                  │   │       │           │   │   ├─{Watchdog},1505
                  │   │       │           │   │   ├─{llvmpipe-0},1487
                  │   │       │           │   │   ├─{llvmpipe-1},1488
                  │   │       │           │   │   ├─{llvmpipe-2},1489
                  │   │       │           │   │   └─{llvmpipe-3},1490
                  │   │       │           │   ├─{AudioThread},1444
                  │   │       │           │   ├─{CacheThread_Blo},1466
                  │   │       │           │   ├─{Chrome_IOThread},1428
                  │   │       │           │   ├─{CompositorTileW},1443
                  │   │       │           │   ├─{CrShutdownDetec},1432
                  │   │       │           │   ├─{D-Bus thread},1431
                  │   │       │           │   ├─{NetworkChangeNo},1429
                  │   │       │           │   ├─{TaskSchedulerBa},1434
                  │   │       │           │   ├─{TaskSchedulerBa},1462
                  │   │       │           │   ├─{TaskSchedulerFo},1436
                  │   │       │           │   ├─{TaskSchedulerFo},1439
                  │   │       │           │   ├─{TaskSchedulerSe},1433
                  │   │       │           │   ├─{TaskSchedulerSi},1441
                  │   │       │           │   ├─{TaskSchedulerSi},1442
                  │   │       │           │   ├─{TaskSchedulerSi},1573
                  │   │       │           │   ├─{electron},1191
                  │   │       │           │   ├─{electron},1192
                  │   │       │           │   ├─{electron},1193
                  │   │       │           │   ├─{electron},1221
                  │   │       │           │   ├─{electron},1414
                  │   │       │           │   ├─{electron},1415
                  │   │       │           │   ├─{electron},1416
                  │   │       │           │   ├─{electron},1417
                  │   │       │           │   ├─{electron},1453
                  │   │       │           │   ├─{gdbus},1179
                  │   │       │           │   ├─{gmain},1178
                  │   │       │           │   ├─{inotify_reader},1430
                  │   │       │           │   ├─{llvmpipe-0},1167
                  │   │       │           │   ├─{llvmpipe-1},1168
                  │   │       │           │   ├─{llvmpipe-2},1169
                  │   │       │           │   ├─{llvmpipe-3},1170
                  │   │       │           │   └─{sandbox_ipc_thr},1125
                  │   │       │           ├─{node},1050
                  │   │       │           ├─{node},1051
                  │   │       │           ├─{node},1052
                  │   │       │           ├─{node},1053
                  │   │       │           ├─{node},1054
                  │   │       │           └─{node},1057
                  │   │       ├─{node},934
                  │   │       ├─{node},935
                  │   │       ├─{node},936
                  │   │       ├─{node},937
                  │   │       ├─{node},938
                  │   │       ├─{node},945
                  │   │       ├─{npm},1013
                  │   │       ├─{npm},1014
                  │   │       ├─{npm},1015
                  │   │       └─{npm},1016
                  │   ├─{PM2 v3.5.1: God},915
                  │   ├─{PM2 v3.5.1: God},916
                  │   ├─{PM2 v3.5.1: God},917
                  │   ├─{PM2 v3.5.1: God},918
                  │   ├─{node},814
                  │   ├─{node},815
                  │   ├─{node},816
                  │   ├─{node},817
                  │   ├─{node},818
                  │   └─{node},819
                  ├─agetty,509 --noclear tty1 linux
                  ├─avahi-daemon,333
                  │   └─avahi-daemon,370
                  ├─bluealsa,455
                  │   ├─{bactl},463
                  │   ├─{gdbus},479
                  │   └─{gmain},478
                  ├─bluetoothd,454
                  ├─cron,340 -f
                  ├─dbus-daemon,323 --system --address=systemd: --nofork --nopidfile --systemd-activation
                  ├─dbus-daemon,951 --fork --print-address 5 --print-pid 6 --session
                  ├─dhcpcd,372 -q -b
                  ├─hciattach,446 /dev/serial1 bcm43xx 921600 noflow - b8:27:eb:fc:c6:fc
                  ├─lightdm,506
                  │   ├─Xorg,517 :0 -seat seat0 -auth /var/run/lightdm/root/:0 -nolisten tcp vt7 -novtswitch
                  │   │   ├─{InputThread},631
                  │   │   ├─{llvmpipe-0},623
                  │   │   ├─{llvmpipe-1},624
                  │   │   ├─{llvmpipe-2},625
                  │   │   └─{llvmpipe-3},626
                  │   ├─lightdm,634 --session-child 14 17
                  │   │   ├─lxsession,650 -s LXDE-pi -e LXDE
                  │   │   │   ├─lxpanel,785 --profile LXDE-pi
                  │   │   │   │   ├─chromium-browse,1766
                  │   │   │   │   │   ├─chromium-browse,1792
                  │   │   │   │   │   │   └─chromium-browse,1794
                  │   │   │   │   │   │       ├─chromium-browse,1989
                  │   │   │   │   │   │       │   ├─{Chrome_ChildIOT},2001
                  │   │   │   │   │   │       │   ├─{CompositorTileW},2020
                  │   │   │   │   │   │       │   ├─{CompositorTileW},2021
                  │   │   │   │   │   │       │   ├─{CompositorTileW},2022
                  │   │   │   │   │   │       │   ├─{Compositor},2013
                  │   │   │   │   │   │       │   ├─{Font_Proxy_Thre},2003
                  │   │   │   │   │   │       │   ├─{GpuMemoryThread},2002
                  │   │   │   │   │   │       │   ├─{TaskSchedulerFo},2000
                  │   │   │   │   │   │       │   ├─{TaskSchedulerFo},2114
                  │   │   │   │   │   │       │   ├─{TaskSchedulerFo},2255
                  │   │   │   │   │   │       │   ├─{TaskSchedulerFo},2256
                  │   │   │   │   │   │       │   └─{TaskSchedulerSe},1997
                  │   │   │   │   │   │       └─chromium-browse,2035
                  │   │   │   │   │   │           ├─{Chrome_ChildIOT},2039
                  │   │   │   │   │   │           ├─{CompositorTileW},2043
                  │   │   │   │   │   │           ├─{CompositorTileW},2044
                  │   │   │   │   │   │           ├─{CompositorTileW},2045
                  │   │   │   │   │   │           ├─{Compositor},2042
                  │   │   │   │   │   │           ├─{Font_Proxy_Thre},2041
                  │   │   │   │   │   │           ├─{GpuMemoryThread},2040
                  │   │   │   │   │   │           ├─{MemoryInfra},2091
                  │   │   │   │   │   │           ├─{ScriptStreamer },2049
                  │   │   │   │   │   │           ├─{TaskSchedulerFo},2038
                  │   │   │   │   │   │           ├─{TaskSchedulerFo},2046
                  │   │   │   │   │   │           ├─{TaskSchedulerFo},2254
                  │   │   │   │   │   │           └─{TaskSchedulerSe},2036
                  │   │   │   │   │   ├─chromium-browse,1824
                  │   │   │   │   │   │   ├─{Chrome_ChildIOT},1886
                  │   │   │   │   │   │   ├─{TaskSchedulerFo},1884
                  │   │   │   │   │   │   ├─{TaskSchedulerFo},1885
                  │   │   │   │   │   │   ├─{TaskSchedulerSe},1883
                  │   │   │   │   │   │   ├─{Watchdog},1882
                  │   │   │   │   │   │   ├─{llvmpipe-0},1877
                  │   │   │   │   │   │   ├─{llvmpipe-1},1878
                  │   │   │   │   │   │   ├─{llvmpipe-2},1879
                  │   │   │   │   │   │   └─{llvmpipe-3},1880
                  │   │   │   │   │   ├─{AudioThread},1818
                  │   │   │   │   │   ├─{Bluez D-Bus thr},1809
                  │   │   │   │   │   ├─{BrowserWatchdog},1825
                  │   │   │   │   │   ├─{CacheThread_Blo},1821
                  │   │   │   │   │   ├─{Chrome_HistoryT},1876
                  │   │   │   │   │   ├─{Chrome_IOThread},1802
                  │   │   │   │   │   ├─{CompositorTileW},1817
                  │   │   │   │   │   ├─{CrShutdownDetec},1810
                  │   │   │   │   │   ├─{NetworkChangeNo},1808
                  │   │   │   │   │   ├─{TaskSchedulerFo},1816
                  │   │   │   │   │   ├─{TaskSchedulerFo},2032
                  │   │   │   │   │   ├─{TaskSchedulerFo},2053
                  │   │   │   │   │   ├─{TaskSchedulerFo},2208
                  │   │   │   │   │   ├─{TaskSchedulerSe},1797
                  │   │   │   │   │   ├─{TaskSchedulerSi},1820
                  │   │   │   │   │   ├─{TaskSchedulerSi},1822
                  │   │   │   │   │   ├─{TaskSchedulerSi},1875
                  │   │   │   │   │   ├─{TaskSchedulerSi},1881
                  │   │   │   │   │   ├─{chromium-browse},1795
                  │   │   │   │   │   ├─{extension_crash},1986
                  │   │   │   │   │   ├─{gdbus},1807
                  │   │   │   │   │   ├─{gmain},1806
                  │   │   │   │   │   ├─{gpu-process_cra},1823
                  │   │   │   │   │   ├─{inotify_reader},1801
                  │   │   │   │   │   ├─{renderer_crash_},1894
                  │   │   │   │   │   ├─{sandbox_ipc_thr},1790
                  │   │   │   │   │   └─{utility_crash_u},2061
                  │   │   │   │   ├─lxterminal,2148
                  │   │   │   │   │   ├─bash,2150
                  │   │   │   │   │   │   └─pstree,2260 -ap
                  │   │   │   │   │   ├─gnome-pty-helpe,2149
                  │   │   │   │   │   ├─{gdbus},2159
                  │   │   │   │   │   └─{gmain},2151
                  │   │   │   │   ├─oosplash,2177 --writer
                  │   │   │   │   │   ├─soffice.bin,2195 --writer --splash-pipe=5
                  │   │   │   │   │   │   ├─{PipeIPC},2204
                  │   │   │   │   │   │   ├─{SelectionManage},2209
                  │   │   │   │   │   │   ├─{gdbus},2206
                  │   │   │   │   │   │   ├─{gmain},2205
                  │   │   │   │   │   │   ├─{rtl_cache_wsupd},2198
                  │   │   │   │   │   │   ├─{soffice.bin},2233
                  │   │   │   │   │   │   ├─{soffice.bin},2234
                  │   │   │   │   │   │   ├─{soffice.bin},2235
                  │   │   │   │   │   │   ├─{soffice.bin},2236
                  │   │   │   │   │   │   ├─{soffice.bin},2237
                  │   │   │   │   │   │   ├─{soffice.bin},2238
                  │   │   │   │   │   │   ├─{soffice.bin},2239
                  │   │   │   │   │   │   └─{soffice.bin},2240
                  │   │   │   │   │   ├─{osl_executeProc},2194
                  │   │   │   │   │   └─{rtl_cache_wsupd},2190
                  │   │   │   │   ├─(sh,847)
                  │   │   │   │   ├─{gdbus},825
                  │   │   │   │   ├─{gmain},824
                  │   │   │   │   └─{menu-cache-io},895
                  │   │   │   ├─lxpolkit,780
                  │   │   │   │   ├─{gdbus},801
                  │   │   │   │   └─{gmain},799
                  │   │   │   ├─openbox,773 --config-file /home/pi/.config/openbox/lxde-pi-rc.xml
                  │   │   │   ├─pcmanfm,791 --desktop --profile LXDE-pi
                  │   │   │   │   ├─{gdbus},821
                  │   │   │   │   └─{gmain},820
                  │   │   │   ├─ssh-agent,756 x-session-manager
                  │   │   │   ├─{gdbus},762
                  │   │   │   └─{gmain},761
                  │   │   ├─{gdbus},638
                  │   │   └─{gmain},637
                  │   ├─{gdbus},515
                  │   └─{gmain},513
                  ├─menu-cached,831 /run/user/1000/menu-cached-:0
                  │   ├─{gdbus},834
                  │   └─{gmain},833
                  ├─polkitd,804 --no-debug
                  │   ├─{gdbus},811
                  │   └─{gmain},809
                  ├─rngd,361 -r /dev/hwrng
                  │   ├─{rngd},362
                  │   ├─{rngd},363
                  │   └─{rngd},364
                  ├─rsyslogd,331 -n
                  │   ├─{in:imklog},377
                  │   ├─{in:imuxsock},376
                  │   └─{rs:main Q:Reg},378
                  ├─ssh-agent,803 -s
                  ├─systemd,642 --user
                  │   ├─(sd-pam),645
                  │   ├─dbus-daemon,659 --session --address=systemd: --nofork --nopidfile --systemd-activation
                  │   ├─gvfs-afc-volume,866
                  │   │   ├─{gdbus},870
                  │   │   ├─{gmain},868
                  │   │   └─{gvfs-afc-volume},867
                  │   ├─gvfs-goa-volume,858
                  │   │   ├─{gdbus},860
                  │   │   └─{gmain},859
                  │   ├─gvfs-gphoto2-vo,854
                  │   │   ├─{gdbus},857
                  │   │   └─{gmain},855
                  │   ├─gvfs-mtp-volume,862
                  │   │   ├─{gdbus},865
                  │   │   └─{gmain},863
                  │   ├─gvfs-udisks2-vo,835
                  │   │   ├─{gdbus},837
                  │   │   └─{gmain},836
                  │   ├─gvfsd,763
                  │   │   ├─{gdbus},765
                  │   │   └─{gmain},764
                  │   ├─gvfsd-fuse,768 /run/user/1000/gvfs -f -o big_writes
                  │   │   ├─{gdbus},787
                  │   │   ├─{gmain},786
                  │   │   ├─{gvfs-fuse-sub},792
                  │   │   ├─{gvfsd-fuse},782
                  │   │   └─{gvfsd-fuse},783
                  │   └─gvfsd-trash,904 --spawner :1.4 /org/gtk/gvfs/exec_spaw/0
                  │       ├─{gdbus},906
                  │       └─{gmain},905
                  ├─systemd-journal,107
                  ├─systemd-logind,334
                  ├─systemd-timesyn,305
                  │   └─{sd-resolve},320
                  ├─systemd-udevd,139
                  ├─thd,322 --triggers /etc/triggerhappy/triggers.d/ --socket /run/thd.socket --user nobody --deviceglob /dev/input/event*
                  ├─udisksd,838 --no-debug
                  │   ├─{cleanup},852
                  │   ├─{gdbus},841
                  │   ├─{gmain},839
                  │   └─{probing-thread},842
                  ├─wpa_supplicant,327 -u -s -O /run/wpa_supplicant
                  └─wpa_supplicant,422 -B -c/etc/wpa_supplicant/wpa_supplicant.conf -iwlan0 -Dnl80211,wext
                 ├─(kthreadd,2)
                 │   ├─(DWC Notificatio,62)
                 │   ├─(SMIO,67)
                 │   ├─(SMIO,189)
                 │   ├─(brcmf_wdog/mmc1,239)
                 │   ├─(brcmf_wq/mmc1:0,237)
                 │   ├─(cfg80211,231)
                 │   ├─(cpuhp/0,13)
                 │   ├─(cpuhp/1,14)
                 │   ├─(cpuhp/2,19)
                 │   ├─(cpuhp/3,24)
                 │   ├─(crypto,38)
                 │   ├─(dwc_otg,61)
                 │   ├─(ext4-rsv-conver,78)
                 │   ├─(ext4-rsv-conver,914)
                 │   ├─(ipv6_addrconf,79)
                 │   ├─(irq/86-mmc1,69)
                 │   ├─(iscsi_eh,60)
                 │   ├─(jbd2/mmcblk0p5-,913)
                 │   ├─(jbd2/mmcblk0p7-,77)
                 │   ├─(kblockd,39)
                 │   ├─(kcompactd0,37)
                 │   ├─(kdevtmpfs,29)
                 │   ├─(khungtaskd,34)
                 │   ├─(krfcommd,489)
                 │   ├─(ksoftirqd/0,9)
                 │   ├─(ksoftirqd/1,16)
                 │   ├─(ksoftirqd/2,21)
                 │   ├─(ksoftirqd/3,26)
                 │   ├─(kswapd0,46)
                 │   ├─(kthrotld,58)
                 │   ├─(kworker/0:0-event,1796)
                 │   ├─(kworker/0:0H-kblo,1789)
                 │   ├─(kworker/0:1-event,31)
                 │   ├─(kworker/0:1H-mmc_,74)
                 │   ├─(kworker/0:2-event,2231)
                 │   ├─(kworker/0:2H,2147)
                 │   ├─(kworker/1:0-mm_pe,1741)
                 │   ├─(kworker/1:0H-kblo,1785)
                 │   ├─(kworker/1:1-event,2213)
                 │   ├─(kworker/1:1H-kblo,75)
                 │   ├─(kworker/1:2-mm_pe,2048)
                 │   ├─(kworker/1:2H-kblo,2176)
                 │   ├─(kworker/2:0-event,1783)
                 │   ├─(kworker/2:0H-kblo,23)
                 │   ├─(kworker/2:1-event,33)
                 │   ├─(kworker/2:1H-kblo,1784)
                 │   ├─(kworker/2:2-event,2223)
                 │   ├─(kworker/2:2H,2196)
                 │   ├─(kworker/3:0-event,1742)
                 │   ├─(kworker/3:0H-kblo,1772)
                 │   ├─(kworker/3:1-mm_pe,2034)
                 │   ├─(kworker/3:1H-kblo,73)
                 │   ├─(kworker/3:2-event,68)
                 │   ├─(kworker/3:2H,2189)
                 │   ├─(kworker/3:3,2248)
                 │   ├─(kworker/u8:0-even,7)
                 │   ├─(kworker/u8:2-flus,100)
                 │   ├─(kworker/u9:0-hci0,42)
                 │   ├─(kworker/u9:1-hci0,448)
                 │   ├─(migration/0,12)
                 │   ├─(migration/1,15)
                 │   ├─(migration/2,20)
                 │   ├─(migration/3,25)
                 │   ├─(mm_percpu_wq,8)
                 │   ├─(mmal-vchiq,215)
                 │   ├─(mmal-vchiq,217)
                 │   ├─(mmal-vchiq,219)
                 │   ├─(mmc_complete,72)
                 │   ├─(netns,30)
                 │   ├─(nfsiod,47)
                 │   ├─(oom_reaper,35)
                 │   ├─(rcu_bh,11)
                 │   ├─(rcu_gp,3)
                 │   ├─(rcu_par_gp,4)
                 │   ├─(rcu_sched,10)
                 │   ├─(rpciod,41)
                 │   ├─(vchiq-keep/0,66)
                 │   ├─(vchiq-recy/0,64)
                 │   ├─(vchiq-slot/0,63)
                 │   ├─(vchiq-sync/0,65)
                 │   ├─(watchdogd,40)
                 │   ├─(writeback,36)
                 │   └─(xprtiod,43)
                 └─systemd,1 splash
                     │   │   └─npm,929
                     │   │       │           ├─{node},1050
                     │   │       │           ├─{node},1051
                     │   │       │           ├─{node},1052
                     │   │       │           ├─{node},1053
                     │   │       │           ├─{node},1054
                     │   │       │           └─{node},1057
                     │   │       ├─{node},934
                     │   │       ├─{node},935
                     │   │       ├─{node},936
                     │   │       ├─{node},937
                     │   │       ├─{node},938
                     │   │       ├─{node},945
                     │   │       ├─{npm},1013
                     │   │       ├─{npm},1014
                     │   │       ├─{npm},1015
                     │   │       └─{npm},1016
                     │   ├─{node},814
                     │   ├─{node},815
                     │   ├─{node},816
                     │   ├─{node},817
                     │   ├─{node},818
                     │   └─{node},819
                     ├─avahi-daemon,333
                     ├─bluealsa,455
                     │   ├─{bactl},463
                     │   ├─{gdbus},479
                     │   └─{gmain},478
                     ├─bluetoothd,454
                     ├─cron,340 -f
                     ├─dhcpcd,372 -q -b
                     ├─lightdm,506
                     │   │   │   │   │   │   └─pstree,2271 -ap 0
                     │   │   │   │   ├─(sh,847)
                     │   │   │   ├─{gdbus},762
                     │   │   │   └─{gmain},761
                     │   │   ├─{gdbus},638
                     │   │   └─{gmain},637
                     │   ├─{gdbus},515
                     │   └─{gmain},513
                     │   ├─{gdbus},834
                     │   └─{gmain},833
                     │   ├─{gdbus},811
                     │   └─{gmain},809
                     │   ├─{rngd},362
                     │   ├─{rngd},363
                     │   └─{rngd},364
                     ├─rsyslogd,331 -n
                     │   ├─{in:imklog},377
                     ├─ssh-agent,803 -s
                     │   ├─(sd-pam),645
                     │   │   ├─{gdbus},870
                     │   │   ├─{gmain},868
                     │   │   ├─{gdbus},860
                     │   │   └─{gmain},859
                     │   │   ├─{gdbus},857
                     │   │   └─{gmain},855
                     │   │   ├─{gdbus},865
                     │   │   └─{gmain},863
                     │   │   ├─{gdbus},837
                     │   │   └─{gmain},836
                     │   ├─gvfsd,763
                     │   │   ├─{gdbus},765
                     │   │   └─{gmain},764
                     │   │   ├─{gdbus},787
                     │   │   ├─{gmain},786
                     │       ├─{gdbus},906
                     │       └─{gmain},905
                     ├─systemd-udevd,139
                     │   ├─{cleanup},852
                     │   ├─{gdbus},841
                     │   ├─{gmain},839
                pi@raspberrypi:~ $
                • evroomE
                  evroom @bill22
                  @bill22
                  In order to remove avm_stream from pm2; I think you have to do:
                  pm2 stop avm_stream
                  pm2 delete avm_stream
                  pm2 save
                  pm2 status
                  If pm2 status does not show the pid column, my command does not make sense.
                  First stretch out the ssh window so that it shows.
                  This is not good:
                  pi@MagicPi:~/MagicMirror/css $ pm2 status
                  │ axis │ 1  │ fork │ online │ 0 │ 0%  │ 2.5 MB   │
                  │ mm   │ 0  │ fork │ online │ 0 │ 0%  │ 2.5 MB   │
                  This is better:
                  │ App name │ id │ version │ mode │ pid   │ status │ restart │ uptime │ cpu │ mem      │ user │ watching │
                  │ axis     │ 1  │ 2.5.0   │ fork │ 14186 │ online │ 0       │ 20h    │ 0%  │ 2.5 MB   │ pi   │ disabled │
                  │ mm       │ 0  │ 2.5.0   │ fork │ 14180 │ online │ 0       │ 20h    │ 0%  │ 2.5 MB   │ pi   │ disabled │
                    bill22
                    thanks, i removed the avm_stream.
                    Below the status including the PID. Missed that before…
                    │ mm                   │ 1  │ N/A│ fork │ 940 │ online  │ 0             │ 37m    │ 0%  │ 2.3 MB   │ pi   │ disabled │
                    │ omx_stream1 │ 0  │ N/A         │ fork │ 0   │ stopped │ 17          │ 0          │ 0%  │ 0 B          │ pi   │ disabled │
                    PIDs remain the same when I run pm2 status again
                    • evroomE
                      evroom @bill22
                      @bill22
                      pm2 status will show the current status; will not restart mm & omx_stream1.
                      You can try pm2 restart mm and see what happens.
                      Repeat
                      a few times.
                      I guess that you will see different PIDs and then status stopped (with pm2 status).
                      But perhaps it will remain stable.
                        bill22
                        @evroom
                        the PIDs of omx_stream1 is changing:
                        [PM2] [mm](1) ✓
                        │ mm          │ 1  │ N/A     │ fork │ 2976 │ online  │ 1       │ 0s     │ 0%  │ 2.3 MB   │ pi   │ disabled │
                        │ mm          │ 1  │ N/A     │ fork │ 2976 │ online │ 1       │ 2m     │ 0%  │ 2.3 MB   │ pi   │ disabled │
                        │ omx_stream1 │ 0  │ N/A     │ fork │ 4609 │ online │ 58      │ 2s     │ 0%  │ 2.4 MB   │ pi   │ disabled │
                          bill22
                          @evroom
                          │ omx_stream1 │ 0  │ N/A     │ fork │ 5123 │ online │ 71      │ 1s     │ 0%  │ 2.6 MB   │ pi   │ disabled │
                          │ mm          │ 1  │ N/A     │ fork │ 2976 │ online │ 1       │ 4m     │ 0%  │ 2.3 MB   │ pi   │ disabled │
                          │ omx_stream1 │ 0  │ N/A     │ fork │ 7749 │ online │ 141     │ 1s     │ 0%  │ 2.5 MB   │ pi   │ disabled │
                          │ omx_stream1 │ 0  │ N/A     │ fork │ 7831 │ online │ 143     │ 1s     │ 0%  │ 2.5 MB   │ pi   │ disabled │
                          systemd,1 splash
                            ├─PM2 v3.5.1: God,781
                            │   ├─bash,2976 /home/pi/mm.sh
                            │   │   └─npm,2977
                            │   │       ├─sh,2991 -c sh run-start.sh
                            │   │       │   └─sh,2992 run-start.sh
                            │   │       │       └─node,2993 /home/pi/MagicMirror/node_modules/.bin/electron js/electron.js
                            │   │       │           ├─electron,3000
                            │   │       │           │   ├─electron,3002
                            │   │       │           │   │   └─electron,3039
                            │   │       │           │   │       ├─{Chrome_ChildIOT},3045
                            │   │       │           │   │       ├─{CompositorTileW},3049
                            │   │       │           │   │       ├─{CompositorTileW},3050
                            │   │       │           │   │       ├─{CompositorTileW},3051
                            │   │       │           │   │       ├─{Compositor},3048
                            │   │       │           │   │       ├─{File thread},3047
                            │   │       │           │   │       ├─{GpuMemoryThread},3046
                            │   │       │           │   │       ├─{ScriptStreamer },3071
                            │   │       │           │   │       ├─{TaskSchedulerBa},3041
                            │   │       │           │   │       ├─{TaskSchedulerBa},3042
                            │   │       │           │   │       ├─{TaskSchedulerFo},3043
                            │   │       │           │   │       ├─{TaskSchedulerFo},3044
                            │   │       │           │   │       ├─{TaskSchedulerFo},7868
                            │   │       │           │   │       ├─{TaskSchedulerSe},3040
                            │   │       │           │   │       └─{electron},3065
                            │   │       │           │   ├─electron,3036
                            │   │       │           │   │   ├─{Chrome_ChildIOT},3063
                            │   │       │           │   │   ├─{TaskSchedulerBa},3059
                            │   │       │           │   │   ├─{TaskSchedulerBa},3060
                            │   │       │           │   │   ├─{TaskSchedulerFo},3061
                            │   │       │           │   │   ├─{TaskSchedulerFo},3062
                            │   │       │           │   │   ├─{TaskSchedulerSe},3058
                            │   │       │           │   │   ├─{Watchdog},3057
                            │   │       │           │   │   ├─{llvmpipe-0},3053
                            │   │       │           │   │   ├─{llvmpipe-1},3054
                            │   │       │           │   │   ├─{llvmpipe-2},3055
                            │   │       │           │   │   └─{llvmpipe-3},3056
                            │   │       │           │   ├─{AudioThread},3033
                            │   │       │           │   ├─{CacheThread_Blo},3038
                            │   │       │           │   ├─{Chrome_IOThread},3017
                            │   │       │           │   ├─{CompositorTileW},3032
                            │   │       │           │   ├─{CrShutdownDetec},3021
                            │   │       │           │   ├─{D-Bus thread},3019
                            │   │       │           │   ├─{NetworkChangeNo},3018
                            │   │       │           │   ├─{TaskSchedulerBa},3023
                            │   │       │           │   ├─{TaskSchedulerBa},3024
                            │   │       │           │   ├─{TaskSchedulerFo},3025
                            │   │       │           │   ├─{TaskSchedulerFo},3067
                            │   │       │           │   ├─{TaskSchedulerFo},8081
                            │   │       │           │   ├─{TaskSchedulerSe},3022
                            │   │       │           │   ├─{TaskSchedulerSi},3030
                            │   │       │           │   ├─{TaskSchedulerSi},3031
                            │   │       │           │   ├─{TaskSchedulerSi},3073
                            │   │       │           │   ├─{electron},3008
                            │   │       │           │   ├─{electron},3009
                            │   │       │           │   ├─{electron},3010
                            │   │       │           │   ├─{electron},3011
                            │   │       │           │   ├─{electron},3013
                            │   │       │           │   ├─{electron},3014
                            │   │       │           │   ├─{electron},3015
                            │   │       │           │   ├─{electron},3016
                            │   │       │           │   ├─{electron},3034
                            │   │       │           │   ├─{gdbus},3007
                            │   │       │           │   ├─{gmain},3006
                            │   │       │           │   ├─{inotify_reader},3020
                            │   │       │           │   └─{sandbox_ipc_thr},3001
                            │   │       │           ├─{node},2994
                            │   │       │           ├─{node},2995
                            │   │       │           ├─{node},2996
                            │   │       │           ├─{node},2997
                            │   │       │           ├─{node},2998
                            │   │       │           └─{node},2999
                            │   │       ├─{node},2978
                            │   │       ├─{node},2979
                            │   │       ├─{node},2980
                            │   │       ├─{node},2981
                            │   │       ├─{node},2982
                            │   │       ├─{node},2983
                            │   │       ├─{npm},2986
                            │   │       ├─{npm},2987
                            │   │       ├─{npm},2988
                            │   │       └─{npm},2989
                            │   ├─bash,8279 /usr/bin/omxplayer --avdict rtsp_transport:tcp --win 666, 361, 1018, 603 --live --video_queue 4 --audio_queue 4 --fps 25...
                            │   ├─{PM2 v3.5.1: God},919
                            │   ├─{node},784
                            │   ├─{node},785
                            │   ├─{node},786
                            │   ├─{node},787
                            │   ├─{node},788
                            │   └─{node},789
                            ├─agetty,502 --noclear tty1 linux
                            ├─avahi-daemon,364
                            │   └─avahi-daemon,386
                            ├─bluealsa,607
                            │   ├─{bactl},633
                            │   ├─{gdbus},635
                            │   └─{gmain},634
                            ├─bluetoothd,558
                            ├─cron,358 -f
                            ├─dbus-daemon,365 --system --address=systemd: --nofork --nopidfile --systemd-activation
                            ├─dbus-daemon,968 --fork --print-address 5 --print-pid 6 --session
                            ├─dhcpcd,413 -q -b
                            ├─hciattach,539 /dev/serial1 bcm43xx 921600 noflow - b8:27:eb:fc:c6:fc
                            ├─lightdm,449
                            │   ├─Xorg,511 :0 -seat seat0 -auth /var/run/lightdm/root/:0 -nolisten tcp vt7 -novtswitch
                            │   │   ├─{InputThread},653
                            │   │   ├─{llvmpipe-0},645
                            │   │   ├─{llvmpipe-1},646
                            │   │   ├─{llvmpipe-2},647
                            │   │   └─{llvmpipe-3},648
                            │   ├─lightdm,656 --session-child 14 17
                            │   │   ├─lxsession,672 -s LXDE-pi -e LXDE
                            │   │   │   ├─lxpanel,817 --profile LXDE-pi
                            │   │   │   │   ├─chromium-browse,1784
                            │   │   │   │   │   ├─chromium-browse,1805
                            │   │   │   │   │   │   └─chromium-browse,1808
                            │   │   │   │   │   │       ├─chromium-browse,1967
                            │   │   │   │   │   │       │   ├─{Chrome_ChildIOT},1980
                            │   │   │   │   │   │       │   ├─{CompositorTileW},2029
                            │   │   │   │   │   │       │   ├─{CompositorTileW},2030
                            │   │   │   │   │   │       │   ├─{CompositorTileW},2031
                            │   │   │   │   │   │       │   ├─{Compositor},2024
                            │   │   │   │   │   │       │   ├─{Font_Proxy_Thre},1984
                            │   │   │   │   │   │       │   ├─{GpuMemoryThread},1983
                            │   │   │   │   │   │       │   ├─{TaskSchedulerFo},1979
                            │   │   │   │   │   │       │   ├─{TaskSchedulerFo},2830
                            │   │   │   │   │   │       │   └─{TaskSchedulerSe},1976
                            │   │   │   │   │   │       └─chromium-browse,2050
                            │   │   │   │   │   │           ├─{Chrome_ChildIOT},2054
                            │   │   │   │   │   │           ├─{CompositorTileW},2058
                            │   │   │   │   │   │           ├─{CompositorTileW},2059
                            │   │   │   │   │   │           ├─{CompositorTileW},2060
                            │   │   │   │   │   │           ├─{Compositor},2057
                            │   │   │   │   │   │           ├─{Font_Proxy_Thre},2056
                            │   │   │   │   │   │           ├─{GpuMemoryThread},2055
                            │   │   │   │   │   │           ├─{Media},2463
                            │   │   │   │   │   │           ├─{MemoryInfra},2104
                            │   │   │   │   │   │           ├─{ScriptStreamer },2088
                            │   │   │   │   │   │           ├─{TaskSchedulerFo},2053
                            │   │   │   │   │   │           ├─{TaskSchedulerFo},2958
                            │   │   │   │   │   │           ├─{TaskSchedulerFo},6650
                            │   │   │   │   │   │           ├─{TaskSchedulerFo},7786
                            │   │   │   │   │   │           └─{TaskSchedulerSe},2051
                            │   │   │   │   │   ├─chromium-browse,1837
                            │   │   │   │   │   │   ├─{Chrome_ChildIOT},1899
                            │   │   │   │   │   │   ├─{TaskSchedulerFo},1897
                            │   │   │   │   │   │   ├─{TaskSchedulerFo},1898
                            │   │   │   │   │   │   ├─{TaskSchedulerSe},1896
                            │   │   │   │   │   │   ├─{Watchdog},1895
                            │   │   │   │   │   │   ├─{llvmpipe-0},1890
                            │   │   │   │   │   │   ├─{llvmpipe-1},1891
                            │   │   │   │   │   │   ├─{llvmpipe-2},1892
                            │   │   │   │   │   │   └─{llvmpipe-3},1893
                            │   │   │   │   │   ├─{AudioThread},1831
                            │   │   │   │   │   ├─{Bluez D-Bus thr},1822
                            │   │   │   │   │   ├─{BrowserWatchdog},1838
                            │   │   │   │   │   ├─{CacheThread_Blo},1834
                            │   │   │   │   │   ├─{Chrome_HistoryT},1889
                            │   │   │   │   │   ├─{Chrome_IOThread},1815
                            │   │   │   │   │   ├─{CompositorTileW},1830
                            │   │   │   │   │   ├─{CrShutdownDetec},1823
                            │   │   │   │   │   ├─{LevelDBEnv},2146
                            │   │   │   │   │   ├─{NetworkChangeNo},1821
                            │   │   │   │   │   ├─{TaskSchedulerFo},2044
                            │   │   │   │   │   ├─{TaskSchedulerFo},2671
                            │   │   │   │   │   ├─{TaskSchedulerFo},2832
                            │   │   │   │   │   ├─{TaskSchedulerFo},7990
                            │   │   │   │   │   ├─{TaskSchedulerSe},1810
                            │   │   │   │   │   ├─{TaskSchedulerSi},1833
                            │   │   │   │   │   ├─{TaskSchedulerSi},1835
                            │   │   │   │   │   ├─{TaskSchedulerSi},1888
                            │   │   │   │   │   ├─{TaskSchedulerSi},1894
                            │   │   │   │   │   ├─{chromium-browse},1809
                            │   │   │   │   │   ├─{extension_crash},1966
                            │   │   │   │   │   ├─{gdbus},1820
                            │   │   │   │   │   ├─{gmain},1819
                            │   │   │   │   │   ├─{gpu-process_cra},1836
                            │   │   │   │   │   ├─{inotify_reader},1814
                            │   │   │   │   │   ├─{renderer_crash_},1904
                            │   │   │   │   │   └─{sandbox_ipc_thr},1803
                            │   │   │   │   ├─lxterminal,2945
                            │   │   │   │   │   ├─bash,2947
                            │   │   │   │   │   │   └─pstree,8300 -ap
                            │   │   │   │   │   ├─gnome-pty-helpe,2946
                            │   │   │   │   │   ├─{gdbus},2955
                            │   │   │   │   │   └─{gmain},2948
                            │   │   │   │   ├─oosplash,2160 --writer
                            │   │   │   │   │   ├─soffice.bin,2178 --writer --splash-pipe=5
                            │   │   │   │   │   │   ├─{PipeIPC},2188
                            │   │   │   │   │   │   ├─{SelectionManage},2193
                            │   │   │   │   │   │   ├─{gdbus},2191
                            │   │   │   │   │   │   ├─{gmain},2190
                            │   │   │   │   │   │   ├─{rtl_cache_wsupd},2182
                            │   │   │   │   │   │   ├─{soffice.bin},2197
                            │   │   │   │   │   │   ├─{soffice.bin},2198
                            │   │   │   │   │   │   ├─{soffice.bin},2199
                            │   │   │   │   │   │   ├─{soffice.bin},2200
                            │   │   │   │   │   │   ├─{soffice.bin},2201
                            │   │   │   │   │   │   ├─{soffice.bin},2202
                            │   │   │   │   │   │   ├─{soffice.bin},2203
                            │   │   │   │   │   │   └─{soffice.bin},2204
                            │   │   │   │   │   ├─{osl_executeProc},2177
                            │   │   │   │   │   └─{rtl_cache_wsupd},2172
                            │   │   │   │   ├─(sh,864)
                            │   │   │   │   ├─{gdbus},844
                            │   │   │   │   ├─{gmain},843
                            │   │   │   │   └─{menu-cache-io},921
                            │   │   │   ├─lxpolkit,809
                            │   │   │   │   ├─{gdbus},832
                            │   │   │   │   └─{gmain},831
                            │   │   │   ├─openbox,807 --config-file /home/pi/.config/openbox/lxde-pi-rc.xml
                            │   │   │   ├─pcmanfm,820 --desktop --profile LXDE-pi
                            │   │   │   │   ├─leafpad,1770 /home/pi/omxplayer.log
                            │   │   │   │   │   ├─{gdbus},1772
                            │   │   │   │   │   └─{gmain},1771
                            │   │   │   │   ├─leafpad,2133 /home/pi/.npm/_logs/2019-07-11T21_30_10_606Z-debug.log
                            │   │   │   │   │   ├─{gdbus},2135
                            │   │   │   │   │   └─{gmain},2134
                            │   │   │   │   ├─{gdbus},846
                            │   │   │   │   └─{gmain},845
                            │   │   │   ├─ssh-agent,778 x-session-manager
                            │   │   │   ├─{gdbus},791
                            │   │   │   └─{gmain},790
                            │   │   ├─{gdbus},660
                            │   │   └─{gmain},659
                            │   ├─{gdbus},453
                            │   └─{gmain},451
                            ├─menu-cached,853 /run/user/1000/menu-cached-:0
                            │   ├─{gdbus},856
                            │   └─{gmain},855
                            ├─polkitd,835 --no-debug
                            │   ├─{gdbus},840
                            │   └─{gmain},838
                            ├─rngd,409 -r /dev/hwrng
                            │   ├─{rngd},410
                            │   ├─{rngd},411
                            │   └─{rngd},412
                            ├─rsyslogd,359 -n
                            │   ├─{in:imklog},389
                            │   ├─{in:imuxsock},388
                            │   └─{rs:main Q:Reg},390
                            ├─ssh-agent,830 -s
                            ├─systemd,664 --user
                            │   ├─(sd-pam),667
                            │   ├─dbus-daemon,681 --session --address=systemd: --nofork --nopidfile --systemd-activation
                            │   ├─gvfs-afc-volume,888
                            │   │   ├─{gdbus},892
                            │   │   ├─{gmain},890
                            │   │   └─{gvfs-afc-volume},889
                            │   ├─gvfs-goa-volume,880
                            │   │   ├─{gdbus},882
                            │   │   └─{gmain},881
                            │   ├─gvfs-gphoto2-vo,876
                            │   │   ├─{gdbus},879
                            │   │   └─{gmain},877
                            │   ├─gvfs-mtp-volume,884
                            │   │   ├─{gdbus},887
                            │   │   └─{gmain},885
                            │   ├─gvfs-udisks2-vo,857
                            │   │   ├─{gdbus},863
                            │   │   └─{gmain},862
                            │   ├─gvfsd,792
                            │   │   ├─{gdbus},794
                            │   │   └─{gmain},793
                            │   ├─gvfsd-fuse,797 /run/user/1000/gvfs -f -o big_writes
                            │   │   ├─{gdbus},814
                            │   │   ├─{gmain},813
                            │   │   ├─{gvfs-fuse-sub},821
                            │   │   ├─{gvfsd-fuse},811
                            │   │   └─{gvfsd-fuse},812
                            │   └─gvfsd-trash,930 --spawner :1.4 /org/gtk/gvfs/exec_spaw/0
                            │       ├─{gdbus},933
                            │       └─{gmain},932
                            ├─systemd-journal,103
                            ├─systemd-logind,361
                            ├─systemd-timesyn,324
                            │   └─{sd-resolve},360
                            ├─systemd-udevd,137
                            ├─thd,395 --triggers /etc/triggerhappy/triggers.d/ --socket /run/thd.socket --user nobody --deviceglob /dev/input/event*
                            ├─udisksd,869 --no-debug
                            │   ├─{cleanup},874
                            │   ├─{gdbus},872
                            │   ├─{gmain},870
                            │   └─{probing-thread},873
                            ├─wpa_supplicant,400 -u -s -O /run/wpa_supplicant
                            └─wpa_supplicant,457 -B -c/etc/wpa_supplicant/wpa_supplicant.conf -iwlan0 -Dnl80211,wext
                          bash,8330 /usr/bin/omxplayer --avdict rtsp_transport:tcp --win 666, 361, 1018, 603 --live --video_queue 4 --audio_queue 4 --fps 25...
                            └─bash,8340 /usr/bin/omxplayer --avdict rtsp_transport:tcp --win 666, 361, 1018, 603 --live --video_queue 4 --audio_queue 4 --fps 25...
                                └─node,8341 /home/pi/MagicMirror/node_modules/.bin/which xset
                                    ├─{node},8342
                                    ├─{node},8343
                                    ├─{node},8344
                                    ├─{node},8345
                                    ├─{node},8346
                                    └─{node},8347
                          systemd,1 splash
                            │   │   └─npm,2977
                            │   │       │           │   │       ├─{TaskSchedulerFo},8553
                            │   │       │           ├─{node},2994
                            │   │       │           ├─{node},2995
                            │   │       │           ├─{node},2996
                            │   │       │           ├─{node},2997
                            │   │       │           ├─{node},2998
                            │   │       │           └─{node},2999
                            │   │       ├─{node},2978
                            │   │       ├─{node},2979
                            │   │       ├─{node},2980
                            │   │       ├─{node},2981
                            │   │       ├─{node},2982
                            │   │       ├─{node},2983
                            │   │       ├─{npm},2986
                            │   │       ├─{npm},2987
                            │   │       ├─{npm},2988
                            │   │       └─{npm},2989
                            │   ├─bash,10219 /usr/bin/omxplayer --avdict rtsp_transport:tcp --win 666, 361, 1018, 603 --live --video_queue 4 --audio_queue 4 --fps 25...
                            │   │   └─bash,10221 /usr/bin/omxplayer --avdict rtsp_transport:tcp --win 666, 361, 1018, 603 --live --video_queue 4 --audio_queue 4 --fps 25...
                            │   │       └─node,10222 /home/pi/MagicMirror/node_modules/.bin/which fbset
                            │   │           ├─{node},10223
                            │   │           ├─{node},10224
                            │   │           ├─{node},10225
                            │   │           ├─{node},10226
                            │   │           ├─{node},10227
                            │   │           └─{node},10231
                            │   ├─{node},784
                            │   ├─{node},785
                            │   ├─{node},786
                            │   ├─{node},787
                            │   ├─{node},788
                            │   └─{node},789
                            ├─avahi-daemon,364
                            ├─bluealsa,607
                            │   ├─{bactl},633
                            │   ├─{gdbus},635
                            │   └─{gmain},634
                            ├─bluetoothd,558
                            ├─cron,358 -f
                            ├─dhcpcd,413 -q -b
                            ├─lightdm,449
                            │   │   │   │   │   │   └─pstree,10232 -ap
                            │   │   │   │   ├─(sh,864)
                            │   │   │   ├─{gdbus},791
                            │   │   │   └─{gmain},790
                            │   │   ├─{gdbus},660
                            │   │   └─{gmain},659
                            │   ├─{gdbus},453
                            │   └─{gmain},451
                            │   ├─{gdbus},856
                            │   └─{gmain},855
                            │   ├─{gdbus},840
                            │   └─{gmain},838
                            │   ├─{rngd},410
                            │   ├─{rngd},411
                            │   └─{rngd},412
                            ├─rsyslogd,359 -n
                            │   ├─{in:imklog},389
                            ├─ssh-agent,830 -s
                            │   ├─(sd-pam),667
                            │   │   ├─{gdbus},892
                            │   │   ├─{gmain},890
                            │   │   ├─{gdbus},882
                            │   │   └─{gmain},881
                            │   │   ├─{gdbus},879
                            │   │   └─{gmain},877
                            │   │   ├─{gdbus},887
                            │   │   └─{gmain},885
                            │   │   ├─{gdbus},863
                            │   │   └─{gmain},862
                            │   ├─gvfsd,792
                            │   │   ├─{gdbus},794
                            │   │   └─{gmain},793
                            │   │   ├─{gdbus},814
                            │   │   ├─{gmain},813
                            │       ├─{gdbus},933
                            │       └─{gmain},932
                            ├─systemd-udevd,137
                            │   ├─{cleanup},874
                            │   ├─{gdbus},872
                            │   ├─{gmain},870
                          • evroomE
                            evroom @bill22
                            @bill22
                            And after a little while, does it say stopped?
                            And what does
                            say?
                            If pm2 status has a pid, can you do
                            pstree -ap < pid >
                            Iso < pid > put the pid number from pm2 status.
                              bill22
                              @evroom
                              omx_stream1 remain online, but the uptime shows 0s only (mm is up for 36 min):
                              │ mm          │ 1  │ N/A     │ fork │ 2976  │ online │ 1       │ 36m    │ 0%  │ 2.3 MB   │ pi   │ disabled │
                              │ omx_stream1 │ 0  │ N/A     │ fork │ 10391 │ online │ 1073    │ 0s     │ 0%  │ 2.2 MB   │ pi   │ disabled │
                              pi        1770   820  0 18:17 ?        00:00:04 leafpad /home/pi/omxplayer.log
                              pi       13794   781  1 20:05 ?        00:00:00 bash /usr/bin/omxplayer --avdict rtsp_transport:tcp --win 666, 361, 1018, 603 --live --video_queue 4 --audio_queue 4 --fps 25 rtsp://192.168.178.1:554/?avm=1&freq=394&bw=8&msys=dvbc&mtype=256qam&sr=6900&specinv=0&pids=0,16,17,18,20,266,593,594,595,598,1801,1802,1803
                              pi       13823 13794  0 20:05 ?        00:00:00 /usr/bin/omxplayer.bin --avdict rtsp_transport:tcp --win 666, 361, 1018, 603 --live --video_queue 4 --audio_queue 4 --fps 25 rtsp://192.168.178.1:554/?avm=1&freq=394&bw=8&msys=dvbc&mtype=256qam&sr=6900&specinv=0&pids=0,16,17,18,20,266,593,594,595,598,1801,1802,1803
                              pi@raspberrypi:~ $
                              tried to use
                              pstree -ap < pid >
                              but the PID is constantly changing; therefore no output
                              • evroomE
                                evroom @bill22
                                @bill22
                                To be honest, I am lost, out of ideas.
                                I tried to get the module running myself again, but I cannot even get Bucks Bunny to eat his carrot.
                                I would need to setup MM completely new for it to work I guess.
                                At the moment you are left with the option of running it stand-alone using avm_stream, like I do
                                How where you thinking of using the module should it work?
                                Changing channels would still be a challenge, right?
                                  bill22
                                  @evroom
                                  seems to be quite tricky with that stream…
                                  But thank you for all your efforts so far and again great that we did it at least to run stand alone…!
                                  You are right, channel changing options seems to be a limitation using avm_stream. I wonder if there is a way of “operating” the avm_stream, at least to switch one particular channel/stream on and off without using the terminal…?
                                  evroomE 2 Replies Last reply
                                  • evroomE
                                    evroom @bill22
                                    @bill22
                                    I will look if there is a module that can trigger linux commands at will.
                                    Would be interested in that myself.
                                      bill22
                                      @evroom
                                      if we could find one, it could be probably used to start/stop the stream. On the other hand it could be an option to define several “stand alone streams” and call those individually. Position of the streams could be even offset to each other…Just a thought…
                                      • evroomE
                                        evroom @bill22
                                        @bill22
                                        Btw, do you “fancy” stuff like Voice Control or Alexa ?
                                        I don’t, but those would be modules that could trigger something.
                                          bill22
                                          @evroom
                                          me neither
                                          • evroomE
                                            evroom @bill22
                                            @bill22
                                            I used this Sunday to setup a second Pi, whilst watching F1.
                                            Used a new SD, installed Debian Buster and Magic Mirror v2.8.0.
                                            After I made sure I did not have any errors after rebooting, restarting MM, etc, I setup MMM-RTSPStream.
                                            It now works for Bucks Bunny, my IP cam and my SAT receiver.
                                            I can even rotate 2 SAT channels.
                                            I also tested the little fix with --audio_queue 4and that works to (although I cannot check audio, as I have no speaker).
                                            It does not say that this method will work for you (my RTSP was dead as a dodo), but it could be something to consider.
                                            I will play a bit with single quotes, double quotes, etc, as that is a potential problem in your URL.
                                            And it still leaves the issue with selecting a channel at will, through a trigger.
                                            • 15
                                            • 16
                                            • 17
                                            • 18
                                            • 19
                                            • 30
                                            • 31
                                            • 17 / 31
