    nodejs Warnings on recent Stretch-Buster update
    6 Posts 4 Posters 3.7k Views 5 Watching
    • qu1queQ
      qu1que Project Sponsor
      Hi all,
      Recently I’ve updated my raspbian stretch to raspbian buster on the Raspberry Pi 3 where I have installed MM (v. 2.8.0). Everything goes well, except for one thing. When I launch the following commands (on a bash script):
      #!/bin/bash
      npm start
      The mirror starts well, but I get these warnings:
      npm WARN npm npm does not support Node.js v10.15.2
      npm WARN npm You should probably upgrade to a newer version of node as we
      npm WARN npm can't make any promises that npm will work with this version.
      npm WARN npm Supported releases of Node.js are the latest release of 4, 6, 7, 8, 9.
      npm WARN npm You can find the latest version at https://nodejs.org/
      After MM starts, some modules are not showed, and I think maybe is for that reason.
      How could I solve this?
      Thanks in advance!
      • qu1queQ
        Finally I’ve found the solution looking at the forum:
        sudo npm install npm@latest -g
        • G
          gotchabeats
          im having the same problem. So all i have to do is run sudo npm install npm@latest -g
            Joern
            @qu1que said in nodejs Warnings on recent Stretch-Buster update:
            Hello, tried also under manuell install process to use:
            pi@raspberrypi:~/MagicMirror $ sudo npm install npm@latest -g
            /usr/bin/npm -> /usr/lib/node_modules/npm/bin/npm-cli.js
            /usr/bin/npx -> /usr/lib/node_modules/npm/bin/npx-cli.js
            + npm@6.10.1
            added 19 packages from 13 contributors, removed 12 packages and updated 32 packages in 61.073s
            But still:
            > magicmirror@2.8.0 start /home/pi/MagicMirror
            > sh run-start.sh
            run-start.sh: 4: run-start.sh: electron: not found
            npm ERR! file sh
            npm ERR! code ELIFECYCLE
            npm ERR! errno ENOENT
            npm ERR! syscall spawn
            npm ERR! magicmirror@2.8.0 start: `sh run-start.sh`
            npm ERR! spawn ENOENT
            npm ERR!
            npm ERR! Failed at the magicmirror@2.8.0 start script.
            npm WARN Local package.json exists, but node_modules missing, did you mean to install?
            npm ERR!     /home/pi/.npm/_logs/2019-07-13T16_53_04_944Z-debug.log
              sdetweil @Joern
              @Joern from the MagicMirror folder now do again
              npm install
                Joern
                @sdetweil said in nodejs Warnings on recent Stretch-Buster update:
                npm install
                Oh that’s looks better & I can start now. Below outcome of installation.
                So what did I do with the line “npm@latest -g” before. Did I define for nom to use older version, that was appliedduring current run of “npm install”?
                pi@raspberrypi:~/MagicMirror $ npm install
                npm WARN deprecated time-grunt@2.0.0: Deprecated because Grunt is practically unmaintained. Move on to something better. This package will continue to work with Grunt v1, but it will not receive any updates.
                > electron-chromedriver@1.8.0 install /home/pi/MagicMirror/node_modules/electron-chromedriver
                > node ./download-chromedriver.js
                successfully dowloaded and extracted!
                > core-js@2.6.9 postinstall /home/pi/MagicMirror/node_modules/core-js
                > node scripts/postinstall || echo "ignore"
                Thank you for using core-js ( https://github.com/zloirock/core-js ) for polyfilling JavaScript standard library!
                The project needs your help! Please consider supporting of core-js on Open Collective or Patreon:
                > https://opencollective.com/core-js
                > https://www.patreon.com/zloirock
                Also, the author of core-js ( https://github.com/zloirock ) is looking for a good job -)
                > electron@3.1.10 postinstall /home/pi/MagicMirror/node_modules/electron
                > node install.js
                Downloading tmp-2201-1-SHASUMS256.txt-3.1.10
                [============================================>] 100.0% of 4.79 kB (4.79 kB/s)
                > magicmirror@2.8.0 install /home/pi/MagicMirror
                > cd vendor && npm install
                npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@1.2.4 (node_modules/fsevents):
                npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@1.2.4: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
                added 82 packages from 57 contributors and audited 220 packages in 30.154s
                found 5 vulnerabilities (4 low, 1 high)
                  run `npm audit fix` to fix them, or `npm audit` for details
                > magicmirror@2.8.0 postinstall /home/pi/MagicMirror
                > sh installers/postinstall/postinstall.sh && npm run install-fonts
                MagicMirror installation successful!
                > magicmirror@2.8.0 install-fonts /home/pi/MagicMirror
                > cd fonts && npm install
                added 1 package from 1 contributor and audited 1 package in 7.521s
                found 0 vulnerabilities
                added 1008 packages from 1328 contributors and audited 3572 packages in 299.519s
