    Installing on a Pi Zero
    175 Posts 33 Posters 303.4k Views 33 Watching
    • A
      andyc7687 @cdh1001
      @cdh1001 thanks, I will amend my guide over the weekend then.
        Smolo
        Thanks for the script and the hints so far :-)
        Unfortunately I am really frustrated after x installations. :-( Currently everything is installed the autostart works but chrome says “err_connection_refused”!
        Does anyone have an idea?
        Zero W V1.1 / Raspian Desktop / no sudo
        bheplerB 1 Reply Last reply
        • bheplerB
          bhepler Module Developer @Smolo
          @smolo Some suggestions: First, make sure that some form of IP address is present in the address key. Usually 127.0.0.1, but the IP address of your pi will probably work too. Without that value, the web server has a tendency to freak out.
          Second, make sure you are specifying the port in your web call. That one has bitten me a couple times.
          Third, I would double-check your IP whitelist in the config.js. Possibly open it up to all connections and attempt to view the magic mirror from another computer. See if the problem is local to the PI Zero or if it is on a deeper level.
            Smolo
            @bhepler
            First, as a supplement the installation is absolute standard except for another VNC server.
            Chromium starts automaticly with http://localhost:8080
            I have already tested the following constellations before my post.
            the local ip (192.168.2.84:8080)
            127.0.0.1:8080
            localhost:8080
            with https browser fault > “err_address_unreachable”
            Other things :…
            • ublock is inactive!
            • Configuration vom MagicMirror Config:
              var config = {
              port: 8080,
              address: “0.0.0.0”,
              ipWhitelist: [],
            • Test from another pc > “err_connection_refused”
              Smolo
              I’ve solved the problem and it’s going crazy. After I tried with a portscanner to find out if there is anything running I found out that there is no port 8080 open.
              If somebody has problems checking the logs via "pm2 logs MagicMirror --lines 1000
              I missed the npm module “moment” under “/home/pi/MagicMirror/node_modules/moment”!!!:astonished_face:
              Go to MagicMirror > “npm install” the problem was solved!:slightly_smiling_face:
              • A
                AnalogCHeep
                @andyc7687, thanks a lot! It will be easy for me now, I planned going for building a device like yours
                Regards
                A 1 Reply Last reply
                • A
                  andyc7687 @AnalogCHeep
                  @analogcheep thanks, let me know if yours works and upvote if it is helpful!
                    12wsx
                    today i have to reinstall MM and I have some small problem. MM do not show on local hdmi outpul- I can see the dektop but no MM. Server is working properly because when I open it from laptop i can see MM, when I connect to raspberry pi via vnc i can see to MM. What is going on? what i miss?
                      sdetweil @12wsx
                      @12wsx in terminal, or script u use to start mm do
                      export DISPLAY=:0
                      Then npm start
                        12wsx
                        thank you for help, i had to reinstal system once more becase there were a lot of errors.
                        After new instalation pm2 didn’t start properly. after few hours i found why.
                        In pm2_MagicMirrorPi0.json
                        line:
                        “script” : “/MagicMirror/PiZero/startMagicMirror.sh”,
                        should be :
                        “script” : “/MagicMirror/PiZero/startMagicMirrorPi0.sh”,
                          which installer are you using? I don’t see the filename pm2_MagicMirrorPi0.json
                          or “script” : “/MagicMirror/PiZero/startMagicMirror.sh”,
                          in the raspberry.sh script…
                            ah, ok… i see you followed the manual instructions back a few posts…
                            i have a modified raspberry.sh I have for testing, that takes user into account
                            https://www.dropbox.com/s/izj6dz2z9557oga/raspberry.sh?dl=0
                            to use it like normal
                            bash -c “$(curl -sL https://www.dropbox.com/s/izj6dz2z9557oga/raspberry.sh?dl=0)”
                              johnnyt1111
                              If I try to install magic mirror on the pi zero i get an error that electron 3.0.13 not found for armv6 , by editing the package.json file to specify electron 2.0.18. I can get it to work, although I cannot find a version of electron for armv6 on the electron repo. Any idea why 2.0.18 would work? What would I need to try to compile electron 3 for armv6?
                              https://github.com/electron/electron/releases/tag/v2.0.18
                              Thanks!
                              S 2 Replies Last reply
                                sdetweil @johnnyt1111
                                @johnnyt1111 download the electron source and follow the build process
                                  @johnnyt1111 why work. Cause electron 2.0.18 binary exists and 3.0.13 does not. There may be a technical reason, or they skipped it due to low demand.
                                  J 1 Reply Last reply
                                  • qu1queQ
                                    qu1que Project Sponsor
                                    I’ve found the same problem on last MM update:
                                    https://forum.magicmirror.builders/topic/10188/can-t-upgrade-mm-2-7-0-on-raspberry-pi-zero-w/2
                                      johnnyt1111 @sdetweil
                                      @sdetweil Thanks for the reply, I’m surprised the 2.0.18 even exists for armv6 as the electron issues states they don’t support it and is not listed in the releases page. but as long as it works I’m ok with that, thanks!
                                        johnnyt1111 @qu1que
                                        @qu1que Thanks for the link! Glad I’m not the only looking into this problem, hopefully we can get electron 3 working on the pi zero. but updating the package.json electron to “^2.0.0” will install 2.0.18 and will work with latest version of magic mirror
                                        • L
                                          liamangelus
                                          can you explain in detail how to do it? I’m new and have the same problem
                                            sdetweil @liamangelus
                                            @liamangelus git clone the mm repo from GitHub.
                                            Then edit the package.json file and change the number behind electron to the string mentioned above “^2.0.0”
                                            Then follow the manual install steps from the readme
                                            qu1queQ 1 Reply Last reply
                                            • 3 / 9
