    Magic Mirror Redesign WIP :D
    Scheduled Pinned Locked Moved Showcase
    47 Posts 21 Posters 50.0k Views 26 Watching
    • E
      earlman @skibro
      @skibro That’s actually just a mockup I made in Figma (a design tool). I haven’t built that into my mirror yet, by since you’re interested, I’ll move that up the priority list. I’ll post back here when I have something up on github.
        bachoo786 @earlman
        @earlman this looks proper nice do you mind sharing the whole lot i.e. your css, the wallpapers etc?
        Thanks.
        • E
          earlman
          @bachoo786 @skibro What modules are you guys currently using? I’m doing some prep work for release and wanna make sure it works with your current setups
            A Former User
            Is it possible to use horizontal layout instead vertical?
            E 2 Replies Last reply Reply Quote 1
            • E
              earlman @Guest
              @Sean yup! The reason I messed around with the CSS so much was to make it much more flexible with different screen sizes. I’ll post a screenshot once I get back to my computer
              • E
                earlman @Guest
                @Sean i like keeping it pretty minimal right now, but here’s what it looks like in landscape 0_1567030482787_25D7C3A6-B9CA-4000-97FB-A1B08E8810AD.png
                  smackenzie5 @earlman
                  @earlman
                  I’m using the default clock, calendar, current weather, and weather forecast. I’m also using google-route. I’d be interested in anything you could do to make the Google map look better in the route module. I assume you don’t care about the modules that run in the background and don’t show on the screen. Thanks
                    A Former User @earlman
                    @earlman
                    Looks so nice. I want to try yours.
                    1 Reply Last reply Reply Quote -1
                    • E
                      earlman
                      Project Update (& Installation Instructions)
                      @skibro @bachoo786 @Sean @smackenzie5
                      Alrighty y’all! Got some great news for those who wanna try this setup out. Heads up though—might take a bit of time to set up,
                      so don’t expect to get it looking right in a couple clicks.
                      First, I’ve added Pexels support to MMM-Wallpaper (thanks @kolbyjack for the quick response).
                      As for everything else, all the instructions for setting it up can be found here
                      Though I’ve been doing development work for a while, this is one of my first open-source projects, so I’ll definitely do my best to help you guys out if you need it.
                      • lavolp3L
                        lavolp3 Module Developer @earlman
                        @earlman I have to say I really love the grid concept. I have a monitor sitting in the lower right corner of the mirror and a grid design would look much better.
                        Can you share your main.css or is it on GitHub?
                        Sorry just saw the latest reply with all the information I needed. Thanks man!!
                        How to troubleshoot modules
                        MMM-soccer v2, MMM-AVStock
                          @earlman
                          Thanks for putting this together.
                          Finally had some time to work on this today but got the following error message when running it for the first time:
                          pi@raspberrypi:~ $ cd MagicMirror
                          pi@raspberrypi:~/MagicMirror $ sudo npm start
                          > magicmirror@2.7.1 start /home/pi/MagicMirror
                          > sh run-start.sh
                          Starting MagicMirror: v2.7.1
                          Loading config ...
                          WARNING! Could not validate config file. Starting with default configuration. Please correct syntax errors at or above this line: /home/pi/MagicMirror/config/config.js:116
                              				pexels_key: [my API key was here],
                          SyntaxError: Invalid or unexpected token
                              at new Script (vm.js:74:7)
                              at createScript (vm.js:246:10)
                              at Object.runInThisContext (vm.js:298:10)
                              at Module._compile (internal/modules/cjs/loader.js:678:28)
                              at Object.Module._extensions..js (internal/modules/cjs/loader.js:722:10)
                              at Module.load (internal/modules/cjs/loader.js:620:32)
                              at tryModuleLoad (internal/modules/cjs/loader.js:559:12)
                              at Function.Module._load (internal/modules/cjs/loader.js:551:3)
                              at Module.require (internal/modules/cjs/loader.js:658:17)
                              at require (internal/modules/cjs/helpers.js:20:18)
                          Loading module helpers ...
                          No helper found for module: helloworld.
                          All module helpers loaded.
                          Server started ...
                          Launching application.
                          Here’s my config.js:
                          			module: "MMM-Wallpaper",
                          			position: "fullscreen_below",
                          			config: { // See "Configuration options" for more information.
                          				source: "pexels",
                              				slideInterval: 60 * 1000, // Change slides every minute
                              				orientation: "vertical",
                              				pexels_search: "beach"
                          Thoughts?
                          Thanks,
                          Scott
                            sdetweil @smackenzie5
                            @smackenzie5 said in Magic Mirror Redesign WIP :D:
                            you need to get a pexels api key and put in where the text says
                              smackenzie5 @sdetweil
                              Yeah, I have the Pexels API key.
                              Replaced it with those words just for the forum post.
                              @earlman
                              BTW - getting the Pexels API key was immediate, no wait
                              Thanks,
                              Scott
                                @smackenzie5 did you put quotes around the key value? If not, that would explain the config error message
                                • E
                                  earlman
                                  @smackenzie5 nice good news, glad it was quick to get.
                                  What sdetweil said, did ya put quotes around the key?
                                  • E
                                    earlman @lavolp3
                                    @lavolp3 Yup, no problem :D hope it works out, if you’re having layout troubles feel free to post a screenshot. Haven’t tested this on a more filled out layout so I’d be curious how it looks
                                      @earlman @sdetweil
                                      Yeah, that would be the problem…
                                      Works now - thanks.
                                      Two pictures, before and after:
                                      Obviously, have some work to do on the After but it’s too late tonight to get started with that.
                                      Thanks,
                                      Scott
                                      • N
                                        nobita @earlman
                                        @earlman
                                        I have question
                                        how to add emoji or Icon on Header Text
                                        Thanks for hint
                                        • E
                                          earlman @nobita
                                          @nobita You can put them straight into the “header” field on your config file. If you’re using Windows, press [WINDOWSKEY + .] Not sure how to insert emojis on a mac, though. Hope that helps.
                                          • N
                                            nobita @earlman
                                            @earlman I See, Thanks for quick hint answer
