    MMM-GooglePhotos
    294 Posts 56 Posters 415.8k Views 59 Watching
      A Former User @sdetweil
      @sdetweil @orayoflighto
      I’ll update(or build newly) about it on next patch.
      O 1 Reply Last reply
      • O
        orayoflighto Project Sponsor @Guest
        @Sean looking forward to it. Thanks again for an awesome module.
        @sdetweil I now have a cron job to turn the monitor off. Is that what you mean by “sleep”? Does that stop the API requests?
          @orayoflighto sadly no. The MagicMirror code doesn’t know the screen is off
            Bestboy4
            @Sean I don’t know how you keep your patients with all of us. I’m using many of your modules, so thanks for your contribution to the masses.
            Has anyone noticed that when you sort with “time” that it pulls photos from google in the order in which each photo was uploaded, and not the order you put them in the album.
            I have 12 pictures in my album that I have put in order to represent each calendar month. Is there a way to force the module to sort according the album order, and not time?
            ? 1 Reply Last reply
              A Former User @Bestboy4
              @Bestboy4
              Sorry, there is no key to sort that way in API. The only values could be used for sorting was creationTime.
              B 2 Replies Last reply
                Bestboy4 @Guest
                @Sean I was afraid of that. Thanks for the reply.
                  Bestboy4 @Guest
                  @Sean Sorry to keep kicking a dead horse, but if the API gives access to the creationTime, then can one create a short script to to show a particular photo for a particular date? Like, when in the month of December, only show me photos with a time stamp of 12/**/****.
                  Here is what I am getting at; I can edit the time stamp on each photo to reorganize in google photos. However, if there is a power glitch, and my Rpi resets, then the photos will start over at the beginning of the photo album. Normally this wouldn’t be a big deal if I were to use my MM as just a photo frame. However I suspect that I’m like most people, and am displaying our family calendar as well (kudos for the CalendarExt BTW). Having the photos coincide with the what time of the year it is would be very beneficial. For instance I wouldn’t want snow scenes to be displayed in the middle of July (unless I am in Australia, :-P ). So far there doesn’t seem to be a module like that.
                  • X
                    xundre
                    The module has been working great , however , i am running into a situation now where it constantly request google authentication. I can leave and come back and there are 50 chromium tabs opened trying to authenticate to google , and it also covers other modules.
                    Any idea how to fix this ?
                    Regards!
                      A Former User @xundre
                      @xundre
                      give me more details especially server log.
                      X 1 Reply Last reply
                      • X
                        xundre @Guest
                        @Sean said in MMM-GooglePhotos:
                        @xundre
                        Hi , Sorry not exactly sure how to get the logs.
                          @xundre
                          If you are requested to auth your project on each time module running, your authentification was missing something or failed.
                          Try re auth again. (https://github.com/eouia/MMM-GooglePhotos#get-auth-and-albumid)
                          • X
                            xundre @Guest
                            @Sean I do but then it comes back up again in x number of days. I go through the auth process and it works again, but then starts popping up windows to auth after sometime.
                            It used to work consistently without having to reauth , not quite sure what changed.
                              @xundre
                              Very weird. If possible, plz contact me tomorrow through Telegram (my id is @eouia) I’m convenient when normal weekdays 10am ~ 17pm in Central European Timezone. We can see what’s happening on realtime.
                                mcneilp
                                If I have an album with a very large number of photos does it scan all of them? I switched to a small album and it loads nice and fast…but the large one never seems to get a photo. Is this a one time scan (for each time it starts up). Or will it always be super slow.
                                Google Photos auto adds photos to albums based on who is in them, so its a shame to not be able to use one of these albums.
                                M 1 Reply Last reply
                                  mcneilp @mcneilp
                                  @mcneilp If i let it run long enough it loads an image…but sometimes it goes blank for a while. I assume this is because its processing photos. Too bad it can’t just load a few at a time and run fast.
                                    A Former User @mcneilp
                                    @mcneilp
                                    Show me your config. And Google Photos has its API request limit for usage.
                                    • G
                                      gonzonia
                                      Sean,
                                      It seems you make my favorite modules. I’m trying to get the GooglePhotos to work and it does if I leave it long enough. On startup though nothing shows (makes it real hard to configure the appearance). I’m seeing this in the log. Is the album I chose too big? I’m using the config you posted for fullscreen (except I changed to mode: hybrid).
                                      Error: { Error: Client network socket disconnected before secure TLS connection was established
                                      at TLSSocket.onConnectEnd (_tls_wrap.js:1092:19)
                                      at Object.onceWrapper (events.js:273:13)
                                      at TLSSocket.emit (events.js:187:15)
                                      at endReadableNT (_stream_readable.js:1090:12)
                                      at process._tickCallback (internal/process/next_tick.js:63:19)
                                      code: ‘ECONNRESET’,
                                      path: null,
                                      host: ‘photoslibrary.googleapis.com’,
                                      port: 443,
                                      localAddress: undefined }
                                        A Former User @gonzonia
                                        @gonzonia
                                        well, the error log is saying just network problem. However I’m not in front of machine at this moment, but i’ll check this tomorrow
                                        G 1 Reply Last reply
                                        • G
                                          gonzonia
                                          Thanks. Seems to be working now. Like I said, it starts out that way and then eventually loads fine. The album has about 900 photos I’m showing randomly. Trying to decide if I want them fullscreen or not…
                                          • G
                                            gonzonia @Guest
                                            @Sean It’s weird. I had it working. I went to adjust the settings (sizing didn’t look good) and then it stopped. Getting the network error consistently.
                                            This is my latest config. I’ve tried various configurations of showWidth/showHeight and originalWidthPx/originalHeightPx
                                              module: "MMM-GooglePhotos",
                                                albumId: ["XXX"], // your album id(s) from result of
                                               refreshInterval: 1000*60,
                                                scanInterval: 1000*60*10, // too many scans might cause API quota limit also.
                                                //note(2018-07-29). It is some weird. API documents said temporal image url would live for 1 hour, but it might be broken shorter. So, per 10 min scanning could prevent dead url.
                                                sort: "random", //'time', 'reverse', 'random'
                                                showWidth: "800", // how large the photo will be shown as. (e.g;'100%' for fullscreen)
                                                showHeight: "600",
                                                originalWidthPx: 1920, // original size of loaded image. (related with image quality)
                                                originalHeightPx: 1080, // Bigger size gives you better quality, but can give you network burden.
                                                mode: "hybrid", // "cover" or "contain" (https://www.w3schools.com/cssref/css3_pr_background-size.asp)
                                                //ADDED. "hybrid" : if you set as "hybrid" it will change "cover" and "contain" automatically by aspect ratio.
                                            • 14
                                            • 15
                                            • 7 / 15
