config.js help
Guys and Girls can you help my config has gone to Well you know, can you help me sort this as i just cant see whats up i have removed the code for all the keys so its just empty “” thanks in advance
/* Magic Mirror Config Sample * * By Michael Teeuw http://michaelteeuw.nl * MIT Licensed. * * For more information how you can configurate this file * See https://github.com/MichMich/MagicMirror#configuration * */ var config = { address: "localhost", // Address to listen on, can be: // - "localhost", "127.0.0.1", "::1" to listen on loopback interface // - another specific IPv4/6 to listen on a specific interface // - "", "0.0.0.0", "::" to listen on any interface // Default, when address config is left out, is "localhost" port: 8080, ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1"], // Set [] to allow all IP addresses // or add a specific IPv4 of 192.168.1.5 : // ["127.0.0.1", "::ffff:127.0.0.1", "::1", "::ffff:192.168.1.5"], // or IPv4 range of 192.168.3.0 --> 192.168.3.15 use CIDR format : // ["127.0.0.1", "::ffff:127.0.0.1", "::1", "::ffff:192.168.3.0/28"], language: "en", timeFormat: 24, units: "metric", modules: [ { module: "MMM-Remote-Control-Repository", } }, { module: "alert", } }, { module: "MMM-Remote-Control", position: "center", } }, { module: "clock", position: "top_left" } }, { module: "mmm-hue-lights", position: "bottom_right", config: { bridgeIp: "192.168.1.23", user: "", updateInterval: "1000", hideOff: "false", displayMode: "groups", displayType: "list", minimalList: "true", coloredList: "true", hideFilter: ["home-away"], alignment: "right", } }, { module: "compliments", position: "lower_third", }, { module: "MMM-NOAA3", position: "top_right", config: { provider: "darksky", apiKey: "", airKey: "", css: "NOAA3", updateInterval: 15, userlat: "51.806460", userlon: "-0.778230" } }, { module: "calendar", header: "Calendar", position: "top_left", config: { timeFormat:"absolute", titleReplace: {"United Kingdom:" : ""}, urgency: 0, getRelative: 6, fullDayEventDateFormat: "D MMMM", dateFormat: "D MMMM - H:mm:ss", fetchInterval: 4000000, colored: true, coloredSymbolOnly: true, maximumEntries: 9, showEnd: false, Calendars: [ { symbol: "calendar-check-o ", url: "https://www.officeholidays.com/ics/ics_country_code.php?iso=GB", } }, { module: "mmm-nest-status", position: "bottom_left", // pick whichever position you want config: { token: "", displayMode: "all", displayType: "list", thermostatsToShow: "all", units: "metric", updateInterval: "50000", thermostatSize: "small", alignment: "left", // ... and whatever else configuration options you want to use } }, { module: "MMM-SystemStats", position: "Top_Center", updateInterval: 5000, align: "right", units: "metric", label: "text" } }, { module: "newsfeed", position: "bottom_bar", config: { feeds: [ { title: "BBC NEWS UK", url: "http://feeds.bbci.co.uk/news/uk/rss.xml" } ], showSourceTitle: true, showPublishDate: true } }, ] }; /*************** DO NOT EDIT THE LINE BELOW ***************/ if (typeof module !== "undefined") {module.exports = config;} -
You are missing config lines and have to many
}-bracketsI would just suggest that you rename that config.js file to config.js.bak and start over from scratch.
Try this, but you really need to clean up ;) :P
/* Magic Mirror Config Sample * * By Michael Teeuw http://michaelteeuw.nl * MIT Licensed. * * For more information how you can configurate this file * See https://github.com/MichMich/MagicMirror#configuration * */ var config = { address: "localhost", // Address to listen on, can be: // - "localhost", "127.0.0.1", "::1" to listen on loopback interface // - another specific IPv4/6 to listen on a specific interface // - "", "0.0.0.0", "::" to listen on any interface // Default, when address config is left out, is "localhost" port: 8080, ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1"], // Set [] to allow all IP addresses // or add a specific IPv4 of 192.168.1.5 : // ["127.0.0.1", "::ffff:127.0.0.1", "::1", "::ffff:192.168.1.5"], // or IPv4 range of 192.168.3.0 --> 192.168.3.15 use CIDR format : // ["127.0.0.1", "::ffff:127.0.0.1", "::1", "::ffff:192.168.3.0/28"], language: "en", timeFormat: 24, units: "metric", modules: [ { module: "MMM-Remote-Control-Repository", }, { module: "alert", }, { module: "MMM-Remote-Control", position: "center", }, { module: "clock", position: "top_left" }, { module: "mmm-hue-lights", position: "bottom_right", config: { bridgeIp: "192.168.1.23", user: "", updateInterval: "1000", hideOff: "false", displayMode: "groups", displayType: "list", minimalList: "true", coloredList: "true", hideFilter: ["home-away"], alignment: "right" } }, { module: "compliments", position: "lower_third", }, { module: "MMM-NOAA3", position: "top_right", config: { provider: "darksky", apiKey: "", airKey: "", css: "NOAA3", updateInterval: 15, userlat: "51.806460", userlon: "-0.778230" } }, { module: "calendar", header: "Calendar", position: "top_left", config: { timeFormat:"absolute", titleReplace: {"United Kingdom:" : ""}, urgency: 0, getRelative: 6, fullDayEventDateFormat: "D MMMM", dateFormat: "D MMMM - H:mm:ss", fetchInterval: 4000000, colored: true, coloredSymbolOnly: true, maximumEntries: 9, showEnd: false, Calendars: [ { symbol: "calendar-check-o ", url: "https://www.officeholidays.com/ics/ics_country_code.php?iso=GB", } ] } }, { module: "mmm-nest-status", position: "bottom_left", // pick whichever position you want config: { token: "", displayMode: "all", displayType: "list", thermostatsToShow: "all", units: "metric", updateInterval: "50000", thermostatSize: "small", alignment: "left", // ... and whatever else configuration options you want to use } }, { module: "MMM-SystemStats", position: "Top_Center", updateInterval: 5000, align: "right", units: "metric", label: "text" }, { module: "newsfeed", position: "bottom_bar", config: { feeds: [ { title: "BBC NEWS UK", url: "http://feeds.bbci.co.uk/news/uk/rss.xml" } ], }, showSourceTitle: true, showPublishDate: true } ] }; /*************** DO NOT EDIT THE LINE BELOW ***************/ if (typeof module !== "undefined") {module.exports = config;}For the future u can put in your code here: https://jshint.com
Just to analyze what maybe went wrong
