    Installing on a Pi Zero
    175 Posts 33 Posters 294.0k Views 33 Watching
      sdetweil @liamangelus
      @liamangelus git clone the mm repo from GitHub.
      Then edit the package.json file and change the number behind electron to the string mentioned above “^2.0.0”
      Then follow the manual install steps from the readme
      qu1queQ 1 Reply Last reply Reply Quote 1
      • L Offline
        liamangelus
        After editing the electron version in the package.json as ^ 2.0.0, I will apply the other steps in the same way. If I encounter a problem I would like to help you again. Thanx a lot.
        • qu1queQ Offline
          qu1que Project Sponsor @sdetweil
          That works for me. Thanks!
          • qu1queQ Offline
            Again the same problem when updating to 2.8.0 version
              sdetweil @qu1que
              @qu1que yes, sadly the electron folks have not provided updates for pi zero
                johnnyt1111
                looks like changing the electron version to “^2.0.0” isn;t working anymore as it tries to intsall 1.8.0 and it gets the following error. Any idea why it isn’t looking for the version in the package.json file? thanks!
                “Error: Failed to find Electron v1.8.0 for linux-armv6l at https://github.com/electron/electron/releases/download/v1.8.0/chromedriver-v1.8.0-linux-armv6l.zip”
                • I Offline
                  InfiProj
                  Solve it like this: “npm install --arch=armv7l”
                  qu1queQ 1 Reply Last reply Reply Quote 2
                  • qu1queQ Offline
                    qu1que Project Sponsor @InfiProj
                    @InfiProj
                    Did u mean that instead of simply “npm install” ?
                    I’ll try on next update
                    • I Offline
                      InfiProj @qu1que
                      @qu1que
                      Yes, I just update installation command by --arch argument, and MM installs w/o errors.
                        sdetweil @InfiProj
                        @InfiProj is there a command u could use to tell this is a zero, So I could update the installer?
                        • I Offline
                          InfiProj @sdetweil
                          In Linux we can ask OS about architecture. “arch” - this command returns CPU architecture. For rpi zero - armv6l, for rpi 3b - armv7l. Maybe that helps you.
                            sdetweil @InfiProj
                            @InfiProj it does. Thx
                            Not near computer, maybe uname provides info too
                            • I Offline
                              InfiProj
                              “uname -m” - does the same as “arch”,
                              “uname -p” and “uname -i” says unknown.
                              • K Offline
                                kingfisher
                                Thanks for the PDF guide/instructions, after a week of tinkering and googling this was the only method I got to work with my Zero (Wish I started with this guide!)
                                  sdetweil @InfiProj
                                  @InfiProj thanks… I’ve updated my new test installer to use that info
                                  https://forum.magicmirror.builders/topic/10171/anyone-want-to-try-updated-installer?page=1
                                  my intent is to submit this new installer to replace the project version…
                                  • N Offline
                                    nigel-daniels
                                    I just attempted to install 2.11.0 on a Pi0 W, I got the following error running npm install:
                                    npm install
                                    npm ERR! Cannot read property 'resolve' of undefined
                                    npm ERR!     /home/pi/.npm/_logs/2020-04-12T20_08_37_082Z-debug.log
                                    The log contains:
                                    1 verbose cli [ '/usr/local/bin/node', '/usr/local/bin/npm', 'install' ]
                                    2 info using npm@6.14.4
                                    3 info using node@v10.20.0
                                    4 verbose npm-session ed148b8dcfcaa591
                                    5 silly install runPreinstallTopLevelLifecycles
                                    6 silly preinstall magicmirror@2.11.0
                                    7 info lifecycle magicmirror@2.11.0~preinstall: magicmirror@2.11.0
                                    8 silly install loadCurrentTree
                                    9 silly install readLocalPackageData
                                    10 timing stage:loadCurrentTree Completed in 897ms
                                    11 silly install loadIdealTree
                                    12 silly install cloneCurrentTreeToIdealTree
                                    13 timing stage:loadIdealTree:cloneCurrentTree Completed in 10ms
                                    14 silly install loadShrinkwrap
                                    15 timing stage:loadIdealTree:loadShrinkwrap Completed in 42390ms
                                    16 silly install loadAllDepsIntoIdealTree
                                    17 silly fetchPackageMetaData error for grunt@latest Cannot read property 'resol
                                    ve' of undefined
                                    18 silly fetchPackageMetaData error for grunt-eslint@latest Cannot read property
                                    19 silly fetchPackageMetaData error for grunt-jsonlint@latest Cannot read property 'resolve' of undefined
                                    20 silly fetchPackageMetaData error for grunt-markdownlint@latest Cannot read property 'resolve' of undefined
                                    21 silly fetchPackageMetaData error for grunt-stylelint@latest Cannot read property 'resolve' of undefined
                                    22 silly fetchPackageMetaData error for grunt-yamllint@latest Cannot read property 'resolve' of undefined
                                    23 silly fetchPackageMetaData error for stylelint@latest Cannot read property 'resolve' of undefined
                                    24 silly fetchPackageMetaData error for stylelint-config-standard@latest Cannot read property 'resolve' of undefined
                                    25 silly fetchPackageMetaData error for time-grunt@latest Cannot read property 'resolve' of undefined
                                    26 silly fetchPackageMetaData error for feedme@latest Cannot read property 'resolve' of undefined
                                    27 silly fetchPackageMetaData error for iconv-lite@latest Cannot read property 'resolve' of undefined
                                    28 silly fetchPackageMetaData error for moment@latest Cannot read property 'resolve' of undefined
                                    29 silly fetchPackageMetaData error for valid-url@latest Cannot read property 'resolve' of undefined
                                    30 silly fetchPackageMetaData error for feedme@latest Cannot read property 'resolve' of undefined
                                    31 silly fetchPackageMetaData error for iconv-lite@latest Cannot read property 'resolve' of undefined
                                    32 silly fetchPackageMetaData error for moment@latest Cannot read property 'resolve' of undefined
                                    33 silly fetchPackageMetaData error for valid-url@latest Cannot read property 'resolve' of undefined
                                    34 timing stage:rollbackFailedOptional Completed in 6ms
                                    35 timing stage:runTopLevelLifecycles Completed in 47409ms
                                    36 silly saveTree magicmirror@2.11.0
                                    36 silly saveTree ├─┬ chai-as-promised@7.1.1
                                    36 silly saveTree │ └── check-error@1.0.2
                                    36 silly saveTree     │ └── querystring@0.2.0
                                    36 silly saveTree     ├── wdio-dot-reporter@0.0.10
                                    36 silly saveTree     └── wgxpath@1.0.0
                                    37 verbose stack TypeError: Cannot read property 'resolve' of undefined
                                    37 verbose stack     at regFetch (/usr/local/lib/node_modules/npm/node_modules/n
                                    pm-registry-fetch/index.js:88:23)
                                    37 verbose stack     at fetchPackument (/usr/local/lib/node_modules/npm/node_mod
                                    ules/pacote/lib/fetchers/registry/packument.js:42:10)
                                    37 verbose stack     at packument (/usr/local/lib/node_modules/npm/node_modules/
                                    pacote/lib/fetchers/registry/packument.js:20:10)
                                    37 verbose stack     at getManifest (/usr/local/lib/node_modules/npm/node_module
                                    s/pacote/lib/fetchers/registry/manifest.js:22:10)
                                    37 verbose stack     at manifest (/usr/local/lib/node_modules/npm/node_modules/p
                                    acote/lib/fetchers/registry/manifest.js:13:10)
                                    37 verbose stack     at Object.manifest (/usr/local/lib/node_modules/npm/node_mo
                                    dules/pacote/lib/fetchers/registry/index.js:17:12)
                                    37 verbose stack     at Object.Fetcher#manifest [as manifest] (/usr/local/lib/no
                                    de_modules/npm/node_modules/genfun/lib/genfun.js:15:38)
                                    acote/lib/fetch.js:23:18)
                                    37 verbose stack     at pinflight (/usr/local/lib/node_modules/npm/node_modules/pacote/manifest.js:24:12)
                                    37 verbose stack     at /usr/local/lib/node_modules/npm/node_modules/promiseinflight/inflight.js:29:24
                                    37 verbose stack     at Promise._execute (/usr/local/lib/node_modules/npm/node_modules/bluebird/js/release/debuggability.js:313:9)
                                    37 verbose stack     at Promise._resolveFromExecutor (/usr/local/lib/node_modules/npm/node_modules/bluebird/js/release/promise.js:488:18)
                                    37 verbose stack     at new Promise (/usr/local/lib/node_modules/npm/node_modules/bluebird/js/release/promise.js:79:10)
                                    37 verbose stack     at _inflight (/usr/local/lib/node_modules/npm/node_modules/promise-inflight/inflight.js:28:25)
                                    37 verbose stack     at /usr/local/lib/node_modules/npm/node_modules/promise-inflight/inflight.js:22:14
                                    37 verbose stack     at tryCatcher (/usr/local/lib/node_modules/npm/node_modules/bluebird/js/release/util.js:16:23)
                                    38 verbose cwd /home/pi/MagicMirror
                                    39 verbose Linux 4.9.35+
                                    40 verbose argv "/usr/local/bin/node" "/usr/local/bin/npm" "install"
                                    41 verbose node v10.20.0
                                    42 verbose npm  v6.14.4
                                    43 error Cannot read property 'resolve' of undefined
                                    44 verbose exit [ 1, true ]
                                    Any idea where resolve should be set and what is missing?
                                      sdetweil @nigel-daniels
                                      @nigel-daniels i do not know… please use the scripted install from here
                                      look at the instructions
                                      also, rename MagicMirror folder out of the way… or erase it… install thinks it is doing for the 1st time.
                                      • N Offline
                                        nigel-daniels @sdetweil
                                        @sdetweil hi, I have everything else set up and don’t really want to change thing, I had configured the PiZero some time ago. I was just reinstalling MM2. I decided I had left it so long since the last up date I just backed up my modules + config and have performed a reinstall. As far as I can tell the script is attempting a full config of the pi0?
                                          @nigel-daniels no, just mm
                                          • N Offline
                                            @sdetweil looks like the script gets to the same place :(
                                            Installing dependencies ...
                                            npm WARN optional SKIPPING OPTIONAL DEPENDENCY: electron@^6.1.7 (node_modules/electron):
                                            npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Cannot read property 'resolve' of undefined
                                            npm ERR!     /home/pi/.npm/_logs/2020-04-13T15_17_35_327Z-debug.log
                                            Unable to install dependencies!
                                            The config.json only mentions electron in the optional dependancies so I don’t know where the resolve comes from. It looks to the the property of some var that is not being set.
                                            • 4 / 9
