    Magic Mirror Redesign WIP :D
    Scheduled Pinned Locked Moved Showcase
    47 Posts 21 Posters 50.8k Views 26 Watching
      bachoo786 @earlman
      @earlman this looks proper nice do you mind sharing the whole lot i.e. your css, the wallpapers etc?
      Thanks.
      • E
        earlman
        @bachoo786 @skibro What modules are you guys currently using? I’m doing some prep work for release and wanna make sure it works with your current setups
          A Former User
          Is it possible to use horizontal layout instead vertical?
          E 2 Replies Last reply
          • E
            earlman @Guest
            @Sean yup! The reason I messed around with the CSS so much was to make it much more flexible with different screen sizes. I’ll post a screenshot once I get back to my computer
            • E
              earlman @Guest
              @Sean i like keeping it pretty minimal right now, but here’s what it looks like in landscape 0_1567030482787_25D7C3A6-B9CA-4000-97FB-A1B08E8810AD.png
              ? 1 Reply Last reply
                smackenzie5 @earlman
                @earlman
                I’m using the default clock, calendar, current weather, and weather forecast. I’m also using google-route. I’d be interested in anything you could do to make the Google map look better in the route module. I assume you don’t care about the modules that run in the background and don’t show on the screen. Thanks
                  A Former User @earlman
                  @earlman
                  Looks so nice. I want to try yours.
                  Reply Quote -1
                  • E
                    earlman
                    Project Update (& Installation Instructions)
                    @skibro @bachoo786 @Sean @smackenzie5
                    Alrighty y’all! Got some great news for those who wanna try this setup out. Heads up though—might take a bit of time to set up,
                    so don’t expect to get it looking right in a couple clicks.
                    First, I’ve added Pexels support to MMM-Wallpaper (thanks @kolbyjack for the quick response).
                    As for everything else, all the instructions for setting it up can be found here
                    Though I’ve been doing development work for a while, this is one of my first open-source projects, so I’ll definitely do my best to help you guys out if you need it.
                    • lavolp3L
                      lavolp3 Module Developer @earlman
                      @earlman I have to say I really love the grid concept. I have a monitor sitting in the lower right corner of the mirror and a grid design would look much better.
                      Can you share your main.css or is it on GitHub?
                      Sorry just saw the latest reply with all the information I needed. Thanks man!!
                      How to troubleshoot modules
                      MMM-soccer v2, MMM-AVStock
                      E 1 Reply Last reply
                        @earlman
                        Thanks for putting this together.
                        Finally had some time to work on this today but got the following error message when running it for the first time:
                        pi@raspberrypi:~ $ cd MagicMirror
                        pi@raspberrypi:~/MagicMirror $ sudo npm start
                        > magicmirror@2.7.1 start /home/pi/MagicMirror
                        > sh run-start.sh
                        Starting MagicMirror: v2.7.1
                        Loading config ...
                        WARNING! Could not validate config file. Starting with default configuration. Please correct syntax errors at or above this line: /home/pi/MagicMirror/config/config.js:116
                            				pexels_key: [my API key was here],
                        SyntaxError: Invalid or unexpected token
                            at new Script (vm.js:74:7)
                            at createScript (vm.js:246:10)
                            at Object.runInThisContext (vm.js:298:10)
                            at Module._compile (internal/modules/cjs/loader.js:678:28)
                            at Object.Module._extensions..js (internal/modules/cjs/loader.js:722:10)
                            at Module.load (internal/modules/cjs/loader.js:620:32)
                            at tryModuleLoad (internal/modules/cjs/loader.js:559:12)
                            at Function.Module._load (internal/modules/cjs/loader.js:551:3)
                            at Module.require (internal/modules/cjs/loader.js:658:17)
                            at require (internal/modules/cjs/helpers.js:20:18)
                        Loading module helpers ...
                        No helper found for module: helloworld.
                        All module helpers loaded.
                        Server started ...
                        Launching application.
                        Here’s my config.js:
                        			module: "MMM-Wallpaper",
                        			position: "fullscreen_below",
                        			config: { // See "Configuration options" for more information.
                        				source: "pexels",
                            				slideInterval: 60 * 1000, // Change slides every minute
                            				orientation: "vertical",
                            				pexels_search: "beach"
                        Thoughts?
                        Thanks,
                        Scott
                          sdetweil @smackenzie5
                          @smackenzie5 said in Magic Mirror Redesign WIP :D:
                          you need to get a pexels api key and put in where the text says
                            smackenzie5 @sdetweil
                            Yeah, I have the Pexels API key.
                            Replaced it with those words just for the forum post.
                            @earlman
                            BTW - getting the Pexels API key was immediate, no wait
                            Thanks,
                            Scott
                              @smackenzie5 did you put quotes around the key value? If not, that would explain the config error message
                              • E
                                earlman
                                @smackenzie5 nice good news, glad it was quick to get.
                                What sdetweil said, did ya put quotes around the key?
                                • E
                                  earlman @lavolp3
                                  @lavolp3 Yup, no problem :D hope it works out, if you’re having layout troubles feel free to post a screenshot. Haven’t tested this on a more filled out layout so I’d be curious how it looks
                                    @earlman @sdetweil
                                    Yeah, that would be the problem…
                                    Works now - thanks.
                                    Two pictures, before and after:
                                    Obviously, have some work to do on the After but it’s too late tonight to get started with that.
                                    Thanks,
                                    Scott
                                    • N
                                      nobita @earlman
                                      @earlman
                                      I have question
                                      how to add emoji or Icon on Header Text
                                      Thanks for hint
                                      • E
                                        earlman @nobita
                                        @nobita You can put them straight into the “header” field on your config file. If you’re using Windows, press [WINDOWSKEY + .] Not sure how to insert emojis on a mac, though. Hope that helps.
                                        N 1 Reply Last reply
                                        • N
                                          nobita @earlman
                                          @earlman I See, Thanks for quick hint answer
                                            ramac21
                                            Hi, it’s really pretty! Can these templates be downloaded for my mirror? or is it a private job?
