    Magic Mirror Redesign WIP :D
    Scheduled Pinned Locked Moved Showcase
    47 Posts 21 Posters 48.5k Views 26 Watching
    • E Offline
      earlman
      This is how it currently looks
      This is what I’m planning for the eventual v1.0.0 release:
      If you’re interested in how I did this, let me know. I dove pretty deep into the development. Here’s some not-so-apparent features I’ve added:
      • Refactored the Layout in main.css to use CSS Grid
        • This allows for a more flexible layout that’s easier to work with
      • Modified MMM-Wallpaper to load images from Pexels
      • Using two instances of MMM-Todoist to load my “Daily Highlight” for the day
      • After 6:00pm, changes the Daily Highlight to tomorrow’s highlight
      S B lavolp3L N M 6 Replies Last reply Reply Quote 5
        skibro @earlman
        @earlman HI! That looks fantastic, very nice work! Which calendar modul are you planning to use? I would love something like this - in weekly view. I would be greatful if you could point me in the right direction with this. Thanks for sharing!
        • E Offline
          earlman @skibro
          @skibro hiyaa! This is the one I’ve used in the past. It has the best documentation and is the most stripped down, making it the easiest to style. Tons of config options, too.
            skibro @earlman
            @earlman Hiyaa! Thanks for your reply. I will try the linked module - I am quite new to js and css, would you mind to share some of your calendar related CSS? I am especially curious of the upper border styiling in the second image you posted. Thanks in advance, have a great day!
            • E Offline
              earlman @skibro
              @skibro That’s actually just a mockup I made in Figma (a design tool). I haven’t built that into my mirror yet, by since you’re interested, I’ll move that up the priority list. I’ll post back here when I have something up on github.
                bachoo786 @earlman
                @earlman this looks proper nice do you mind sharing the whole lot i.e. your css, the wallpapers etc?
                Thanks.
                • E Offline
                  earlman
                  @bachoo786 @skibro What modules are you guys currently using? I’m doing some prep work for release and wanna make sure it works with your current setups
                    [[global:former-user]]
                    Is it possible to use horizontal layout instead vertical?
                    E 2 Replies Last reply Reply Quote 1
                    • E Offline
                      earlman @Guest
                      @Sean yup! The reason I messed around with the CSS so much was to make it much more flexible with different screen sizes. I’ll post a screenshot once I get back to my computer
                      • E Offline
                        earlman @Guest
                        @Sean i like keeping it pretty minimal right now, but here’s what it looks like in landscape 0_1567030482787_25D7C3A6-B9CA-4000-97FB-A1B08E8810AD.png
                          smackenzie5 @earlman
                          @earlman
                          I’m using the default clock, calendar, current weather, and weather forecast. I’m also using google-route. I’d be interested in anything you could do to make the Google map look better in the route module. I assume you don’t care about the modules that run in the background and don’t show on the screen. Thanks
                            [[global:former-user]] @earlman
                            @earlman
                            Looks so nice. I want to try yours.
                            1 Reply Last reply Reply Quote -1
                            • E Offline
                              earlman
                              Project Update (& Installation Instructions)
                              @skibro @bachoo786 @Sean @smackenzie5
                              Alrighty y’all! Got some great news for those who wanna try this setup out. Heads up though—might take a bit of time to set up,
                              so don’t expect to get it looking right in a couple clicks.
                              First, I’ve added Pexels support to MMM-Wallpaper (thanks @kolbyjack for the quick response).
                              As for everything else, all the instructions for setting it up can be found here
                              Though I’ve been doing development work for a while, this is one of my first open-source projects, so I’ll definitely do my best to help you guys out if you need it.
                              • lavolp3L Offline
                                lavolp3 Module Developer @earlman
                                @earlman I have to say I really love the grid concept. I have a monitor sitting in the lower right corner of the mirror and a grid design would look much better.
                                Can you share your main.css or is it on GitHub?
                                Sorry just saw the latest reply with all the information I needed. Thanks man!!
                                How to troubleshoot modules
                                MMM-soccer v2, MMM-AVStock
                                  @earlman
                                  Thanks for putting this together.
                                  Finally had some time to work on this today but got the following error message when running it for the first time:
                                  pi@raspberrypi:~ $ cd MagicMirror
                                  pi@raspberrypi:~/MagicMirror $ sudo npm start
                                  > magicmirror@2.7.1 start /home/pi/MagicMirror
                                  > sh run-start.sh
                                  Starting MagicMirror: v2.7.1
                                  Loading config ...
                                  WARNING! Could not validate config file. Starting with default configuration. Please correct syntax errors at or above this line: /home/pi/MagicMirror/config/config.js:116
                                      				pexels_key: [my API key was here],
                                  SyntaxError: Invalid or unexpected token
                                      at new Script (vm.js:74:7)
                                      at createScript (vm.js:246:10)
                                      at Object.runInThisContext (vm.js:298:10)
                                      at Module._compile (internal/modules/cjs/loader.js:678:28)
                                      at Object.Module._extensions..js (internal/modules/cjs/loader.js:722:10)
                                      at Module.load (internal/modules/cjs/loader.js:620:32)
                                      at tryModuleLoad (internal/modules/cjs/loader.js:559:12)
                                      at Function.Module._load (internal/modules/cjs/loader.js:551:3)
                                      at Module.require (internal/modules/cjs/loader.js:658:17)
                                      at require (internal/modules/cjs/helpers.js:20:18)
                                  Loading module helpers ...
                                  No helper found for module: helloworld.
                                  All module helpers loaded.
                                  Server started ...
                                  Launching application.
                                  Here’s my config.js:
                                  			module: "MMM-Wallpaper",
                                  			position: "fullscreen_below",
                                  			config: { // See "Configuration options" for more information.
                                  				source: "pexels",
                                      				slideInterval: 60 * 1000, // Change slides every minute
                                      				orientation: "vertical",
                                      				pexels_search: "beach"
                                  Thoughts?
                                  Thanks,
                                  Scott
                                    sdetweil @smackenzie5
                                    @smackenzie5 said in Magic Mirror Redesign WIP :D:
                                    you need to get a pexels api key and put in where the text says
                                      smackenzie5 @sdetweil
                                      Yeah, I have the Pexels API key.
                                      Replaced it with those words just for the forum post.
                                      @earlman
                                      BTW - getting the Pexels API key was immediate, no wait
                                      Thanks,
                                      Scott
                                        @smackenzie5 did you put quotes around the key value? If not, that would explain the config error message
                                        • E Offline
                                          earlman
                                          @smackenzie5 nice good news, glad it was quick to get.
                                          What sdetweil said, did ya put quotes around the key?
                                          • E Offline
                                            earlman @lavolp3
                                            @lavolp3 Yup, no problem :D hope it works out, if you’re having layout troubles feel free to post a screenshot. Haven’t tested this on a more filled out layout so I’d be curious how it looks
