    MMM-Face-Reco-DNN - All new Face Recognition
    36 Posts 14 Posters 25.0k Views 17 Watching
      ChrizZz
      damn - 2nd try without a virtual environment.
      @nischi: Is there a chance that you merge your module also with MMM-MotionDetector? Currently I use the camera to activate and deactive my screen and Google told me that it isn’t possible that 2 processes use the same camera. The suggested solution was to use a 2nd camera, merge both processes or stream the camera picture.
      nischiN 1 Reply Last reply
      • I
        Ivanov_d
        @ChrizZz I have used camera motion detection and I gave it up, because:
        1. It is not very reliable (maybe it was just my cheap camera that I used for testing back then)
        2. it is resource hungry
        Because of that I use an external wireless PIR sensor which is part of my smart home system to turn on/off my SmartMirror and it works great. Since the motion processing happens on my smart home system and the Mirror is turned on/off via SSH command it takes up no resources at all from the MagicMirror which is already at 60% load when using Facial Recognition.
        Reply Quote 2
        • nischiN
          nischi @ChrizZz
          @ChrizZz
          You can use my other Module https://github.com/nischi/MMM-MotionControl to control TV with my Face Reco Module. It communicate with Notifications and is not using an own Camera Stream.
          G 1 Reply Last reply
            ChrizZz
            oh, I didn’t know that you have a modul for it. But unfortunately it isn’t working on my Pi. Your modul doesn’t recognize a motion.
            Do I have to uninstall the MMM-MotionDetector first?
            Or do I need to run Face-Reco-DNN or the OCV3 version?
            //edit: I think I know why it isn’t working. Maybe my display isn’t HDMI-CEC ready. I changed the command of your node_helper.js.
            Default:
            turnOn: function() {
            		var self = this;
            		exec('echo "on 0" | cec-client ' + this.config.comport + ' -s -d 1', function (error, stdout, stderr) {
            			self.status = 'on';
            My version:
            		var self = this;
            		exec('vcgencmd display_power 1', function (error, stdout, stderr) {
            			self.status = 'on';
            Instead of sending a note to my display for standby I switch off the display_power. But I can’t wake up the display again. I think I have to use Face-Reco-DNN or Facial-Recognition-OCV3. Currently I don’t use them because I have to do the setup for the DNN version.
            • nischiN
              nischi @ChrizZz
              @ChrizZz
              Yes you need to use one of the Face Reco Module that this works. Better my new Module ;) it’s much more accurate.
              C 1 Reply Last reply
                ChrizZz @nischi
                @nischi said in MMM-Face-Reco-DNN - All new Face Recognition:
                @ChrizZz
                Thanks, I will use your new module.
                During the setup I have another issue. It’s when I want to start encoding I get this error message:
                  File "encode.py", line 5, in <module>
                    from imutils import paths
                  File "/usr/local/lib/python3.7/dist-packages/imutils/__init__.py", line 8, in <module>
                    from .convenience import translate
                  File "/usr/local/lib/python3.7/dist-packages/imutils/convenience.py", line 6, in <module>
                    import cv2
                ModuleNotFoundError: No module named 'cv2'
                I think it’s a problem of my OpenCV installation where I skipped the virtualenvs. In step 6 of the tutorial I should do this:
                $ cd ~/.virtualenvs/cv/lib/python3.5/site-packages/
                $ ln -s /usr/local/python/cv2/python-3.5/cv2.cpython-35m-arm-linux-gnueabihf.so cv2.so
                $ cd ~
                I skipped that because I have no idea where I have to create the link when I install this without virtualenvs. But it seems that I have to link it…
                //edit: Key to success:
                cd ~/opencv-4.0.0/build/lib/python3
                sudo cp cv2.cpython-35m-arm-linux-gnueabihf.so /usr/local/lib/python3.5/dist-packages/cv2.so
                • nischiN
                  nischi @ChrizZz
                  @ChrizZz
                  Thanks for your solution. Usually it’s because the link for cv2 is to the wrong python Version.
                  Happy to hear that it works.
                    ChrizZz
                    is it common that it takes 40sec between face recognition and turning the TV on?
                    I see it happen after a freshly restarted pi, that it takes 40/45sec. The scenario is that I restart my pi, mm is autostarting and the TV is turned off by the module. Between the restart and the 1st face recognition is ~3min time.
                    • nischiN
                      nischi @ChrizZz
                      @ChrizZz
                      Sound a little bit long to me, for me it works faster. But it took a while until they are startet. Do you use default settings?
                        ChrizZz @nischi
                        @ChrizZz
                        My logs file is also a bit weird:
                        [MMM-Face-Reco-DNN] Users ChrizZz logged in.
                        CECControl received (current, new): off on
                        CECControl received (current, new): on off
                        [MMM-Face-Reco-DNN] Users ChrizZz logged out.
                        This is a 3min part of the logs and the 1st time I was in front of the mirror and recognized by the module this evening.
                        My settings are:
                        			module: 'MMM-CECControl',
                              					  // Comport of your Raspberry Pi
                              					  comport: 'RPI',
                              					  // Turn the TV off if the Mirror start
                               					 offOnStartup: true
                            			module: 'MMM-MotionControl',
                             					   // Delay to turn the TV off
                               						 delay: 60000,
                               					 // Interval to check modules
                         					       interval: 5000,
                         				       // Use the module MMM-Facial-Recognition-OCV3
                          				      useFacialRecognitionOCV3: false,
                           				     // Use the module MMM-Face-Reco-DNN
                           				     useMMMFaceRecoDNN: true,
                           				     // Array where tv should be on
                        				        ontime: []
                        			module: 'MMM-Face-Reco-DNN',
                              					// Logout 15 seconds after user was not detecte anymore, if they will be detected between this 15 Seconds, they delay will start again
                              					logoutDelay: 30000,
                              					// How many time the recognition starts, with a RasPi 3+ it would be good every 2 seconds
                              					checkInterval: 2000,
                              					// Module set used for strangers and if no user is detected
                              					defaultClass: 'default',
                              					// Set of modules which should be shown for every user
                              					everyoneClass: 'everyone',
                              					// XML to recognize with haarcascae
                              					cascade: 'modules/MMM-Face-Reco-DNN/tools/haarcascade_frontalface_default.xml',
                              					// Pre encoded pickle with the faces
                              					encodings: 'modules/MMM-Face-Reco-DNN/tools/encodings.pickle',
                              					// You wanna use pi camera or usb / builtin (1 = raspi camera, 0 = other camera)
                              					usePiCamera: 1,
                              					// Method of face detection (dnn = deep neural network, haar = haarcascade)
                              					method: 'dnn',
                              					// Which face detection model to use. "hog" is less accurate but faster on CPUs. "cnn" is a more accurate deep-learning model which is GPU/CUDA accelerated (if available).
                              					detectionMethod: 'hog',
                              					// How fast in ms should the modules hide and show (face effect)
                              					animationSpeed: 0,
                              					// Path to Python to run the face recognition (null / '' means default path)
                              					pythonPath: null,
                              					// Should shown welcome message over alert module from MagicMirror
                              					welcomeMessage: true
                          dragontattoo
                          Is it working fine??
                            ChrizZz @dragontattoo
                            @dragontattoo said in MMM-Face-Reco-DNN - All new Face Recognition:
                            Depends on how you define working fine…The face recognition is working quite good, setting it up is easy with the advice you get in this thread. For me it’s just the “slow” reaction to activate the display which is an issue. But I’m optimistic that there is a way to solve it and I have a special environment with a display which hasn’t CEC control.
                            • nischiN
                              nischi @ChrizZz
                              @ChrizZz
                              Yes i know this issue. i’m currently working on a bugfix. will tell you if i’m done.
                              Reply Quote 2
                              • I
                                Ivanov_d
                                I am turning on the monitor using a PIR sensor and it is instant. Keep in mind that it also depends on your monitor, some are slower to respond - this is my second monitor, the first one was very slow to respond to any HDMI related commands.
                                  ChrizZz
                                  I have a new strange error and I think it’s just if I restart mm with “pm2 restart mm”. If I reboot my pi, everything is fine.
                                  SyntaxError: Unexpected token m in JSON at position 0
                                      at JSON.parse (<anonymous>:null:null)
                                      at PythonShell.asJson (/home/pi/MagicMirror/modules/MMM-Face-Reco-DNN/node_modules/python-shell/index.js:375:21)
                                      at /home/pi/MagicMirror/modules/MMM-Face-Reco-DNN/node_modules/python-shell/index.js:326:42
                                      at Array.forEach (<anonymous>:null:null)
                                      at PythonShell.receiveInternal (/home/pi/MagicMirror/modules/MMM-Face-Reco-DNN/node_modules/python-shell/index.js:322:15)
                                      at PythonShell.receiveStderr (/home/pi/MagicMirror/modules/MMM-Face-Reco-DNN/node_modules/python-shell/index.js:306:21)
                                      at Socket.<anonymous> (/home/pi/MagicMirror/modules/MMM-Face-Reco-DNN/node_modules/python-shell/index.js:109:22)
                                      at Socket.emit (events.js:182:13)
                                      at addChunk (_stream_readable.js:279:12)
                                      at readableAddChunk (_stream_readable.js:260:13)
                                      at Socket.Readable.push (_stream_readable.js:219:10)
                                      at Pipe.onread (net.js:636:20)
                                  SyntaxError: Unexpected token T in JSON at position 0
                                  { Error: mmal: mmal_vc_port_enable: failed to enable port vc.null_sink:in:0(OPQV): ENOSPC
                                  mmal: mmal_port_enable: failed to enable connected port (vc.null_sink:in:0(OPQV))0x631b2f0 (ENOSPC)
                                  mmal: mmal_connection_enable: output port couldn't be enabled
                                    File "modules/MMM-Face-Reco-DNN/tools/facerecognition.py", line 56, in <module>
                                      vs = VideoStream(usePiCamera=True).start()
                                    File "/home/pi/MagicMirror/modules/MMM-Face-Reco-DNN/tools/stream.py", line 18, in __init__
                                      framerate=framerate)
                                    File "/home/pi/MagicMirror/modules/MMM-Face-Reco-DNN/tools/picam.py", line 10, in __init__
                                      self.camera = PiCamera()
                                    File "/usr/lib/python3/dist-packages/picamera/camera.py", line 433, in __init__
                                      self._init_preview()
                                    File "/usr/lib/python3/dist-packages/picamera/camera.py", line 513, in _init_preview
                                      self, self._camera.outputs[self.CAMERA_PREVIEW_PORT])
                                    File "/usr/lib/python3/dist-packages/picamera/renderers.py", line 558, in __init__
                                      self.renderer.inputs[0].connect(source).enable()
                                    File "/usr/lib/python3/dist-packages/picamera/mmalobj.py", line 2212, in enable
                                      prefix="Failed to enable connection")
                                    File "/usr/lib/python3/dist-packages/picamera/exc.py", line 184, in mmal_check
                                      raise PiCameraMMALError(status, prefix)
                                  picamera.exc.PiCameraMMALError: Failed to enable connection: Out of resources
                                      at PythonShell.parseError (/home/pi/MagicMirror/modules/MMM-Face-Reco-DNN/node_modules/python-shell/index.js:268:21)
                                      at terminateIfNeeded (/home/pi/MagicMirror/modules/MMM-Face-Reco-DNN/node_modules/python-shell/index.js:139:32)
                                      at ChildProcess.<anonymous> (/home/pi/MagicMirror/modules/MMM-Face-Reco-DNN/node_modules/python-shell/index.js:131:13)
                                      at ChildProcess.emit (events.js:182:13)
                                      at Process.ChildProcess._handle.onexit (internal/child_process.js:237:12)
                                    executable: 'python3',
                                    options: null,
                                    script: 'modules/MMM-Face-Reco-DNN/tools/facerecognition.py',
                                    args:
                                     [ '--cascade=modules/MMM-Face-Reco-DNN/tools/haarcascade_frontalface_default.xml',
                                       '--encodings=modules/MMM-Face-Reco-DNN/tools/encodings.pickle',
                                       '--usePiCamera=1',
                                       '--method=dnn',
                                       '--detectionMethod=hog',
                                       '--interval=2000',
                                       '--output=0' ],
                                    exitCode: 1 }
                                    Blauenfeldt
                                    I get this too, when my PI can’t connect to the camera. I know that, because if i use
                                    I will get an error there too. A reboot seems to fix it though. I don’t know what makes it happen, but i suspect the cable.
                                      sdetweil @Blauenfeldt
                                      @Blauenfeldt the python code returns an error, but the module does not expect it, and fails.
                                        rjlinden
                                        Will this work if the camera is rotated? If not, can you tell me where I need to change the code?
                                        • H
                                          hANNEsLUL
                                          when im trying to install the face_recogtnition I’m getting this error code:
                                          Does anybody know how to fix this/what is causing this?
                                          Sorry if it’s obvious, im a super noob with this kind of stuff
                                          Cheers
                                          pi@raspberrypi:~ $ pip install face_recognition
                                          Looking in indexes: https://pypi.org/simple, https://www.piwheels.org/simple
                                          Collecting face_recognition
                                            Using cached https://files.pythonhosted.org/packages/1e/95/f6c9330f54ab07bfa032bf3715c12455a381083125d8880c43cbe76bb3d0/face_recognition-1.3.0-py2.py3-none-any.whl
                                          Requirement already satisfied: dlib>=19.7 in ./.local/lib/python2.7/site-packages (from face_recognition) (19.19.0)
                                          Collecting face-recognition-models>=0.3.0 (from face_recognition)
                                            Downloading https://www.piwheels.org/simple/face-recognition-models/face_recognition_models-0.3.0-py2.py3-none-any.whl (100.6MB)
                                              99% |████████████████████████████████| 100.6MB 1.7MB/s eta 0:00:01
                                          Exception:
                                            File "/usr/lib/python2.7/dist-packages/pip/_internal/cli/base_command.py", line 143, in main
                                              status = self.run(options, args)
                                            File "/usr/lib/python2.7/dist-packages/pip/_internal/commands/install.py", line 338, in run
                                              resolver.resolve(requirement_set)
                                            File "/usr/lib/python2.7/dist-packages/pip/_internal/resolve.py", line 102, in resolve
                                              self._resolve_one(requirement_set, req)
                                            File "/usr/lib/python2.7/dist-packages/pip/_internal/resolve.py", line 256, in _resolve_one
                                              abstract_dist = self._get_abstract_dist_for(req_to_install)
                                            File "/usr/lib/python2.7/dist-packages/pip/_internal/resolve.py", line 209, in _get_abstract_dist_for
                                              self.require_hashes
                                            File "/usr/lib/python2.7/dist-packages/pip/_internal/operations/prepare.py", line 283, in prepare_linked_requirement
                                              progress_bar=self.progress_bar
                                            File "/usr/lib/python2.7/dist-packages/pip/_internal/download.py", line 836, in unpack_url
                                              progress_bar=progress_bar
                                            File "/usr/lib/python2.7/dist-packages/pip/_internal/download.py", line 673, in unpack_http_url
                                              progress_bar)
                                            File "/usr/lib/python2.7/dist-packages/pip/_internal/download.py", line 897, in _download_http_url
                                              _download_url(resp, link, content_file, hashes, progress_bar)
                                            File "/usr/lib/python2.7/dist-packages/pip/_internal/download.py", line 617, in _download_url
                                              hashes.check_against_chunks(downloaded_chunks)
                                            File "/usr/lib/python2.7/dist-packages/pip/_internal/utils/hashes.py", line 48, in check_against_chunks
                                              for chunk in chunks:
                                            File "/usr/lib/python2.7/dist-packages/pip/_internal/download.py", line 585, in written_chunks
                                            File "/usr/lib/python2.7/dist-packages/pip/_internal/utils/ui.py", line 159, in iter
                                              for x in it:
                                            File "/usr/lib/python2.7/dist-packages/pip/_internal/download.py", line 574, in resp_read
                                              decode_content=False):
                                            File "/usr/share/python-wheels/urllib3-1.24.1-py2.py3-none-any.whl/urllib3/response.py", line 494, in stream
                                              data = self.read(amt=amt, decode_content=decode_content)
                                            File "/usr/share/python-wheels/urllib3-1.24.1-py2.py3-none-any.whl/urllib3/response.py", line 442, in read
                                              data = self._fp.read(amt)
                                            File "/usr/share/python-wheels/CacheControl-0.11.7-py2.py3-none-any.whl/cachecontrol/filewrapper.py", line 63, in read
                                              self._close()
                                            File "/usr/share/python-wheels/CacheControl-0.11.7-py2.py3-none-any.whl/cachecontrol/filewrapper.py", line 50, in _close
                                              self.__callback(self.__buf.getvalue())
                                            File "/usr/share/python-wheels/CacheControl-0.11.7-py2.py3-none-any.whl/cachecontrol/controller.py", line 275, in cache_response
                                              self.serializer.dumps(request, response, body=body),
                                            File "/usr/share/python-wheels/CacheControl-0.11.7-py2.py3-none-any.whl/cachecontrol/serialize.py", line 87, in dumps
                                              ).encode("utf8"),
                                          MemoryError
                                          • G
                                            gaudouy @hANNEsLUL
                                            @hANNEsLUL
                                            Try this :
                                            pip --no-cache-dir install face_recognition
                                            -python setup.py install
                                            H 1 Reply Last reply
