    Magic Mirror Redesign WIP :D
    Scheduled Pinned Locked Moved Showcase
    47 Posts 21 Posters 36.0k Views 26 Watching
      skibro @earlman
      @earlman HI! That looks fantastic, very nice work! Which calendar modul are you planning to use? I would love something like this - in weekly view. I would be greatful if you could point me in the right direction with this. Thanks for sharing!
      • E Offline
        earlman @skibro
        @skibro hiyaa! This is the one I’ve used in the past. It has the best documentation and is the most stripped down, making it the easiest to style. Tons of config options, too.
          skibro @earlman
          @earlman Hiyaa! Thanks for your reply. I will try the linked module - I am quite new to js and css, would you mind to share some of your calendar related CSS? I am especially curious of the upper border styiling in the second image you posted. Thanks in advance, have a great day!
          • E Offline
            earlman @skibro
            @skibro That’s actually just a mockup I made in Figma (a design tool). I haven’t built that into my mirror yet, by since you’re interested, I’ll move that up the priority list. I’ll post back here when I have something up on github.
              bachoo786 @earlman
              @earlman this looks proper nice do you mind sharing the whole lot i.e. your css, the wallpapers etc?
              Thanks.
              • E Offline
                earlman
                @bachoo786 @skibro What modules are you guys currently using? I’m doing some prep work for release and wanna make sure it works with your current setups
                  A Former User
                  Is it possible to use horizontal layout instead vertical?
                  E 2 Replies Last reply Reply Quote 1
                  • E Offline
                    earlman @Guest
                    @Sean yup! The reason I messed around with the CSS so much was to make it much more flexible with different screen sizes. I’ll post a screenshot once I get back to my computer
                    • E Offline
                      earlman @Guest
                      @Sean i like keeping it pretty minimal right now, but here’s what it looks like in landscape 0_1567030482787_25D7C3A6-B9CA-4000-97FB-A1B08E8810AD.png
                        smackenzie5 @earlman
                        @earlman
                        I’m using the default clock, calendar, current weather, and weather forecast. I’m also using google-route. I’d be interested in anything you could do to make the Google map look better in the route module. I assume you don’t care about the modules that run in the background and don’t show on the screen. Thanks
                        • 1 / 5
