    MMM-GooglePhotos
    294 Posts 56 Posters 418.0k Views 59 Watching
      redink
      Thanks!
      For anyone who wants to do the same, just add the following to your custom.css file
      #GPHOTO{
           /*1 is fully opaque, 0 is fully transparent*/
          opacity: 0.3 !important;
      • WasupDudeW
        WasupDude Banned
        wow, that’s really interesting ;)
        • K
          King321
          Is there a way to have videos play as well?
          • O
            orayoflighto Project Sponsor
            First, thanks for a great module. Its greatly appreciated.
            Is there a way to prevent API requests during certain time periods? I have 14000 photos in an album that is only going to grow with time which is going to kill my API requests but I don’t need requests to take place at 2AM for instance.
              sdetweil @orayoflighto
              @orayoflighto do u put your mirror to sleep when u are not around? it should not fetch new images while mirror is asleep…
              ? 1 Reply Last reply
                A Former User @sdetweil
                @sdetweil @orayoflighto
                I’ll update(or build newly) about it on next patch.
                O 1 Reply Last reply
                • O
                  orayoflighto Project Sponsor @Guest
                  @Sean looking forward to it. Thanks again for an awesome module.
                  @sdetweil I now have a cron job to turn the monitor off. Is that what you mean by “sleep”? Does that stop the API requests?
                    @orayoflighto sadly no. The MagicMirror code doesn’t know the screen is off
                      Bestboy4
                      @Sean I don’t know how you keep your patients with all of us. I’m using many of your modules, so thanks for your contribution to the masses.
                      Has anyone noticed that when you sort with “time” that it pulls photos from google in the order in which each photo was uploaded, and not the order you put them in the album.
                      I have 12 pictures in my album that I have put in order to represent each calendar month. Is there a way to force the module to sort according the album order, and not time?
                        A Former User @Bestboy4
                        @Bestboy4
                        Sorry, there is no key to sort that way in API. The only values could be used for sorting was creationTime.
                        B 2 Replies Last reply
                          Bestboy4 @Guest
                          @Sean I was afraid of that. Thanks for the reply.
                            Bestboy4 @Guest
                            @Sean Sorry to keep kicking a dead horse, but if the API gives access to the creationTime, then can one create a short script to to show a particular photo for a particular date? Like, when in the month of December, only show me photos with a time stamp of 12/**/****.
                            Here is what I am getting at; I can edit the time stamp on each photo to reorganize in google photos. However, if there is a power glitch, and my Rpi resets, then the photos will start over at the beginning of the photo album. Normally this wouldn’t be a big deal if I were to use my MM as just a photo frame. However I suspect that I’m like most people, and am displaying our family calendar as well (kudos for the CalendarExt BTW). Having the photos coincide with the what time of the year it is would be very beneficial. For instance I wouldn’t want snow scenes to be displayed in the middle of July (unless I am in Australia, :-P ). So far there doesn’t seem to be a module like that.
                            • X
                              xundre
                              The module has been working great , however , i am running into a situation now where it constantly request google authentication. I can leave and come back and there are 50 chromium tabs opened trying to authenticate to google , and it also covers other modules.
                              Any idea how to fix this ?
                              Regards!
                                A Former User @xundre
                                @xundre
                                give me more details especially server log.
                                X 1 Reply Last reply
                                • X
                                  xundre @Guest
                                  @Sean said in MMM-GooglePhotos:
                                  @xundre
                                  Hi , Sorry not exactly sure how to get the logs.
                                    @xundre
                                    If you are requested to auth your project on each time module running, your authentification was missing something or failed.
                                    Try re auth again. (https://github.com/eouia/MMM-GooglePhotos#get-auth-and-albumid)
                                    • X
                                      xundre @Guest
                                      @Sean I do but then it comes back up again in x number of days. I go through the auth process and it works again, but then starts popping up windows to auth after sometime.
                                      It used to work consistently without having to reauth , not quite sure what changed.
                                        @xundre
                                        Very weird. If possible, plz contact me tomorrow through Telegram (my id is @eouia) I’m convenient when normal weekdays 10am ~ 17pm in Central European Timezone. We can see what’s happening on realtime.
                                          mcneilp
                                          If I have an album with a very large number of photos does it scan all of them? I switched to a small album and it loads nice and fast…but the large one never seems to get a photo. Is this a one time scan (for each time it starts up). Or will it always be super slow.
                                          Google Photos auto adds photos to albums based on who is in them, so its a shame to not be able to use one of these albums.
                                          M 1 Reply Last reply
                                            mcneilp @mcneilp
                                            @mcneilp If i let it run long enough it loads an image…but sometimes it goes blank for a while. I assume this is because its processing photos. Too bad it can’t just load a few at a time and run fast.
                                            • 14
                                            • 15
                                            • 7 / 15
