    602 Posts 67 Posters 2.3m Views 68 Watching
      bill22
      @evroom
      it shows the following status after the modification:
      pi@raspberrypi:~ $ pm2 restart mm
      [PM2] Applying action restartProcessId on app [mm](ids: 1)
      [PM2] [mm](1) ✓
      │ Name        │ id │ mode │ status  │ ↺  │ cpu │ memory   │
      │ avm_stream  │ 2  │ fork │ stopped │ 1  │ 0%  │ 0 B      │
      │ mm          │ 1  │ fork │ online  │ 1  │ 0%  │ 2.5 MB   │
      │ omx_stream1 │ 0  │ fork │ stopped │ 31 │ 0%  │ 0 B      │
       Use `pm2 show <id|name>` to get more details about an app
      pi@raspberrypi:~ $ pm2 logs mm
      [TAILING] Tailing last 15 lines for [mm] process (change the value with --lines option)
      1|mm       | npm ERR!     /home/pi/.npm/_logs/2019-07-09T20_38_42_696Z-debug.log
      1|mm       |
      1|mm       | (electron:1742): Gtk-WARNING **: cannot open display: :0
      1|mm       | npm ERR! code ELIFECYCLE
      1|mm       | npm ERR! errno 1
      1|mm       | npm ERR! magicmirror@2.7.1 start: `sh run-start.sh`
      1|mm       | npm ERR! Exit status 1
      1|mm       | npm ERR!
      1|mm       | npm ERR! Failed at the magicmirror@2.7.1 start script.
      1|mm       | npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
      1|mm       |
      1|mm       | npm ERR! A complete log of this run can be found in:
      1|mm       | npm ERR!     /home/pi/.npm/_logs/2019-07-09T20_38_45_348Z-debug.log
      1|mm       | ATTENTION: default value of option force_s3tc_enable overridden by environment.
      1|mm       |     "--avdict",
      1|mm       |     "rtsp_transport:tcp",
      1|mm       |     "--win",
      1|mm       |     "666, 393, 1018, 635",
      1|mm       |     "--live",
      1|mm       |     "--video_queue",
      1|mm       |     "4",
      1|mm       |     "--audio_queue",
      1|mm       |     "4",
      1|mm       |     "--fps",
      1|mm       |     "25",
      1|mm       |     "rtsp://192.168.178.1:554/?avm=1&freq=394&bw=8&msys=dvbc&mtype=256qam&sr=6900&specinv=0&pids=0,16,17,18,20,266,593,594,595,598,1801,1802,1803"
      1|mm       | ]
      1|mm       | Starting PM2 for omx_stream1
      1|mm       | PM2 started for omx_stream1
      pi@raspberrypi:~ $ ps -eaf | grep omxplayer | grep -v grep
      pi        6325   813  0 23:17 ?        00:00:00 bash /usr/bin/omxplayer --avdict rtsp_transport:tcp --win 666, 393, 1018, 635 --live --video_queue 4 --audio_queue 4 --fps 25 rtsp://192.168.178.1:554/?avm=1&freq=394&bw=8&msys=dvbc&mtype=256qam&sr=6900&specinv=0&pids=0,16,17,18,20,266,593,594,595,598,1801,1802,1803
      pi        6327  6325  0 23:17 ?        00:00:00 bash /usr/bin/omxplayer --avdict rtsp_transport:tcp --win 666, 393, 1018, 635 --live --video_queue 4 --audio_queue 4 --fps 25 rtsp://192.168.178.1:554/?avm=1&freq=394&bw=8&msys=dvbc&mtype=256qam&sr=6900&specinv=0&pids=0,16,17,18,20,266,593,594,595,598,1801,1802,1803
      pi@raspberrypi:~ $ pm2 status
      │ omx_stream1 │ 0  │ fork │ online  │ 117 │ 0%  │ 2.6 MB   │
      evroomE 1 Reply Last reply
      • evroomE
        evroom @bill22
        @bill22
        Overall it looks good I would say.
        The ERR are a concern, but I do not see a connection with RTSP.
        Give the /home/pi/.npm/_logs/2019-07-09T20_38_42_696Z-debug.log and /home/pi/.npm/_logs/2019-07-09T20_38_45_348Z-debug.loga clue ?
        Or when you restart mm, the newly generated log files ?
        With $ ps -eaf | grep omxplayer | grep -v grepand pm2 status, are the PIDs for omxplayer and omx_stream1 stable, or do they change ?
        Could you do ?
        $ pstree -ap `pgrep omxplayer | head -1`; pstree -ap `pm2 status | grep omx_stream1 | awk '{print $10}'`
        MagicMirror version: 2.37.0
        • evroomE
          evroom
          The pstree command might not work when the width of your terminal is not enough.
          Make it wide enough to have pm2 status show the PID column.
            bill22
            @evroom
            i couldnt find something in the log so far…
            I may overlook something here in genera. Looks like the avm_stream is still starting on rebooting the RPI…I tried with stop and save within pm2 already…So if I reboot, the avm_stream is online again…
            │ avm_stream  │ 2  │ fork │ stopped │ 0  │ 0%  │ 0 B      │
            │ mm          │ 1  │ fork │ online  │ 0  │ 0%  │ 2.6 MB   │
            │ omx_stream1 │ 0  │ fork │ stopped │ 15 │ 0%  │ 0 B      │
            pi@raspberrypi:~ $ pstree -ap `pgrep omxplayer | head -1`; pstree -ap `pm2 status | grep omx_stream1 | awk '{print $10}'`
            systemd,1 splash
              ├─PM2 v3.5.1: God,813
              │   ├─bash,923 /home/pi/mm.sh
              │   │   └─npm,929
              │   │       ├─sh,1047 -c sh run-start.sh
              │   │       │   └─sh,1048 run-start.sh
              │   │       │       └─node,1049 /home/pi/MagicMirror/node_modules/.bin/electron js/electron.js
              │   │       │           ├─electron,1064
              │   │       │           │   ├─electron,1126
              │   │       │           │   │   └─electron,1467
              │   │       │           │   │       ├─{Chrome_ChildIOT},1473
              │   │       │           │   │       ├─{CompositorTileW},1496
              │   │       │           │   │       ├─{CompositorTileW},1501
              │   │       │           │   │       ├─{CompositorTileW},1503
              │   │       │           │   │       ├─{Compositor},1495
              │   │       │           │   │       ├─{File thread},1479
              │   │       │           │   │       ├─{GpuMemoryThread},1474
              │   │       │           │   │       ├─{ScriptStreamer },1539
              │   │       │           │   │       ├─{TaskSchedulerBa},1469
              │   │       │           │   │       ├─{TaskSchedulerBa},1470
              │   │       │           │   │       ├─{TaskSchedulerFo},1472
              │   │       │           │   │       ├─{TaskSchedulerFo},1737
              │   │       │           │   │       ├─{TaskSchedulerSe},1468
              │   │       │           │   │       └─{electron},1524
              │   │       │           │   ├─electron,1454
              │   │       │           │   │   ├─{Chrome_ChildIOT},1511
              │   │       │           │   │   ├─{TaskSchedulerBa},1507
              │   │       │           │   │   ├─{TaskSchedulerBa},1508
              │   │       │           │   │   ├─{TaskSchedulerFo},1509
              │   │       │           │   │   ├─{TaskSchedulerFo},1510
              │   │       │           │   │   ├─{TaskSchedulerSe},1506
              │   │       │           │   │   ├─{Watchdog},1505
              │   │       │           │   │   ├─{llvmpipe-0},1487
              │   │       │           │   │   ├─{llvmpipe-1},1488
              │   │       │           │   │   ├─{llvmpipe-2},1489
              │   │       │           │   │   └─{llvmpipe-3},1490
              │   │       │           │   ├─{AudioThread},1444
              │   │       │           │   ├─{CacheThread_Blo},1466
              │   │       │           │   ├─{Chrome_IOThread},1428
              │   │       │           │   ├─{CompositorTileW},1443
              │   │       │           │   ├─{CrShutdownDetec},1432
              │   │       │           │   ├─{D-Bus thread},1431
              │   │       │           │   ├─{NetworkChangeNo},1429
              │   │       │           │   ├─{TaskSchedulerBa},1434
              │   │       │           │   ├─{TaskSchedulerBa},1462
              │   │       │           │   ├─{TaskSchedulerFo},1436
              │   │       │           │   ├─{TaskSchedulerFo},1439
              │   │       │           │   ├─{TaskSchedulerSe},1433
              │   │       │           │   ├─{TaskSchedulerSi},1441
              │   │       │           │   ├─{TaskSchedulerSi},1442
              │   │       │           │   ├─{TaskSchedulerSi},1573
              │   │       │           │   ├─{electron},1191
              │   │       │           │   ├─{electron},1192
              │   │       │           │   ├─{electron},1193
              │   │       │           │   ├─{electron},1221
              │   │       │           │   ├─{electron},1414
              │   │       │           │   ├─{electron},1415
              │   │       │           │   ├─{electron},1416
              │   │       │           │   ├─{electron},1417
              │   │       │           │   ├─{electron},1453
              │   │       │           │   ├─{gdbus},1179
              │   │       │           │   ├─{gmain},1178
              │   │       │           │   ├─{inotify_reader},1430
              │   │       │           │   ├─{llvmpipe-0},1167
              │   │       │           │   ├─{llvmpipe-1},1168
              │   │       │           │   ├─{llvmpipe-2},1169
              │   │       │           │   ├─{llvmpipe-3},1170
              │   │       │           │   └─{sandbox_ipc_thr},1125
              │   │       │           ├─{node},1050
              │   │       │           ├─{node},1051
              │   │       │           ├─{node},1052
              │   │       │           ├─{node},1053
              │   │       │           ├─{node},1054
              │   │       │           └─{node},1057
              │   │       ├─{node},934
              │   │       ├─{node},935
              │   │       ├─{node},936
              │   │       ├─{node},937
              │   │       ├─{node},938
              │   │       ├─{node},945
              │   │       ├─{npm},1013
              │   │       ├─{npm},1014
              │   │       ├─{npm},1015
              │   │       └─{npm},1016
              │   ├─{PM2 v3.5.1: God},915
              │   ├─{PM2 v3.5.1: God},916
              │   ├─{PM2 v3.5.1: God},917
              │   ├─{PM2 v3.5.1: God},918
              │   ├─{node},814
              │   ├─{node},815
              │   ├─{node},816
              │   ├─{node},817
              │   ├─{node},818
              │   └─{node},819
              ├─agetty,509 --noclear tty1 linux
              ├─avahi-daemon,333
              │   └─avahi-daemon,370
              ├─bluealsa,455
              │   ├─{bactl},463
              │   ├─{gdbus},479
              │   └─{gmain},478
              ├─bluetoothd,454
              ├─cron,340 -f
              ├─dbus-daemon,323 --system --address=systemd: --nofork --nopidfile --systemd-activation
              ├─dbus-daemon,951 --fork --print-address 5 --print-pid 6 --session
              ├─dhcpcd,372 -q -b
              ├─hciattach,446 /dev/serial1 bcm43xx 921600 noflow - b8:27:eb:fc:c6:fc
              ├─lightdm,506
              │   ├─Xorg,517 :0 -seat seat0 -auth /var/run/lightdm/root/:0 -nolisten tcp vt7 -novtswitch
              │   │   ├─{InputThread},631
              │   │   ├─{llvmpipe-0},623
              │   │   ├─{llvmpipe-1},624
              │   │   ├─{llvmpipe-2},625
              │   │   └─{llvmpipe-3},626
              │   ├─lightdm,634 --session-child 14 17
              │   │   ├─lxsession,650 -s LXDE-pi -e LXDE
              │   │   │   ├─lxpanel,785 --profile LXDE-pi
              │   │   │   │   ├─chromium-browse,1766
              │   │   │   │   │   ├─chromium-browse,1792
              │   │   │   │   │   │   └─chromium-browse,1794
              │   │   │   │   │   │       ├─chromium-browse,1989
              │   │   │   │   │   │       │   ├─{Chrome_ChildIOT},2001
              │   │   │   │   │   │       │   ├─{CompositorTileW},2020
              │   │   │   │   │   │       │   ├─{CompositorTileW},2021
              │   │   │   │   │   │       │   ├─{CompositorTileW},2022
              │   │   │   │   │   │       │   ├─{Compositor},2013
              │   │   │   │   │   │       │   ├─{Font_Proxy_Thre},2003
              │   │   │   │   │   │       │   ├─{GpuMemoryThread},2002
              │   │   │   │   │   │       │   ├─{TaskSchedulerFo},2000
              │   │   │   │   │   │       │   ├─{TaskSchedulerFo},2114
              │   │   │   │   │   │       │   ├─{TaskSchedulerFo},2255
              │   │   │   │   │   │       │   ├─{TaskSchedulerFo},2256
              │   │   │   │   │   │       │   └─{TaskSchedulerSe},1997
              │   │   │   │   │   │       └─chromium-browse,2035
              │   │   │   │   │   │           ├─{Chrome_ChildIOT},2039
              │   │   │   │   │   │           ├─{CompositorTileW},2043
              │   │   │   │   │   │           ├─{CompositorTileW},2044
              │   │   │   │   │   │           ├─{CompositorTileW},2045
              │   │   │   │   │   │           ├─{Compositor},2042
              │   │   │   │   │   │           ├─{Font_Proxy_Thre},2041
              │   │   │   │   │   │           ├─{GpuMemoryThread},2040
              │   │   │   │   │   │           ├─{MemoryInfra},2091
              │   │   │   │   │   │           ├─{ScriptStreamer },2049
              │   │   │   │   │   │           ├─{TaskSchedulerFo},2038
              │   │   │   │   │   │           ├─{TaskSchedulerFo},2046
              │   │   │   │   │   │           ├─{TaskSchedulerFo},2254
              │   │   │   │   │   │           └─{TaskSchedulerSe},2036
              │   │   │   │   │   ├─chromium-browse,1824
              │   │   │   │   │   │   ├─{Chrome_ChildIOT},1886
              │   │   │   │   │   │   ├─{TaskSchedulerFo},1884
              │   │   │   │   │   │   ├─{TaskSchedulerFo},1885
              │   │   │   │   │   │   ├─{TaskSchedulerSe},1883
              │   │   │   │   │   │   ├─{Watchdog},1882
              │   │   │   │   │   │   ├─{llvmpipe-0},1877
              │   │   │   │   │   │   ├─{llvmpipe-1},1878
              │   │   │   │   │   │   ├─{llvmpipe-2},1879
              │   │   │   │   │   │   └─{llvmpipe-3},1880
              │   │   │   │   │   ├─{AudioThread},1818
              │   │   │   │   │   ├─{Bluez D-Bus thr},1809
              │   │   │   │   │   ├─{BrowserWatchdog},1825
              │   │   │   │   │   ├─{CacheThread_Blo},1821
              │   │   │   │   │   ├─{Chrome_HistoryT},1876
              │   │   │   │   │   ├─{Chrome_IOThread},1802
              │   │   │   │   │   ├─{CompositorTileW},1817
              │   │   │   │   │   ├─{CrShutdownDetec},1810
              │   │   │   │   │   ├─{NetworkChangeNo},1808
              │   │   │   │   │   ├─{TaskSchedulerFo},1816
              │   │   │   │   │   ├─{TaskSchedulerFo},2032
              │   │   │   │   │   ├─{TaskSchedulerFo},2053
              │   │   │   │   │   ├─{TaskSchedulerFo},2208
              │   │   │   │   │   ├─{TaskSchedulerSe},1797
              │   │   │   │   │   ├─{TaskSchedulerSi},1820
              │   │   │   │   │   ├─{TaskSchedulerSi},1822
              │   │   │   │   │   ├─{TaskSchedulerSi},1875
              │   │   │   │   │   ├─{TaskSchedulerSi},1881
              │   │   │   │   │   ├─{chromium-browse},1795
              │   │   │   │   │   ├─{extension_crash},1986
              │   │   │   │   │   ├─{gdbus},1807
              │   │   │   │   │   ├─{gmain},1806
              │   │   │   │   │   ├─{gpu-process_cra},1823
              │   │   │   │   │   ├─{inotify_reader},1801
              │   │   │   │   │   ├─{renderer_crash_},1894
              │   │   │   │   │   ├─{sandbox_ipc_thr},1790
              │   │   │   │   │   └─{utility_crash_u},2061
              │   │   │   │   ├─lxterminal,2148
              │   │   │   │   │   ├─bash,2150
              │   │   │   │   │   │   └─pstree,2260 -ap
              │   │   │   │   │   ├─gnome-pty-helpe,2149
              │   │   │   │   │   ├─{gdbus},2159
              │   │   │   │   │   └─{gmain},2151
              │   │   │   │   ├─oosplash,2177 --writer
              │   │   │   │   │   ├─soffice.bin,2195 --writer --splash-pipe=5
              │   │   │   │   │   │   ├─{PipeIPC},2204
              │   │   │   │   │   │   ├─{SelectionManage},2209
              │   │   │   │   │   │   ├─{gdbus},2206
              │   │   │   │   │   │   ├─{gmain},2205
              │   │   │   │   │   │   ├─{rtl_cache_wsupd},2198
              │   │   │   │   │   │   ├─{soffice.bin},2233
              │   │   │   │   │   │   ├─{soffice.bin},2234
              │   │   │   │   │   │   ├─{soffice.bin},2235
              │   │   │   │   │   │   ├─{soffice.bin},2236
              │   │   │   │   │   │   ├─{soffice.bin},2237
              │   │   │   │   │   │   ├─{soffice.bin},2238
              │   │   │   │   │   │   ├─{soffice.bin},2239
              │   │   │   │   │   │   └─{soffice.bin},2240
              │   │   │   │   │   ├─{osl_executeProc},2194
              │   │   │   │   │   └─{rtl_cache_wsupd},2190
              │   │   │   │   ├─(sh,847)
              │   │   │   │   ├─{gdbus},825
              │   │   │   │   ├─{gmain},824
              │   │   │   │   └─{menu-cache-io},895
              │   │   │   ├─lxpolkit,780
              │   │   │   │   ├─{gdbus},801
              │   │   │   │   └─{gmain},799
              │   │   │   ├─openbox,773 --config-file /home/pi/.config/openbox/lxde-pi-rc.xml
              │   │   │   ├─pcmanfm,791 --desktop --profile LXDE-pi
              │   │   │   │   ├─{gdbus},821
              │   │   │   │   └─{gmain},820
              │   │   │   ├─ssh-agent,756 x-session-manager
              │   │   │   ├─{gdbus},762
              │   │   │   └─{gmain},761
              │   │   ├─{gdbus},638
              │   │   └─{gmain},637
              │   ├─{gdbus},515
              │   └─{gmain},513
              ├─menu-cached,831 /run/user/1000/menu-cached-:0
              │   ├─{gdbus},834
              │   └─{gmain},833
              ├─polkitd,804 --no-debug
              │   ├─{gdbus},811
              │   └─{gmain},809
              ├─rngd,361 -r /dev/hwrng
              │   ├─{rngd},362
              │   ├─{rngd},363
              │   └─{rngd},364
              ├─rsyslogd,331 -n
              │   ├─{in:imklog},377
              │   ├─{in:imuxsock},376
              │   └─{rs:main Q:Reg},378
              ├─ssh-agent,803 -s
              ├─systemd,642 --user
              │   ├─(sd-pam),645
              │   ├─dbus-daemon,659 --session --address=systemd: --nofork --nopidfile --systemd-activation
              │   ├─gvfs-afc-volume,866
              │   │   ├─{gdbus},870
              │   │   ├─{gmain},868
              │   │   └─{gvfs-afc-volume},867
              │   ├─gvfs-goa-volume,858
              │   │   ├─{gdbus},860
              │   │   └─{gmain},859
              │   ├─gvfs-gphoto2-vo,854
              │   │   ├─{gdbus},857
              │   │   └─{gmain},855
              │   ├─gvfs-mtp-volume,862
              │   │   ├─{gdbus},865
              │   │   └─{gmain},863
              │   ├─gvfs-udisks2-vo,835
              │   │   ├─{gdbus},837
              │   │   └─{gmain},836
              │   ├─gvfsd,763
              │   │   ├─{gdbus},765
              │   │   └─{gmain},764
              │   ├─gvfsd-fuse,768 /run/user/1000/gvfs -f -o big_writes
              │   │   ├─{gdbus},787
              │   │   ├─{gmain},786
              │   │   ├─{gvfs-fuse-sub},792
              │   │   ├─{gvfsd-fuse},782
              │   │   └─{gvfsd-fuse},783
              │   └─gvfsd-trash,904 --spawner :1.4 /org/gtk/gvfs/exec_spaw/0
              │       ├─{gdbus},906
              │       └─{gmain},905
              ├─systemd-journal,107
              ├─systemd-logind,334
              ├─systemd-timesyn,305
              │   └─{sd-resolve},320
              ├─systemd-udevd,139
              ├─thd,322 --triggers /etc/triggerhappy/triggers.d/ --socket /run/thd.socket --user nobody --deviceglob /dev/input/event*
              ├─udisksd,838 --no-debug
              │   ├─{cleanup},852
              │   ├─{gdbus},841
              │   ├─{gmain},839
              │   └─{probing-thread},842
              ├─wpa_supplicant,327 -u -s -O /run/wpa_supplicant
              └─wpa_supplicant,422 -B -c/etc/wpa_supplicant/wpa_supplicant.conf -iwlan0 -Dnl80211,wext
             ├─(kthreadd,2)
             │   ├─(DWC Notificatio,62)
             │   ├─(SMIO,67)
             │   ├─(SMIO,189)
             │   ├─(brcmf_wdog/mmc1,239)
             │   ├─(brcmf_wq/mmc1:0,237)
             │   ├─(cfg80211,231)
             │   ├─(cpuhp/0,13)
             │   ├─(cpuhp/1,14)
             │   ├─(cpuhp/2,19)
             │   ├─(cpuhp/3,24)
             │   ├─(crypto,38)
             │   ├─(dwc_otg,61)
             │   ├─(ext4-rsv-conver,78)
             │   ├─(ext4-rsv-conver,914)
             │   ├─(ipv6_addrconf,79)
             │   ├─(irq/86-mmc1,69)
             │   ├─(iscsi_eh,60)
             │   ├─(jbd2/mmcblk0p5-,913)
             │   ├─(jbd2/mmcblk0p7-,77)
             │   ├─(kblockd,39)
             │   ├─(kcompactd0,37)
             │   ├─(kdevtmpfs,29)
             │   ├─(khungtaskd,34)
             │   ├─(krfcommd,489)
             │   ├─(ksoftirqd/0,9)
             │   ├─(ksoftirqd/1,16)
             │   ├─(ksoftirqd/2,21)
             │   ├─(ksoftirqd/3,26)
             │   ├─(kswapd0,46)
             │   ├─(kthrotld,58)
             │   ├─(kworker/0:0-event,1796)
             │   ├─(kworker/0:0H-kblo,1789)
             │   ├─(kworker/0:1-event,31)
             │   ├─(kworker/0:1H-mmc_,74)
             │   ├─(kworker/0:2-event,2231)
             │   ├─(kworker/0:2H,2147)
             │   ├─(kworker/1:0-mm_pe,1741)
             │   ├─(kworker/1:0H-kblo,1785)
             │   ├─(kworker/1:1-event,2213)
             │   ├─(kworker/1:1H-kblo,75)
             │   ├─(kworker/1:2-mm_pe,2048)
             │   ├─(kworker/1:2H-kblo,2176)
             │   ├─(kworker/2:0-event,1783)
             │   ├─(kworker/2:0H-kblo,23)
             │   ├─(kworker/2:1-event,33)
             │   ├─(kworker/2:1H-kblo,1784)
             │   ├─(kworker/2:2-event,2223)
             │   ├─(kworker/2:2H,2196)
             │   ├─(kworker/3:0-event,1742)
             │   ├─(kworker/3:0H-kblo,1772)
             │   ├─(kworker/3:1-mm_pe,2034)
             │   ├─(kworker/3:1H-kblo,73)
             │   ├─(kworker/3:2-event,68)
             │   ├─(kworker/3:2H,2189)
             │   ├─(kworker/3:3,2248)
             │   ├─(kworker/u8:0-even,7)
             │   ├─(kworker/u8:2-flus,100)
             │   ├─(kworker/u9:0-hci0,42)
             │   ├─(kworker/u9:1-hci0,448)
             │   ├─(migration/0,12)
             │   ├─(migration/1,15)
             │   ├─(migration/2,20)
             │   ├─(migration/3,25)
             │   ├─(mm_percpu_wq,8)
             │   ├─(mmal-vchiq,215)
             │   ├─(mmal-vchiq,217)
             │   ├─(mmal-vchiq,219)
             │   ├─(mmc_complete,72)
             │   ├─(netns,30)
             │   ├─(nfsiod,47)
             │   ├─(oom_reaper,35)
             │   ├─(rcu_bh,11)
             │   ├─(rcu_gp,3)
             │   ├─(rcu_par_gp,4)
             │   ├─(rcu_sched,10)
             │   ├─(rpciod,41)
             │   ├─(vchiq-keep/0,66)
             │   ├─(vchiq-recy/0,64)
             │   ├─(vchiq-slot/0,63)
             │   ├─(vchiq-sync/0,65)
             │   ├─(watchdogd,40)
             │   ├─(writeback,36)
             │   └─(xprtiod,43)
             └─systemd,1 splash
                 │   │   └─npm,929
                 │   │       │           ├─{node},1050
                 │   │       │           ├─{node},1051
                 │   │       │           ├─{node},1052
                 │   │       │           ├─{node},1053
                 │   │       │           ├─{node},1054
                 │   │       │           └─{node},1057
                 │   │       ├─{node},934
                 │   │       ├─{node},935
                 │   │       ├─{node},936
                 │   │       ├─{node},937
                 │   │       ├─{node},938
                 │   │       ├─{node},945
                 │   │       ├─{npm},1013
                 │   │       ├─{npm},1014
                 │   │       ├─{npm},1015
                 │   │       └─{npm},1016
                 │   ├─{node},814
                 │   ├─{node},815
                 │   ├─{node},816
                 │   ├─{node},817
                 │   ├─{node},818
                 │   └─{node},819
                 ├─avahi-daemon,333
                 ├─bluealsa,455
                 │   ├─{bactl},463
                 │   ├─{gdbus},479
                 │   └─{gmain},478
                 ├─bluetoothd,454
                 ├─cron,340 -f
                 ├─dhcpcd,372 -q -b
                 ├─lightdm,506
                 │   │   │   │   │   │   └─pstree,2271 -ap 0
                 │   │   │   │   ├─(sh,847)
                 │   │   │   ├─{gdbus},762
                 │   │   │   └─{gmain},761
                 │   │   ├─{gdbus},638
                 │   │   └─{gmain},637
                 │   ├─{gdbus},515
                 │   └─{gmain},513
                 │   ├─{gdbus},834
                 │   └─{gmain},833
                 │   ├─{gdbus},811
                 │   └─{gmain},809
                 │   ├─{rngd},362
                 │   ├─{rngd},363
                 │   └─{rngd},364
                 ├─rsyslogd,331 -n
                 │   ├─{in:imklog},377
                 ├─ssh-agent,803 -s
                 │   ├─(sd-pam),645
                 │   │   ├─{gdbus},870
                 │   │   ├─{gmain},868
                 │   │   ├─{gdbus},860
                 │   │   └─{gmain},859
                 │   │   ├─{gdbus},857
                 │   │   └─{gmain},855
                 │   │   ├─{gdbus},865
                 │   │   └─{gmain},863
                 │   │   ├─{gdbus},837
                 │   │   └─{gmain},836
                 │   ├─gvfsd,763
                 │   │   ├─{gdbus},765
                 │   │   └─{gmain},764
                 │   │   ├─{gdbus},787
                 │   │   ├─{gmain},786
                 │       ├─{gdbus},906
                 │       └─{gmain},905
                 ├─systemd-udevd,139
                 │   ├─{cleanup},852
                 │   ├─{gdbus},841
                 │   ├─{gmain},839
            pi@raspberrypi:~ $
            • evroomE
              evroom @bill22
              @bill22
              In order to remove avm_stream from pm2; I think you have to do:
              pm2 stop avm_stream
              pm2 delete avm_stream
              pm2 save
              pm2 status
              If pm2 status does not show the pid column, my command does not make sense.
              First stretch out the ssh window so that it shows.
              This is not good:
              pi@MagicPi:~/MagicMirror/css $ pm2 status
              │ axis │ 1  │ fork │ online │ 0 │ 0%  │ 2.5 MB   │
              │ mm   │ 0  │ fork │ online │ 0 │ 0%  │ 2.5 MB   │
              This is better:
              │ App name │ id │ version │ mode │ pid   │ status │ restart │ uptime │ cpu │ mem      │ user │ watching │
              │ axis     │ 1  │ 2.5.0   │ fork │ 14186 │ online │ 0       │ 20h    │ 0%  │ 2.5 MB   │ pi   │ disabled │
              │ mm       │ 0  │ 2.5.0   │ fork │ 14180 │ online │ 0       │ 20h    │ 0%  │ 2.5 MB   │ pi   │ disabled │
                bill22
                thanks, i removed the avm_stream.
                Below the status including the PID. Missed that before…
                │ mm                   │ 1  │ N/A│ fork │ 940 │ online  │ 0             │ 37m    │ 0%  │ 2.3 MB   │ pi   │ disabled │
                │ omx_stream1 │ 0  │ N/A         │ fork │ 0   │ stopped │ 17          │ 0          │ 0%  │ 0 B          │ pi   │ disabled │
                PIDs remain the same when I run pm2 status again
                • evroomE
                  evroom @bill22
                  @bill22
                  pm2 status will show the current status; will not restart mm & omx_stream1.
                  You can try pm2 restart mm and see what happens.
                  Repeat
                  a few times.
                  I guess that you will see different PIDs and then status stopped (with pm2 status).
                  But perhaps it will remain stable.
                    bill22
                    @evroom
                    the PIDs of omx_stream1 is changing:
                    [PM2] [mm](1) ✓
                    │ mm          │ 1  │ N/A     │ fork │ 2976 │ online  │ 1       │ 0s     │ 0%  │ 2.3 MB   │ pi   │ disabled │
                    │ mm          │ 1  │ N/A     │ fork │ 2976 │ online │ 1       │ 2m     │ 0%  │ 2.3 MB   │ pi   │ disabled │
                    │ omx_stream1 │ 0  │ N/A     │ fork │ 4609 │ online │ 58      │ 2s     │ 0%  │ 2.4 MB   │ pi   │ disabled │
                      bill22
                      @evroom
                      │ omx_stream1 │ 0  │ N/A     │ fork │ 5123 │ online │ 71      │ 1s     │ 0%  │ 2.6 MB   │ pi   │ disabled │
                      │ mm          │ 1  │ N/A     │ fork │ 2976 │ online │ 1       │ 4m     │ 0%  │ 2.3 MB   │ pi   │ disabled │
                      │ omx_stream1 │ 0  │ N/A     │ fork │ 7749 │ online │ 141     │ 1s     │ 0%  │ 2.5 MB   │ pi   │ disabled │
                      │ omx_stream1 │ 0  │ N/A     │ fork │ 7831 │ online │ 143     │ 1s     │ 0%  │ 2.5 MB   │ pi   │ disabled │
                      systemd,1 splash
                        ├─PM2 v3.5.1: God,781
                        │   ├─bash,2976 /home/pi/mm.sh
                        │   │   └─npm,2977
                        │   │       ├─sh,2991 -c sh run-start.sh
                        │   │       │   └─sh,2992 run-start.sh
                        │   │       │       └─node,2993 /home/pi/MagicMirror/node_modules/.bin/electron js/electron.js
                        │   │       │           ├─electron,3000
                        │   │       │           │   ├─electron,3002
                        │   │       │           │   │   └─electron,3039
                        │   │       │           │   │       ├─{Chrome_ChildIOT},3045
                        │   │       │           │   │       ├─{CompositorTileW},3049
                        │   │       │           │   │       ├─{CompositorTileW},3050
                        │   │       │           │   │       ├─{CompositorTileW},3051
                        │   │       │           │   │       ├─{Compositor},3048
                        │   │       │           │   │       ├─{File thread},3047
                        │   │       │           │   │       ├─{GpuMemoryThread},3046
                        │   │       │           │   │       ├─{ScriptStreamer },3071
                        │   │       │           │   │       ├─{TaskSchedulerBa},3041
                        │   │       │           │   │       ├─{TaskSchedulerBa},3042
                        │   │       │           │   │       ├─{TaskSchedulerFo},3043
                        │   │       │           │   │       ├─{TaskSchedulerFo},3044
                        │   │       │           │   │       ├─{TaskSchedulerFo},7868
                        │   │       │           │   │       ├─{TaskSchedulerSe},3040
                        │   │       │           │   │       └─{electron},3065
                        │   │       │           │   ├─electron,3036
                        │   │       │           │   │   ├─{Chrome_ChildIOT},3063
                        │   │       │           │   │   ├─{TaskSchedulerBa},3059
                        │   │       │           │   │   ├─{TaskSchedulerBa},3060
                        │   │       │           │   │   ├─{TaskSchedulerFo},3061
                        │   │       │           │   │   ├─{TaskSchedulerFo},3062
                        │   │       │           │   │   ├─{TaskSchedulerSe},3058
                        │   │       │           │   │   ├─{Watchdog},3057
                        │   │       │           │   │   ├─{llvmpipe-0},3053
                        │   │       │           │   │   ├─{llvmpipe-1},3054
                        │   │       │           │   │   ├─{llvmpipe-2},3055
                        │   │       │           │   │   └─{llvmpipe-3},3056
                        │   │       │           │   ├─{AudioThread},3033
                        │   │       │           │   ├─{CacheThread_Blo},3038
                        │   │       │           │   ├─{Chrome_IOThread},3017
                        │   │       │           │   ├─{CompositorTileW},3032
                        │   │       │           │   ├─{CrShutdownDetec},3021
                        │   │       │           │   ├─{D-Bus thread},3019
                        │   │       │           │   ├─{NetworkChangeNo},3018
                        │   │       │           │   ├─{TaskSchedulerBa},3023
                        │   │       │           │   ├─{TaskSchedulerBa},3024
                        │   │       │           │   ├─{TaskSchedulerFo},3025
                        │   │       │           │   ├─{TaskSchedulerFo},3067
                        │   │       │           │   ├─{TaskSchedulerFo},8081
                        │   │       │           │   ├─{TaskSchedulerSe},3022
                        │   │       │           │   ├─{TaskSchedulerSi},3030
                        │   │       │           │   ├─{TaskSchedulerSi},3031
                        │   │       │           │   ├─{TaskSchedulerSi},3073
                        │   │       │           │   ├─{electron},3008
                        │   │       │           │   ├─{electron},3009
                        │   │       │           │   ├─{electron},3010
                        │   │       │           │   ├─{electron},3011
                        │   │       │           │   ├─{electron},3013
                        │   │       │           │   ├─{electron},3014
                        │   │       │           │   ├─{electron},3015
                        │   │       │           │   ├─{electron},3016
                        │   │       │           │   ├─{electron},3034
                        │   │       │           │   ├─{gdbus},3007
                        │   │       │           │   ├─{gmain},3006
                        │   │       │           │   ├─{inotify_reader},3020
                        │   │       │           │   └─{sandbox_ipc_thr},3001
                        │   │       │           ├─{node},2994
                        │   │       │           ├─{node},2995
                        │   │       │           ├─{node},2996
                        │   │       │           ├─{node},2997
                        │   │       │           ├─{node},2998
                        │   │       │           └─{node},2999
                        │   │       ├─{node},2978
                        │   │       ├─{node},2979
                        │   │       ├─{node},2980
                        │   │       ├─{node},2981
                        │   │       ├─{node},2982
                        │   │       ├─{node},2983
                        │   │       ├─{npm},2986
                        │   │       ├─{npm},2987
                        │   │       ├─{npm},2988
                        │   │       └─{npm},2989
                        │   ├─bash,8279 /usr/bin/omxplayer --avdict rtsp_transport:tcp --win 666, 361, 1018, 603 --live --video_queue 4 --audio_queue 4 --fps 25...
                        │   ├─{PM2 v3.5.1: God},919
                        │   ├─{node},784
                        │   ├─{node},785
                        │   ├─{node},786
                        │   ├─{node},787
                        │   ├─{node},788
                        │   └─{node},789
                        ├─agetty,502 --noclear tty1 linux
                        ├─avahi-daemon,364
                        │   └─avahi-daemon,386
                        ├─bluealsa,607
                        │   ├─{bactl},633
                        │   ├─{gdbus},635
                        │   └─{gmain},634
                        ├─bluetoothd,558
                        ├─cron,358 -f
                        ├─dbus-daemon,365 --system --address=systemd: --nofork --nopidfile --systemd-activation
                        ├─dbus-daemon,968 --fork --print-address 5 --print-pid 6 --session
                        ├─dhcpcd,413 -q -b
                        ├─hciattach,539 /dev/serial1 bcm43xx 921600 noflow - b8:27:eb:fc:c6:fc
                        ├─lightdm,449
                        │   ├─Xorg,511 :0 -seat seat0 -auth /var/run/lightdm/root/:0 -nolisten tcp vt7 -novtswitch
                        │   │   ├─{InputThread},653
                        │   │   ├─{llvmpipe-0},645
                        │   │   ├─{llvmpipe-1},646
                        │   │   ├─{llvmpipe-2},647
                        │   │   └─{llvmpipe-3},648
                        │   ├─lightdm,656 --session-child 14 17
                        │   │   ├─lxsession,672 -s LXDE-pi -e LXDE
                        │   │   │   ├─lxpanel,817 --profile LXDE-pi
                        │   │   │   │   ├─chromium-browse,1784
                        │   │   │   │   │   ├─chromium-browse,1805
                        │   │   │   │   │   │   └─chromium-browse,1808
                        │   │   │   │   │   │       ├─chromium-browse,1967
                        │   │   │   │   │   │       │   ├─{Chrome_ChildIOT},1980
                        │   │   │   │   │   │       │   ├─{CompositorTileW},2029
                        │   │   │   │   │   │       │   ├─{CompositorTileW},2030
                        │   │   │   │   │   │       │   ├─{CompositorTileW},2031
                        │   │   │   │   │   │       │   ├─{Compositor},2024
                        │   │   │   │   │   │       │   ├─{Font_Proxy_Thre},1984
                        │   │   │   │   │   │       │   ├─{GpuMemoryThread},1983
                        │   │   │   │   │   │       │   ├─{TaskSchedulerFo},1979
                        │   │   │   │   │   │       │   ├─{TaskSchedulerFo},2830
                        │   │   │   │   │   │       │   └─{TaskSchedulerSe},1976
                        │   │   │   │   │   │       └─chromium-browse,2050
                        │   │   │   │   │   │           ├─{Chrome_ChildIOT},2054
                        │   │   │   │   │   │           ├─{CompositorTileW},2058
                        │   │   │   │   │   │           ├─{CompositorTileW},2059
                        │   │   │   │   │   │           ├─{CompositorTileW},2060
                        │   │   │   │   │   │           ├─{Compositor},2057
                        │   │   │   │   │   │           ├─{Font_Proxy_Thre},2056
                        │   │   │   │   │   │           ├─{GpuMemoryThread},2055
                        │   │   │   │   │   │           ├─{Media},2463
                        │   │   │   │   │   │           ├─{MemoryInfra},2104
                        │   │   │   │   │   │           ├─{ScriptStreamer },2088
                        │   │   │   │   │   │           ├─{TaskSchedulerFo},2053
                        │   │   │   │   │   │           ├─{TaskSchedulerFo},2958
                        │   │   │   │   │   │           ├─{TaskSchedulerFo},6650
                        │   │   │   │   │   │           ├─{TaskSchedulerFo},7786
                        │   │   │   │   │   │           └─{TaskSchedulerSe},2051
                        │   │   │   │   │   ├─chromium-browse,1837
                        │   │   │   │   │   │   ├─{Chrome_ChildIOT},1899
                        │   │   │   │   │   │   ├─{TaskSchedulerFo},1897
                        │   │   │   │   │   │   ├─{TaskSchedulerFo},1898
                        │   │   │   │   │   │   ├─{TaskSchedulerSe},1896
                        │   │   │   │   │   │   ├─{Watchdog},1895
                        │   │   │   │   │   │   ├─{llvmpipe-0},1890
                        │   │   │   │   │   │   ├─{llvmpipe-1},1891
                        │   │   │   │   │   │   ├─{llvmpipe-2},1892
                        │   │   │   │   │   │   └─{llvmpipe-3},1893
                        │   │   │   │   │   ├─{AudioThread},1831
                        │   │   │   │   │   ├─{Bluez D-Bus thr},1822
                        │   │   │   │   │   ├─{BrowserWatchdog},1838
                        │   │   │   │   │   ├─{CacheThread_Blo},1834
                        │   │   │   │   │   ├─{Chrome_HistoryT},1889
                        │   │   │   │   │   ├─{Chrome_IOThread},1815
                        │   │   │   │   │   ├─{CompositorTileW},1830
                        │   │   │   │   │   ├─{CrShutdownDetec},1823
                        │   │   │   │   │   ├─{LevelDBEnv},2146
                        │   │   │   │   │   ├─{NetworkChangeNo},1821
                        │   │   │   │   │   ├─{TaskSchedulerFo},2044
                        │   │   │   │   │   ├─{TaskSchedulerFo},2671
                        │   │   │   │   │   ├─{TaskSchedulerFo},2832
                        │   │   │   │   │   ├─{TaskSchedulerFo},7990
                        │   │   │   │   │   ├─{TaskSchedulerSe},1810
                        │   │   │   │   │   ├─{TaskSchedulerSi},1833
                        │   │   │   │   │   ├─{TaskSchedulerSi},1835
                        │   │   │   │   │   ├─{TaskSchedulerSi},1888
                        │   │   │   │   │   ├─{TaskSchedulerSi},1894
                        │   │   │   │   │   ├─{chromium-browse},1809
                        │   │   │   │   │   ├─{extension_crash},1966
                        │   │   │   │   │   ├─{gdbus},1820
                        │   │   │   │   │   ├─{gmain},1819
                        │   │   │   │   │   ├─{gpu-process_cra},1836
                        │   │   │   │   │   ├─{inotify_reader},1814
                        │   │   │   │   │   ├─{renderer_crash_},1904
                        │   │   │   │   │   └─{sandbox_ipc_thr},1803
                        │   │   │   │   ├─lxterminal,2945
                        │   │   │   │   │   ├─bash,2947
                        │   │   │   │   │   │   └─pstree,8300 -ap
                        │   │   │   │   │   ├─gnome-pty-helpe,2946
                        │   │   │   │   │   ├─{gdbus},2955
                        │   │   │   │   │   └─{gmain},2948
                        │   │   │   │   ├─oosplash,2160 --writer
                        │   │   │   │   │   ├─soffice.bin,2178 --writer --splash-pipe=5
                        │   │   │   │   │   │   ├─{PipeIPC},2188
                        │   │   │   │   │   │   ├─{SelectionManage},2193
                        │   │   │   │   │   │   ├─{gdbus},2191
                        │   │   │   │   │   │   ├─{gmain},2190
                        │   │   │   │   │   │   ├─{rtl_cache_wsupd},2182
                        │   │   │   │   │   │   ├─{soffice.bin},2197
                        │   │   │   │   │   │   ├─{soffice.bin},2198
                        │   │   │   │   │   │   ├─{soffice.bin},2199
                        │   │   │   │   │   │   ├─{soffice.bin},2200
                        │   │   │   │   │   │   ├─{soffice.bin},2201
                        │   │   │   │   │   │   ├─{soffice.bin},2202
                        │   │   │   │   │   │   ├─{soffice.bin},2203
                        │   │   │   │   │   │   └─{soffice.bin},2204
                        │   │   │   │   │   ├─{osl_executeProc},2177
                        │   │   │   │   │   └─{rtl_cache_wsupd},2172
                        │   │   │   │   ├─(sh,864)
                        │   │   │   │   ├─{gdbus},844
                        │   │   │   │   ├─{gmain},843
                        │   │   │   │   └─{menu-cache-io},921
                        │   │   │   ├─lxpolkit,809
                        │   │   │   │   ├─{gdbus},832
                        │   │   │   │   └─{gmain},831
                        │   │   │   ├─openbox,807 --config-file /home/pi/.config/openbox/lxde-pi-rc.xml
                        │   │   │   ├─pcmanfm,820 --desktop --profile LXDE-pi
                        │   │   │   │   ├─leafpad,1770 /home/pi/omxplayer.log
                        │   │   │   │   │   ├─{gdbus},1772
                        │   │   │   │   │   └─{gmain},1771
                        │   │   │   │   ├─leafpad,2133 /home/pi/.npm/_logs/2019-07-11T21_30_10_606Z-debug.log
                        │   │   │   │   │   ├─{gdbus},2135
                        │   │   │   │   │   └─{gmain},2134
                        │   │   │   │   ├─{gdbus},846
                        │   │   │   │   └─{gmain},845
                        │   │   │   ├─ssh-agent,778 x-session-manager
                        │   │   │   ├─{gdbus},791
                        │   │   │   └─{gmain},790
                        │   │   ├─{gdbus},660
                        │   │   └─{gmain},659
                        │   ├─{gdbus},453
                        │   └─{gmain},451
                        ├─menu-cached,853 /run/user/1000/menu-cached-:0
                        │   ├─{gdbus},856
                        │   └─{gmain},855
                        ├─polkitd,835 --no-debug
                        │   ├─{gdbus},840
                        │   └─{gmain},838
                        ├─rngd,409 -r /dev/hwrng
                        │   ├─{rngd},410
                        │   ├─{rngd},411
                        │   └─{rngd},412
                        ├─rsyslogd,359 -n
                        │   ├─{in:imklog},389
                        │   ├─{in:imuxsock},388
                        │   └─{rs:main Q:Reg},390
                        ├─ssh-agent,830 -s
                        ├─systemd,664 --user
                        │   ├─(sd-pam),667
                        │   ├─dbus-daemon,681 --session --address=systemd: --nofork --nopidfile --systemd-activation
                        │   ├─gvfs-afc-volume,888
                        │   │   ├─{gdbus},892
                        │   │   ├─{gmain},890
                        │   │   └─{gvfs-afc-volume},889
                        │   ├─gvfs-goa-volume,880
                        │   │   ├─{gdbus},882
                        │   │   └─{gmain},881
                        │   ├─gvfs-gphoto2-vo,876
                        │   │   ├─{gdbus},879
                        │   │   └─{gmain},877
                        │   ├─gvfs-mtp-volume,884
                        │   │   ├─{gdbus},887
                        │   │   └─{gmain},885
                        │   ├─gvfs-udisks2-vo,857
                        │   │   ├─{gdbus},863
                        │   │   └─{gmain},862
                        │   ├─gvfsd,792
                        │   │   ├─{gdbus},794
                        │   │   └─{gmain},793
                        │   ├─gvfsd-fuse,797 /run/user/1000/gvfs -f -o big_writes
                        │   │   ├─{gdbus},814
                        │   │   ├─{gmain},813
                        │   │   ├─{gvfs-fuse-sub},821
                        │   │   ├─{gvfsd-fuse},811
                        │   │   └─{gvfsd-fuse},812
                        │   └─gvfsd-trash,930 --spawner :1.4 /org/gtk/gvfs/exec_spaw/0
                        │       ├─{gdbus},933
                        │       └─{gmain},932
                        ├─systemd-journal,103
                        ├─systemd-logind,361
                        ├─systemd-timesyn,324
                        │   └─{sd-resolve},360
                        ├─systemd-udevd,137
                        ├─thd,395 --triggers /etc/triggerhappy/triggers.d/ --socket /run/thd.socket --user nobody --deviceglob /dev/input/event*
                        ├─udisksd,869 --no-debug
                        │   ├─{cleanup},874
                        │   ├─{gdbus},872
                        │   ├─{gmain},870
                        │   └─{probing-thread},873
                        ├─wpa_supplicant,400 -u -s -O /run/wpa_supplicant
                        └─wpa_supplicant,457 -B -c/etc/wpa_supplicant/wpa_supplicant.conf -iwlan0 -Dnl80211,wext
                      bash,8330 /usr/bin/omxplayer --avdict rtsp_transport:tcp --win 666, 361, 1018, 603 --live --video_queue 4 --audio_queue 4 --fps 25...
                        └─bash,8340 /usr/bin/omxplayer --avdict rtsp_transport:tcp --win 666, 361, 1018, 603 --live --video_queue 4 --audio_queue 4 --fps 25...
                            └─node,8341 /home/pi/MagicMirror/node_modules/.bin/which xset
                                ├─{node},8342
                                ├─{node},8343
                                ├─{node},8344
                                ├─{node},8345
                                ├─{node},8346
                                └─{node},8347
                      systemd,1 splash
                        │   │   └─npm,2977
                        │   │       │           │   │       ├─{TaskSchedulerFo},8553
                        │   │       │           ├─{node},2994
                        │   │       │           ├─{node},2995
                        │   │       │           ├─{node},2996
                        │   │       │           ├─{node},2997
                        │   │       │           ├─{node},2998
                        │   │       │           └─{node},2999
                        │   │       ├─{node},2978
                        │   │       ├─{node},2979
                        │   │       ├─{node},2980
                        │   │       ├─{node},2981
                        │   │       ├─{node},2982
                        │   │       ├─{node},2983
                        │   │       ├─{npm},2986
                        │   │       ├─{npm},2987
                        │   │       ├─{npm},2988
                        │   │       └─{npm},2989
                        │   ├─bash,10219 /usr/bin/omxplayer --avdict rtsp_transport:tcp --win 666, 361, 1018, 603 --live --video_queue 4 --audio_queue 4 --fps 25...
                        │   │   └─bash,10221 /usr/bin/omxplayer --avdict rtsp_transport:tcp --win 666, 361, 1018, 603 --live --video_queue 4 --audio_queue 4 --fps 25...
                        │   │       └─node,10222 /home/pi/MagicMirror/node_modules/.bin/which fbset
                        │   │           ├─{node},10223
                        │   │           ├─{node},10224
                        │   │           ├─{node},10225
                        │   │           ├─{node},10226
                        │   │           ├─{node},10227
                        │   │           └─{node},10231
                        │   ├─{node},784
                        │   ├─{node},785
                        │   ├─{node},786
                        │   ├─{node},787
                        │   ├─{node},788
                        │   └─{node},789
                        ├─avahi-daemon,364
                        ├─bluealsa,607
                        │   ├─{bactl},633
                        │   ├─{gdbus},635
                        │   └─{gmain},634
                        ├─bluetoothd,558
                        ├─cron,358 -f
                        ├─dhcpcd,413 -q -b
                        ├─lightdm,449
                        │   │   │   │   │   │   └─pstree,10232 -ap
                        │   │   │   │   ├─(sh,864)
                        │   │   │   ├─{gdbus},791
                        │   │   │   └─{gmain},790
                        │   │   ├─{gdbus},660
                        │   │   └─{gmain},659
                        │   ├─{gdbus},453
                        │   └─{gmain},451
                        │   ├─{gdbus},856
                        │   └─{gmain},855
                        │   ├─{gdbus},840
                        │   └─{gmain},838
                        │   ├─{rngd},410
                        │   ├─{rngd},411
                        │   └─{rngd},412
                        ├─rsyslogd,359 -n
                        │   ├─{in:imklog},389
                        ├─ssh-agent,830 -s
                        │   ├─(sd-pam),667
                        │   │   ├─{gdbus},892
                        │   │   ├─{gmain},890
                        │   │   ├─{gdbus},882
                        │   │   └─{gmain},881
                        │   │   ├─{gdbus},879
                        │   │   └─{gmain},877
                        │   │   ├─{gdbus},887
                        │   │   └─{gmain},885
                        │   │   ├─{gdbus},863
                        │   │   └─{gmain},862
                        │   ├─gvfsd,792
                        │   │   ├─{gdbus},794
                        │   │   └─{gmain},793
                        │   │   ├─{gdbus},814
                        │   │   ├─{gmain},813
                        │       ├─{gdbus},933
                        │       └─{gmain},932
                        ├─systemd-udevd,137
                        │   ├─{cleanup},874
                        │   ├─{gdbus},872
                        │   ├─{gmain},870
                      • evroomE
                        evroom @bill22
                        @bill22
                        And after a little while, does it say stopped?
                        And what does
                        say?
                        If pm2 status has a pid, can you do
                        pstree -ap < pid >
                        Iso < pid > put the pid number from pm2 status.
                          bill22
                          @evroom
                          omx_stream1 remain online, but the uptime shows 0s only (mm is up for 36 min):
                          │ mm          │ 1  │ N/A     │ fork │ 2976  │ online │ 1       │ 36m    │ 0%  │ 2.3 MB   │ pi   │ disabled │
                          │ omx_stream1 │ 0  │ N/A     │ fork │ 10391 │ online │ 1073    │ 0s     │ 0%  │ 2.2 MB   │ pi   │ disabled │
                          pi        1770   820  0 18:17 ?        00:00:04 leafpad /home/pi/omxplayer.log
                          pi       13794   781  1 20:05 ?        00:00:00 bash /usr/bin/omxplayer --avdict rtsp_transport:tcp --win 666, 361, 1018, 603 --live --video_queue 4 --audio_queue 4 --fps 25 rtsp://192.168.178.1:554/?avm=1&freq=394&bw=8&msys=dvbc&mtype=256qam&sr=6900&specinv=0&pids=0,16,17,18,20,266,593,594,595,598,1801,1802,1803
                          pi       13823 13794  0 20:05 ?        00:00:00 /usr/bin/omxplayer.bin --avdict rtsp_transport:tcp --win 666, 361, 1018, 603 --live --video_queue 4 --audio_queue 4 --fps 25 rtsp://192.168.178.1:554/?avm=1&freq=394&bw=8&msys=dvbc&mtype=256qam&sr=6900&specinv=0&pids=0,16,17,18,20,266,593,594,595,598,1801,1802,1803
                          pi@raspberrypi:~ $
                          tried to use
                          pstree -ap < pid >
                          but the PID is constantly changing; therefore no output
                          • evroomE
                            evroom @bill22
                            @bill22
                            To be honest, I am lost, out of ideas.
                            I tried to get the module running myself again, but I cannot even get Bucks Bunny to eat his carrot.
                            I would need to setup MM completely new for it to work I guess.
                            At the moment you are left with the option of running it stand-alone using avm_stream, like I do
                            How where you thinking of using the module should it work?
                            Changing channels would still be a challenge, right?
                              bill22
                              @evroom
                              seems to be quite tricky with that stream…
                              But thank you for all your efforts so far and again great that we did it at least to run stand alone…!
                              You are right, channel changing options seems to be a limitation using avm_stream. I wonder if there is a way of “operating” the avm_stream, at least to switch one particular channel/stream on and off without using the terminal…?
                              evroomE 2 Replies Last reply
                              • evroomE
                                evroom @bill22
                                @bill22
                                I will look if there is a module that can trigger linux commands at will.
                                Would be interested in that myself.
                                  bill22
                                  @evroom
                                  if we could find one, it could be probably used to start/stop the stream. On the other hand it could be an option to define several “stand alone streams” and call those individually. Position of the streams could be even offset to each other…Just a thought…
                                  • evroomE
                                    evroom @bill22
                                    @bill22
                                    Btw, do you “fancy” stuff like Voice Control or Alexa ?
                                    I don’t, but those would be modules that could trigger something.
                                      bill22
                                      @evroom
                                      me neither
                                      • evroomE
                                        evroom @bill22
                                        @bill22
                                        I used this Sunday to setup a second Pi, whilst watching F1.
                                        Used a new SD, installed Debian Buster and Magic Mirror v2.8.0.
                                        After I made sure I did not have any errors after rebooting, restarting MM, etc, I setup MMM-RTSPStream.
                                        It now works for Bucks Bunny, my IP cam and my SAT receiver.
                                        I can even rotate 2 SAT channels.
                                        I also tested the little fix with --audio_queue 4and that works to (although I cannot check audio, as I have no speaker).
                                        It does not say that this method will work for you (my RTSP was dead as a dodo), but it could be something to consider.
                                        I will play a bit with single quotes, double quotes, etc, as that is a potential problem in your URL.
                                        And it still leaves the issue with selecting a channel at will, through a trigger.
                                          bill22
                                          @evroom
                                          Hi and sorry for the late response.
                                          Sounds pretty good and promising!
                                          How do you “rotate” your SAT channels? Does it change based on time (after x seconds)?
                                          For me it could be good enough to have a few channels to change, of course better to select from a small list.
                                          • evroomE
                                            evroom @bill22
                                            @bill22
                                            In the config part add
                                            rotateStreams: true,
                                            rotateStreamTimeout: 60,
                                            and add 2 or more streams (stream1 and stream2).
                                            • 16
                                            • 17
                                            • 18
                                            • 19
                                            • 20
                                            • 30
                                            • 31
                                            • 18 / 31
