    Error code EADDRINUSE
    41 Posts 3 Posters 19.1k Views 3 Watching
      PXNDA
      I mean that Electron won’t accept 0.0.0.0
        PXNDA
        It works fine with localhost.
          PXNDA
          I’m trying to use MMM-Remote-Control.
            sdetweil @PXNDA
            @PXNDA that just says listen anywhere (all adapters)
            localhost means ONLY localhost, ONLY from THAT machine to THAT machine
            external machines should not be able to connect
            with 0.0.0.0 you also need to open the whitelist (allowed sources) , by default NO other ip address (localhost only still)…
            RemoteControl ois listening on the MM ip address (using the express server and routes/(paths in the url)
            so if ONLY localhost then cannot connect from outside the pi)… makes ;remote ’ control pretty hard…
              PXNDA
              I’ve also done that, no change.
              S mumblebajM 2 Replies Last reply
                sdetweil @PXNDA
                @PXNDA is this windows? Open the firewall on 8080
                  PXNDA
                  • mumblebajM
                    mumblebaj Module Developer @PXNDA
                    @PXNDA It was suggested with the v2.8 update that anybody running Electron should update to the latest Raspbian version prior to upgrading to v2.8. Have you updated your Raspbian to the latest version?
                      PXNDA
                      I’ve opened a new rule on firewall for port 8080 @sdetweil and there is no change. @mumblebaj I’m using Windows 10.
                        sdetweil @PXNDA
                        @PXNDA ok, change the config.js port to something else, 8090 for example
                        • 3 / 3
