    Radio module
    6 Posts 3 Posters 2.6k Views 2 Watching
      PXNDA
      Does anyone know a radio module or could be happy to code it which allows you to play radio stations? Or maybe you could help me code one?
      • brobergB
        broberg Project Sponsor
        @PXNDA
        You would need a radio-reciever then. Or Are you referring to web broadcasts from radio stations?
        If it’s the last one there is a couple of modules that does that already.
        A quick search for “radio” in the forum gives me these :
        https://forum.magicmirror.builders/topic/1106/a-very-simple-web-radio-player-controled-by-voice
        https://forum.magicmirror.builders/topic/6600/mmm-myradio-web-radio-player
        https://forum.magicmirror.builders/topic/1601/mmm-touchplayerbasic-simple-webradio-and-mp3-playlist-player
        https://forum.magicmirror.builders/topic/1663/mmm-radiode-simple-web-radio-de-player
        The three on top uses mpg123, a command line mp3 player that supports m3u radio-streams.
          PXNDA
          @broberg
          I want to play radio stations such as LBC. I don’t know if I can use web broadcasts for it.
          • brobergB
            LBC have some channels with m3u streams it looks like :
            LBC (London stream)
            http://media-ice.musicradio.com/LBCLondon.m3u (HE AAC format)
            http://media-ice.musicradio.com/LBCLondonMP3Low (MP3 low bit rate)
            LBC (National stream)
            http://media-ice.musicradio.com/LBCUK.m3u (HE AAC format)
            http://media-ice.musicradio.com/LBCUKMP3Low (MP3 low bit rate)
            LBC London News 1152
            http://media-ice.musicradio.com/LBC1152.m3u (HE AAC format)
            http://media-ice.musicradio.com/LBC1152MP3Low (MP3 low bit rate)
              PXNDA
              @broberg
              Would it work with a voice assistant? I’m using Evan Cohen’s magic mirror software, so will I have to modify the code?
                sdetweil @PXNDA
                @PXNDA yes, the modules here do not work there, and vice versa…
                I have a sample module for smart-mirror as well as MagicMirror.
                for help on smart-mirror you need to use discord on the smart-mirror channel.
