    How do I now Rotate display ?
    10 Posts 4 Posters 10.2k Views 4 Watching
    • johnnyboyJ Offline
      johnnyboy
      I’ve just upgraded Jessie to Stretch… and did a fresh install of MM.
      Last time I set MM up I done the - display_rotate=1 in sudo nano /boot/config.txt… but obviosly things have changed since I done that first time around…
      so can someone tell me what is the new way of rotating the display now?
      I tried to do what I read in another post, - sudo raspi-config. Go to the Advanced Options menu and select A7 GL Driver. Next, select the G1 GL (Full KMS) OpenGL desktop driver with full KMS. nano ~/.config/lxsession/LXDE-pi/autostart and to then insert @xrandr --output HDMI-1 --rotate right… but the Terminal says - Directory ‘/home/pi/.config/lxsession/LXDE-pi’ does not exist?
      TVMIA
      • K Offline
        Knapoc
        so just create the folder… mkdir -p /home/pi/.config/lxsession/LXDE-pi
        johnnyboyJ 1 Reply Last reply Reply Quote 0
          johnnyboy @Knapoc
          @Knapoc said in How do I now Rotate display ?:
          Thanks, I entered as you suggested, and then entered the lines from above… nano ~/.config/lxsession/LXDE-pi/autostart and to then insert @xrandr --output HDMI-1 --rotate right… then did a reboot, but display is still normal, and have now lost PM2 as it just goes straight to desktop now.
          PM2 Start procures - [pm2] [ERROR] File ecosystem.config.js not found
          MM worked perfect and PM2 worked as it booted into the MM… until I did as stated above and it has now done something?
          EDIT - PM2 has worked again.
          Still need to figuire out how to rotate the screen though.
          • K Offline
            Knapoc
            @johnnyboy said in How do I now Rotate display ?:
            What GL driver are you using? I’m currently having rotation issues with the fkms (fake) one, which is usually done by editing /boot/config.txt.
            Now I switched to the full kms one and the solution you just tried works… You can change the driver via /boot/config.txt:
            dtoverlay=vc4-kms-v3d
            or by choosing it in sudo raspi-config.
            The wiki-page also states, that the default location for autostart file changed:
            To do so, edit the autostart file: (autostart file has been moved in the latest version of Raspbian Stretch, Version: April 2019, Release Date: 2019-04-08 Kernel: 4.14 to /etc/xdg/lxsession/LXDE-pi/autostart
            Even though I have a fresh stretch install (last week), I cannot confirm that the location changed - I set the rotation config as mentioned in my previous post.
            johnnyboyJ K 2 Replies Last reply Reply Quote 1
            • evroomE Offline
              evroom
              This topic discusses an alternative way to rotate the screen:
              https://forum.magicmirror.builders/topic/9707/save-performance-when-rotating-screen-e-g-on-raspberry-pi?page=1
              It worked for me.
              MagicMirror version: 2.37.0
              johnnyboyJ 2 Replies Last reply Reply Quote 1
                johnnyboy @Knapoc
                Tried everything above again, but… Still will not rotate, and again lost PM2?.. All very strange… Maybe needs a bug fix of sorts? ( display_rotate=1 in sudo nano /boot/config.txt was soooooo perfect )
                Will now try the Custom CSS approach and see if that will be any better?
                  johnnyboy @evroom
                  @evroom said in How do I now Rotate display ?:
                  It worked for me.
                  Thanks… will play around with that and see if that helps… Strange why doing what I did above shuts down PM2 though?
                    johnnyboy @evroom
                    It worked for me.
                    Thanks… ^^^ This worked for me too now.
                    Appreciate all the help on this guys.
                    • K Offline
                      Knapoc @Knapoc
                      to add to my latest post:
                      so if you add an autostart file under ~/.config/lxsession/LXDE-pi/ the default file located under /etc/xdg/lxsession/LXDE-pi/autostart is overridden for the user. Since I had a user-config the changes applied in the default file had no effect. See this post for reference.
                      To summarise the following configuration works in my case.
                      ~/.config/lxsession/LXDE-pi/autostart:
                      # hide mouse pointer when idle
                      @unclutter -display :0 -idle 3 -root -noevents
                      # rotate display by 90 degrees
                      (I opted for this way, since I don’t want to load the desktop ui)
                      /boot/config.txt (snippet):
                      # MagicMirror configuration
                      disable_splash=1
                      avoid_warnings=1
                      gpu_mem=128
                      Make sure that there’s no dtoverlay=vc4-fkms-v3dentry or comment it.
                      • T Offline
                        tisnatch
                        Just tried this. It seems the fkms + display_rotate no longer works. There are some comments about in the rpi forums too, like this one:
                        https://www.raspberrypi.org/forums/viewtopic.php?t=246146
                        Using the kms driver plus the edits to the autostart file worked for me. Is there a way to get an official update to the documentation?
