    Installing on a Pi Zero
    175 Posts 33 Posters 294.0k Views 33 Watching
    • 1 Offline
      12wsx
      thank you for help, i had to reinstal system once more becase there were a lot of errors.
      After new instalation pm2 didn’t start properly. after few hours i found why.
      In pm2_MagicMirrorPi0.json
      line:
      “script” : “/MagicMirror/PiZero/startMagicMirror.sh”,
      should be :
      “script” : “/MagicMirror/PiZero/startMagicMirrorPi0.sh”,
        which installer are you using? I don’t see the filename pm2_MagicMirrorPi0.json
        or “script” : “/MagicMirror/PiZero/startMagicMirror.sh”,
        in the raspberry.sh script…
          ah, ok… i see you followed the manual instructions back a few posts…
          i have a modified raspberry.sh I have for testing, that takes user into account
          https://www.dropbox.com/s/izj6dz2z9557oga/raspberry.sh?dl=0
          to use it like normal
          bash -c “$(curl -sL https://www.dropbox.com/s/izj6dz2z9557oga/raspberry.sh?dl=0)”
            johnnyt1111
            If I try to install magic mirror on the pi zero i get an error that electron 3.0.13 not found for armv6 , by editing the package.json file to specify electron 2.0.18. I can get it to work, although I cannot find a version of electron for armv6 on the electron repo. Any idea why 2.0.18 would work? What would I need to try to compile electron 3 for armv6?
            https://github.com/electron/electron/releases/tag/v2.0.18
            Thanks!
              sdetweil @johnnyt1111
              @johnnyt1111 download the electron source and follow the build process
                @johnnyt1111 why work. Cause electron 2.0.18 binary exists and 3.0.13 does not. There may be a technical reason, or they skipped it due to low demand.
                • qu1queQ Offline
                  qu1que Project Sponsor
                  I’ve found the same problem on last MM update:
                  https://forum.magicmirror.builders/topic/10188/can-t-upgrade-mm-2-7-0-on-raspberry-pi-zero-w/2
                    johnnyt1111 @sdetweil
                    @sdetweil Thanks for the reply, I’m surprised the 2.0.18 even exists for armv6 as the electron issues states they don’t support it and is not listed in the releases page. but as long as it works I’m ok with that, thanks!
                      johnnyt1111 @qu1que
                      @qu1que Thanks for the link! Glad I’m not the only looking into this problem, hopefully we can get electron 3 working on the pi zero. but updating the package.json electron to “^2.0.0” will install 2.0.18 and will work with latest version of magic mirror
                      • L Offline
                        liamangelus
                        can you explain in detail how to do it? I’m new and have the same problem
                          sdetweil @liamangelus
                          @liamangelus git clone the mm repo from GitHub.
                          Then edit the package.json file and change the number behind electron to the string mentioned above “^2.0.0”
                          Then follow the manual install steps from the readme
                          qu1queQ 1 Reply Last reply Reply Quote 1
                          • L Offline
                            liamangelus
                            After editing the electron version in the package.json as ^ 2.0.0, I will apply the other steps in the same way. If I encounter a problem I would like to help you again. Thanx a lot.
                            • qu1queQ Offline
                              qu1que Project Sponsor @sdetweil
                              That works for me. Thanks!
                              • qu1queQ Offline
                                Again the same problem when updating to 2.8.0 version
                                  sdetweil @qu1que
                                  @qu1que yes, sadly the electron folks have not provided updates for pi zero
                                    johnnyt1111
                                    looks like changing the electron version to “^2.0.0” isn;t working anymore as it tries to intsall 1.8.0 and it gets the following error. Any idea why it isn’t looking for the version in the package.json file? thanks!
                                    “Error: Failed to find Electron v1.8.0 for linux-armv6l at https://github.com/electron/electron/releases/download/v1.8.0/chromedriver-v1.8.0-linux-armv6l.zip”
                                    • I Offline
                                      InfiProj
                                      Solve it like this: “npm install --arch=armv7l”
                                      qu1queQ 1 Reply Last reply Reply Quote 2
                                      • qu1queQ Offline
                                        qu1que Project Sponsor @InfiProj
                                        @InfiProj
                                        Did u mean that instead of simply “npm install” ?
                                        I’ll try on next update
                                        • I Offline
                                          InfiProj @qu1que
                                          @qu1que
                                          Yes, I just update installation command by --arch argument, and MM installs w/o errors.
                                            sdetweil @InfiProj
                                            @InfiProj is there a command u could use to tell this is a zero, So I could update the installer?
                                            • 3 / 9
