    602 Posts 67 Posters 2.3m Views 68 Watching
      bill22
      @evroom
      me neither
      • evroomE Offline
        evroom @bill22
        @bill22
        I used this Sunday to setup a second Pi, whilst watching F1.
        Used a new SD, installed Debian Buster and Magic Mirror v2.8.0.
        After I made sure I did not have any errors after rebooting, restarting MM, etc, I setup MMM-RTSPStream.
        It now works for Bucks Bunny, my IP cam and my SAT receiver.
        I can even rotate 2 SAT channels.
        I also tested the little fix with --audio_queue 4and that works to (although I cannot check audio, as I have no speaker).
        It does not say that this method will work for you (my RTSP was dead as a dodo), but it could be something to consider.
        I will play a bit with single quotes, double quotes, etc, as that is a potential problem in your URL.
        And it still leaves the issue with selecting a channel at will, through a trigger.
        MagicMirror version: 2.37.0
          bill22
          @evroom
          Hi and sorry for the late response.
          Sounds pretty good and promising!
          How do you “rotate” your SAT channels? Does it change based on time (after x seconds)?
          For me it could be good enough to have a few channels to change, of course better to select from a small list.
          • evroomE Offline
            evroom @bill22
            @bill22
            In the config part add
            rotateStreams: true,
            rotateStreamTimeout: 60,
            and add 2 or more streams (stream1 and stream2).
            • BKeyportB Offline
              BKeyport Module Developer
              Silly question - is there a way within the RTSP protocal to detect when the camera detects motion, so you can trigger something? What I was thinking is to flash the screen background if the camera sees motion…
              Thanks!
              • twosquirrelsT Offline
                twosquirrels
                Is there a way to hide the play/pause button? I’m not using a mouse on my mirror so it’s useless. Also, i’s creating its own separate gigantic white box that doesn’t line up with my actual video stream (which I have to force its position using moduleOffset).
                • BKeyportB Offline
                  The white box is easy to get rid of:
                  In ~/MagicMirror/css/custom.css
                  /* This removes the white border around the RTSP feed(s). */
                  .MMM-RTSPStream .innerWrapper {
                    border: 0;
                  As far as the play button, I’ve never seen it, so I don’t know how to get rid of it, I don’t use keyboard or mouse on my mirror.
                  FYI, other css that might be useful:
                  /* This shrinks the left and right regions so that RTSPStream don't overlap. */
                  .region.right .module-content,
                  .region.left .module-content {
                    min-width: 450px;
                    max-width: 450px;
                  – B
                  twosquirrelsT 1 Reply Last reply Reply Quote 0
                    twosquirrels @BKeyport
                    @BKeyport That worked to remove the white box, thanks!
                    I’m still struggling with getting the module to just show where I want it. I don’t know why it doesn’t just listen to “position” like every other module where I can tell them all to be top_right and they’d all line up in the appropriate order. I’m fighting with moduleOffset entering random numbers to see if I can find a decent spot, but it still overlaps, causes indentation, and is just a mess. Then often times the module will just disappear after being on screen for a couple minutes.
                    • BKeyportB Offline
                      Odd - I’m having no problem moving it around - although, if you’re using OMXPlayer, it’s overlaying on top of the screen, it won’t play nice with other modules in the same position…
                      • O Offline
                        osnapus
                        Hello, I’m Peter,
                        when I add RTSTStream to my MagicMirror, I have a little problem with RTSPStream module.
                        When display is in normal mode on 27’ screen, everything is ok, picture from Cam is good, normal dimensions etc
                        https://photos.app.goo.gl/czoZvwryGmqfJRDg6
                        But when in /boot/config.txt in rpi3 the display_rotation=1, picture form cam is cut like on screen.
                        https://photos.app.goo.gl/VRycUb7zMw9LQVxh6
                        Someone could help me with this problem?
                        Many thanks to You All
                        Peter
                        buzzkcB 1 Reply Last reply Reply Quote 0
                        • buzzkcB Offline
                          buzzkc @osnapus
                          @osnapus
                          Try using the GL driver to rotate…
                          https://github.com/michmich/magicmirror/wiki/configuring-the-raspberry-pi#enable-the-open-gl-driver-to-decrease-electrons-cpu-usage
                          I’ll post my config.txt and autostart settings tonight, don’t have access to them right now.
                          Darren
                          My Build: https://forum.magicmirror.builders/topic/11153/new-non-mirror
                            acimail01
                            Is it possible to define a stream for playing a local file (e.g. .mp4 or .avi)?
                              acimail01
                              works with
                              			module: "MMM-RTSPStream",
                              			position: "middle_center",
                              				autoStart			: true,
                              				rotateStreams		: false,
                              				rotateStreamTimeout	: 30,
                              				moduleWidth			: 354,
                              				moduleHeight		: 240,
                              				localPlayer			: 'omxplayer',
                              				shutdownDelay		: 0,
                              					stream1: {
                              						url: 'file:///home/pi/MagicMirror/modules/MMM-RTSPStream/Videos/Feuer.mp4',
                              but no sound !
                              in bash console works with: omxplayer -o alsa Feuer.mp4
                              How to set hdmi sound as default ?
                                p4lsec
                                Just wanted to cross-post this in case people are looking in this thread for a way to monitor and restart streams that have stopped:
                                https://forum.magicmirror.builders/topic/11828/short-script-to-monitor-and-restart-your-mmm-rtspstreams
                                • K Offline
                                  kris1208
                                  hello, I have a problem with this module, I have the displays which are truncated and this since the update.
                                  bonjour, j’ai un probleme avec ce module, j’ai les affichages qui sont tronqué et ce depuis la mise a jour.
                                  Merci.
                                  • K Offline
                                    kris1208
                                    nobody to tell me how to solve my cut image problem? Thank you
                                    • evroomE Offline
                                      evroom @kris1208
                                      @kris1208
                                      Perhaps you can share the config.js part for MMM-RTSPStream with us?
                                      The pm2 log output for this module is useful too.
                                      The part where it shows the applied coordinates.
                                      • K Offline
                                        kris1208
                                        @evroom said in [MMM-RTSPStream] - Video Streaming from Live Feeds & Security Cameras:
                                        Thank you for your response, could you tell me the file I need to post to you?
                                        module: “MMM-RTSPStream”,
                                        position: “top_center”,
                                        rotateStreamTimeout: 20, // Seconds
                                        stream1: {
                                        url: “rtsp://MDP@192.168.1.16/MediaInput/h264”
                                        stream2: {
                                        url: “rtsp://MDP@192.168.1.17/12”
                                        • evroomE Offline
                                          evroom @kris1208
                                          @kris1208
                                          Hi, bonjour, to be honest I do not see the problem right away. With truncated you mean you expect to see more? Of the top stream or the bottom stream, or both? What resolution(s) do you expect to see?
                                          I suppose you followed the instructions from this repository:
                                          https://github.com/shbatm/MMM-RTSPStream
                                          Including the “To use this module, use the configuration builder tool included.” part to produce a recommended config for your stream(s).
                                          I think your config defaults to the vlc player. Could you please do:
                                          ps -eaf | grep -v grep | egrep 'omxplayer|vlc'
                                          If you (re)start MagicMirror (or mm), then you will find some MMM-RTSPStream module related info.
                                          pm2 logs --lines 200
                                          It will start with something like this:
                                          Starting stream stream1 with args:
                                          I personally use omxplayer, but standalone, without using MMM-RTSPStream. Since it is an overlay anyway, I feel I can control it more.
                                          Good luck gathering the information.
                                          • K Offline
                                            kris1208
                                            ps -eaf | grep -v grep | egrep ‘omxplayer|vlc’
                                            0|mm | Whoops! There was an uncaught exception…
                                            0|mm | TypeError: Cannot convert undefined or null to object
                                            0|mm | at Function.keys ()
                                            0|mm | at stopProcs (/home/pi/MagicMirror/modules/MMM-RTSPStream/node_helper.js:469:32)
                                            0|mm | at pm2.list (/home/pi/MagicMirror/modules/MMM-RTSPStream/node_helper.js:498:17)
                                            0|mm | at /home/pi/MagicMirror/modules/MMM-RTSPStream/node_modules/pm2/lib/API.js:606:19
                                            0|mm | at /home/pi/MagicMirror/modules/MMM-RTSPStream/node_modules/pm2-axon-rpc/lib/client.js:45:10
                                            0|mm | at Parser. (/home/pi/MagicMirror/modules/MMM-RTSPStream/node_modules/pm2-axon/lib/sockets/req.js:67:8)
                                            0|mm | at Parser.emit (events.js:182:13)
                                            0|mm | at Parser._write (/home/pi/MagicMirror/modules/MMM-RTSPStream/node_modules/amp/lib/stream.js:91:16)
                                            0|mm | at doWrite (_stream_writable.js:410:12)
                                            0|mm | at writeOrBuffer (_stream_writable.js:394:5)
                                            0|mm | MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                                            0|mm | If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                                            0|mm | ATTENTION: default value of option force_s3tc_enable overridden by environment.
                                            0|mm | Create new news fetcher for url: https://www.bfmtv.com/rss/info/flux-rss/flux-toutes-les-actualites/ - Interval: 300000
                                            0|mm | Starting stream stream1 using VLC with args --width 352 --height 242 -I dummy --video-on-top --no-video-deco --no-embedded-video --video-title=stream1 rtsp://MDP@192.168.1.16/MediaInput/h264…
                                            0|mm | Starting stream stream2 using VLC with args --width 352 --height 242 -I dummy --video-on-top --no-video-deco --no-embedded-video --video-title=stream2 rtsp://MDP@192.168.1.17/12…
                                            0|mm | DP2: Running window resizers…
                                            0|mm | at stopProcs (/home/pi/MagicMirror/modules/MMM-RTSPStream/node_ helper.js:469:32)
                                            0|mm | at pm2.list (/home/pi/MagicMirror/modules/MMM-RTSPStream/node_h elper.js:498:17)
                                            0|mm | at /home/pi/MagicMirror/modules/MMM-RTSPStream/node_modules/pm2 /lib/API.js:606:19
                                            0|mm | at /home/pi/MagicMirror/modules/MMM-RTSPStream/node_modules/pm2 -axon-rpc/lib/client.js:45:10
                                            0|mm | at Parser. (/home/pi/MagicMirror/modules/MMM-RTSPStr eam/node_modules/pm2-axon/lib/sockets/req.js:67:8)
                                            0|mm | at Parser._write (/home/pi/MagicMirror/modules/MMM-RTSPStream/n ode_modules/amp/lib/stream.js:91:16)
                                            0|mm | npm ERR! code ELIFECYCLE
                                            0|mm | npm ERR! errno 1
                                            0|mm | npm ERR! magicmirror@2.9.0 start: sh run-start.sh
                                            0|mm | npm ERR! Exit status 1
                                            0|mm | npm ERR!
                                            0|mm | npm ERR! Failed at the magicmirror@2.9.0 start script.
                                            0|mm | npm ERR! This is probably not a problem with npm. There is likely a dditional logging output above.
                                            0|mm |
                                            0|mm | npm ERR! A complete log of this run can be found in:
                                            0|mm | npm ERR! /home/pi/.npm/logs/2019-12-27T19_17_29_282Z-debug.log
                                            0|mm | getrandom indicates that the entropy pool has not been initialized. Rather than continue with poor entropy, this process will block until entropy i s available.
                                            helper.js:469:32)
                                            0|mm | at writeOrBuffer (stream_writable.js:394:5)
                                            helper.js:469:32)
                                            0|mm | fatal: unable to access ‘https://github.com/shbatm/MMM-RTSPStream.g it/’: Could not resolve host: github.com
                                            0|mm |
                                            0|mm | fatal: unable to access ‘https://github.com/prysme01/MMM-Jeedom.git /’: Could not resolve host: github.com
                                            here is what i found. before it worked well, I think the best is to delete the plugin properly but I do not know how?
                                            • 16
                                            • 17
                                            • 18
                                            • 19
                                            • 20
                                            • 30
                                            • 31
                                            • 18 / 31
