    MMM-Face-Reco-DNN - All new Face Recognition
    36 Posts 14 Posters 23.8k Views 17 Watching
    • I Offline
      Ivanov_d
      @ChrizZz I have used camera motion detection and I gave it up, because:
      1. It is not very reliable (maybe it was just my cheap camera that I used for testing back then)
      2. it is resource hungry
      Because of that I use an external wireless PIR sensor which is part of my smart home system to turn on/off my SmartMirror and it works great. Since the motion processing happens on my smart home system and the Mirror is turned on/off via SSH command it takes up no resources at all from the MagicMirror which is already at 60% load when using Facial Recognition.
      • nischiN Offline
        nischi @ChrizZz
        @ChrizZz
        You can use my other Module https://github.com/nischi/MMM-MotionControl to control TV with my Face Reco Module. It communicate with Notifications and is not using an own Camera Stream.
        G 1 Reply Last reply Reply Quote 1
          ChrizZz
          oh, I didn’t know that you have a modul for it. But unfortunately it isn’t working on my Pi. Your modul doesn’t recognize a motion.
          Do I have to uninstall the MMM-MotionDetector first?
          Or do I need to run Face-Reco-DNN or the OCV3 version?
          //edit: I think I know why it isn’t working. Maybe my display isn’t HDMI-CEC ready. I changed the command of your node_helper.js.
          Default:
          turnOn: function() {
          		var self = this;
          		exec('echo "on 0" | cec-client ' + this.config.comport + ' -s -d 1', function (error, stdout, stderr) {
          			self.status = 'on';
          My version:
          		var self = this;
          		exec('vcgencmd display_power 1', function (error, stdout, stderr) {
          			self.status = 'on';
          Instead of sending a note to my display for standby I switch off the display_power. But I can’t wake up the display again. I think I have to use Face-Reco-DNN or Facial-Recognition-OCV3. Currently I don’t use them because I have to do the setup for the DNN version.
          nischiN 1 Reply Last reply Reply Quote 0
          • nischiN Offline
            nischi @ChrizZz
            @ChrizZz
            Yes you need to use one of the Face Reco Module that this works. Better my new Module ;) it’s much more accurate.
              ChrizZz @nischi
              @nischi said in MMM-Face-Reco-DNN - All new Face Recognition:
              @ChrizZz
              Thanks, I will use your new module.
              During the setup I have another issue. It’s when I want to start encoding I get this error message:
                File "encode.py", line 5, in <module>
                  from imutils import paths
                File "/usr/local/lib/python3.7/dist-packages/imutils/__init__.py", line 8, in <module>
                  from .convenience import translate
                File "/usr/local/lib/python3.7/dist-packages/imutils/convenience.py", line 6, in <module>
                  import cv2
              ModuleNotFoundError: No module named 'cv2'
              I think it’s a problem of my OpenCV installation where I skipped the virtualenvs. In step 6 of the tutorial I should do this:
              $ cd ~/.virtualenvs/cv/lib/python3.5/site-packages/
              $ ln -s /usr/local/python/cv2/python-3.5/cv2.cpython-35m-arm-linux-gnueabihf.so cv2.so
              $ cd ~
              I skipped that because I have no idea where I have to create the link when I install this without virtualenvs. But it seems that I have to link it…
              //edit: Key to success:
              cd ~/opencv-4.0.0/build/lib/python3
              sudo cp cv2.cpython-35m-arm-linux-gnueabihf.so /usr/local/lib/python3.5/dist-packages/cv2.so
              • nischiN Offline
                nischi @ChrizZz
                @ChrizZz
                Thanks for your solution. Usually it’s because the link for cv2 is to the wrong python Version.
                Happy to hear that it works.
                  ChrizZz
                  is it common that it takes 40sec between face recognition and turning the TV on?
                  I see it happen after a freshly restarted pi, that it takes 40/45sec. The scenario is that I restart my pi, mm is autostarting and the TV is turned off by the module. Between the restart and the 1st face recognition is ~3min time.
                  • nischiN Offline
                    nischi @ChrizZz
                    @ChrizZz
                    Sound a little bit long to me, for me it works faster. But it took a while until they are startet. Do you use default settings?
                      ChrizZz @nischi
                      @ChrizZz
                      My logs file is also a bit weird:
                      [MMM-Face-Reco-DNN] Users ChrizZz logged in.
                      CECControl received (current, new): off on
                      CECControl received (current, new): on off
                      [MMM-Face-Reco-DNN] Users ChrizZz logged out.
                      This is a 3min part of the logs and the 1st time I was in front of the mirror and recognized by the module this evening.
                      My settings are:
                      			module: 'MMM-CECControl',
                            					  // Comport of your Raspberry Pi
                            					  comport: 'RPI',
                            					  // Turn the TV off if the Mirror start
                             					 offOnStartup: true
                          			module: 'MMM-MotionControl',
                           					   // Delay to turn the TV off
                             						 delay: 60000,
                             					 // Interval to check modules
                       					       interval: 5000,
                       				       // Use the module MMM-Facial-Recognition-OCV3
                        				      useFacialRecognitionOCV3: false,
                         				     // Use the module MMM-Face-Reco-DNN
                         				     useMMMFaceRecoDNN: true,
                         				     // Array where tv should be on
                      				        ontime: []
                      			module: 'MMM-Face-Reco-DNN',
                            					// Logout 15 seconds after user was not detecte anymore, if they will be detected between this 15 Seconds, they delay will start again
                            					logoutDelay: 30000,
                            					// How many time the recognition starts, with a RasPi 3+ it would be good every 2 seconds
                            					checkInterval: 2000,
                            					// Module set used for strangers and if no user is detected
                            					defaultClass: 'default',
                            					// Set of modules which should be shown for every user
                            					everyoneClass: 'everyone',
                            					// XML to recognize with haarcascae
                            					cascade: 'modules/MMM-Face-Reco-DNN/tools/haarcascade_frontalface_default.xml',
                            					// Pre encoded pickle with the faces
                            					encodings: 'modules/MMM-Face-Reco-DNN/tools/encodings.pickle',
                            					// You wanna use pi camera or usb / builtin (1 = raspi camera, 0 = other camera)
                            					usePiCamera: 1,
                            					// Method of face detection (dnn = deep neural network, haar = haarcascade)
                            					method: 'dnn',
                            					// Which face detection model to use. "hog" is less accurate but faster on CPUs. "cnn" is a more accurate deep-learning model which is GPU/CUDA accelerated (if available).
                            					detectionMethod: 'hog',
                            					// How fast in ms should the modules hide and show (face effect)
                            					animationSpeed: 0,
                            					// Path to Python to run the face recognition (null / '' means default path)
                            					pythonPath: null,
                            					// Should shown welcome message over alert module from MagicMirror
                            					welcomeMessage: true
                        dragontattoo
                        Is it working fine??
                          ChrizZz @dragontattoo
                          @dragontattoo said in MMM-Face-Reco-DNN - All new Face Recognition:
                          Depends on how you define working fine…The face recognition is working quite good, setting it up is easy with the advice you get in this thread. For me it’s just the “slow” reaction to activate the display which is an issue. But I’m optimistic that there is a way to solve it and I have a special environment with a display which hasn’t CEC control.
                          • nischiN Offline
                            nischi @ChrizZz
                            @ChrizZz
                            Yes i know this issue. i’m currently working on a bugfix. will tell you if i’m done.
                            • I Offline
                              Ivanov_d
                              I am turning on the monitor using a PIR sensor and it is instant. Keep in mind that it also depends on your monitor, some are slower to respond - this is my second monitor, the first one was very slow to respond to any HDMI related commands.
                                ChrizZz
                                I have a new strange error and I think it’s just if I restart mm with “pm2 restart mm”. If I reboot my pi, everything is fine.
                                SyntaxError: Unexpected token m in JSON at position 0
                                    at JSON.parse (<anonymous>:null:null)
                                    at PythonShell.asJson (/home/pi/MagicMirror/modules/MMM-Face-Reco-DNN/node_modules/python-shell/index.js:375:21)
                                    at /home/pi/MagicMirror/modules/MMM-Face-Reco-DNN/node_modules/python-shell/index.js:326:42
                                    at Array.forEach (<anonymous>:null:null)
                                    at PythonShell.receiveInternal (/home/pi/MagicMirror/modules/MMM-Face-Reco-DNN/node_modules/python-shell/index.js:322:15)
                                    at PythonShell.receiveStderr (/home/pi/MagicMirror/modules/MMM-Face-Reco-DNN/node_modules/python-shell/index.js:306:21)
                                    at Socket.<anonymous> (/home/pi/MagicMirror/modules/MMM-Face-Reco-DNN/node_modules/python-shell/index.js:109:22)
                                    at Socket.emit (events.js:182:13)
                                    at addChunk (_stream_readable.js:279:12)
                                    at readableAddChunk (_stream_readable.js:260:13)
                                    at Socket.Readable.push (_stream_readable.js:219:10)
                                    at Pipe.onread (net.js:636:20)
                                SyntaxError: Unexpected token T in JSON at position 0
                                { Error: mmal: mmal_vc_port_enable: failed to enable port vc.null_sink:in:0(OPQV): ENOSPC
                                mmal: mmal_port_enable: failed to enable connected port (vc.null_sink:in:0(OPQV))0x631b2f0 (ENOSPC)
                                mmal: mmal_connection_enable: output port couldn't be enabled
                                  File "modules/MMM-Face-Reco-DNN/tools/facerecognition.py", line 56, in <module>
                                    vs = VideoStream(usePiCamera=True).start()
                                  File "/home/pi/MagicMirror/modules/MMM-Face-Reco-DNN/tools/stream.py", line 18, in __init__
                                    framerate=framerate)
                                  File "/home/pi/MagicMirror/modules/MMM-Face-Reco-DNN/tools/picam.py", line 10, in __init__
                                    self.camera = PiCamera()
                                  File "/usr/lib/python3/dist-packages/picamera/camera.py", line 433, in __init__
                                    self._init_preview()
                                  File "/usr/lib/python3/dist-packages/picamera/camera.py", line 513, in _init_preview
                                    self, self._camera.outputs[self.CAMERA_PREVIEW_PORT])
                                  File "/usr/lib/python3/dist-packages/picamera/renderers.py", line 558, in __init__
                                    self.renderer.inputs[0].connect(source).enable()
                                  File "/usr/lib/python3/dist-packages/picamera/mmalobj.py", line 2212, in enable
                                    prefix="Failed to enable connection")
                                  File "/usr/lib/python3/dist-packages/picamera/exc.py", line 184, in mmal_check
                                    raise PiCameraMMALError(status, prefix)
                                picamera.exc.PiCameraMMALError: Failed to enable connection: Out of resources
                                    at PythonShell.parseError (/home/pi/MagicMirror/modules/MMM-Face-Reco-DNN/node_modules/python-shell/index.js:268:21)
                                    at terminateIfNeeded (/home/pi/MagicMirror/modules/MMM-Face-Reco-DNN/node_modules/python-shell/index.js:139:32)
                                    at ChildProcess.<anonymous> (/home/pi/MagicMirror/modules/MMM-Face-Reco-DNN/node_modules/python-shell/index.js:131:13)
                                    at ChildProcess.emit (events.js:182:13)
                                    at Process.ChildProcess._handle.onexit (internal/child_process.js:237:12)
                                  executable: 'python3',
                                  options: null,
                                  script: 'modules/MMM-Face-Reco-DNN/tools/facerecognition.py',
                                  args:
                                   [ '--cascade=modules/MMM-Face-Reco-DNN/tools/haarcascade_frontalface_default.xml',
                                     '--encodings=modules/MMM-Face-Reco-DNN/tools/encodings.pickle',
                                     '--usePiCamera=1',
                                     '--method=dnn',
                                     '--detectionMethod=hog',
                                     '--interval=2000',
                                     '--output=0' ],
                                  exitCode: 1 }
                                  Blauenfeldt
                                  I get this too, when my PI can’t connect to the camera. I know that, because if i use
                                  I will get an error there too. A reboot seems to fix it though. I don’t know what makes it happen, but i suspect the cable.
                                    sdetweil @Blauenfeldt
                                    @Blauenfeldt the python code returns an error, but the module does not expect it, and fails.
                                      rjlinden
                                      Will this work if the camera is rotated? If not, can you tell me where I need to change the code?
                                      • H Offline
                                        hANNEsLUL
                                        when im trying to install the face_recogtnition I’m getting this error code:
                                        Does anybody know how to fix this/what is causing this?
                                        Sorry if it’s obvious, im a super noob with this kind of stuff
                                        Cheers
                                        pi@raspberrypi:~ $ pip install face_recognition
                                        Looking in indexes: https://pypi.org/simple, https://www.piwheels.org/simple
                                        Collecting face_recognition
                                          Using cached https://files.pythonhosted.org/packages/1e/95/f6c9330f54ab07bfa032bf3715c12455a381083125d8880c43cbe76bb3d0/face_recognition-1.3.0-py2.py3-none-any.whl
                                        Requirement already satisfied: dlib>=19.7 in ./.local/lib/python2.7/site-packages (from face_recognition) (19.19.0)
                                        Collecting face-recognition-models>=0.3.0 (from face_recognition)
                                          Downloading https://www.piwheels.org/simple/face-recognition-models/face_recognition_models-0.3.0-py2.py3-none-any.whl (100.6MB)
                                            99% |████████████████████████████████| 100.6MB 1.7MB/s eta 0:00:01
                                        Exception:
                                          File "/usr/lib/python2.7/dist-packages/pip/_internal/cli/base_command.py", line 143, in main
                                            status = self.run(options, args)
                                          File "/usr/lib/python2.7/dist-packages/pip/_internal/commands/install.py", line 338, in run
                                            resolver.resolve(requirement_set)
                                          File "/usr/lib/python2.7/dist-packages/pip/_internal/resolve.py", line 102, in resolve
                                            self._resolve_one(requirement_set, req)
                                          File "/usr/lib/python2.7/dist-packages/pip/_internal/resolve.py", line 256, in _resolve_one
                                            abstract_dist = self._get_abstract_dist_for(req_to_install)
                                          File "/usr/lib/python2.7/dist-packages/pip/_internal/resolve.py", line 209, in _get_abstract_dist_for
                                            self.require_hashes
                                          File "/usr/lib/python2.7/dist-packages/pip/_internal/operations/prepare.py", line 283, in prepare_linked_requirement
                                            progress_bar=self.progress_bar
                                          File "/usr/lib/python2.7/dist-packages/pip/_internal/download.py", line 836, in unpack_url
                                            progress_bar=progress_bar
                                          File "/usr/lib/python2.7/dist-packages/pip/_internal/download.py", line 673, in unpack_http_url
                                            progress_bar)
                                          File "/usr/lib/python2.7/dist-packages/pip/_internal/download.py", line 897, in _download_http_url
                                            _download_url(resp, link, content_file, hashes, progress_bar)
                                          File "/usr/lib/python2.7/dist-packages/pip/_internal/download.py", line 617, in _download_url
                                            hashes.check_against_chunks(downloaded_chunks)
                                          File "/usr/lib/python2.7/dist-packages/pip/_internal/utils/hashes.py", line 48, in check_against_chunks
                                            for chunk in chunks:
                                          File "/usr/lib/python2.7/dist-packages/pip/_internal/download.py", line 585, in written_chunks
                                          File "/usr/lib/python2.7/dist-packages/pip/_internal/utils/ui.py", line 159, in iter
                                            for x in it:
                                          File "/usr/lib/python2.7/dist-packages/pip/_internal/download.py", line 574, in resp_read
                                            decode_content=False):
                                          File "/usr/share/python-wheels/urllib3-1.24.1-py2.py3-none-any.whl/urllib3/response.py", line 494, in stream
                                            data = self.read(amt=amt, decode_content=decode_content)
                                          File "/usr/share/python-wheels/urllib3-1.24.1-py2.py3-none-any.whl/urllib3/response.py", line 442, in read
                                            data = self._fp.read(amt)
                                          File "/usr/share/python-wheels/CacheControl-0.11.7-py2.py3-none-any.whl/cachecontrol/filewrapper.py", line 63, in read
                                            self._close()
                                          File "/usr/share/python-wheels/CacheControl-0.11.7-py2.py3-none-any.whl/cachecontrol/filewrapper.py", line 50, in _close
                                            self.__callback(self.__buf.getvalue())
                                          File "/usr/share/python-wheels/CacheControl-0.11.7-py2.py3-none-any.whl/cachecontrol/controller.py", line 275, in cache_response
                                            self.serializer.dumps(request, response, body=body),
                                          File "/usr/share/python-wheels/CacheControl-0.11.7-py2.py3-none-any.whl/cachecontrol/serialize.py", line 87, in dumps
                                            ).encode("utf8"),
                                        MemoryError
                                        • G Offline
                                          gaudouy @hANNEsLUL
                                          @hANNEsLUL
                                          Try this :
                                          pip --no-cache-dir install face_recognition
                                          -python setup.py install
                                          • G Offline
                                            gaudouy
                                            What is the best camera for this module ?
                                            Pi NoIR Camera V2
                                            alt text
                                            https://www.raspberrypi.org/products/pi-noir-camera-v2/
                                            Or
                                            Camera Module V2
                                            alt text
                                            https://www.raspberrypi.org/products/camera-module-v2/
                                            Thanks for advance :)
