    nodejs Warnings on recent Stretch-Buster update
    6 Posts 4 Posters 3.4k Views 5 Watching
    • qu1queQ Offline
      qu1que Project Sponsor
      Finally I’ve found the solution looking at the forum:
      sudo npm install npm@latest -g
      • G Offline
        gotchabeats
        im having the same problem. So all i have to do is run sudo npm install npm@latest -g
          Joern
          @qu1que said in nodejs Warnings on recent Stretch-Buster update:
          Hello, tried also under manuell install process to use:
          pi@raspberrypi:~/MagicMirror $ sudo npm install npm@latest -g
          /usr/bin/npm -> /usr/lib/node_modules/npm/bin/npm-cli.js
          /usr/bin/npx -> /usr/lib/node_modules/npm/bin/npx-cli.js
          + npm@6.10.1
          added 19 packages from 13 contributors, removed 12 packages and updated 32 packages in 61.073s
          But still:
          > magicmirror@2.8.0 start /home/pi/MagicMirror
          > sh run-start.sh
          run-start.sh: 4: run-start.sh: electron: not found
          npm ERR! file sh
          npm ERR! code ELIFECYCLE
          npm ERR! errno ENOENT
          npm ERR! syscall spawn
          npm ERR! magicmirror@2.8.0 start: `sh run-start.sh`
          npm ERR! spawn ENOENT
          npm ERR!
          npm ERR! Failed at the magicmirror@2.8.0 start script.
          npm WARN Local package.json exists, but node_modules missing, did you mean to install?
          npm ERR!     /home/pi/.npm/_logs/2019-07-13T16_53_04_944Z-debug.log
            sdetweil @Joern
            @Joern from the MagicMirror folder now do again
            npm install
              Joern
              @sdetweil said in nodejs Warnings on recent Stretch-Buster update:
              npm install
              Oh that’s looks better & I can start now. Below outcome of installation.
              So what did I do with the line “npm@latest -g” before. Did I define for nom to use older version, that was appliedduring current run of “npm install”?
              pi@raspberrypi:~/MagicMirror $ npm install
              npm WARN deprecated time-grunt@2.0.0: Deprecated because Grunt is practically unmaintained. Move on to something better. This package will continue to work with Grunt v1, but it will not receive any updates.
              > electron-chromedriver@1.8.0 install /home/pi/MagicMirror/node_modules/electron-chromedriver
              > node ./download-chromedriver.js
              successfully dowloaded and extracted!
              > core-js@2.6.9 postinstall /home/pi/MagicMirror/node_modules/core-js
              > node scripts/postinstall || echo "ignore"
              Thank you for using core-js ( https://github.com/zloirock/core-js ) for polyfilling JavaScript standard library!
              The project needs your help! Please consider supporting of core-js on Open Collective or Patreon:
              > https://opencollective.com/core-js
              > https://www.patreon.com/zloirock
              Also, the author of core-js ( https://github.com/zloirock ) is looking for a good job -)
              > electron@3.1.10 postinstall /home/pi/MagicMirror/node_modules/electron
              > node install.js
              Downloading tmp-2201-1-SHASUMS256.txt-3.1.10
              [============================================>] 100.0% of 4.79 kB (4.79 kB/s)
              > magicmirror@2.8.0 install /home/pi/MagicMirror
              > cd vendor && npm install
              npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@1.2.4 (node_modules/fsevents):
              npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@1.2.4: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
              added 82 packages from 57 contributors and audited 220 packages in 30.154s
              found 5 vulnerabilities (4 low, 1 high)
                run `npm audit fix` to fix them, or `npm audit` for details
              > magicmirror@2.8.0 postinstall /home/pi/MagicMirror
              > sh installers/postinstall/postinstall.sh && npm run install-fonts
              MagicMirror installation successful!
              > magicmirror@2.8.0 install-fonts /home/pi/MagicMirror
              > cd fonts && npm install
              added 1 package from 1 contributor and audited 1 package in 7.521s
              found 0 vulnerabilities
              added 1008 packages from 1328 contributors and audited 3572 packages in 299.519s
