    Installing on a Pi Zero
    175 Posts 33 Posters 294.0k Views 33 Watching
      johnnyt1111 @qu1que
      @qu1que Thanks for the link! Glad I’m not the only looking into this problem, hopefully we can get electron 3 working on the pi zero. but updating the package.json electron to “^2.0.0” will install 2.0.18 and will work with latest version of magic mirror
      • L Offline
        liamangelus
        can you explain in detail how to do it? I’m new and have the same problem
          sdetweil @liamangelus
          @liamangelus git clone the mm repo from GitHub.
          Then edit the package.json file and change the number behind electron to the string mentioned above “^2.0.0”
          Then follow the manual install steps from the readme
          qu1queQ 1 Reply Last reply Reply Quote 1
          • L Offline
            liamangelus
            After editing the electron version in the package.json as ^ 2.0.0, I will apply the other steps in the same way. If I encounter a problem I would like to help you again. Thanx a lot.
            • qu1queQ Offline
              qu1que Project Sponsor @sdetweil
              That works for me. Thanks!
              • qu1queQ Offline
                Again the same problem when updating to 2.8.0 version
                  sdetweil @qu1que
                  @qu1que yes, sadly the electron folks have not provided updates for pi zero
                    johnnyt1111
                    looks like changing the electron version to “^2.0.0” isn;t working anymore as it tries to intsall 1.8.0 and it gets the following error. Any idea why it isn’t looking for the version in the package.json file? thanks!
                    “Error: Failed to find Electron v1.8.0 for linux-armv6l at https://github.com/electron/electron/releases/download/v1.8.0/chromedriver-v1.8.0-linux-armv6l.zip”
                    • I Offline
                      InfiProj
                      Solve it like this: “npm install --arch=armv7l”
                      qu1queQ 1 Reply Last reply Reply Quote 2
                      • qu1queQ Offline
                        qu1que Project Sponsor @InfiProj
                        @InfiProj
                        Did u mean that instead of simply “npm install” ?
                        I’ll try on next update
                        • I Offline
                          InfiProj @qu1que
                          @qu1que
                          Yes, I just update installation command by --arch argument, and MM installs w/o errors.
                            sdetweil @InfiProj
                            @InfiProj is there a command u could use to tell this is a zero, So I could update the installer?
                            • I Offline
                              InfiProj @sdetweil
                              In Linux we can ask OS about architecture. “arch” - this command returns CPU architecture. For rpi zero - armv6l, for rpi 3b - armv7l. Maybe that helps you.
                                sdetweil @InfiProj
                                @InfiProj it does. Thx
                                Not near computer, maybe uname provides info too
                                • I Offline
                                  InfiProj
                                  “uname -m” - does the same as “arch”,
                                  “uname -p” and “uname -i” says unknown.
                                  • K Offline
                                    kingfisher
                                    Thanks for the PDF guide/instructions, after a week of tinkering and googling this was the only method I got to work with my Zero (Wish I started with this guide!)
                                      sdetweil @InfiProj
                                      @InfiProj thanks… I’ve updated my new test installer to use that info
                                      https://forum.magicmirror.builders/topic/10171/anyone-want-to-try-updated-installer?page=1
                                      my intent is to submit this new installer to replace the project version…
                                      • N Offline
                                        nigel-daniels
                                        I just attempted to install 2.11.0 on a Pi0 W, I got the following error running npm install:
                                        npm install
                                        npm ERR! Cannot read property 'resolve' of undefined
                                        npm ERR!     /home/pi/.npm/_logs/2020-04-12T20_08_37_082Z-debug.log
                                        The log contains:
                                        1 verbose cli [ '/usr/local/bin/node', '/usr/local/bin/npm', 'install' ]
                                        2 info using npm@6.14.4
                                        3 info using node@v10.20.0
                                        4 verbose npm-session ed148b8dcfcaa591
                                        5 silly install runPreinstallTopLevelLifecycles
                                        6 silly preinstall magicmirror@2.11.0
                                        7 info lifecycle magicmirror@2.11.0~preinstall: magicmirror@2.11.0
                                        8 silly install loadCurrentTree
                                        9 silly install readLocalPackageData
                                        10 timing stage:loadCurrentTree Completed in 897ms
                                        11 silly install loadIdealTree
                                        12 silly install cloneCurrentTreeToIdealTree
                                        13 timing stage:loadIdealTree:cloneCurrentTree Completed in 10ms
                                        14 silly install loadShrinkwrap
                                        15 timing stage:loadIdealTree:loadShrinkwrap Completed in 42390ms
                                        16 silly install loadAllDepsIntoIdealTree
                                        17 silly fetchPackageMetaData error for grunt@latest Cannot read property 'resol
                                        ve' of undefined
                                        18 silly fetchPackageMetaData error for grunt-eslint@latest Cannot read property
                                        19 silly fetchPackageMetaData error for grunt-jsonlint@latest Cannot read property 'resolve' of undefined
                                        20 silly fetchPackageMetaData error for grunt-markdownlint@latest Cannot read property 'resolve' of undefined
                                        21 silly fetchPackageMetaData error for grunt-stylelint@latest Cannot read property 'resolve' of undefined
                                        22 silly fetchPackageMetaData error for grunt-yamllint@latest Cannot read property 'resolve' of undefined
                                        23 silly fetchPackageMetaData error for stylelint@latest Cannot read property 'resolve' of undefined
                                        24 silly fetchPackageMetaData error for stylelint-config-standard@latest Cannot read property 'resolve' of undefined
                                        25 silly fetchPackageMetaData error for time-grunt@latest Cannot read property 'resolve' of undefined
                                        26 silly fetchPackageMetaData error for feedme@latest Cannot read property 'resolve' of undefined
                                        27 silly fetchPackageMetaData error for iconv-lite@latest Cannot read property 'resolve' of undefined
                                        28 silly fetchPackageMetaData error for moment@latest Cannot read property 'resolve' of undefined
                                        29 silly fetchPackageMetaData error for valid-url@latest Cannot read property 'resolve' of undefined
                                        30 silly fetchPackageMetaData error for feedme@latest Cannot read property 'resolve' of undefined
                                        31 silly fetchPackageMetaData error for iconv-lite@latest Cannot read property 'resolve' of undefined
                                        32 silly fetchPackageMetaData error for moment@latest Cannot read property 'resolve' of undefined
                                        33 silly fetchPackageMetaData error for valid-url@latest Cannot read property 'resolve' of undefined
                                        34 timing stage:rollbackFailedOptional Completed in 6ms
                                        35 timing stage:runTopLevelLifecycles Completed in 47409ms
                                        36 silly saveTree magicmirror@2.11.0
                                        36 silly saveTree ├─┬ chai-as-promised@7.1.1
                                        36 silly saveTree │ └── check-error@1.0.2
                                        36 silly saveTree     │ └── querystring@0.2.0
                                        36 silly saveTree     ├── wdio-dot-reporter@0.0.10
                                        36 silly saveTree     └── wgxpath@1.0.0
                                        37 verbose stack TypeError: Cannot read property 'resolve' of undefined
                                        37 verbose stack     at regFetch (/usr/local/lib/node_modules/npm/node_modules/n
                                        pm-registry-fetch/index.js:88:23)
                                        37 verbose stack     at fetchPackument (/usr/local/lib/node_modules/npm/node_mod
                                        ules/pacote/lib/fetchers/registry/packument.js:42:10)
                                        37 verbose stack     at packument (/usr/local/lib/node_modules/npm/node_modules/
                                        pacote/lib/fetchers/registry/packument.js:20:10)
                                        37 verbose stack     at getManifest (/usr/local/lib/node_modules/npm/node_module
                                        s/pacote/lib/fetchers/registry/manifest.js:22:10)
                                        37 verbose stack     at manifest (/usr/local/lib/node_modules/npm/node_modules/p
                                        acote/lib/fetchers/registry/manifest.js:13:10)
                                        37 verbose stack     at Object.manifest (/usr/local/lib/node_modules/npm/node_mo
                                        dules/pacote/lib/fetchers/registry/index.js:17:12)
                                        37 verbose stack     at Object.Fetcher#manifest [as manifest] (/usr/local/lib/no
                                        de_modules/npm/node_modules/genfun/lib/genfun.js:15:38)
                                        acote/lib/fetch.js:23:18)
                                        37 verbose stack     at pinflight (/usr/local/lib/node_modules/npm/node_modules/pacote/manifest.js:24:12)
                                        37 verbose stack     at /usr/local/lib/node_modules/npm/node_modules/promiseinflight/inflight.js:29:24
                                        37 verbose stack     at Promise._execute (/usr/local/lib/node_modules/npm/node_modules/bluebird/js/release/debuggability.js:313:9)
                                        37 verbose stack     at Promise._resolveFromExecutor (/usr/local/lib/node_modules/npm/node_modules/bluebird/js/release/promise.js:488:18)
                                        37 verbose stack     at new Promise (/usr/local/lib/node_modules/npm/node_modules/bluebird/js/release/promise.js:79:10)
                                        37 verbose stack     at _inflight (/usr/local/lib/node_modules/npm/node_modules/promise-inflight/inflight.js:28:25)
                                        37 verbose stack     at /usr/local/lib/node_modules/npm/node_modules/promise-inflight/inflight.js:22:14
                                        37 verbose stack     at tryCatcher (/usr/local/lib/node_modules/npm/node_modules/bluebird/js/release/util.js:16:23)
                                        38 verbose cwd /home/pi/MagicMirror
                                        39 verbose Linux 4.9.35+
                                        40 verbose argv "/usr/local/bin/node" "/usr/local/bin/npm" "install"
                                        41 verbose node v10.20.0
                                        42 verbose npm  v6.14.4
                                        43 error Cannot read property 'resolve' of undefined
                                        44 verbose exit [ 1, true ]
                                        Any idea where resolve should be set and what is missing?
                                          sdetweil @nigel-daniels
                                          @nigel-daniels i do not know… please use the scripted install from here
                                          look at the instructions
                                          also, rename MagicMirror folder out of the way… or erase it… install thinks it is doing for the 1st time.
                                          • N Offline
                                            nigel-daniels @sdetweil
                                            @sdetweil hi, I have everything else set up and don’t really want to change thing, I had configured the PiZero some time ago. I was just reinstalling MM2. I decided I had left it so long since the last up date I just backed up my modules + config and have performed a reinstall. As far as I can tell the script is attempting a full config of the pi0?
                                            • 4 / 9
