    Installing on a Pi Zero
    175 Posts 33 Posters 303.4k Views 33 Watching
      ah, ok… i see you followed the manual instructions back a few posts…
      i have a modified raspberry.sh I have for testing, that takes user into account
      https://www.dropbox.com/s/izj6dz2z9557oga/raspberry.sh?dl=0
      to use it like normal
      bash -c “$(curl -sL https://www.dropbox.com/s/izj6dz2z9557oga/raspberry.sh?dl=0)”
        johnnyt1111
        If I try to install magic mirror on the pi zero i get an error that electron 3.0.13 not found for armv6 , by editing the package.json file to specify electron 2.0.18. I can get it to work, although I cannot find a version of electron for armv6 on the electron repo. Any idea why 2.0.18 would work? What would I need to try to compile electron 3 for armv6?
        https://github.com/electron/electron/releases/tag/v2.0.18
        Thanks!
        S 2 Replies Last reply
          sdetweil @johnnyt1111
          @johnnyt1111 download the electron source and follow the build process
            @johnnyt1111 why work. Cause electron 2.0.18 binary exists and 3.0.13 does not. There may be a technical reason, or they skipped it due to low demand.
            J 1 Reply Last reply
            • qu1queQ
              qu1que Project Sponsor
              I’ve found the same problem on last MM update:
              https://forum.magicmirror.builders/topic/10188/can-t-upgrade-mm-2-7-0-on-raspberry-pi-zero-w/2
                johnnyt1111 @sdetweil
                @sdetweil Thanks for the reply, I’m surprised the 2.0.18 even exists for armv6 as the electron issues states they don’t support it and is not listed in the releases page. but as long as it works I’m ok with that, thanks!
                  johnnyt1111 @qu1que
                  @qu1que Thanks for the link! Glad I’m not the only looking into this problem, hopefully we can get electron 3 working on the pi zero. but updating the package.json electron to “^2.0.0” will install 2.0.18 and will work with latest version of magic mirror
                  • L
                    liamangelus
                    can you explain in detail how to do it? I’m new and have the same problem
                      sdetweil @liamangelus
                      @liamangelus git clone the mm repo from GitHub.
                      Then edit the package.json file and change the number behind electron to the string mentioned above “^2.0.0”
                      Then follow the manual install steps from the readme
                      qu1queQ 1 Reply Last reply
                      • L
                        liamangelus
                        After editing the electron version in the package.json as ^ 2.0.0, I will apply the other steps in the same way. If I encounter a problem I would like to help you again. Thanx a lot.
                        • qu1queQ
                          qu1que Project Sponsor @sdetweil
                          That works for me. Thanks!
                          • qu1queQ
                            Again the same problem when updating to 2.8.0 version
                              sdetweil @qu1que
                              @qu1que yes, sadly the electron folks have not provided updates for pi zero
                                johnnyt1111
                                looks like changing the electron version to “^2.0.0” isn;t working anymore as it tries to intsall 1.8.0 and it gets the following error. Any idea why it isn’t looking for the version in the package.json file? thanks!
                                “Error: Failed to find Electron v1.8.0 for linux-armv6l at https://github.com/electron/electron/releases/download/v1.8.0/chromedriver-v1.8.0-linux-armv6l.zip”
                                • I
                                  InfiProj
                                  Solve it like this: “npm install --arch=armv7l”
                                  Reply Quote 2
                                  • qu1queQ
                                    qu1que Project Sponsor @InfiProj
                                    @InfiProj
                                    Did u mean that instead of simply “npm install” ?
                                    I’ll try on next update
                                    I 1 Reply Last reply
                                    • I
                                      InfiProj @qu1que
                                      @qu1que
                                      Yes, I just update installation command by --arch argument, and MM installs w/o errors.
                                        sdetweil @InfiProj
                                        @InfiProj is there a command u could use to tell this is a zero, So I could update the installer?
                                        • I
                                          InfiProj @sdetweil
                                          In Linux we can ask OS about architecture. “arch” - this command returns CPU architecture. For rpi zero - armv6l, for rpi 3b - armv7l. Maybe that helps you.
                                            sdetweil @InfiProj
                                            @InfiProj it does. Thx
                                            Not near computer, maybe uname provides info too
                                            • 3 / 9
